[GRASS-SVN] r33584 - grass/trunk/imagery/i.vi
Sun Sep 28 13:15:49 EDT 2008
Author: glynn
Date: 2008-09-28 13:15:48 -0400 (Sun, 28 Sep 2008)
New Revision: 33584
   grass/trunk/imagery/i.vi/
   grass/trunk/imagery/i.vi/main.c
Set svn:ignore property
Simply code
Fix formatting
Property changes on: grass/trunk/imagery/i.vi
___________________________________________________________________
   + *OBJ*
Modified: grass/trunk/imagery/i.vi/main.c
--- grass/trunk/imagery/i.vi/main.c	2008-09-28 09:55:40 UTC (rev 33583)
+++ grass/trunk/imagery/i.vi/main.c	2008-09-28 17:15:48 UTC (rev 33584)
@@ -23,147 +23,109 @@
  * Changelog:	 Added EVI on 20080718 (Yann)
 #include <stdio.h>
 #include <stdlib.h>
 #include <string.h>
 #include <grass/gis.h>
 #include <grass/glocale.h>
-double s_r(double redchan, double nirchan);
+double s_r(double redchan, double nirchan);
 double nd_vi(double redchan, double nirchan);
 double ip_vi(double redchan, double nirchan);
 double d_vi(double redchan, double nirchan);
 double e_vi(double bluechan, double redchan, double nirchan);
 double p_vi(double redchan, double nirchan);
 double wd_vi(double redchan, double nirchan);
 double sa_vi(double redchan, double nirchan);
 double msa_vi(double redchan, double nirchan);
 double msa_vi2(double redchan, double nirchan);
 double ge_mi(double redchan, double nirchan);
 double ar_vi(double redchan, double nirchan, double bluechan);
 double g_vi(double bluechan, double greenchan, double redchan,
 	     double nirchan, double chan5chan, double chan7chan);
 double ga_ri(double redchan, double nirchan, double bluechan,
 	      double greenchan);
 int main(int argc, char *argv[])
-    struct Cell_head cellhd;	/*region+header info */
-    char *mapset;		/*mapset name */
     int nrows, ncols;
     int row, col;
     char *viflag;		/*Switch for particular index */
     struct GModule *module;
     struct Option *input1, *input2, *input3, *input4, *input5, *input6,
 	*input7, *output;
-    struct Flag *flag1;
     struct History history;	/*metadata */
     struct Colors colors;	/*Color rules */
-	/* FMEO Declarations**************** */
-    char *name;			/*input raster name */
+    /* FMEO Declarations */
     char *result;		/*output raster name */
-	/*File Descriptors */
+    /* File Descriptors */
     int infd_redchan, infd_nirchan, infd_greenchan;
     int infd_bluechan, infd_chan5chan, infd_chan7chan;
     int outfd;
     char *bluechan, *greenchan, *redchan, *nirchan, *chan5chan, *chan7chan;
+    DCELL *inrast_redchan, *inrast_nirchan, *inrast_greenchan;
+    DCELL *inrast_bluechan, *inrast_chan5chan, *inrast_chan7chan;
+    DCELL *outrast;
-    int i = 0, j = 0;
+    G_gisinit(argv[0]);
-    void *inrast_redchan, *inrast_nirchan, *inrast_greenchan;
-    void *inrast_bluechan, *inrast_chan5chan, *inrast_chan7chan;
-    DCELL * outrast;
-    RASTER_MAP_TYPE data_type_output = DCELL_TYPE;
-    RASTER_MAP_TYPE data_type_redchan;
-    RASTER_MAP_TYPE data_type_nirchan;
-    RASTER_MAP_TYPE data_type_greenchan;
