[GRASS-SVN] r33486 - in grass/trunk: display/d.colors display/d.rgb imagery/i.atcorr include/Make lib/db/sqlp/test ps/ps.map raster/r.le/r.le.setup/polytocell raster/simwe/simlib vector/v.mapcalc vector/v.vol.rst
Wed Sep 17 11:59:51 EDT 2008
Author: glynn
Date: 2008-09-17 11:59:51 -0400 (Wed, 17 Sep 2008)
New Revision: 33486
   grass/trunk/display/d.colors/Makefile
   grass/trunk/display/d.rgb/Makefile
   grass/trunk/imagery/i.atcorr/Makefile
   grass/trunk/include/Make/Grass.make
   grass/trunk/lib/db/sqlp/test/Makefile
   grass/trunk/ps/ps.map/Makefile
   grass/trunk/raster/r.le/r.le.setup/polytocell/Makefile
   grass/trunk/raster/simwe/simlib/Makefile
   grass/trunk/vector/v.mapcalc/Makefile
   grass/trunk/vector/v.vol.rst/Makefile
Fix incorrect variables names
Miscellaneous Makefile cleanup
Remove references to vask, edit libraries
Modified: grass/trunk/display/d.colors/Makefile
--- grass/trunk/display/d.colors/Makefile	2008-09-17 15:09:28 UTC (rev 33485)
+++ grass/trunk/display/d.colors/Makefile	2008-09-17 15:59:51 UTC (rev 33486)
@@ -3,7 +3,7 @@
 PGM = d.colors
 LIBES     = $(DISPLAYLIB) $(RASTERLIB) $(GISLIB) $(CURSES)
-DEPENDENCIES= $(DISPLAYDEP) $(RASTERDEP) $(GISDEP) $(CURSESDEP)
+DEPENDENCIES= $(DISPLAYDEP) $(RASTERDEP) $(GISDEP)
 include $(MODULE_TOPDIR)/include/Make/Module.make
Modified: grass/trunk/display/d.rgb/Makefile
--- grass/trunk/display/d.rgb/Makefile	2008-09-17 15:09:28 UTC (rev 33485)
+++ grass/trunk/display/d.rgb/Makefile	2008-09-17 15:59:51 UTC (rev 33486)
@@ -3,7 +3,7 @@
 PGM = d.rgb
-DEPLIBS= $(DEPD_LIB) $(DEPDISPLAYLIB) $(DEPRASTERLIB) $(DEPGISLIB)
+DEPLIBS= $(DISPLAYDEP) $(RASTERDEP) $(GISDEP)
Modified: grass/trunk/imagery/i.atcorr/Makefile
--- grass/trunk/imagery/i.atcorr/Makefile	2008-09-17 15:09:28 UTC (rev 33485)
+++ grass/trunk/imagery/i.atcorr/Makefile	2008-09-17 15:59:51 UTC (rev 33486)
@@ -5,7 +5,7 @@
 LIBES = $(GISLIB)
-DEPENDENCIES = $(DEPGISLIB)
+DEPENDENCIES = $(GISDEP)
 LINK = $(CXX)
Modified: grass/trunk/include/Make/Grass.make
--- grass/trunk/include/Make/Grass.make	2008-09-17 15:09:28 UTC (rev 33485)
+++ grass/trunk/include/Make/Grass.make	2008-09-17 15:59:51 UTC (rev 33486)
@@ -116,7 +116,6 @@
 ROWIO_LIBNAME         = grass_rowio
 SEGMENT_LIBNAME       = grass_segment
 STATS_LIBNAME	      = grass_stats
-VASK_LIBNAME	      = grass_vask
 XGD_LIBNAME	      = grass_Xgd
 XGI_LIBNAME	      = grass_Xgi
 XPM_LIBNAME	      = grass_Xpm
@@ -196,7 +195,6 @@
 PSDRIVERLIB   = -l$(PSDRIVER_LIBNAME) $(DRIVERLIB) $(GISLIB)
 CAIRODRIVERLIB= -l$(CAIRODRIVER_LIBNAME) $(DRIVERLIB) $(GISLIB)
 HTMLDRIVERLIB = -l$(HTMLDRIVER_LIBNAME) $(DRIVERLIB) $(GISLIB)
-EDITLIB       = -l$(EDIT_LIBNAME) $(GISLIB) $(VASKLIB)
 G3DLIB        = -l$(G3D_LIBNAME) $(GISLIB)
 GISLIB        = -l$(GIS_LIBNAME) $(DATETIMELIB) $(XDRLIB) $(SOCKLIB) $(INTLLIB)
 GMATHLIB      = -l$(GMATH_LIBNAME) $(GISLIB)
@@ -215,7 +213,6 @@
 ROWIOLIB      = -l$(ROWIO_LIBNAME)
 SEGMENTLIB    = -l$(SEGMENT_LIBNAME) $(GISLIB)
 STATSLIB      = -l$(STATS_LIBNAME) $(GISLIB)
-VASKLIB       = -l$(VASK_LIBNAME)
 XGDLIB        = -l$(XGD_LIBNAME)
 XGILIB        = -l$(XGI_LIBNAME)
 XPMLIB        = -l$(XPM_LIBNAME)
@@ -297,7 +294,6 @@
 CAIRODRIVERDEP = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(CAIRODRIVER_LIBNAME)$(LIB_SUFFIX)
 HTMLDRIVERDEP = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(HTMLDRIVER_LIBNAME)$(LIB_SUFFIX)
 DSPFDEP     = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(DSPF_LIBNAME)$(LIB_SUFFIX)
