[GRASS-SVN] r33574 - in grass/trunk/imagery: i.albedo i.qc.modis
svn_grass at osgeo.org
Sat Sep 27 19:18:20 EDT 2008
Author: glynn
Date: 2008-09-27 19:18:20 -0400 (Sat, 27 Sep 2008)
New Revision: 33574
grass/trunk/imagery/i.albedo/
grass/trunk/imagery/i.albedo/bb_alb_aster.c
grass/trunk/imagery/i.albedo/bb_alb_landsat.c
grass/trunk/imagery/i.albedo/bb_alb_modis.c
grass/trunk/imagery/i.albedo/bb_alb_noaa.c
grass/trunk/imagery/i.albedo/main.c
grass/trunk/imagery/i.qc.modis/
grass/trunk/imagery/i.qc.modis/main.c
Remove erroneous svn:executable properties
Add svn:ignore properties
Convert to ANSI C (C89)
Use strcmp instead of strcoll
Read data as CELL (using map's quant rules) rather than using C typecast
Add ->options to qcname=
Fix formatting
Miscellaneous cleanup
Property changes on: grass/trunk/imagery/i.albedo
___________________________________________________________________
+ *OBJ*
Property changes on: grass/trunk/imagery/i.albedo/bb_alb_aster.c
Property changes on: grass/trunk/imagery/i.albedo/bb_alb_landsat.c
Property changes on: grass/trunk/imagery/i.albedo/bb_alb_modis.c
Property changes on: grass/trunk/imagery/i.albedo/bb_alb_noaa.c
Modified: grass/trunk/imagery/i.albedo/main.c
--- grass/trunk/imagery/i.albedo/main.c 2008-09-27 23:04:00 UTC (rev 33573)
+++ grass/trunk/imagery/i.albedo/main.c 2008-09-27 23:18:20 UTC (rev 33574)
@@ -34,67 +34,51 @@
int main(int argc, char *argv[])
struct Cell_head cellhd; /*region+header info */
- char *mapset; /*mapset name */
int nrows, ncols;
int row, col;
struct GModule *module;
struct Option *input, *output;
struct Flag *flag1, *flag2, *flag3;
struct Flag *flag4, *flag5, *flag6;
struct History history; /*metadata */
struct Colors colors; /*Color rules */
/* FMEO Declarations**************** */
char *name; /*input raster name */
char *result; /*output raster name */
/*File Descriptors */
int nfiles;
int infd[MAXFILES];
int outfd;
char **names;
char **ptr;
- int ok;
int i = 0, j = 0;
int modis = 0, aster = 0, avhrr = 0, landsat = 0;
void *inrast[MAXFILES];
unsigned char *outrast;
int data_format; /* 0=double 1=float 2=32bit signed int 5=8bit unsigned int (ie text) */
RASTER_MAP_TYPE in_data_type[MAXFILES]; /* 0=numbers 1=text */
RASTER_MAP_TYPE out_data_type = DCELL_TYPE;
+ int peak1, peak2, peak3;
+ int i_peak1, i_peak2, i_peak3;
+ int bottom1a, bottom1b;
+ int bottom2a, bottom2b;
+ int bottom3a, bottom3b;
+ int i_bottom1a, i_bottom1b;
+ int i_bottom2a, i_bottom2b;
+ int i_bottom3a, i_bottom3b;
int histogram[100];
/* Albedo correction coefficients*** */
double a, b;
G_gisinit(argv[0]);
@@ -115,39 +99,37 @@
/* Define the different flags */
flag1 = G_define_flag();
- flag1->key = _('m');
+ flag1->key = 'm';
flag1->description = _("Modis (7 input bands:1,2,3,4,5,6,7)");
flag2 = G_define_flag();
- flag2->key = _('n');
+ flag2->key = 'n';
flag2->description = _("NOAA AVHRR (2 input bands:1,2)");
flag3 = G_define_flag();
- flag3->key = _('l');
+ flag3->key = 'l';
flag3->description = _("Landsat (6 input bands:1,2,3,4,5,7)");
flag4 = G_define_flag();
- flag4->key = _('a');
