[GRASS-SVN] r33524 - in grass/trunk: lib/python scripts/v.rast.stats
svn_grass at osgeo.org
Wed Sep 24 14:41:31 EDT 2008
Author: glynn
Date: 2008-09-24 14:41:31 -0400 (Wed, 24 Sep 2008)
New Revision: 33524
grass/trunk/lib/python/grass.py
grass/trunk/scripts/v.rast.stats/v.rast.stats.py
Add, use parse_key_val
Modified: grass/trunk/lib/python/grass.py
--- grass/trunk/lib/python/grass.py 2008-09-24 15:38:20 UTC (rev 33523)
+++ grass/trunk/lib/python/grass.py 2008-09-24 18:41:31 UTC (rev 33524)
@@ -127,19 +127,45 @@
def tempfile():
return read_command("g.tempfile", pid = os.getpid()).strip()
+# key-value parsers
+def parse_key_val(s, sep = '=', dflt = None):
+ result = {}
+ for line in s.splitlines():
+ kv = line.split(sep, 1)
+ k = kv[0].strip()
+ if len(kv) > 1:
+ v = kv[1]
+ else:
+ v = dflt
+ result[k] = v
+ return result
+_kv_regex = None
+def parse_key_val2(s):
+ global _kv_regex
+ if _kv_regex == None:
+ _kv_regex = re.compile("([^=]+)='(.*)';?")
+ result = []
+ m = _kv_regex.match(line)
+ if m != None:
+ result.append(m.groups())
+ else:
+ result.append(line.split('=', 1))
+ return dict(result)
# interface to g.gisenv
-_kv_regex = re.compile("([^=]+)='(.*)';?")
def gisenv():
- lines = read_command("g.gisenv").splitlines()
- return dict([_kv_regex.match(line).groups() for line in lines])
+ return parse_key_val2(read_command("g.gisenv"))
# interface to g.region
def region():
- lines = read_command("g.region", flags='g').splitlines()
- return dict([line.split('=',1) for line in lines])
+ s = read_command("g.region", flags='g')
+ return parse_key_val(s)
def use_temp_region():
name = "tmp.%s.%d" % (os.path.basename(sys.argv[0]), os.getpid())
@@ -157,15 +183,8 @@
# interface to g.findfile
def find_file(name, element = 'cell', mapset = None):
- lines = read_command("g.findfile", element = element, file = name, mapset = mapset).splitlines()
- result = []
- for line in lines:
- m = _kv_regex.match(line)
- if m != None:
- result.append(m.groups())
- else:
- result.append(line.split('='))
- return dict(result)
+ s = read_command("g.findfile", element = element, file = name, mapset = mapset)
+ return parse_key_val2(s)
# interface to g.list
Modified: grass/trunk/scripts/v.rast.stats/v.rast.stats.py
--- grass/trunk/scripts/v.rast.stats/v.rast.stats.py 2008-09-24 15:38:20 UTC (rev 33523)
+++ grass/trunk/scripts/v.rast.stats/v.rast.stats.py 2008-09-24 18:41:31 UTC (rev 33524)
@@ -137,12 +137,9 @@
#get RASTER resolution of map which we want to query:
#fetch separated to permit for non-square cells (latlong etc)
s = grass.read_command('r.info', flags = 's', map = raster)
- d = {}
- for l in s.splitlines():
- kv = l.split('=')
- d[kv[0]] = float(kv[1])
- nsres = d['nsres']
- ewres = d['ewres']
+ kv = grass.parse_key_val(s)
+ nsres = float(kv['nsres'])
+ ewres = float(kv['ewres'])
#save current settings:
grass.use_temp_region()
@@ -171,9 +168,10 @@
#check if DBF driver used, in this case cut to 10 chars col names:
s = grass.read_command('v.db.connect', flags = 'g', map = vector, layer = layer)
# we need this for non-DBF driver:
- table = s.split()[1]
- db_database = s.split()[3]
- db_sqldriver = s.split()[4]
+ f = s.split()
+ table = f[1]
+ db_database = f[3]
+ db_sqldriver = f[4]
dbfdriver = db_sqldriver == 'dbf'
#Find out which table is linked to the vector map on the given layer
@@ -247,16 +245,7 @@
#n, min, max, range, mean, stddev, variance, coeff_var, sum
# How to test r.univar $? exit status? using -e creates the real possibility of out-of-memory errors
s = grass.read_command('r.univar', flags = 'g' + extstat, map = raster, percentile = percentile)
- vars = {}
- kv = l.split('=')
- if len(kv) != 2:
- continue
- var = kv[0]
- val = kv[1]
- if val.lower() == 'nan':
- val = 'NULL'
- vars[var] = val
+ vars = grass.parse_key_val(s)
vars['cf_var'] = vars['coeff_var']
@@ -266,6 +255,8 @@
for var in basecols + extracols:
value = vars[var]
+ if value.lower() == 'nan':
+ value = 'NULL'
colname = '%s_%s' % (colprefix, var)
if dbfdriver:
colname = colname[:10]
