[GRASS-SVN] r33598 - in grass/trunk: db/base display/d.grid
display/d.thematic.area doc/vector/v.example general/g.mapset
general/g.proj gui/wxpython/gui_modules
imagery/i.ortho.photo/photo.2image
imagery/i.ortho.photo/photo.2target imagery/i.points
imagery/i.vpoints lib/db/dbmi_client lib/db/dbmi_driver
lib/gis lib/gpde lib/ogsf lib/proj lib/sites lib/vector/Vlib
lib/vector/diglib locale/templates raster/r.gwflow
raster/r.le/r.le.patch raster/r.out.arc raster/r.out.gdal
raster/r.to.vect scripts/d.vect.thematic scripts/r.tileset
scripts/v.what.vect vector/v.clean vector/v.distance
vector/v.edit vector/v.label.sa
svn_grass at osgeo.org
Mon Sep 29 13:31:57 EDT 2008
Author: glynn
Date: 2008-09-29 13:31:56 -0400 (Mon, 29 Sep 2008)
New Revision: 33598
grass/trunk/db/base/copy.c
grass/trunk/display/d.grid/main.c
grass/trunk/display/d.thematic.area/main.c
grass/trunk/doc/vector/v.example/main.c
grass/trunk/general/g.mapset/main.c
grass/trunk/general/g.proj/datumtrans.c
grass/trunk/gui/wxpython/gui_modules/menudata.py
grass/trunk/gui/wxpython/gui_modules/nviz_tools.py
grass/trunk/gui/wxpython/gui_modules/render.py
grass/trunk/gui/wxpython/gui_modules/toolbars.py
grass/trunk/gui/wxpython/gui_modules/toolbox.py
grass/trunk/imagery/i.ortho.photo/photo.2image/main.c
grass/trunk/imagery/i.ortho.photo/photo.2image/where.c
grass/trunk/imagery/i.ortho.photo/photo.2target/main.c
grass/trunk/imagery/i.ortho.photo/photo.2target/where.c
grass/trunk/imagery/i.points/main.c
grass/trunk/imagery/i.vpoints/drawvect.c
grass/trunk/imagery/i.vpoints/main.c
grass/trunk/imagery/i.vpoints/where.c
grass/trunk/lib/db/dbmi_client/copy_tab.c
grass/trunk/lib/db/dbmi_client/start.c
grass/trunk/lib/db/dbmi_driver/driver.c
grass/trunk/lib/gis/cats.c
grass/trunk/lib/gis/env.c
grass/trunk/lib/gis/error.c
grass/trunk/lib/gis/get_window.c
grass/trunk/lib/gis/gisinit.c
grass/trunk/lib/gpde/N_arrays_io.c
grass/trunk/lib/ogsf/gsd_legend.c
grass/trunk/lib/proj/convert.c
grass/trunk/lib/sites/sites.c
grass/trunk/lib/vector/Vlib/area.c
grass/trunk/lib/vector/Vlib/break_lines.c
grass/trunk/lib/vector/Vlib/break_polygons.c
grass/trunk/lib/vector/Vlib/bridges.c
grass/trunk/lib/vector/Vlib/buffer.c
grass/trunk/lib/vector/Vlib/build.c
grass/trunk/lib/vector/Vlib/build_nat.c
grass/trunk/lib/vector/Vlib/dangles.c
grass/trunk/lib/vector/Vlib/remove_duplicates.c
grass/trunk/lib/vector/Vlib/snap.c
grass/trunk/lib/vector/diglib/plus_struct.c
grass/trunk/locale/templates/
grass/trunk/raster/r.gwflow/main.c
grass/trunk/raster/r.le/r.le.patch/patch.c
grass/trunk/raster/r.out.arc/main.c
grass/trunk/raster/r.out.gdal/main.c
grass/trunk/raster/r.to.vect/main.c
grass/trunk/scripts/d.vect.thematic/d.vect.thematic
grass/trunk/scripts/r.tileset/r.tileset
grass/trunk/scripts/v.what.vect/v.what.vect
grass/trunk/scripts/v.what.vect/v.what.vect.py
grass/trunk/vector/v.clean/proto.h
grass/trunk/vector/v.distance/main.c
grass/trunk/vector/v.edit/a2b.c
grass/trunk/vector/v.edit/args.c
grass/trunk/vector/v.label.sa/main.c
Fix various typos
Add svn:ignore property to locale/templates
Modified: grass/trunk/db/base/copy.c
--- grass/trunk/db/base/copy.c 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/db/base/copy.c 2008-09-29 17:31:56 UTC (rev 33598)
@@ -34,7 +34,7 @@
module->keywords = _("database, attribute table, SQL");
module->label = _("Copy a table.");
module->description =
- _("Either 'from_table' (optionaly with 'where') can be used "
+ _("Either 'from_table' (optionally with 'where') can be used "
"or 'select' option, but not 'from_table' and 'select' at the same time.");
from_driver = G_define_standard_option(G_OPT_DB_DRIVER);
Modified: grass/trunk/display/d.grid/main.c
--- grass/trunk/display/d.grid/main.c 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/display/d.grid/main.c 2008-09-29 17:31:56 UTC (rev 33598)
@@ -151,7 +151,7 @@
mark_type = MARK_GRID;