-EDITDEP     = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(EDIT_LIBNAME)$(LIB_SUFFIX)
 G3DDEP      = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(G3D_LIBNAME)$(LIB_SUFFIX)
 GISDEP      = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(GIS_LIBNAME)$(LIB_SUFFIX)
 GMATHDEP    = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(GMATH_LIBNAME)$(LIB_SUFFIX)
@@ -313,7 +309,6 @@
 ROWIODEP    = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(ROWIO_LIBNAME)$(LIB_SUFFIX)
 SEGMENTDEP  = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(SEGMENT_LIBNAME)$(LIB_SUFFIX)
 STATSDEP    = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(STATS_LIBNAME)$(LIB_SUFFIX)
-VASKDEP     = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(VASK_LIBNAME)$(LIB_SUFFIX)
 XGDDEP	    = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(XGD_LIBNAME)$(LIB_SUFFIX)
 XGIDEP	    = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(XGI_LIBNAME)$(LIB_SUFFIX)
 XPMDEP	    = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(XPM_LIBNAME)$(LIB_SUFFIX)
Modified: grass/trunk/lib/db/sqlp/test/Makefile
--- grass/trunk/lib/db/sqlp/test/Makefile	2008-09-17 15:09:28 UTC (rev 33485)
+++ grass/trunk/lib/db/sqlp/test/Makefile	2008-09-17 15:59:51 UTC (rev 33486)
@@ -3,7 +3,7 @@
 include $(MODULE_TOPDIR)/include/Make/Other.make
-LIBES = $(SQLPLIB) $(DBMILIB) $(GISLIB) $(LEXLIB)
+LIBES = $(SQLPLIB) $(DBMILIB) $(GISLIB) $(MATHLIB) $(ZLIBLIBPATH) $(ZLIB)
 EXTRA_CLEAN_FILES = sqlptest
@@ -11,5 +11,5 @@
 sqlptest: sqlptest.c
-	$(CC) $(CFLAGS) $(LDFLAGS) -o $@ sqlptest.c  $(LIBES) -lm -lz
+	$(CC) $(CFLAGS) $(LDFLAGS) -o $@ $<  $(LIBES)
Modified: grass/trunk/ps/ps.map/Makefile
--- grass/trunk/ps/ps.map/Makefile	2008-09-17 15:09:28 UTC (rev 33485)
+++ grass/trunk/ps/ps.map/Makefile	2008-09-17 15:59:51 UTC (rev 33486)
@@ -4,22 +4,25 @@
 PROLOG=$(ETC)/paint/prolog.ps
 LIBES     = $(VECTLIB) $(GPROJLIB) $(SYMBLIB) $(GISLIB) $(DATETIMELIB) $(IMAGERYLIB) $(GMATHLIB)
-DEPENDENCIES = $(VECTDEP) $(SYMBDEP) $(GISDEP) $(DATETIDEP) $(IMAGERYDEP) $(GMATHDEP) \
-               colortable.h group.h labels.h map_info.h ps_info.h vector.h \
-               comment.h header.h local_proto.h
+DEPENDENCIES = $(VECTDEP) $(SYMBDEP) $(GISDEP) $(DATETIMEDEP) $(IMAGERYDEP) $(GMATHDEP)
 EXTRA_INC = $(VECT_INC) $(PROJINC)
 EXTRA_CFLAGS = $(VECT_CFLAGS)
+SRCPAT := $(wildcard patterns/*.eps)
+DSTPAT := $(patsubst patterns/%.eps,$(ETC)/paint/patterns/%.eps,$(SRCPAT))
 default: cmd $(PROLOG) patt
 $(PROLOG): prolog.ps
 	$(MKDIR) $(ETC)/paint
-	$(INSTALL_DATA) prolog.ps $(PROLOG)
+	$(INSTALL_DATA) $< $@
 patt:
 	$(MKDIR) $(ETC)/paint/patterns/
-	$(INSTALL_DATA) patterns/*.eps $(ETC)/paint/patterns/
+	$(MAKE) $(DSTPAT)
+$(ETC)/paint/patterns/%.eps: patterns/%.eps
Modified: grass/trunk/raster/r.le/r.le.setup/polytocell/Makefile
--- grass/trunk/raster/r.le/r.le.setup/polytocell/Makefile	2008-09-17 15:09:28 UTC (rev 33485)
+++ grass/trunk/raster/r.le/r.le.setup/polytocell/Makefile	2008-09-17 15:59:51 UTC (rev 33486)
@@ -10,7 +10,7 @@
 	$(OBJDIR)/yadjust.o
 LIBES = $(GISLIB)
-DEPENDENCIES= $(DEPGISLIB)
+DEPENDENCIES= $(GISDEP)
Modified: grass/trunk/raster/simwe/simlib/Makefile
--- grass/trunk/raster/simwe/simlib/Makefile	2008-09-17 15:09:28 UTC (rev 33485)
+++ grass/trunk/raster/simwe/simlib/Makefile	2008-09-17 15:59:51 UTC (rev 33486)
@@ -1,7 +1,7 @@
 MODULE_TOPDIR = ../../..
