[GRASS-SVN] r33522 - grass/trunk/scripts/v.rast.stats
svn_grass at osgeo.org
Wed Sep 24 11:20:16 EDT 2008
Author: glynn
Date: 2008-09-24 11:20:16 -0400 (Wed, 24 Sep 2008)
New Revision: 33522
Added:
grass/trunk/scripts/v.rast.stats/v.rast.stats.py
Convert v.rast.ststs to Python
Added: grass/trunk/scripts/v.rast.stats/v.rast.stats.py
--- grass/trunk/scripts/v.rast.stats/v.rast.stats.py (rev 0)
+++ grass/trunk/scripts/v.rast.stats/v.rast.stats.py 2008-09-24 15:20:16 UTC (rev 33522)
@@ -0,0 +1,294 @@
+#!/usr/bin/env python
+# MODULE: v.rast.stats
+# AUTHOR(S): Markus Neteler, converted to Python by Glynn Clements
+# PURPOSE: Calculates univariate statistics from a GRASS raster map
+# only for areas covered by vector objects on a per-category base
+# COPYRIGHT: (C) 2005-2008 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+# TODO: do we need layer= management?
+#%Module
+#% description: Calculates univariate statistics from a GRASS raster map based on vector polygons and uploads statistics to new attribute columns.
+#% keywords: vector, raster, statistics
+#%End
+#%flag
+#% key: c
+#% description: Continue if upload column(s) already exist
+#%END
+#%flag
+#% key: e
+#% description: Calculate extended statistics
+#%END
+#%option
+#% key: vector
+#% type: string
+#% key_desc: name
+#% gisprompt: old,vector,vector
+#% description: Name of vector polygon map
+#% required : yes
+#%End
+#%option
+#% key: layer
+#% type: integer
+#% description: Layer to which the table to be changed is connected
+#% answer: 1
+#% required : no
+#%end
+#%option
+#% key: raster
+#% type: string
+#% key_desc: name
+#% gisprompt: old,cell,raster
+#% description: Name of raster map to calculate statistics from
+#% required : yes
+#%END
+#%option
+#% key: colprefix
+#% type: string
+#% description: Column prefix for new attribute columns
+#% required : yes
+#%end
+#%option
+#% key: percentile
+#% type: integer
+#% description: Percentile to calculate (requires extended statistics flag)
+#% options: 0-100
+#% answer: 90
+#% required : no
+#%end
+import sys
+import os
+import atexit
+import grass
+def has_column(vector, col):
+ s = grass.read_command('v.info', flags = 'c', map = vector, quiet = True)
+ for l in s.splitlines():
+ f = l.split('|')
+ if len(f) < 2:
+ continue
+ if f[1] == col:
+ return True
+ return False
+def cleanup():
+ grass.run_command('g.remove', rast = '%s_%s' % (vector, tmpname), quiet = True)
+ grass.run_command('g.remove', rast = 'MASK', quiet = True, stderr = nuldev)
+ if mask_found:
+ grass.message("Restoring previous MASK...")
+ grass.run_command('g.rename', rast = (tmpname + "_origmask", 'MASK'), quiet = True)
+ for f in [tmp, tmpname, sqltmp]:
+ try:
+ os.remove(f)
+ except:
+ pass
+def main():
+ global tmp, sqltmp, tmpname, nuldev, vector, mask_found
+ #### setup temporary files
+ tmp = grass.tempfile()
+ sqltmp = tmp + ".sql"
+ # we need a random name
+ tmpname = os.path.basename(tmp)
+ nuldev = file(os.devnull, 'w')
+ raster = options['raster']
+ colprefix = options['colprefix']
+ vector = options['vector']
+ layer = options['layer']
+ percentile = options['percentile']
+ ### setup enviro vars ###
+ env = grass.gisenv()
+ mapset = env['MAPSET']
+ vs = vector.split('@')
+ if len(vs) > 1:
+ vect_mapset = vs[1]
+ else:
+ vect_mapset = mapset
+ # does map exist in CURRENT mapset?