if (cross->answer && fiducial->answer)
- G_fatal_error(_("Chose a single mark style"));
+ G_fatal_error(_("Choose a single mark style"));
if (cross->answer)
mark_type = MARK_CROSS;
if (fiducial->answer)
Modified: grass/trunk/display/d.thematic.area/main.c
--- grass/trunk/display/d.thematic.area/main.c 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/display/d.thematic.area/main.c 2008-09-29 17:31:56 UTC (rev 33598)
@@ -75,7 +75,7 @@
module = G_define_module();
module->keywords = _("display");
- _("Displays a thematic vector area map in the active"
+ _("Displays a thematic vector area map in the active "
"frame on the graphics monitor.");
map_opt = G_define_standard_option(G_OPT_V_MAP);
Modified: grass/trunk/doc/vector/v.example/main.c
--- grass/trunk/doc/vector/v.example/main.c 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/doc/vector/v.example/main.c 2008-09-29 17:31:56 UTC (rev 33598)
@@ -164,7 +164,7 @@
/* Now execute query */
if (db_open_select_cursor(driver, &dbsql, &cursor, DB_SEQUENTIAL)
!= DB_OK)
- G_warning(_("Unabale to get attribute data for cat %d"), cat);
+ G_warning(_("Unable to get attribute data for cat %d"), cat);
else {
/* Result count */
nrows = db_get_num_rows(&cursor);
Modified: grass/trunk/general/g.mapset/main.c
--- grass/trunk/general/g.mapset/main.c 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/general/g.mapset/main.c 2008-09-29 17:31:56 UTC (rev 33598)
@@ -151,7 +151,7 @@
/* Check if the mapset is in use */
gis_lock = getenv("GIS_LOCK");
if (!gis_lock)
- G_fatal_error(_("Unable to read GIS_LOCK enviroment variable"));
+ G_fatal_error(_("Unable to read GIS_LOCK environment variable"));
G_asprintf(&lock_prog, "%s/etc/lock", G_gisbase());
Modified: grass/trunk/general/g.proj/datumtrans.c
--- grass/trunk/general/g.proj/datumtrans.c 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/general/g.proj/datumtrans.c 2008-09-29 17:31:56 UTC (rev 33598)
@@ -86,7 +86,7 @@
if (datumtrans > paramsets)
G_fatal_error
- ("Invalid tranformation number %d; valid range is 1 to %d",
+ ("Invalid transformation number %d; valid range is 1 to %d",
datumtrans, paramsets);
list = GPJ_get_datum_transform_by_name(datum);
Modified: grass/trunk/gui/wxpython/gui_modules/menudata.py
--- grass/trunk/gui/wxpython/gui_modules/menudata.py 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/gui/wxpython/gui_modules/menudata.py 2008-09-29 17:31:56 UTC (rev 33598)
@@ -1835,7 +1835,7 @@
(_("Copy table"),
- _("Copy a table. Either 'from_table' (optionaly with 'where') can be used or 'select' option, but not 'from_table' and 'select' at the same time."),
+ _("Copy a table. Either 'from_table' (optionally with 'where') can be used or 'select' option, but not 'from_table' and 'select' at the same time."),
"self.OnMenuCmd",
"db.copy"),
Modified: grass/trunk/gui/wxpython/gui_modules/nviz_tools.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_tools.py 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_tools.py 2008-09-29 17:31:56 UTC (rev 33598)
@@ -578,9 +578,9 @@
gridSizer.Add(item=display, flag=wx.ALIGN_CENTER_VERTICAL,
pos=(0, 7))
- # hight
+ # height
gridSizer.Add(item=wx.StaticText(parent=panel, id=wx.ID_ANY,
- label=_("Hight above surface:")),
+ label=_("Height above surface:")),
pos=(1, 0), flag=wx.ALIGN_CENTER_VERTICAL,
span=(1, 2))
@@ -685,7 +685,7 @@
# high
span=(1, 2))
@@ -1211,7 +1211,7 @@
# icon width
- label=_("Witdh:")),
+ label=_("Width:")),
pos=(row, 2), flag=wx.ALIGN_CENTER_VERTICAL)
iwidth = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
Modified: grass/trunk/gui/wxpython/gui_modules/render.py
--- grass/trunk/gui/wxpython/gui_modules/render.py 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/gui/wxpython/gui_modules/render.py 2008-09-29 17:31:56 UTC (rev 33598)
@@ -360,7 +360,7 @@
# environment settings
- # enviroment variables, like MAPSET, LOCATION_NAME, etc.
