[GRASS-SVN] r33535 - grass/branches/develbranch_6/lib/vector/diglib
svn_grass at osgeo.org
Thu Sep 25 07:40:11 EDT 2008
Author: martinl
Date: 2008-09-25 07:40:11 -0400 (Thu, 25 Sep 2008)
New Revision: 33535
grass/branches/develbranch_6/lib/vector/diglib/plus_line.c
vlib: Vect_restore_line() added (initial step towards vector digitizer undo) - update r33533
Modified: grass/branches/develbranch_6/lib/vector/diglib/plus_line.c
--- grass/branches/develbranch_6/lib/vector/diglib/plus_line.c 2008-09-25 11:39:17 UTC (rev 33534)
+++ grass/branches/develbranch_6/lib/vector/diglib/plus_line.c 2008-09-25 11:40:11 UTC (rev 33535)
@@ -17,34 +17,13 @@
#include <stdlib.h>
#include <grass/Vect.h>
- * \brief Add new line to Plus_head structure.
- * \param[in,out] plus pointer to Plus_head structure
- * \param[in] type feature type
- * \param[in] Points line geometry
- * \param[in] offset line offset
- * \return -1 on error
- * \return line id
-int
-dig_add_line(struct Plus_head *plus, int type, struct line_pnts *Points,
- long offset)
+static int add_line(struct Plus_head *plus, int lineid, int type, struct line_pnts *Points,
+ long offset)
- int lineid, node, lp;
+ int node, lp;
P_LINE *line;
BOUND_BOX box;
- /* First look if we have space in array of pointers to lines
- * and reallocate if necessary */
- if (plus->n_lines >= plus->alloc_lines) { /* array is full */
- if (dig_alloc_lines(plus, 1000) == -1)
- return -1;
- /* allocate line structure */
- lineid = plus->n_lines + 1;
plus->Line[lineid] = dig_alloc_line();
line = plus->Line[lineid];
@@ -98,6 +77,45 @@
line->S = 0;
line->E = 0;
line->W = 0;
+ dig_line_box(Points, &box);
+ dig_line_set_box(plus, lineid, &box);
+ dig_spidx_add_line(plus, lineid, &box);
+ if (plus->do_uplist)
+ dig_line_add_updated(plus, lineid);
+ return (lineid);
+ * \brief Add new line to Plus_head structure.
+ * \param[in,out] plus pointer to Plus_head structure
+ * \param[in] type feature type
+ * \param[in] Points line geometry
+ * \param[in] offset line offset
+ * \return -1 on error
+ * \return line id
+int
+dig_add_line(struct Plus_head *plus, int type, struct line_pnts *Points,
+ long offset)
+ int ret;
+ /* First look if we have space in array of pointers to lines
+ * and reallocate if necessary */
+ if (plus->n_lines >= plus->alloc_lines) { /* array is full */
+ if (dig_alloc_lines(plus, 1000) == -1)
+ return -1;
+ ret = add_line(plus, plus->n_lines + 1, type, Points, offset);
+ if (ret == -1)
+ return ret;
plus->n_lines++;
switch (type) {
@@ -121,13 +139,30 @@
break;
- dig_line_box(Points, &box);
- dig_line_set_box(plus, lineid, &box);
- dig_spidx_add_line(plus, lineid, &box);
- if (plus->do_uplist)
- dig_line_add_updated(plus, lineid);
+ return ret;
- return (lineid);
+ * \brief Restore line in Plus_head structure.
+ * \return line id
+int
+dig_restore_line(struct Plus_head *plus, int lineid,
+ int type, struct line_pnts *Points,
+ long offset)
+ if (lineid < 1 || lineid > plus->n_lines) {
+ return -1;
+ return add_line(plus, lineid, type, Points, offset);