-    RASTER_MAP_TYPE data_type_bluechan;
-    RASTER_MAP_TYPE data_type_chan5chan;
-    RASTER_MAP_TYPE data_type_chan7chan;
-	G_gisinit(argv[0]);
     module = G_define_module();
     module->keywords = _("vegetation index, biophysical parameters");
     module->description =
 	_("14 types of vegetation indices from red and nir, and only some requiring additional bands");
-	/* Define the different options */
-	input1 = G_define_option();
+    /* Define the different options */
+    input1 = G_define_option();
     input1->key = _("viname");
     input1->type = TYPE_STRING;
     input1->required = YES;
     input1->gisprompt = _("Name of VI");
     input1->description =
 	_("Name of VI: sr,ndvi,ipvi,dvi,evi,pvi,wdvi,savi,msavi,msavi2,gemi,arvi,gvi,gari.");
     input1->answer = _("ndvi");
     input2 = G_define_standard_option(G_OPT_R_INPUT);
     input2->key = _("red");
     input2->description =
 	_("Name of the RED Channel surface reflectance map [0.0;1.0]");
     input3 = G_define_standard_option(G_OPT_R_INPUT);
     input3->key = _("nir");
     input3->description =
 	_("Name of the NIR Channel surface reflectance map [0.0;1.0]");
     input4 = G_define_standard_option(G_OPT_R_INPUT);
     input4->key = _("green");
     input4->required = NO;
     input4->description =
 	_("Name of the GREEN Channel surface reflectance map [0.0;1.0]");
     input5 = G_define_standard_option(G_OPT_R_INPUT);
     input5->key = _("blue");
     input5->required = NO;
     input5->description =
 	_("Name of the BLUE Channel surface reflectance map [0.0;1.0]");
     input6 = G_define_standard_option(G_OPT_R_INPUT);
     input6->key = _("chan5");
     input6->required = NO;
     input6->description =
 	_("Name of the CHAN5 Channel surface reflectance map [0.0;1.0]");
     input7 = G_define_standard_option(G_OPT_R_INPUT);
     input7->key = _("chan7");
     input7->required = NO;
     input7->description =
 	_("Name of the CHAN7 Channel surface reflectance map [0.0;1.0]");
     output = G_define_standard_option(G_OPT_R_OUTPUT);
     output->description = _("Name of the output vi layer");
-	if (G_parser(argc, argv))
+    if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
     viflag = input1->answer;
     redchan = input2->answer;
     nirchan = input3->answer;
@@ -172,139 +134,50 @@
     chan5chan = input6->answer;
     chan7chan = input7->answer;
     result = output->answer;
-	mapset = G_find_cell2(redchan, "");
-    if (mapset == NULL) {
-	G_fatal_error(_("%s - cell file [%s] not found"),
-			G_program_name(), redchan);
-    data_type_redchan = G_raster_map_type(redchan, mapset);
-    if ((infd_redchan = G_open_cell_old(redchan, mapset)) < 0){
-	G_fatal_error(_("%s - Cannot open cell file [%s]"),
-    if (G_get_cellhd(redchan, mapset, &cellhd) < 0){
-	G_fatal_error(_("%s - Cannot read file header of [%s])"),
-    inrast_redchan = G_allocate_raster_buf(data_type_redchan);
+    if ((infd_redchan = G_open_cell_old(redchan, "")) < 0)