+ # environment variables, like MAPSET, LOCATION_NAME, etc.
self.env = {}
# path to external gisrc
self.gisrc = gisrc
@@ -560,7 +560,7 @@
Get region settings (g.region -upgc)
- Optionaly extent, raster or vector map layer can be given.
+ Optionally extent, raster or vector map layer can be given.
@param rast raster name or None
@param vect vector name or None
Modified: grass/trunk/gui/wxpython/gui_modules/toolbars.py
--- grass/trunk/gui/wxpython/gui_modules/toolbars.py 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/gui/wxpython/gui_modules/toolbars.py 2008-09-29 17:31:56 UTC (rev 33598)
@@ -413,7 +413,7 @@
# only one dialog can be open
self.settingsDialog = None
- # create toolbars (two rows optionaly)
+ # create toolbars (two rows optionally)
self.toolbar = []
self.numOfRows = 1 # number of rows for toolbar
for row in range(0, self.numOfRows):
@@ -1144,7 +1144,7 @@
Update list of available vector map layers.
This list consists only editable layers (in the current mapset)
- Optionaly also update toolbar
+ Optionally also update toolbar
Debug.msg (4, "VDigitToolbar.UpdateListOfLayers(): updateTool=%d" % \
Modified: grass/trunk/gui/wxpython/gui_modules/toolbox.py
--- grass/trunk/gui/wxpython/gui_modules/toolbox.py 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/gui/wxpython/gui_modules/toolbox.py 2008-09-29 17:31:56 UTC (rev 33598)
@@ -14,7 +14,7 @@
</qgisgrass>
test_modules = {"g.gisenv":"""
-<qgisgrassmodule label="GRASS enviroment variables" module="g.gisenv">
+<qgisgrassmodule label="GRASS environment variables" module="g.gisenv">
</qgisgrassmodule>
""","r.to.vect.area":"""
<qgisgrassmodule label="Convert a raster to vector areas" module="r.to.vect">
Modified: grass/trunk/imagery/i.ortho.photo/photo.2image/main.c
--- grass/trunk/imagery/i.ortho.photo/photo.2image/main.c 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/imagery/i.ortho.photo/photo.2image/main.c 2008-09-29 17:31:56 UTC (rev 33598)
@@ -88,7 +88,7 @@
group.photo_points.count = 0;
G_suppress_warnings(0);
- /* determine tranformation equation */
+ /* determine transformation equation */
Compute_equation();
signal(SIGINT, SIG_IGN);
Modified: grass/trunk/imagery/i.ortho.photo/photo.2image/where.c
--- grass/trunk/imagery/i.ortho.photo/photo.2image/where.c 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/imagery/i.ortho.photo/photo.2image/where.c 2008-09-29 17:31:56 UTC (rev 33598)
@@ -57,7 +57,7 @@
sprintf(buf, "North: %10.2f", n1);
Curses_write_window(w1, 4, 3, buf);
- /* if tranformation equation is useable, determine point via equation */
+ /* if transformation equation is useable, determine point via equation */
if (group.ref_equation_stat <= 0)
return 1;
Modified: grass/trunk/imagery/i.ortho.photo/photo.2target/main.c
--- grass/trunk/imagery/i.ortho.photo/photo.2target/main.c 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/imagery/i.ortho.photo/photo.2target/main.c 2008-09-29 17:31:56 UTC (rev 33598)
@@ -134,7 +134,7 @@
G_warning(msg);
- /* get target info and enviroment */
+ /* get target info and environment */
G_suppress_warnings(1);
get_target();
find_target_files();
@@ -153,7 +153,7 @@
Compute_ref_equation();
/* read group control points, format: image x,y,cfl; target E,N,Z */
