[GRASS-SVN] r33481 - in
grass/branches/develbranch_6/swig/python/NumPtr: . src
svn_grass at osgeo.org
Wed Sep 17 04:06:47 EDT 2008
Author: hamish
Date: 2008-09-17 04:06:47 -0400 (Wed, 17 Sep 2008)
New Revision: 33481
grass/branches/develbranch_6/swig/python/NumPtr/Makefile
grass/branches/develbranch_6/swig/python/NumPtr/README.GRASS
grass/branches/develbranch_6/swig/python/NumPtr/src/Makefile
clean clean; rm needs -f in case setup.pyc isn't there
Modified: grass/branches/develbranch_6/swig/python/NumPtr/Makefile
--- grass/branches/develbranch_6/swig/python/NumPtr/Makefile 2008-09-17 07:53:23 UTC (rev 33480)
+++ grass/branches/develbranch_6/swig/python/NumPtr/Makefile 2008-09-17 08:06:47 UTC (rev 33481)
@@ -9,3 +9,5 @@
clean:
-rm -rf build/
+ -rm -f setup.pyc
+ $(MAKE) -C src clean
Modified: grass/branches/develbranch_6/swig/python/NumPtr/README.GRASS
--- grass/branches/develbranch_6/swig/python/NumPtr/README.GRASS 2008-09-17 07:53:23 UTC (rev 33480)
+++ grass/branches/develbranch_6/swig/python/NumPtr/README.GRASS 2008-09-17 08:06:47 UTC (rev 33481)
@@ -48,13 +48,13 @@
Modifications from the upstream tarball:
* updated setup.py with current version number, upstream URL
* removed old backup versions of a few files
- * removed binary lib/NumPtr.pyc. It will be automaticall regenerated (??)
+ * removed binary lib/NumPtr.pyc. It will be automatically regenerated
+ * update and GNUify src/Makefile (mostly unused)
* added this file, VERSION file
TODO:
- * incorporate the build into swig/python/Makefile, including byte-
- compiling the .pyc file (by running build/lib.../test.py) and setting
+ * incorporate the build into swig/python/Makefile, including setting
an appropriate install destination. (use "setup.py install" to do the
install or use the common Makefile method for that?)
Modified: grass/branches/develbranch_6/swig/python/NumPtr/src/Makefile
--- grass/branches/develbranch_6/swig/python/NumPtr/src/Makefile 2008-09-17 07:53:23 UTC (rev 33480)
+++ grass/branches/develbranch_6/swig/python/NumPtr/src/Makefile 2008-09-17 08:06:47 UTC (rev 33481)
@@ -48,7 +48,7 @@
$(CC) -c -I$(PYTHONINC) -o $(name)_wrap.o $(name)_wrap.c
clean:
- rm -f $(OBJ) *.so *_wrap.* *.pyc *_lib.*
+ rm -f $(OBJ) *.so *_wrap.* *.pyc *_lib.* $(name).py
test:
python test.py