+ flag4->key = 'a';
flag4->description = _("Aster (6 input bands:1,3,5,6,8,9)");
flag5 = G_define_flag();
- flag5->key = _('c');
+ flag5->key = 'c';
flag5->description =
_("Albedo dry run to calculate some water to beach/sand/desert stretching, a kind of simple atmospheric correction. Agressive mode (Landsat).");
flag6 = G_define_flag();
- flag6->key = _('d');
+ flag6->key = 'd';
flag6->description =
_("Albedo dry run to calculate some water to beach/sand/desert stretching, a kind of simple atmospheric correction. Soft mode (Modis).");
/* FMEO init nfiles */
nfiles = 1;
if (G_parser(argc, argv))
exit(-1);
- ok = 1;
names = input->answers;
ptr = input->answers;
@@ -158,80 +140,60 @@
landsat = (flag3->answer);
aster = (flag4->answer);
- if (G_legal_filename(result) < 0) {
+ if (G_legal_filename(result) < 0)
G_fatal_error(_("[%s] is an illegal name"), result);
for (; *ptr != NULL; ptr++) {
if (nfiles >= MAXFILES)
- G_fatal_error(_("%s - too many ETa files. Only %d allowed"),
- G_program_name(), MAXFILES);
+ G_fatal_error(_("too many ETa files. Only %d allowed"), MAXFILES);
name = *ptr;
- /* find map in mapset */
- mapset = G_find_cell2(name, "");
- if (mapset == NULL) {
- G_fatal_error(_("cell file [%s] not found"), name);
- ok = 0;
- if (!ok) {
+ infd[nfiles] = G_open_cell_old(name, "");
+ if (infd[nfiles] < 0)
continue;
- infd[nfiles] = G_open_cell_old(name, mapset);
- if (infd[nfiles] < 0) {
- ok = 0;
- continue;
/* Allocate input buffer */
- in_data_type[nfiles] = G_raster_map_type(name, mapset);
- if ((infd[nfiles] = G_open_cell_old(name, mapset)) < 0) {
+ in_data_type[nfiles] = G_raster_map_type(name, "");
+ if ((infd[nfiles] = G_open_cell_old(name, "")) < 0)
G_fatal_error(_("Cannot open cell file [%s]"), name);
- if ((G_get_cellhd(name, mapset, &cellhd)) < 0) {
+ if ((G_get_cellhd(name, "", &cellhd)) < 0)
G_fatal_error(_("Cannot read file header of [%s]"), name);
inrast[nfiles] = G_allocate_raster_buf(in_data_type[nfiles]);
nfiles++;
nfiles--;
- if (nfiles <= 1) {
+ if (nfiles <= 1)
G_fatal_error(_("The min specified input map is two (that is NOAA AVHRR)"));
/* Allocate output buffer, use input map data_type */
nrows = G_window_rows();
ncols = G_window_cols();
outrast = G_allocate_raster_buf(out_data_type);
/* Create New raster files */
- if ((outfd = G_open_raster_new(result, 1)) < 0) {
+ if ((outfd = G_open_raster_new(result, 1)) < 0)
G_fatal_error(_("Could not open <%s>"), result);
/*START ALBEDO HISTOGRAM STRETCH */
/*This is correcting contrast for water/sand */
/*A poor man's atmospheric correction... */
- for (i = 0; i < 100; i++) {
+ for (i = 0; i < 100; i++)
histogram[i] = 0;
if (flag5->answer || flag6->answer) {
DCELL de;
DCELL d[MAXFILES];
/* Process pixels histogram */
for (row = 0; row < nrows; row++) {
G_percent(row, nrows, 2);
/* read input map */
for (i = 1; i <= nfiles; i++) {
- if ((G_get_raster_row
- (infd[i], inrast[i], row, in_data_type[i])) < 0) {
+ if ((G_get_raster_row(
+ infd[i], inrast[i], row, in_data_type[i])) < 0)
G_fatal_error(_("Could not read from <%s>"), name);