@@ -169,7 +169,7 @@
&group.control_points, group.E12, group.N12);
fprintf(stderr, "Computing equations ...\n");
if (group.control_points.count > 0)
Compute_ortho_equation();
Modified: grass/trunk/imagery/i.ortho.photo/photo.2target/where.c
--- grass/trunk/imagery/i.ortho.photo/photo.2target/where.c 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/imagery/i.ortho.photo/photo.2target/where.c 2008-09-29 17:31:56 UTC (rev 33598)
@@ -51,7 +51,7 @@
sprintf(buf, "IMAGE Y: %10.2f", n1);
return 1;
Modified: grass/trunk/imagery/i.points/main.c
--- grass/trunk/imagery/i.points/main.c 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/imagery/i.points/main.c 2008-09-29 17:31:56 UTC (rev 33598)
@@ -103,7 +103,7 @@
/* write group files to group list file */
prepare_group_list();
get_target();
@@ -113,7 +113,7 @@
group.points.count = 0;
Compute_equation();
Modified: grass/trunk/imagery/i.vpoints/drawvect.c
--- grass/trunk/imagery/i.vpoints/drawvect.c 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/imagery/i.vpoints/drawvect.c 2008-09-29 17:31:56 UTC (rev 33598)
@@ -46,7 +46,7 @@
static int drawvect(int zoomit, /* -1 = refresh, 0 = new image, 1 = zoom, 2 = warp */
View * zoom_view, double E[], double N[], int trans_order)
-{ /* order of tranformation if warping vectors */
+{ /* order of transformation if warping vectors */
int stat = 0;
int i;
char name[GNAME_MAX], mapset[GMAPSET_MAX];
Modified: grass/trunk/imagery/i.vpoints/main.c
--- grass/trunk/imagery/i.vpoints/main.c 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/imagery/i.vpoints/main.c 2008-09-29 17:31:56 UTC (rev 33598)
@@ -98,7 +98,7 @@
get_target();
@@ -108,7 +108,7 @@
CRS_Compute_equation(1);
Modified: grass/trunk/imagery/i.vpoints/where.c
--- grass/trunk/imagery/i.vpoints/where.c 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/imagery/i.vpoints/where.c 2008-09-29 17:31:56 UTC (rev 33598)
@@ -54,7 +54,7 @@
sprintf(buf, "N = %10.2f", n1);
Curses_write_window(INFO_WINDOW, 18, 3, buf);
if (group.equation_stat <= 0 || windnum == 2) {
Curses_write_window(INFO_WINDOW, 15, 18, " ");
Curses_write_window(INFO_WINDOW, 17, 18, " ");
Modified: grass/trunk/lib/db/dbmi_client/copy_tab.c
--- grass/trunk/lib/db/dbmi_client/copy_tab.c 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/lib/db/dbmi_client/copy_tab.c 2008-09-29 17:31:56 UTC (rev 33598)
@@ -154,7 +154,7 @@
const char *tblname = db_get_string(&tblnames[i]);
if (strcmp(to_tblname, tblname) == 0) {
- G_warning(_("Table <%s> already existsin database <%s>"),
+ G_warning(_("Table <%s> already exists in database <%s>"),
to_dbname, to_dbname);
db_close_database_shutdown_driver(to_driver);
if (from_driver != to_driver)
Modified: grass/trunk/lib/db/dbmi_client/start.c
--- grass/trunk/lib/db/dbmi_client/start.c 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/lib/db/dbmi_client/start.c 2008-09-29 17:31:56 UTC (rev 33598)
@@ -56,7 +56,7 @@
int stdin_fd, stdout_fd;
#endif
- /* Set some enviroment variables which are later read by driver.
+ /* Set some environment variables which are later read by driver.
* This is necessary when application is running without GISRC file and all
* gis variables are set by application.