+	G_fatal_error(_("Cannot open cell file [%s]"), redchan);
+    inrast_redchan = G_allocate_d_raster_buf();
-	mapset = G_find_cell2(nirchan, "");
-			G_program_name(), nirchan);
-    data_type_nirchan = G_raster_map_type(nirchan, mapset);
-    if ((infd_nirchan = G_open_cell_old(nirchan, mapset)) < 0){
-    if (G_get_cellhd(nirchan, mapset, &cellhd) < 0){
-	G_fatal_error(_("%s - Cannot read file header of [%s]"),
-    inrast_nirchan = G_allocate_raster_buf(data_type_nirchan);
+    if ((infd_nirchan = G_open_cell_old(nirchan, "")) < 0)
+	G_fatal_error(_("Cannot open cell file [%s]"), nirchan);
+    inrast_nirchan = G_allocate_d_raster_buf();
-	if (greenchan) {
-	mapset = G_find_cell2(greenchan, "");
-			G_program_name(), greenchan);
-	data_type_greenchan = G_raster_map_type(greenchan, mapset);
-	if ((infd_greenchan = G_open_cell_old(greenchan, mapset)) < 0){
-	if (G_get_cellhd(greenchan, mapset, &cellhd) < 0){
-	inrast_greenchan = G_allocate_raster_buf(data_type_greenchan);
+    if (greenchan) {
+	if ((infd_greenchan = G_open_cell_old(greenchan, "")) < 0)
+	    G_fatal_error(_("Cannot open cell file [%s]"), greenchan);
+	inrast_greenchan = G_allocate_d_raster_buf();
-	if (bluechan) {
-	mapset = G_find_cell2(bluechan, "");
-			G_program_name(), bluechan);
-	data_type_bluechan = G_raster_map_type(bluechan, mapset);
-	if ((infd_bluechan = G_open_cell_old(bluechan, mapset)) < 0){
-	if (G_get_cellhd(bluechan, mapset, &cellhd) < 0){
-	inrast_bluechan = G_allocate_raster_buf(data_type_bluechan);
+    if (bluechan) {
+	if ((infd_bluechan = G_open_cell_old(bluechan, "")) < 0)
+	    G_fatal_error(_("Cannot open cell file [%s]"), bluechan);
+	inrast_bluechan = G_allocate_d_raster_buf();
-	if (chan5chan) {
-	mapset = G_find_cell2(chan5chan, "");
-			G_program_name(), chan5chan);
-	data_type_chan5chan = G_raster_map_type(chan5chan, mapset);
-	if ((infd_chan5chan = G_open_cell_old(chan5chan, mapset)) < 0){
-	if (G_get_cellhd(chan5chan, mapset, &cellhd) < 0){
-	inrast_chan5chan = G_allocate_raster_buf(data_type_chan5chan);
+    if (chan5chan) {
+	if ((infd_chan5chan = G_open_cell_old(chan5chan, "")) < 0)
+	    G_fatal_error(_("Cannot open cell file [%s]"), chan5chan);
+	inrast_chan5chan = G_allocate_d_raster_buf();
-	if (chan7chan) {
-	mapset = G_find_cell2(chan7chan, "");
-			G_program_name(), chan7chan);
-	data_type_chan7chan = G_raster_map_type(chan7chan, mapset);
-	if ((infd_chan7chan = G_open_cell_old(chan7chan, mapset)) < 0){
-	if (G_get_cellhd(chan7chan, mapset, &cellhd) < 0){
-	inrast_chan7chan = G_allocate_raster_buf(data_type_chan7chan);
+    if (chan7chan) {
+	if ((infd_chan7chan = G_open_cell_old(chan7chan, "")) < 0)
+	    G_fatal_error(_("Cannot open cell file [%s]"), chan7chan);
+	inrast_chan7chan = G_allocate_d_raster_buf();
-	G_debug(3, "number of rows %d", cellhd.rows);
     nrows = G_window_rows();
     ncols = G_window_cols();
-    outrast = G_allocate_raster_buf(data_type_output);
-	/* Create New raster files */