/*process the data */
for (col = 0; col < ncols; col++) {
@@ -275,10 +237,7 @@
G_message("Histogram of Albedo\n");
- int peak1, peak2, peak3;
- int i_peak1, i_peak2, i_peak3;
peak1 = 0;
peak2 = 0;
peak3 = 0;
@@ -308,18 +267,7 @@
- int bottom1a, bottom1b;
- int bottom2a, bottom2b;
- int bottom3a, bottom3b;
- int i_bottom1a, i_bottom1b;
- int i_bottom2a, i_bottom2b;
- int i_bottom3a, i_bottom3b;
bottom1a = 100000;
bottom1b = 100000;
bottom2a = 100000;
@@ -391,20 +339,17 @@
} /*END OF FLAG1 */
/* End of processing histogram */
/* Process pixels */
DCELL de;
DCELL d[MAXFILES];
- if ((G_get_raster_row(infd[i], inrast[i], row, in_data_type[i])) <
- 0) {
Property changes on: grass/trunk/imagery/i.qc.modis
+ *OBJ*
Modified: grass/trunk/imagery/i.qc.modis/main.c
--- grass/trunk/imagery/i.qc.modis/main.c 2008-09-27 23:04:00 UTC (rev 33573)
+++ grass/trunk/imagery/i.qc.modis/main.c 2008-09-27 23:18:20 UTC (rev 33574)
@@ -14,105 +14,79 @@
* for details.
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <grass/gis.h>
#include <grass/glocale.h>
/* 250m Products (MOD09Q) */
int qc250a(unsigned int pixel);
int qc250b(unsigned int pixel);
int qc250c(unsigned int pixel, int bandno);
int qc250d(unsigned int pixel);
int qc250e(unsigned int pixel);
int qc250f(unsigned int pixel);
/* 500m Products (MOD09A) */
int qc500a(long int pixel);
int qc500c(long int pixel, int bandno);
int qc500d(long int pixel);
int qc500e(long int pixel);
int nrows, ncols;
int row, col;
char *qcflag; /*Switch for particular index */
struct Option *input1, *input2, *input_band, *output;
- struct Flag *flag1, *flag2;
+ struct Flag *flag1;
- /* FMEO Declarations**************** */
- char *name; /*input raster name */
+ /* FMEO Declarations**************** */
- /*File Descriptors */
- int infd;
+ /*File Descriptors */
+ int infd;
int outfd;
char *qcchan;
int bandno;
- int i = 0, j = 0;
- void *inrast;
- CELL * outrast;
+ CELL *inrast;
+ CELL *outrast;
RASTER_MAP_TYPE data_type_output = CELL_TYPE;
- RASTER_MAP_TYPE data_type_qcchan;
- G_gisinit(argv[0]);
+ G_gisinit(argv[0]);
module = G_define_module();
module->keywords = _("QC, Quality Control, surface reflectance, Modis");
module->description =
_("Extract quality control parameters from Modis QC layers");
- /* Define the different options */
- input1 = G_define_option();
+ /* Define the different options */
+ input1 = G_define_option();
input1->key = _("qcname");
input1->type = TYPE_STRING;
input1->required = YES;
input1->gisprompt = _("Name of QC type to extract");
- input1->description =
- _("Name of QC: modland_qa_bits, cloud, data_quality, atcorr, adjcorr, diff_orbit_from_500m");
+ input1->description = _("Name of QC");
+ input1->options = "adjcorr,atcorr,cloud,data_quality,diff_orbit_from_500m,modland_qa_bits";
input1->answer = _("modland_qa_bits");
input2 = G_define_standard_option(G_OPT_R_INPUT);
input2->description =
_("Name of the surface reflectance QC layer [bit array]");
input_band = G_define_option();
input_band->key = "band";
input_band->type = TYPE_INTEGER;
@@ -120,202 +94,135 @@