* Even if GISRC is set, application may change some variables during runtime,
@@ -82,7 +82,7 @@
else {
/* Warning: GISRC_MODE_MEMORY _must_ be set to G_GISRC_MODE_FILE, because the module can be
- * run from an application which previously set enviroment variable to G_GISRC_MODE_MEMORY */
+ * run from an application which previously set environment variable to G_GISRC_MODE_MEMORY */
sprintf(ebuf, "%d", G_GISRC_MODE_FILE);
G_putenv("GRASS_DB_DRIVER_GISRC_MODE", ebuf);
Modified: grass/trunk/lib/db/dbmi_driver/driver.c
--- grass/trunk/lib/db/dbmi_driver/driver.c 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/lib/db/dbmi_driver/driver.c 2008-09-29 17:31:56 UTC (rev 33598)
@@ -44,7 +44,7 @@
FILE *send, *recv;
char *modestr;
- /* Read and set enviroment variables, see dbmi_client/start.c */
+ /* Read and set environment variables, see dbmi_client/start.c */
if ((modestr = getenv("GRASS_DB_DRIVER_GISRC_MODE"))) {
int mode;
Modified: grass/trunk/lib/gis/cats.c
--- grass/trunk/lib/gis/cats.c 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/lib/gis/cats.c 2008-09-29 17:31:56 UTC (rev 33598)
@@ -52,7 +52,7 @@
* a blank line for the fmt will effectively suppress automatic
* label generation
- * Note: quant rules of Categories structures are heavily dependant
+ * Note: quant rules of Categories structures are heavily dependent
* on the fact that rules are stored in the same order they are entered.
* since i-th rule and i-th label are entered at the same time, we
* know that i-th rule maps fp range to i, thus we know for sure
Modified: grass/trunk/lib/gis/env.c
--- grass/trunk/lib/gis/env.c 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/lib/gis/env.c 2008-09-29 17:31:56 UTC (rev 33598)
@@ -256,7 +256,7 @@
- \brief Get enviroment variable
+ \brief Get environment variable
Calls G_fatal_error() if name not set.
Modified: grass/trunk/lib/gis/error.c
--- grass/trunk/lib/gis/error.c 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/lib/gis/error.c 2008-09-29 17:31:56 UTC (rev 33598)
@@ -67,7 +67,7 @@
* \brief Print a message to stderr
- * The output format depends on enviroment variable GRASS_MESSAGE_FORMAT
+ * The output format depends on environment variable GRASS_MESSAGE_FORMAT
* \param msg string (cannot be NULL)
@@ -87,7 +87,7 @@
* \brief Print a message to stderr but only if module is in verbose mode
- * The output format depends on enviroment variables
+ * The output format depends on environment variables
* GRASS_MESSAGE_FORMAT and GRASS_VERBOSE
@@ -111,7 +111,7 @@
* Ususally just G_percent()/G_clicker() would be shown at this level.
* This allows important non-error/warning messages to display as well.
@@ -132,7 +132,7 @@
* \brief Print a fatal error message to stderr
* By default, the message is handled by an internal routine which
@@ -161,7 +161,7 @@
* \brief Print a warning message to stderr
* A warning message can be suppressed by G_suppress_warnings()
@@ -246,7 +246,7 @@
return 0;
-/* Print info to stderr and optionaly to log file and optionaly send mail */
+/* Print info to stderr and optionally to log file and optionally send mail */
static int print_error(const char *msg, const int type)
static char *prefix_std[3];
Modified: grass/trunk/lib/gis/get_window.c
--- grass/trunk/lib/gis/get_window.c 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/lib/gis/get_window.c 2008-09-29 17:31:56 UTC (rev 33598)
@@ -50,7 +50,7 @@
static struct Cell_head dbwindow;
char *regvar;
- /* Optionaly read the region from enviroment variable */
+ /* Optionally read the region from environment variable */
regvar = getenv("GRASS_REGION");
if (regvar) {
Modified: grass/trunk/lib/gis/gisinit.c
--- grass/trunk/lib/gis/gisinit.c 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/lib/gis/gisinit.c 2008-09-29 17:31:56 UTC (rev 33598)
@@ -135,7 +135,7 @@
/* Set masking flag unknown */
G__.auto_mask = -1;
- /* set architecture dependant bit patterns for embeded null vals */
+ /* set architecture dependent bit patterns for embeded null vals */
G__init_null_patterns();
initialized = 1;
Modified: grass/trunk/lib/gpde/N_arrays_io.c
--- grass/trunk/lib/gpde/N_arrays_io.c 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/lib/gpde/N_arrays_io.c 2008-09-29 17:31:56 UTC (rev 33598)
@@ -224,17 +224,17 @@
if (type == CELL_TYPE)
if (!G_put_c_raster_row(map, rast)) {
G_unopen_cell(map); /*unopen the new raster map */