+ if vect_mapset != mapset or not grass.find_file(vector, 'vector', mapset)['file']:
+ grass.fatal("Vector map <%s> not found in current mapset" % vector)
+ vector = vs[0]
+ #check the input raster map
+ if not grass.find_file(raster, 'cell')['file']:
+ grass.fatal("Raster map <%s> not found" % raster)
+ #check presence of raster MASK, put it aside
+ mask_found = bool(grass.find_file('MASK', 'cell')['file'])
+ if mask_found:
+ grass.message("Raster MASK found, temporarily disabled")
+ grass.run_command('g.rename', rast = ('MASK', tmpname + "_origmask"), quiet = True)
+ #get RASTER resolution of map which we want to query:
+ #fetch separated to permit for non-square cells (latlong etc)
+ s = grass.read_command('r.info', flags = 's', map = raster)
+ d = {}
+ kv = l.split('=')
+ d[kv[0]] = float(kv[1])
+ nsres = d['nsres']
+ ewres = d['ewres']
+ #save current settings:
+ grass.use_temp_region()
+ #Temporarily setting raster resolution to $RASTER resolution
+ #keep boundary settings
+ grass.run_command('g.region', flags = 'a', nsres = nsres, ewres = ewres)
+ #prepare raster MASK
+ if grass.run_command('v.to.rast', input = vector, output = "%s_%s" % (vector, tmpname),
+ use = 'cat', quiet = True) != 0:
+ grass.fatal("An error occurred while converting vector to raster")
+ #dump cats to file to avoid "too many argument" problem:
+ p = grass.pipe_command('r.category', map = '%s_%s' % (vector, tmpname), fs = ';', quiet = True)
+ cats = []
+ for line in p.stdout:
+ cats.append(line.rstrip('\r\n').split(';')[0])
+ p.wait()
+ #echo "List of categories found: $CATSLIST"
+ number = len(cats)
+ if number < 1:
+ grass.fatal("No categories found in raster map")
+ #check if DBF driver used, in this case cut to 10 chars col names:
+ s = grass.read_command('v.db.connect', flags = 'g', map = vector, layer = layer)
+ # we need this for non-DBF driver:
+ table = s.split()[1]
+ db_database = s.split()[3]
+ db_sqldriver = s.split()[4]
+ dbfdriver = db_sqldriver == 'dbf'
+ #Find out which table is linked to the vector map on the given layer
+ if not table:
+ grass.fatal('There is no table connected to this map! Run v.db.connect or v.db.addtable first.')
+ basecols = ['n', 'min', 'max', 'range', 'mean', 'stddev', 'variance', 'cf_var', 'sum']
+ # we need at least three chars to distinguish [mea]n from [med]ian
+ # so colprefix can't be longer than 6 chars with DBF driver
+ if dbfdriver:
+ colprefix = colprefix[:6]
+ # do extended stats?
+ if flags['e']:
+ # namespace is limited in DBF but the % value is important
+ if dbfdriver:
+ perccol = "per" + percentile
+ else:
+ perccol = "percentile_" + percentile
+ extracols = ['first_quartile', 'median', 'third_quartile'] + [perccol]
+ else:
+ extracols = []
+ addcols = []
+ for i in basecols + extracols:
+ #check if column already present
+ currcolumn = ("%s_%s" % (colprefix, i))
+ if dbfdriver:
+ currcolumn = currcolumn[:10]
+ if has_column(vector, currcolumn):
+ if not flags['c']:
+ grass.fatal(("Cannot create column <%s> (already present)." % currcolumn) +
+ "Use -c flag to update values in this column.")
+ else:
+ if i == "n":
+ coltype = "INTEGER"
+ else:
+ coltype = "DOUBLE PRECISION"
+ addcols.append(currcolumn + ' ' + coltype)
+ grass.verbose("Adding columns <%s>" % addcols)
+ if grass.run_command('v.db.addcol', map = vector, columns = addcols) != 0:
+ grass.fatal("Cannot continue (problem adding columns).")
+ #loop over cats and calculate statistics:
+ grass.verbose("Processing data ...")
+ # get rid of any earlier attempts
+ try:
+ os.remove(sqltmp)
+ except:
+ pass
+ if flags['e']:
+ extstat = 'e'
+ else:
+ extstat = ""
+ f = file(sqltmp, 'w')
+ currnum = 1
+ for i in cats:
+ grass.verbose("Processing category %s (%d/%d)" % (i, currnum, number))
+ grass.run_command('r.mapcalc', quiet = True,
+ expression = "MASK = if(%s_%s == %s, 1, null())" % (vector, tmpname, i))
+ #n, min, max, range, mean, stddev, variance, coeff_var, sum
+ # How to test r.univar $? exit status? using -e creates the real possibility of out-of-memory errors
+ s = grass.read_command('r.univar', flags = 'g' + extstat, map = raster, percentile = percentile)
+ vars = {}
+ kv = l.split('=')
+ if len(kv) != 2:
+ continue
+ var = kv[0]
+ val = kv[1]
+ if val.lower() == 'nan':
+ val = 'NULL'
+ vars[var] = val
+ vars['cf_var'] = vars['coeff_var']
+ if flags['e'] and dbfdriver:
+ percvar = 'percentile_' + percentile
+ vars[perccol] = vars[percvar]
+ for var in basecols + extracols:
+ value = vars[var]
+ colname = '%s_%s' % (colprefix, var)
+ if dbfdriver:
+ colname = colname[:10]
+ f.write("UPDATE %s SET %s=%s WHERE cat=%s;\n" % (table, colname, value, i))
+ currnum += 1
+ f.close()
+ grass.verbose("Updating the database ...")
+ exitcode = grass.run_command('db.execute', input = sqltmp,
+ database = db_database, driver = db_sqldriver)
+ if exitcode == 0:
+ grass.message(("Statistics calculated from raster map %s" % raster) +
+ (" and uploaded to attribute table of vector map %s." % vector))
+ grass.message("Done.")
+ sys.exit(exitcode)
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ atexit.register(cleanup)
+ main()