-	if ((outfd = G_open_raster_new(result, data_type_output)) < 0){
-	G_fatal_error(_("%s - Could not open <%s>"),
-			G_program_name(), result);
-	/* Process pixels */
-	for (row = 0; row < nrows; row++)
+    outrast = G_allocate_d_raster_buf();
+    /* Create New raster files */
+    if ((outfd = G_open_raster_new(result, DCELL_TYPE)) < 0)
+	G_fatal_error(_("Could not open <%s>"), result);
+    /* Process pixels */
+    for (row = 0; row < nrows; row++)
 	DCELL d;
 	DCELL d_bluechan;
 	DCELL d_greenchan;
@@ -312,235 +185,103 @@
 	DCELL d_nirchan;
 	DCELL d_chan5chan;
 	DCELL d_chan7chan;
 	G_percent(row, nrows, 2);
-	if (G_get_raster_row
-	     (infd_redchan, inrast_redchan, row, data_type_redchan) < 0){
-	    G_fatal_error(_("%s - Could not read from <%s>"),
-	     (infd_nirchan, inrast_nirchan, row, data_type_nirchan) < 0){
+	if (G_get_d_raster_row(infd_redchan, inrast_redchan, row) < 0)
+	    G_fatal_error(_("Could not read from <%s>"), redchan);
+	if (G_get_d_raster_row(infd_nirchan, inrast_nirchan, row) < 0)
+	    G_fatal_error(_("Could not read from <%s>"), nirchan);
 	if (greenchan) {
-		 (infd_greenchan, inrast_greenchan, row,
-		  data_type_greenchan) < 0){
+	    if (G_get_d_raster_row(infd_greenchan, inrast_greenchan, row) < 0)
+		G_fatal_error(_("Could not read from <%s>"), greenchan);
 	if (bluechan) {
-		 (infd_bluechan, inrast_bluechan, row,
-		  data_type_bluechan) < 0){
+	    if (G_get_d_raster_row(infd_bluechan, inrast_bluechan, row) < 0)
+		G_fatal_error(_("Could not read from <%s>"), bluechan);
 	if (chan5chan) {
-		 (infd_chan5chan, inrast_chan5chan, row,
-		  data_type_chan5chan) < 0){
+	    if (G_get_d_raster_row(infd_chan5chan, inrast_chan5chan, row) < 0)
+		G_fatal_error(_("Could not read from <%s>"), chan5chan);
 	if (chan7chan) {
-		 (infd_chan7chan, inrast_chan7chan, row,
-		  data_type_chan7chan) < 0){
+	    if (G_get_d_raster_row(infd_chan7chan, inrast_chan7chan, row) < 0)
+		G_fatal_error(_("Could not read from <%s>"), chan7chan);
-	    /*process the data */
-	    for (col = 0; col < ncols; col++)
-	    switch (data_type_redchan) {
-	    case CELL_TYPE:
-		d_redchan = (double)((CELL *) inrast_redchan)[col];
-		break;
-	    case FCELL_TYPE:
-		d_redchan = (double)((FCELL *) inrast_redchan)[col];
-		break;
-	    case DCELL_TYPE:
-		d_redchan = ((DCELL *) inrast_redchan)[col];
-		break;
-	    switch (data_type_nirchan) {
-	    case CELL_TYPE:
-		d_nirchan = (double)((CELL *) inrast_nirchan)[col];
-		break;
-	    case FCELL_TYPE:
-		d_nirchan = (double)((FCELL *) inrast_nirchan)[col];
-		break;
-	    case DCELL_TYPE:
-		d_nirchan = ((DCELL *) inrast_nirchan)[col];
-		break;
-	    if (greenchan) {
-		switch (data_type_greenchan) {
-		case CELL_TYPE:
-		    d_greenchan = (double)((CELL *) inrast_greenchan)[col];
-		    break;
-		case FCELL_TYPE:
-		    d_greenchan = (double)((FCELL *) inrast_greenchan)[col];
-		    break;
-		case DCELL_TYPE:
-		    d_greenchan = ((DCELL *) inrast_greenchan)[col];
-		    break;
-	    if (bluechan) {