- G_fatal_error(_("Unable to write rast row %i"), y);
+ G_fatal_error(_("Unable to write raster row %i"), y);
if (type == FCELL_TYPE)
if (!G_put_f_raster_row(map, frast)) {
if (type == DCELL_TYPE)
if (!G_put_d_raster_row(map, drast)) {
Modified: grass/trunk/lib/ogsf/gsd_legend.c
--- grass/trunk/lib/ogsf/gsd_legend.c 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/lib/ogsf/gsd_legend.c 2008-09-29 17:31:56 UTC (rev 33598)
@@ -520,7 +520,7 @@
G_get_color((CELL) tdcell, &red, &green, &blue, &colors);
RGB_TO_INT(red, green, blue, colr);
- if (discrete) { /* draw black-white-black seperator */
+ if (discrete) { /* draw black-white-black separator */
if (k > 0) {
*dv1 -= 2. * incr;
*dv2 -= 2. * incr;
Modified: grass/trunk/lib/proj/convert.c
--- grass/trunk/lib/proj/convert.c 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/lib/proj/convert.c 2008-09-29 17:31:56 UTC (rev 33598)
@@ -437,7 +437,7 @@
"You may want to look into this."), datum);
else if (datumtrans > paramsets) {
- G_warning(_("Invalid tranformation number %d; valid range is 1 to %d. "
+ G_warning(_("Invalid transformation number %d; valid range is 1 to %d. "
"Leaving datum transform parameters unspecified."),
datumtrans = 0;
Modified: grass/trunk/lib/sites/sites.c
--- grass/trunk/lib/sites/sites.c 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/lib/sites/sites.c 2008-09-29 17:31:56 UTC (rev 33598)
@@ -1041,7 +1041,7 @@
char *G_site_format(const Site * s, const char *fs, int id)
-/* sprintf analog to G_site_put with the addition of a field seperator fs
+/* sprintf analog to G_site_put with the addition of a field separator fs
and option of printing site attribute identifiers
Modified: grass/trunk/lib/vector/Vlib/area.c
--- grass/trunk/lib/vector/Vlib/area.c 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/lib/vector/Vlib/area.c 2008-09-29 17:31:56 UTC (rev 33598)
@@ -50,7 +50,7 @@
Area = Plus->Area[area];
if (Area == NULL) { /* dead area */
- G_warning(_("Attempt to read points of nonexisting area"));
+ G_warning(_("Attempt to read points of nonexistent area"));
return -1; /* error , because we should not read dead areas */
Modified: grass/trunk/lib/vector/Vlib/break_lines.c
--- grass/trunk/lib/vector/Vlib/break_lines.c 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/lib/vector/Vlib/break_lines.c 2008-09-29 17:31:56 UTC (rev 33598)
@@ -46,7 +46,7 @@
\brief Break selected lines in vector map at each intersection.
Breaks selected lines specified by type in vector map. Points at
- intersections may be optionaly written to error map. Input vector map
+ intersections may be optionally written to error map. Input vector map
must be opened on level 2 for update at least on GV_BUILD_BASE.
The function also breaks lines forming collapsed loop, for example
Modified: grass/trunk/lib/vector/Vlib/break_polygons.c
--- grass/trunk/lib/vector/Vlib/break_polygons.c 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/lib/vector/Vlib/break_polygons.c 2008-09-29 17:31:56 UTC (rev 33598)
@@ -44,7 +44,7 @@
\brief Break polygons in vector map.
- Breaks lines specified by type in vector map. Points at intersections may be optionaly
+ Breaks lines specified by type in vector map. Points at intersections may be optionally
written to error map. Input map must be opened on level 2 for update at least on GV_BUILD_BASE.
Function is optimized for closed polygons rigs (e.g. imported from OGR) but with clean geometry -
Modified: grass/trunk/lib/vector/Vlib/bridges.c
--- grass/trunk/lib/vector/Vlib/bridges.c 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/lib/vector/Vlib/bridges.c 2008-09-29 17:31:56 UTC (rev 33598)
@@ -32,7 +32,7 @@
Remove bridges (type boundary) connecting areas to islands or 2 islands.
Islands and areas must be already clean, i.e. without dangles.
Bridge may be formed by more lines.
- Optionaly deleted bridges are written to error map.
+ Optionally deleted bridges are written to error map.
Input map must be opened on level 2 for update at least on level GV_BUILD_BASE
\param Map input map where bridges are deleted
@@ -54,7 +54,7 @@
Change the type of bridges (type boundary) connecting areas to islands or 2 islands.
- Optionaly changed bridges are written to error map.
+ Optionally changed bridges are written to error map.
Input map must be opened on level 2 for update at least on level GV_BUILD_BASE.