 EXTRA_LIBS = $(GISLIB) $(BITMAPLIB) $(DBMILIB) $(GMATHLIB) $(LINKMLIB) $(XDRLIB) $(SITESLIB) $(VECTLIB)
-DEPENDENCIES = $(GISDEP) $(DBMIDEP) $(GMATLIBDEP) $(LINKMDEP) $(XDRDEP) $(SITESDEP) $(VECTDEP)
+DEPENDENCIES = $(GISDEP) $(BITMAPDEP) $(DBMIDEP) $(GMATHDEP) $(LINKMDEP) $(XDRDEP) $(SITESDEP) $(VECTDEP)
Modified: grass/trunk/vector/v.mapcalc/Makefile
--- grass/trunk/vector/v.mapcalc/Makefile	2008-09-17 15:09:28 UTC (rev 33485)
+++ grass/trunk/vector/v.mapcalc/Makefile	2008-09-17 15:59:51 UTC (rev 33486)
@@ -1,46 +1,12 @@
-CC = gcc
-#CFLAGS = -g -Wall -Werror -rdynamic
-CFLAGS = -O2 -Wall -Werror -rdynamic
-LDFLAGS = -ldl -lm #-lefence
-YACC = bison
-#YACC = bison -t
-YACCFLAGS = -d
+MODULE_TOPDIR = ../..
-all: v.mapcalc
+PGM = v.mapcalc
-v.mapcalc: mapcalc.o yylex.o v.mapcalc.o number.o vector.o map.o any.o \
-	plugin.o list.o
-	$(CC) $(CFLAGS) -o $@ $^ $(LDFLAGS)
+LIBES = $(MATHLIB)
+DEPENDENCIES =
-v.mapcalc.o: v.mapcalc.tab.c
-	$(CC) $(CFLAGS) -o $@ -c $<
+include $(MODULE_TOPDIR)/include/Make/Module.make
-v.mapcalc.tab.c v.mapcalc.tab.h: v.mapcalc.y
-	$(YACC) $(YACCFLAGS) $<
+default: cmd
-mapcalc.o: mapcalc.c list.h mapcalc.h number.h map.h plugin.h vector.h any.h
-number.o: number.c list.h mapcalc.h
-map.o: map.c list.h mapcalc.h map.h
-any.o: any.c list.h mapcalc.h any.h
-vector.o: vector.c list.h mapcalc.h vector.h
-plugin.o: plugin.c list.h mapcalc.h
-yylex.o: yylex.c mapcalc.h yylex.h v.mapcalc.tab.h
-list.o: list.c list.h
-clean:
-	rm -f *~ .*~ *.o v.mapcalc.tab.[ch] v.mapcalc
+.INTERMEDIATE: v.mapcalc.tab.c v.mapcalc.tab.h v.mapcalc.output
Modified: grass/trunk/vector/v.vol.rst/Makefile
--- grass/trunk/vector/v.vol.rst/Makefile	2008-09-17 15:09:28 UTC (rev 33485)
+++ grass/trunk/vector/v.vol.rst/Makefile	2008-09-17 15:59:51 UTC (rev 33486)
@@ -2,8 +2,8 @@
 PGM = v.vol.rst
-LIBES=$(G3DLIB) $(SITESLIB) $(VECTLIB) $(GISLIB) $(DATETIMELIB) $(BITMAPLIB) $(LINKMLIB)
-DEPENDENCIES=$(G3DLIBDEP) $(VECTDEP) $(GISLIBDEP) $(DATETIMELIBDEP) $(BITMAPLIBDEP) $(LINKMLIBDEP)
+LIBES = $(G3DLIB) $(SITESLIB) $(VECTLIB) $(GISLIB) $(DATETIMELIB) $(BITMAPLIB) $(LINKMLIB)
+DEPENDENCIES = $(G3DDEP) $(SITESDEP) $(VECTDEP) $(GISDEP) $(DATETIMEDEP) $(BITMAPDEP) $(LINKMDEP)