-		switch (data_type_bluechan) {
-		case CELL_TYPE:
-		    d_bluechan = (double)((CELL *) inrast_bluechan)[col];
-		    break;
-		case FCELL_TYPE:
-		    d_bluechan = (double)((FCELL *) inrast_bluechan)[col];
-		    break;
-		case DCELL_TYPE:
-		    d_bluechan = ((DCELL *) inrast_bluechan)[col];
-		    break;
-	    if (chan5chan) {
-		switch (data_type_chan5chan) {
-		case CELL_TYPE:
-		    d_chan5chan = (double)((CELL *) inrast_chan5chan)[col];
-		    break;
-		case FCELL_TYPE:
-		    d_chan5chan = (double)((FCELL *) inrast_chan5chan)[col];
-		    break;
-		case DCELL_TYPE:
-		    d_chan5chan = ((DCELL *) inrast_chan5chan)[col];
-		    break;
-	    if (chan7chan) {
-		switch (data_type_chan7chan) {
-		case CELL_TYPE:
-		    d_chan7chan = (double)((CELL *) inrast_chan7chan)[col];
-		    break;
-		case FCELL_TYPE:
-		    d_chan7chan = (double)((FCELL *) inrast_chan7chan)[col];
-		    break;
-		case DCELL_TYPE:
-		    d_chan7chan = ((DCELL *) inrast_chan7chan)[col];
-		    break;
+	/* process the data */
+	for (col = 0; col < ncols; col++)
+	    d_redchan   = inrast_redchan[col];
+	    d_nirchan   = inrast_nirchan[col];
+	    d_greenchan = inrast_greenchan[col];
+	    d_bluechan  = inrast_bluechan[col];
+	    d_chan5chan = inrast_chan5chan[col];
+	    d_chan7chan = inrast_chan7chan[col];
 	    if (G_is_d_null_value(&d_redchan) ||
-		 G_is_d_null_value(&d_nirchan) ||
-                 ((greenchan) && G_is_d_null_value(&d_greenchan)) ||
-		 ((bluechan) && G_is_d_null_value(&d_bluechan)) ||
-		 ((chan5chan) && G_is_d_null_value(&d_chan5chan)) ||
-		 ((chan7chan) && G_is_d_null_value(&d_chan7chan))) {
+		G_is_d_null_value(&d_nirchan) ||
+		((greenchan) && G_is_d_null_value(&d_greenchan)) ||
+		((bluechan) && G_is_d_null_value(&d_bluechan)) ||
+		((chan5chan) && G_is_d_null_value(&d_chan5chan)) ||
+		((chan7chan) && G_is_d_null_value(&d_chan7chan))) {
 		G_set_d_null_value(&outrast[col], 1);
 	    else {
-		    /*calculate simple_ratio        */
-		    if (!strcmp(viflag, "sr")) {
+		/* calculate simple_ratio        */
+		if (!strcmp(viflag, "sr"))
 		    d = s_r(d_redchan, d_nirchan);
-		    ((DCELL *) outrast)[col] = d;
-		    /*calculate ndvi                    */
-		    if (!strcmp(viflag, "ndvi")) {
-		    if (d_redchan + d_nirchan < 0.001) {
+		/* calculate ndvi                    */
+		if (!strcmp(viflag, "ndvi")) {
+		    if (d_redchan + d_nirchan < 0.001)
-		    else {
-			d = nd_vi(d_redchan, d_nirchan);
+		    else
+			outrast[col] = nd_vi(d_redchan, d_nirchan);
-		    /*calculate ipvi                    */
-		    if (!strcmp(viflag, "ipvi")) {
-		    d = ip_vi(d_redchan, d_nirchan);
-		    /*calculate dvi             */
-		    if (!strcmp(viflag, "dvi")) {
-		    d = d_vi(d_redchan, d_nirchan);
-		    /*calculate evi             */
-		    if (!strcmp(viflag, "evi")) {
-		    d = e_vi(d_bluechan, d_redchan, d_nirchan);
-		    /*calculate pvi             */
-		    if (!strcmp(viflag, "pvi")) {
-		    d = p_vi(d_redchan, d_nirchan);