\param Map input map where bridges are changed
Modified: grass/trunk/lib/vector/Vlib/buffer.c
--- grass/trunk/lib/vector/Vlib/buffer.c 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/lib/vector/Vlib/buffer.c 2008-09-29 17:31:56 UTC (rev 33598)
@@ -117,7 +117,7 @@
/* clean_parallel - clean parallel line created by parallel_line:
** - looking for loops and if loop doesn't contain any other loop
** and centroid of loop is in buffer removes this loop (repeated)
- ** - optionaly removes all end points in buffer
+ ** - optionally removes all end points in buffer
* parameters:
* Points - parallel line
* origPoints - original line
Modified: grass/trunk/lib/vector/Vlib/build.c
--- grass/trunk/lib/vector/Vlib/build.c 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/lib/vector/Vlib/build.c 2008-09-29 17:31:56 UTC (rev 33598)
@@ -93,7 +93,7 @@
Should only be used in special cases of vector processing.
- This functions optionaly builds only some parts of topology. Highest level is specified by build
+ This functions optionally builds only some parts of topology. Highest level is specified by build
parameter which may be:
- GV_BUILD_NONE - nothing is build;
- GV_BUILD_BASE - basic topology, nodes, spatial index;
Modified: grass/trunk/lib/vector/Vlib/build_nat.c
--- grass/trunk/lib/vector/Vlib/build_nat.c 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/lib/vector/Vlib/build_nat.c 2008-09-29 17:31:56 UTC (rev 33598)
@@ -148,7 +148,7 @@
plus = &(Map->plus);
if (plus->Isle[isle] == NULL) {
- G_warning(_("Request to find area outside nonexisting isle"));
+ G_warning(_("Request to find area outside nonexistent isle"));
return 0;
Modified: grass/trunk/lib/vector/Vlib/dangles.c
--- grass/trunk/lib/vector/Vlib/dangles.c 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/lib/vector/Vlib/dangles.c 2008-09-29 17:31:56 UTC (rev 33598)
@@ -39,7 +39,7 @@
such string of lines is taken as one dangle and either deleted are
all parts or nothing.
- Optionaly deleted dangles are written to error map.
+ Optionally deleted dangles are written to error map.
Input map must be opened on level 2 for update.
@@ -67,7 +67,7 @@
no other boundary. If a dangle is formed by more boundaries, such
string of boundaries is taken as one dangle.
@@ -114,9 +114,9 @@
Line is considered to be a dangle if on at least one end node is no
other line of given type(s). If a dangle is formed by more lines,
- all parts or nothing. Optionaly, if chtype is set to 1, only
+ all parts or nothing. Optionally, if chtype is set to 1, only
GV_BOUNDARY are checked for dangles, and if dangle is found lines
- are not deleted but rewritten with type GVLINE. Optionaly deleted
+ are not deleted but rewritten with type GVLINE. Optionally deleted
dangles are written to error map. Input map must be opened on level
Modified: grass/trunk/lib/vector/Vlib/remove_duplicates.c
--- grass/trunk/lib/vector/Vlib/remove_duplicates.c 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/lib/vector/Vlib/remove_duplicates.c 2008-09-29 17:31:56 UTC (rev 33598)
@@ -25,7 +25,7 @@
\brief Remove duplicate lines from vector map.
- Remove duplicate lines of given types from vector map. Duplicate lines may be optionaly
+ Remove duplicate lines of given types from vector map. Duplicate lines may be optionally
written to error map. Input map must be opened on level 2 for update. Categories are merged.
\param Map vector map where duplicate lines will be deleted
Modified: grass/trunk/lib/vector/Vlib/snap.c
--- grass/trunk/lib/vector/Vlib/snap.c 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/lib/vector/Vlib/snap.c 2008-09-29 17:31:56 UTC (rev 33598)
@@ -55,7 +55,7 @@
* \warning Lines are not necessarily snapped to nearest vertex, but to vertex in threshold!
- * Lines showing how vertices were snapped may be optionaly written to error map.
+ * Lines showing how vertices were snapped may be optionally written to error map.
* Input map must be opened on level 2 for update at least on GV_BUILD_BASE.
