[GRASS-SVN] r33578 - in grass/trunk/scripts: db.in.ogr db.out.ogr
v.report
svn_grass at osgeo.org
Sat Sep 27 20:02:45 EDT 2008
Author: glynn
Date: 2008-09-27 20:02:45 -0400 (Sat, 27 Sep 2008)
New Revision: 33578
grass/trunk/scripts/db.in.ogr/db.in.ogr.py
grass/trunk/scripts/db.out.ogr/db.out.ogr.py
grass/trunk/scripts/v.report/v.report.py
Use 'option = None' for unspecified options, rather than **dict
Modified: grass/trunk/scripts/db.in.ogr/db.in.ogr.py
--- grass/trunk/scripts/db.in.ogr/db.in.ogr.py 2008-09-28 00:01:47 UTC (rev 33577)
+++ grass/trunk/scripts/db.in.ogr/db.in.ogr.py 2008-09-28 00:02:45 UTC (rev 33578)
@@ -80,12 +80,13 @@
grass.write_command('db.execute', stdin = "DROP TABLE %s" % output)
# treat DB as real vector map...
- layer_opt = {}
if db_table:
- layer_opt['layer'] = db_table
+ layer = db_table
+ else:
+ layer = None
if grass.run_command('v.in.ogr', flags = 'o', dsn = dsn, output = output,
- quiet = True, **layer_opt) != 0:
+ layer = layer, quiet = True) != 0:
if db_table:
grass.fatal("Input table <%s> not found or not readable" % input)
else:
Modified: grass/trunk/scripts/db.out.ogr/db.out.ogr.py
--- grass/trunk/scripts/db.out.ogr/db.out.ogr.py 2008-09-28 00:01:47 UTC (rev 33577)
+++ grass/trunk/scripts/db.out.ogr/db.out.ogr.py 2008-09-28 00:02:45 UTC (rev 33578)
@@ -66,9 +66,10 @@
if format.lower() == 'dbf':
format = "ESRI_Shapefile"
- olayer = {}
if format.lower() == 'csv':
- olayer['olayer'] = grass.basename(dsn, 'csv')
+ olayer = grass.basename(dsn, 'csv')
+ else:
+ olayer = None
#is there a simpler way of testing for --overwrite?
dbffile = input + '.dbf'
@@ -76,7 +77,7 @@
grass.fatal("File <%s> already exists" % dbffile)
if grass.run_command('v.out.ogr', quiet = True, input = input, dsn = dsn,
- format = format, type = 'point', **olayer) != 0:
+ format = format, type = 'point', olayer = olayer) != 0:
sys.exit(1)
if format == "ESRI_Shapefile":
Modified: grass/trunk/scripts/v.report/v.report.py
--- grass/trunk/scripts/v.report/v.report.py 2008-09-28 00:01:47 UTC (rev 33577)
+++ grass/trunk/scripts/v.report/v.report.py 2008-09-28 00:02:45 UTC (rev 33578)
@@ -112,11 +112,11 @@
extracolnames = [option]
if units in ['p','percent']:
- unitsp = {'units': 'meters'}
+ unitsp = 'meters'
elif units:
+ unitsp = units
else:
- unitsp = {}
+ unitsp = None
# NOTE: we suppress -1 cat and 0 cat
@@ -140,7 +140,7 @@
#fetch the requested attribute sorted by cat:
p = grass.pipe_command('v.to.db', flags = 'p',
map = mapname, option = option, columns = columns,
- layer = layer, **unitsp)
+ layer = layer, units = unitsp)
records2 = []
for line in p.stdout:
fields = line.rstrip('\r\n').split('|')
@@ -166,7 +166,7 @@
#make pre-table
records3 = []
fields = line.split('|')
