[GRASS-SVN] r33545 - grass-addons/raster/r.sun_horizon/r.sun2
svn_grass at osgeo.org
Thu Sep 25 16:08:12 EDT 2008
Author: neteler
Date: 2008-09-25 16:08:12 -0400 (Thu, 25 Sep 2008)
New Revision: 33545
grass-addons/raster/r.sun_horizon/r.sun2/main.c
sync'ed msg descriptions to r.sun
Modified: grass-addons/raster/r.sun_horizon/r.sun2/main.c
--- grass-addons/raster/r.sun_horizon/r.sun2/main.c 2008-09-25 19:48:42 UTC (rev 33544)
+++ grass-addons/raster/r.sun_horizon/r.sun2/main.c 2008-09-25 20:08:12 UTC (rev 33545)
@@ -256,14 +256,14 @@
parm.elevin->type = TYPE_STRING;
parm.elevin->required = YES;
parm.elevin->gisprompt = "old,cell,raster";
- parm.elevin->description = _("Name of the elevation raster file");
+ parm.elevin->description = _("Name of the input elevation raster map [meters]");
parm.aspin = G_define_option();
parm.aspin->key = "aspin";
parm.aspin->type = TYPE_STRING;
parm.aspin->required = NO;
parm.aspin->gisprompt = "old,cell,raster";
- parm.aspin->description = _("Name of the aspect raster file");
+ parm.aspin->description = _("Name of the input aspect map (terrain aspect or azimuth of the solar panel) [decimal degrees]");
parm.aspect = G_define_option();
parm.aspect->key = "aspect";
@@ -277,9 +277,8 @@
parm.slopein->key = "slopein";
parm.slopein->type = TYPE_STRING;
parm.slopein->required = NO;
- /* parm.slopein->gisprompt = "old,cell,raster";
- parm.slopein->description = _("Name of the slope raster file");
+ parm.slopein->gisprompt = "old,cell,raster";
+ parm.slopein->description = _("Name of the input slope raster map (terrain slope or solar panel inclination) [decimal degrees]");
parm.slope = G_define_option();
parm.slope->key = "slope";
@@ -294,7 +293,7 @@
parm.linkein->required = NO;
parm.linkein->gisprompt = "old,cell,raster";
parm.linkein->description =
- _("Name of the Linke turbidity coefficient raster file");
+ _("Name of the Linke atmospheric turbidity coefficient input raster map [-]");
if (parm.linkein->answer == NULL) {
parm.lin = G_define_option();
@@ -303,7 +302,7 @@
parm.lin->answer = LINKE;
parm.lin->required = NO;
parm.lin->description =
- _("A single value of the Linke turbidity coefficient");
+ _("A single value of the Linke atmospheric turbidity coefficient [-]");
parm.albedo = G_define_option();
@@ -311,7 +310,7 @@
parm.albedo->type = TYPE_STRING;
parm.albedo->required = NO;
parm.albedo->gisprompt = "old,cell,raster";
- parm.albedo->description = _("Name of the albedo coefficient raster file");
+ parm.albedo->description = _("Name of the ground albedo coefficient input raster map [-]");
if (parm.albedo->answer == NULL) {
parm.alb = G_define_option();
@@ -319,7 +318,7 @@
parm.alb->type = TYPE_DOUBLE;
parm.alb->answer = ALB;
parm.alb->required = NO;
- parm.alb->description = _("A single value of the albedo coefficient");
+ parm.alb->description = _("A single value of the ground albedo coefficient [-]");
parm.latin = G_define_option();
@@ -327,14 +326,14 @@
parm.latin->type = TYPE_STRING;
parm.latin->required = NO;
parm.latin->gisprompt = "old,cell,raster";
- parm.latin->description = _("Name of the latitude raster file");
+ parm.latin->description = _("Name of the latitudes input raster map [decimal degrees]");
if (parm.latin->answer == NULL) {
parm.lat = G_define_option();
parm.lat->key = "lat";
parm.lat->type = TYPE_DOUBLE;
parm.lat->required = NO;
- parm.lat->description = _("A single value of latitude");
+ parm.lat->description = _("A single value of latitude [decimal degrees]");
parm.longin = G_define_option();
@@ -342,7 +341,7 @@
parm.longin->type = TYPE_STRING;
parm.longin->required = NO;
parm.longin->gisprompt = "old,cell,raster";
- parm.longin->description = _("Name of the longitude raster file");
+ parm.longin->description = _("Name of the longitude input raster map [decimal degrees]");
parm.coefbh = G_define_option();
@@ -351,7 +350,7 @@
parm.coefbh->required = NO;
parm.coefbh->gisprompt = "old,cell,raster";
parm.coefbh->description =
- _("The real-sky beam radiation coefficient file");
+ _("Name of real-sky beam radiation coefficient raster map [-]");
parm.coefdh = G_define_option();
parm.coefdh->key = "coefdh";
@@ -359,7 +358,7 @@
parm.coefdh->required = NO;
parm.coefdh->gisprompt = "old,cell,raster";