input_band->gisprompt = "old,value";
input_band->description =
_("Band number of Modis product 250m=[1,2],500m=[1-7]");
output = G_define_standard_option(G_OPT_R_OUTPUT);
output->key = _("output");
output->description =
_("Name of the output QC type classification layer");
output->answer = _("qc");
flag1->key = 'A';
_("QC for MOD09A product @ 500m instead of default MOD09Q at 250m");
- if (G_parser(argc, argv))
+ if (G_parser(argc, argv))
exit(EXIT_FAILURE);
qcflag = input1->answer;
qcchan = input2->answer;
- if (input_band->answer) {
+ if (input_band->answer)
bandno = atoi(input_band->answer);
result = output->answer;
- if ((!strcoll(qcflag, "cloud") && flag1->answer) ||
- (!strcoll(qcflag, "diff_orbit_from_500m") && flag1->answer)) {
- G_fatal_error("Those flags cannot work with MOD09A @ 500m products");
- if (!strcoll(qcflag, "data_quality")) {
+ if ((!strcmp(qcflag, "cloud") && flag1->answer) ||
+ (!strcmp(qcflag, "diff_orbit_from_500m") && flag1->answer))
+ G_fatal_error(_("Those flags cannot work with MOD09A @ 500m products"));
+ if (!strcmp(qcflag, "data_quality")) {
if (bandno < 1 || bandno > 7)
- G_fatal_error("band number out of allowed range [1-7]");
+ G_fatal_error(_("band number out of allowed range [1-7]"));
if (!flag1->answer && bandno > 2)
- G_fatal_error("250m band number is out of allowed range [1,2]");
+ G_fatal_error(_("250m band number is out of allowed range [1,2]"));
- mapset = G_find_cell2(qcchan, "");
- G_fatal_error(_("cell file [%s] not found"), qcchan);
- data_type_qcchan = G_raster_map_type(qcchan, mapset);
- if ((infd = G_open_cell_old(qcchan, mapset)) < 0)
+ if ((infd = G_open_cell_old(qcchan, "")) < 0)
G_fatal_error(_("Cannot open cell file [%s]"), qcchan);
- if (G_get_cellhd(qcchan, mapset, &cellhd) < 0)
+ if (G_get_cellhd(qcchan, "", &cellhd) < 0)
G_fatal_error(_("Cannot read file header of [%s]"), qcchan);
- inrast = G_allocate_raster_buf(data_type_qcchan);
- G_debug(3, "number of rows %d", cellhd.rows);
+ inrast = G_allocate_c_raster_buf();
+ G_debug(3, "number of rows %d", cellhd.rows);
- outrast = G_allocate_raster_buf(data_type_output);
- /* Create New raster files */
- if ((outfd = G_open_raster_new(result, data_type_output)) < 0)
+ outrast = G_allocate_c_raster_buf();
+ /* Create New raster files */
+ if ((outfd = G_open_raster_new(result, data_type_output)) < 0)
- /* Process pixels */
- for (row = 0; row < nrows; row++)
+ /* Process pixels */
+ for (row = 0; row < nrows; row++)
CELL c;
unsigned int qc250chan;
CELL qc500chan;
- if (G_get_raster_row(infd, inrast, row, data_type_qcchan) < 0)
+ if (G_get_c_raster_row(infd, inrast, row) < 0)
G_fatal_error(_("Could not read from <%s>"), qcchan);
- /*process the data */
- for (col = 0; col < ncols; col++)
- switch (data_type_qcchan) {
- case CELL_TYPE:
- c = (int)((CELL *) inrast)[col];
- break;
- case FCELL_TYPE:
- c = (int)((FCELL *) inrast)[col];
- break;
- case DCELL_TYPE:
- c = (int)((DCELL *) inrast)[col];
- break;
- if (flag1->answer) {
- /* This is a MOD09A at 500m product, QC layer is 32-bit */
- qc500chan = c;
