[GRASS-SVN] r33510 - grass/trunk/scripts/v.report
svn_grass at osgeo.org
Tue Sep 23 15:54:55 EDT 2008
Author: glynn
Date: 2008-09-23 15:54:55 -0400 (Tue, 23 Sep 2008)
New Revision: 33510
Added:
grass/trunk/scripts/v.report/v.report.py
Add Python version of v.report.py
Added: grass/trunk/scripts/v.report/v.report.py
--- grass/trunk/scripts/v.report/v.report.py (rev 0)
+++ grass/trunk/scripts/v.report/v.report.py 2008-09-23 19:54:55 UTC (rev 33510)
@@ -0,0 +1,208 @@
+#!/usr/bin/env python
+# MODULE: v.report
+# AUTHOR(S): Markus Neteler, converted to Python by Glynn Clements
+# PURPOSE: Reports geometry statistics for vector maps
+# COPYRIGHT: (C) 2005, 2007 by MN and the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+#%Module
+#% description: Reports geometry statistics for vectors.
+#% keywords: vector, report, statistics
+#%End
+#%Flag
+#% key: r
+#% description: Reverse sort the result
+#%End
+#%Flag
+#% key: s
+#% description: Sort the result
+#%End
+#%option
+#% key: map
+#% type: string
+#% gisprompt: old,vector,vector
+#% description: Name of input vector map
+#% required: yes
+#%end
+#%option
+#% key: layer
+#% type: integer
+#% answer: 1
+#% description: Layer number
+#% required: no
+#%end
+#%option
+#% key: option
+#% type: string
+#% description: Value to calculate
+#% options: area,length,coor
+#% required: yes
+#%end
+#%option
+#% key: units
+#% type: string
+#% description: mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),p(ercent)
+#% options: mi,miles,f,feet,me,meters,k,kilometers,a,acres,h,hectares,p,percent
+#% required: no
+#%end
+import sys
+import os
+import grass
+def find_key(map, layer):
+ s = grass.read_command('v.db.connect', flags = 'g', map = map);
+ for line in s.splitlines():
+ fields = line.split()
+ if fields[0] == layer:
+ return fields[3]
+ return '<unknown>'
+def uniq(l):
+ result = []
+ last = None
+ for i in l:
+ if i != last:
+ result.append(i)
+ last = i
+ return result
+def main():
+ if flags['r'] and flags['s']:
+ grass.fatal("Either -r or -s flag")
+ mapname = options['map']
+ option = options['option']
+ layer = options['layer']
+ units = options['units']
+ nuldev = file(os.devnull, 'w')
+ if not grass.find_file(mapname, 'vector')['file']:
+ grass.fatal("Vector map '%s' not found in mapset search path." % mapname)
+ table_exists = grass.run_command('v.info', flags = 'c', map = mapname,
+ layer = layer, stdout = nuldev,
+ stderr = nuldev) == 0
+ if table_exists:
+ p = grass.pipe_command('v.info', flags = 'c', map = mapname, layer = layer, stderr = nuldev)
+ colnames = []
+ for line in p.stdout:
+ if '|' not in line:
+ continue
+ colnames.append(line.rstrip('\r\n').split('|')[1])
+ p.wait()
+ else:
+ colnames = ['cat']
+ if option == 'coor':
+ columns = ['dummy1','dummy2','dummy3']
+ extracolnames = ['x','y','z']
+ else:
+ columns = ['dummy1']
+ extracolnames = [option]
+ if units in ['p','percent']:
+ unitsp = {'units': 'meters'}
+ elif units:
+ else:
+ unitsp = {}
+ # NOTE: we suppress -1 cat and 0 cat
+ if table_exists:
+ p = grass.pipe_command('v.db.select', flags='c', map = mapname, layer = layer)
+ records1 = []
+ cols = line.rstrip('\r\n').split('|')
+ if cols[0] == '0':
+ continue
+ records1.append([int(cols[0])] + cols[1:])
+ p.wait()
+ records1.sort()
+ if len(records1) == 0:
+ key = find_key(mapname, layer)
+ grass.fatal("There is a table connected to input vector map '%s', but" +
+ "there are no categories present in the key column '%s'. Consider using" +
+ "v.to.db to correct this." % (mapname, key))
+ #fetch the requested attribute sorted by cat:
+ p = grass.pipe_command('v.to.db', flags = 'p',
+ map = mapname, option = option, columns = columns,
+ layer = layer, **unitsp)
+ records2 = []
+ fields = line.rstrip('\r\n').split('|')
+ if fields[0] in ['cat', '-1', '0']:
+ continue
+ records2.append([int(fields[0])] + fields[1:])
+ p.wait()
+ records2.sort()
+ #make pre-table
+ records3 = [r1 + r2[1:] for r1, r2 in zip(records1, records2)]
+ else:
+ records1 = []
+ p = grass.pipe_command('v.category', inp = mapname, layer = layer, option = 'print')
+ field = int(line.rstrip())
+ if field > 0:
+ records1.append(field)
+ p.wait()
+ records1.sort()
+ records1 = uniq(records1)
+ #make pre-table
+ records3 = []
+ fields = line.split('|')
+ continue
+ records3.append([int(fields[0])] + fields[1:])
+ p.wait()
+ records3.sort()
+ # print table header
+ sys.stdout.write('|'.join(colnames + extracolnames) + '\n')
+ #make and print the table:
+ numcols = len(colnames) + len(extracolnames)
+ # calculate percents if requested
+ if units != '' and units in ['p','percent']:
+ # calculate total area value
+ areatot = 0
+ for r in records3:
+ areatot += float(r[-1])
+ # calculate area percentages
+ records4 = [float(r[-1]) * 100 / areatot for r in records3]
+ records3 = [r1 + [r4] for r1, r4 in zip(records1, records4)]
+ if flags['s']:
+ # sort
+ records3.sort(key = lambda r: (r[0], r[-1]))
+ elif flags['r']:
+ # reverse sort
+ records3.sort(key = lambda r: (r[0], r[-1]), reverse = True)
+ sys.stdout.write('|'.join(map(str,r)) + '\n')
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ main()
Property changes on: grass/trunk/scripts/v.report/v.report.py
___________________________________________________________________
