[GRASS-SVN] r33515 - grass/trunk/lib/python
    svn_grass at osgeo.org
    Tue Sep 23 21:56:00 EDT 2008
Author: glynn
Date: 2008-09-23 21:56:00 -0400 (Tue, 23 Sep 2008)
New Revision: 33515
   grass/trunk/lib/python/grass.py
Make find_file handle the not-found case
Extend make_command to allow option=None to omit the option entirely
Modified: grass/trunk/lib/python/grass.py
--- grass/trunk/lib/python/grass.py	2008-09-23 21:13:38 UTC (rev 33514)
+++ grass/trunk/lib/python/grass.py	2008-09-24 01:56:00 UTC (rev 33515)
@@ -32,7 +32,8 @@
     if flags:
 	args.append("-%s" % flags)
     for opt, val in options.iteritems():
-	args.append("%s=%s" % (opt, _make_val(val)))
+	if val != None:
+	    args.append("%s=%s" % (opt, _make_val(val)))
     return args
 def start_command(prog, flags = "", overwrite = False, quiet = False, verbose = False, **kwargs):
@@ -155,9 +156,16 @@
 # interface to g.findfile
-def find_file(name, element = 'cell'):
-    lines = read_command("g.findfile", element = element, file = name).splitlines()
-    return dict([_kv_regex.match(line).groups() for line in lines])
+def find_file(name, element = 'cell', mapset = None):
+    lines = read_command("g.findfile", element = element, file = name, mapset = mapset).splitlines()
+    result = []
+    for line in lines:
+	m = _kv_regex.match(line)
+	if m != None:
+	    result.append(m.groups())
+	else:
+	    result.append(line.split('='))
+    return dict(result)
 # interface to g.list