- else {
- /* This is a MOD09A at 250m product, QC layer is 16-bit */
- qc250chan = (unsigned int)((CELL *) inrast)[col];
- } if (G_is_c_null_value(&c)) {
+ /*process the data */
+ for (col = 0; col < ncols; col++)
+ c = inrast[col];
+ if (flag1->answer)
+ /* This is a MOD09A at 500m product, QC layer is 32-bit */
+ qc500chan = c;
+ else
+ /* This is a MOD09A at 250m product, QC layer is 16-bit */
+ qc250chan = (unsigned int) c;
+ if (G_is_c_null_value(&c))
G_set_c_null_value(&outrast[col], 1);
+ else if (!strcmp(qcflag, "modland_qa_bits")) {
+ /*calculate modland QA bits extraction */
+ c = qc500a(qc500chan);
+ else
+ c = qc250a(qc250chan);
- else {
- /*calculate modland QA bits extraction */
- if (!strcoll(qcflag, "modland_qa_bits")) {
- /* 500m product */
- c = qc500a(qc500chan);
- else {
- /* 250m product */
- c = qc250a(qc250chan);
- outrast[col] = c;
+ else if (!strcmp(qcflag, "cloud"))
+ /*calculate cloud state */
+ /* ONLY 250m product! */
+ c = qc250b(qc250chan);
+ else if (!strcmp(qcflag, "data_quality")) {
+ c = qc500c(qc500chan, bandno);
else
- /*calculate cloud state */
- if (!strcoll(qcflag, "cloud")) {
- /* ONLY 250m product! */
- c = qc250b(qc250chan);
- outrast[col] = c;
+ c = qc250c(qc250chan, bandno);
+ else if (!strcmp(qcflag, "atcorr")) {
+ /*calculate atmospheric correction flag */
+ c = qc500d(qc500chan);
else
- c = qc500c(qc500chan, bandno);
- else {
- c = qc250c(qc250chan, bandno);
- outrast[col] = c;
+ c = qc250d(qc250chan);
+ else if (!strcmp(qcflag, "adjcorr")) {
+ /*calculate adjacency correction flag */
+ c = qc500e(qc500chan);
else
- /*calculate atmospheric correction flag */
- if (!strcoll(qcflag, "atcorr")) {
- c = qc500d(qc500chan);
- else {
- c = qc250d(qc250chan);
- outrast[col] = c;
- else
- /*calculate adjacency correction flag */
- if (!strcoll(qcflag, "adjcorr")) {
- c = qc500e(qc500chan);
- else {
- c = qc250e(qc250chan);
- outrast[col] = c;
- else
- /*calculate different orbit from 500m flag */
- if (!strcoll(qcflag, "diff_orbit_from_500m")) {
- c = qc250f(qc500chan);
- outrast[col] = c;
- else {
- /* Signal user that the flag name is badly written */
- /* therefore not understood by the application */
- G_fatal_error
- ("Unknown flag name, please check spelling");
+ c = qc250e(qc250chan);
- if (G_put_raster_row(outfd, outrast, data_type_output) < 0)
- G_fatal_error(_("Cannot write to output raster file"));
+ else if (!strcmp(qcflag, "diff_orbit_from_500m"))
+ /*calculate different orbit from 500m flag */
+ c = qc250f(qc500chan);
+ else
+ G_fatal_error(_("Unknown flag name, please check spelling"));
+ outrast[col] = c;
+ if (G_put_c_raster_row(outfd, outrast) < 0)
+ G_fatal_error(_("Cannot write to output raster file"));
G_free(inrast);
G_close_cell(infd);
G_free(outrast);
G_close_cell(outfd);
- /* Color from -1.0 to +1.0 in grey */
- G_init_colors(&colors);
+ /* Color from -1.0 to +1.0 in grey */
+ G_init_colors(&colors);
G_add_color_rule(0, 0, 0, 0, 10, 255, 255, 255, &colors);
G_short_history(result, "raster", &history);
G_command_history(&history);