parm.coefdh->description =
- _("The real-sky diffuse radiation coefficient file");
+ _("Name of real-sky diffuse radiation coefficient raster map [-]");
parm.horizon = G_define_option();
@@ -374,14 +373,14 @@
parm.horizonstep->type = TYPE_DOUBLE;
parm.horizonstep->required = NO;
parm.horizonstep->description =
- _("Angle step size for the horizon information (degrees)");
+ _("Angle step size for the horizon information [degrees]");
parm.incidout = G_define_option();
parm.incidout->key = "incidout";
parm.incidout->type = TYPE_STRING;
parm.incidout->required = NO;
parm.incidout->gisprompt = "old,cell,raster";
- parm.incidout->description = _("Output incidence angle file (raster)");
+ parm.incidout->description = _("Output incidence angle raster map (mode 1 only)");
parm.beam_rad = G_define_option();
parm.beam_rad->key = "beam_rad";
@@ -389,14 +388,14 @@
parm.beam_rad->required = NO;
parm.beam_rad->gisprompt = "old,cell,raster";
parm.beam_rad->description =
- _("Output direct (beam) irradiance/irradiation file (raster)");
+ _("Output beam irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)");
parm.insol_time = G_define_option();
parm.insol_time->key = "insol_time";
parm.insol_time->type = TYPE_STRING;
parm.insol_time->required = NO;
parm.insol_time->gisprompt = "old,cell,raster";
- parm.insol_time->description = _("Output insolation time file (raster)");
+ parm.insol_time->description = _("Output insolation time raster map [h] (mode 2 only)");
parm.diff_rad = G_define_option();
parm.diff_rad->key = "diff_rad";
@@ -404,7 +403,7 @@
parm.diff_rad->required = NO;
parm.diff_rad->gisprompt = "old,cell,raster";
parm.diff_rad->description =
- _("Output diffuse irradiance/irradiation file (raster)");
+ _("Output diffuse irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)");
parm.refl_rad = G_define_option();
parm.refl_rad->key = "refl_rad";
@@ -412,7 +411,7 @@
parm.refl_rad->required = NO;
parm.refl_rad->gisprompt = "old,cell,raster";
parm.refl_rad->description =
- _("Output reflected irradiance/irradiation file (raster)");
+ _("Output ground reflected irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)");
parm.glob_rad = G_define_option();
parm.glob_rad->key = "glob_rad";
@@ -420,7 +419,7 @@
parm.glob_rad->required = NO;
parm.glob_rad->gisprompt = "old,cell,raster";
parm.glob_rad->description =
- _("Output global (total) irradiance/irradiation file (raster)");
+ _("Output global (total) irradiance/irradiation [W.m-2] (mode 1) or irradiance/irradiation raster map [Wh.m-2.day-1] (mode 2)");
parm.day = G_define_option();
@@ -434,21 +433,21 @@
parm.step->type = TYPE_DOUBLE;
parm.step->answer = STEP;
parm.step->required = NO;
- parm.step->description = _("Time step computing all-day radiation");
+ parm.step->description = _("Time step when computing all-day radiation sums [decimal hours]");
parm.declin = G_define_option();
parm.declin->key = "declin";
parm.declin->type = TYPE_DOUBLE;
parm.declin->required = NO;
parm.declin->description =
- _("Required declination value (overriding the internal value)");
+ _("Declination value (overriding the internally computed value) [radians]");
parm.ltime = G_define_option();
parm.ltime->key = "time";
parm.ltime->type = TYPE_DOUBLE;
/* parm.ltime->answer = TIME; */
parm.ltime->required = NO;
- parm.ltime->description = _("Local (solar) time [decimal hours]");
+ parm.ltime->description = _("Local (solar) time (to be set for mode 1 only) [decimal hours]");
* parm.startTime = G_define_option();
@@ -484,19 +483,18 @@
parm.civilTime->type = TYPE_DOUBLE;
parm.civilTime->required = NO;
parm.civilTime->description =
- _
- ("(optional) The civil time zone value, if none, the time will be local solar time");
+ _("(optional) The civil time zone value, if none, the time will be local solar time");
flag.shade = G_define_flag();
flag.shade->key = 's';
flag.shade->description =
- _("Do you want to incorporate the shadowing effect of terrain (y/n)");
+ _("Incorporate the shadowing effect of terrain");
flag.saveMemory = G_define_flag();
flag.saveMemory->key = 'm';
flag.saveMemory->description =
- _("Do you want to use the low-memory version of the program (y/n)");
+ _("Use the low-memory version of the program");
if (G_parser(argc, argv))