-		    /*calculate wdvi                    */
-		    if (!strcmp(viflag, "wdvi")) {
-		    d = wd_vi(d_redchan, d_nirchan);
-		    /*calculate savi                    */
-		    if (!strcmp(viflag, "savi")) {
-		    d = sa_vi(d_redchan, d_nirchan);
-		    /*calculate msavi                   */
-		    if (!strcmp(viflag, "msavi")) {
-		    d = msa_vi(d_redchan, d_nirchan);
-		    /*calculate msavi2            */
-		    if (!strcmp(viflag, "msavi2")) {
-		    d = msa_vi2(d_redchan, d_nirchan);
-		    /*calculate gemi                    */
-		    if (!strcmp(viflag, "gemi")) {
-		    d = ge_mi(d_redchan, d_nirchan);
-		    /*calculate arvi                    */
-		    if (!strcmp(viflag, "arvi")) {
-		    d = ar_vi(d_redchan, d_nirchan, d_bluechan);
-		    /*calculate gvi            */
-		    if (!strcmp(viflag, "gvi")) {
-		    d = g_vi(d_bluechan, d_greenchan, d_redchan, d_nirchan,
-			      d_chan5chan, d_chan7chan);
-		    /*calculate gari                    */
-		    if (!strcmp(viflag, "gari")) {
-		    d = ga_ri(d_redchan, d_nirchan, d_bluechan, d_greenchan);
+		if (!strcmp(viflag, "ipvi"))
+		    outrast[col] = ip_vi(d_redchan, d_nirchan);
+		if (!strcmp(viflag, "dvi"))
+		    outrast[col] = d_vi(d_redchan, d_nirchan);
+		if (!strcmp(viflag, "evi"))
+		    outrast[col] = e_vi(d_bluechan, d_redchan, d_nirchan);
+		if (!strcmp(viflag, "pvi"))
+		    outrast[col] = p_vi(d_redchan, d_nirchan);
+		if (!strcmp(viflag, "wdvi"))
+		    outrast[col] = wd_vi(d_redchan, d_nirchan);
+		if (!strcmp(viflag, "savi"))
+		    outrast[col] = sa_vi(d_redchan, d_nirchan);
+		if (!strcmp(viflag, "msavi"))
+		    outrast[col] = msa_vi(d_redchan, d_nirchan);
+		if (!strcmp(viflag, "msavi2"))
+		    outrast[col] = msa_vi2(d_redchan, d_nirchan);
+		if (!strcmp(viflag, "gemi"))
+		    outrast[col] = ge_mi(d_redchan, d_nirchan);
+		if (!strcmp(viflag, "arvi"))
+		    outrast[col] = ar_vi(d_redchan, d_nirchan, d_bluechan);
+		if (!strcmp(viflag, "gvi"))
+		    outrast[col] = g_vi(d_bluechan, d_greenchan, d_redchan, d_nirchan,
+					d_chan5chan, d_chan7chan);
+		if (!strcmp(viflag, "gari"))
+		    outrast[col] = ga_ri(d_redchan, d_nirchan, d_bluechan, d_greenchan);
-	if (G_put_raster_row(outfd, outrast, data_type_output) < 0){
-	    G_fatal_error(_("%s - Cannot write to output raster file"),
-			G_program_name());
+	if (G_put_d_raster_row(outfd, outrast) < 0)
+	    G_fatal_error(_("Cannot write to output raster file"));
     G_free(inrast_redchan);
     G_close_cell(infd_redchan);
     G_free(inrast_nirchan);
@@ -561,11 +302,12 @@
 	G_free(inrast_chan7chan);
 	G_close_cell(infd_chan7chan);
     G_free(outrast);
     G_close_cell(outfd);
-	/* Color from -1.0 to +1.0 in grey */
-	G_init_colors(&colors);
+    /* Color from -1.0 to +1.0 in grey */
+    G_init_colors(&colors);
     G_add_color_rule(-1.0, 0, 0, 0, 1.0, 255, 255, 255, &colors);
     G_short_history(result, "raster", &history);
     G_command_history(&history);
@@ -573,4 +315,3 @@
     exit(EXIT_SUCCESS);
