[GRASS-SVN] r33568 - grass/trunk/scripts/db.in.ogr
svn_grass at osgeo.org
Sat Sep 27 14:32:36 EDT 2008
Author: glynn
Date: 2008-09-27 14:32:36 -0400 (Sat, 27 Sep 2008)
New Revision: 33568
Added:
grass/trunk/scripts/db.in.ogr/db.in.ogr.py
Convert db.in.ogr.py to Python
Added: grass/trunk/scripts/db.in.ogr/db.in.ogr.py
--- grass/trunk/scripts/db.in.ogr/db.in.ogr.py (rev 0)
+++ grass/trunk/scripts/db.in.ogr/db.in.ogr.py 2008-09-27 18:32:36 UTC (rev 33568)
@@ -0,0 +1,120 @@
+#!/usr/bin/env python
+# MODULE: db.in.ogr
+# AUTHOR(S): Markus Neteler
+# PURPOSE: imports attribute tables in various formats
+# Converted to Python by Glynn Clements
+# COPYRIGHT: (C) 2007, 2008 by Markus Neteler and the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+#%Module
+#% description: Imports attribute tables in various formats.
+#% keywords: database, attribute table
+#%End
+#%option
+#% key: dsn
+#% type: string
+#% key_desc : name
+#% gisprompt: old_file,file,input
+#% description: Table file to be imported or DB connection string
+#% required : yes
+#%end
+#%option
+#% key: db_table
+#% type: string
+#% key_desc : name
+#% description: Table name of SQL DB table
+#% required : no
+#%end
+#%option
+#% key: output
+#% type: string
+#% description: Name for output table
+#% required : no
+#%end
+#%option
+#% key: key
+#% type: string
+#% description: Name for auto-generated unique key column
+#% required : no
+#%end
+import sys
+import os
+import grass
+def main():
+ dsn = options['dsn']
+ db_table = options['db_table']
+ output = options['output']
+ key = options['key']
+ mapset = grass.gisenv()['MAPSET']
+ if db_table:
+ input = db_table
+ else:
+ input = dsn
+ if not output:
+ tmpname = input.replace('.', '_')
+ output = grass.basename(tmpname)
+ if not grass.overwrite():
+ s = grass.read_command('db.tables', flags = 'p')
+ for l in s.splitlines():
+ if l == output:
+ grass.fatal("Table <%s> already exists" % output)
+ else:
+ grass.write_command('db.execute', stdin = "DROP TABLE %s" % output)
+ # treat DB as real vector map...
+ layer_opt = {}
+ if db_table:
+ layer_opt['layer'] = db_table
+ if grass.run_command('v.in.ogr', flags = 'o', dsn = dsn, output = output,
+ quiet = True, **layer_opt) != 0:
+ if db_table:
+ grass.fatal("Input table <%s> not found or not readable" % input)
+ else:
+ grass.fatal("Input DSN <%s> not found or not readable" % input)
+ nuldev = file(os.devnull, 'w')
+ # rename ID col if requested from cat to new name
+ if key:
+ grass.run_command('v.db.renamecol', quiet = True, map = output, layer = 1,
+ column = (cat, key), stdout = nuldev, stderr = nuldev)
+ # ... and immediately drop the empty geometry
+ vectfile = grass.find_file(output, element = 'vector', mapset = mapset)['file']
+ if not file:
+ grass.fatal("Something went wrong. Should not happen")
+ else:
+ # remove the vector part
+ grass.try_remove(file)
+ # get rid of superfluous auto-added cat column (and cat_ if present)
+ grass.run_command('db.dropcol', quiet = True, flags = 'f', table = output,
+ colum = 'cat', stdout = nuldev, stderr = nuldev)
+ s = grass.read_command('db.describe', flags = 'c', table = output)
+ kv = grass.parse_key_val(s, sep = ':')
+ records = int(kv['nrows'].strip())
+ grass.message("Imported table <%s> with %d rows" % (output, records))
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ main()
Property changes on: grass/trunk/scripts/db.in.ogr/db.in.ogr.py
___________________________________________________________________
