[GRASS-SVN] r33553 - grass/trunk/scripts/r.mask
svn_grass at osgeo.org
Thu Sep 25 20:59:54 EDT 2008
Author: glynn
Date: 2008-09-25 20:59:54 -0400 (Thu, 25 Sep 2008)
New Revision: 33553
Added:
grass/trunk/scripts/r.mask/r.mask.py
r.mask converted to Python
Added: grass/trunk/scripts/r.mask/r.mask.py
--- grass/trunk/scripts/r.mask/r.mask.py (rev 0)
+++ grass/trunk/scripts/r.mask/r.mask.py 2008-09-26 00:59:54 UTC (rev 33553)
@@ -0,0 +1,103 @@
+#!/usr/bin/env python
+# MODULE: r.mask
+# AUTHOR(S): Michael Barton, Arizona State University
+# Markus Neteler
+# Converted to Python by Glynn Clements
+# PURPOSE: Facilitates creation of raster MASK using r.reclass
+# COPYRIGHT: (C) 2005, 2007, 2008 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+#%Module
+#% description: Create a MASK for limiting raster operation
+#% keywords: raster, mask
+#%End
+#%option
+#% key: input
+#% type: string
+#% gisprompt: old,cell,raster
+#% description: Raster map to use as MASK
+#% required: no
+#%END
+#%option
+#% key: maskcats
+#% type: string
+#% description: Category values to use for MASK (format: 1 2 3 thru 7 *)
+#% answer: *
+#%END
+#%flag
+#% key: i
+#% description: Create inverse MASK from specified 'maskcats' list
+#%END
+#%flag
+#% key: r
+#% description: Remove existing MASK (overrides other options)
+#%END
+import sys
+import os
+import grass
+import atexit
+import subprocess
+def cleanup():
+ if tmp:
+ grass.run_command('g.remove', rast = tmp, quiet = True)
+def main():
+ input = options['input']
+ maskcats = options['maskcats']
+ remove = flags['r']
+ invert = flags['i']
+ if not remove and not input:
+ grass.fatal("Required parameter <input> not set")
+ mapset = grass.gisenv()['MAPSET']
+ exists = bool(grass.find_file('MASK', element = 'cell', mapset = mapset)['file'])
+ if remove:
+ if exists:
+ grass.run_command('g.remove', rast = 'MASK')
+ grass.message("Raster MASK removed")
+ else:
+ grass.warning("No existing MASK to remove")
+ else:
+ owstr = 'GRASS_OVERWRITE'
+ overwrite = owstr in os.environ and os.environ[owstr] != '0'
+ if exists and not overwrite:
+ grass.fatal("MASK already found in current mapset. Delete first or overwrite")
+ p = grass.start_command('r.reclass', input = input, output = 'MASK', overwrite = True,
+ stdin = subprocess.PIPE)
+ p.stdin.write("%s = 1" % maskcats)
+ p.stdin.close()
+ p.wait()
+ if invert:
+ global tmp
+ tmp = "r_mask_%d" % os.getpid()
+ grass.run_command('g.rename', rast = ('MASK',tmp), quiet = True)
+ grass.run_command('r.mapcalc', expr = "MASK=if(isnull(%s),1,null())" % tmp)
+ grass.message("Inverted MASK created.")
+ else:
+ grass.message("MASK created.")
+ grass.message("All subsequent raster operations will be limited to MASK area" +
+ "Removing or renaming raster file named MASK will" +
+ "restore raster operations to normal")
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ tmp = None
+ atexit.register(cleanup)
+ main()
Property changes on: grass/trunk/scripts/r.mask/r.mask.py
___________________________________________________________________