* \param[in] Map input map where vertices will be snapped
Modified: grass/trunk/lib/vector/diglib/plus_struct.c
--- grass/trunk/lib/vector/diglib/plus_struct.c 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/lib/vector/diglib/plus_struct.c 2008-09-29 17:31:56 UTC (rev 33598)
@@ -25,7 +25,7 @@
* if you dont want it written out, then dont call these routines
* ie check for deleted status before calling a write routine
* in as much as it would be nice to hide that code in here,
- * this is a library routine and we chose to make it dependant on
+ * this is a library routine and we chose to make it dependent on
* as few external files as possible
Property changes on: grass/trunk/locale/templates
___________________________________________________________________
+ *.pot
Modified: grass/trunk/raster/r.gwflow/main.c
--- grass/trunk/raster/r.gwflow/main.c 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/raster/r.gwflow/main.c 2008-09-29 17:31:56 UTC (rev 33598)
@@ -147,7 +147,7 @@
param.river_bed->type = TYPE_STRING;
param.river_bed->required = NO;
param.river_bed->gisprompt = "old,raster,raster";
- param.river_bed->description = _("The hight of the river bed in [m]");
+ param.river_bed->description = _("The height of the river bed in [m]");
param.river_head = G_define_option();
param.river_head->key = "river_head";
@@ -170,7 +170,7 @@
param.drain_bed->type = TYPE_STRING;
param.drain_bed->required = NO;
param.drain_bed->gisprompt = "old,raster,raster";
- param.drain_bed->description = _("The hight of the drainage bed in [m]");
+ param.drain_bed->description = _("The height of the drainage bed in [m]");
param.drain_leak = G_define_option();
param.drain_leak->key = "drain_leak";
Modified: grass/trunk/raster/r.le/r.le.patch/patch.c
--- grass/trunk/raster/r.le/r.le.patch/patch.c 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/raster/r.le/r.le.patch/patch.c 2008-09-29 17:31:56 UTC (rev 33598)
@@ -1594,7 +1594,7 @@
/*Variables
EXTERNAL
- recl_count = an array containg the number of elements in each
+ recl_count = an array containing the number of elements in each
row of the reclass table
IN
att = the attribute value
Modified: grass/trunk/raster/r.out.arc/main.c
--- grass/trunk/raster/r.out.arc/main.c 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/raster/r.out.arc/main.c 2008-09-29 17:31:56 UTC (rev 33598)
@@ -86,7 +86,7 @@
flag.noheader->key = 'h';
flag.noheader->description = _("Suppress printing of header information");
- /* Added to optionaly produce a single line output. -- emes -- 12.10.92 */
+ /* Added to optionally produce a single line output. -- emes -- 12.10.92 */
flag.singleline = G_define_flag();
flag.singleline->key = '1';
flag.singleline->description =
Modified: grass/trunk/raster/r.out.gdal/main.c
--- grass/trunk/raster/r.out.gdal/main.c 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/raster/r.out.gdal/main.c 2008-09-29 17:31:56 UTC (rev 33598)
@@ -336,12 +336,12 @@
if (n_nulls > 0) {
if (maptype == CELL_TYPE)
- G_warning(_("Input raster map constains cells with NULL-value (no-data). "
+ G_warning(_("Input raster map contains cells with NULL-value (no-data). "
"The value %d was used to represent no-data values in the input map."
"You can specify nodata value by %s parameter."),
(int)nodataval, nodatakey);
else
"The value %g was used to represent no-data values in the input map."
Modified: grass/trunk/raster/r.to.vect/main.c
--- grass/trunk/raster/r.to.vect/main.c 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/raster/r.to.vect/main.c 2008-09-29 17:31:56 UTC (rev 33598)
@@ -243,7 +243,7 @@
Vect_build(&Map, stderr);
- /* insert cats and optionaly labels if raster cats were used */
+ /* insert cats and optionally labels if raster cats were used */
if (driver && value_flag) {
char buf[1000];
int c, i, cat, fidx, ncats, lastcat, tp, id;
Modified: grass/trunk/scripts/d.vect.thematic/d.vect.thematic
--- grass/trunk/scripts/d.vect.thematic/d.vect.thematic 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/scripts/d.vect.thematic/d.vect.thematic 2008-09-29 17:31:56 UTC (rev 33598)
@@ -17,7 +17,7 @@
#%Module
-#% description: Displays thematic vectormap
+#% description: Displays thematic vector map
#% keywords: display, legend
#%End
#%option
Modified: grass/trunk/scripts/r.tileset/r.tileset
--- grass/trunk/scripts/r.tileset/r.tileset 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/scripts/r.tileset/r.tileset 2008-09-29 17:31:56 UTC (rev 33598)
@@ -107,7 +107,7 @@
#%option
#% key: fs
#% type: string
-#% description: Output field seperator
+#% description: Output field separator
#% answer:|
#%end
#%option
Modified: grass/trunk/scripts/v.what.vect/v.what.vect
--- grass/trunk/scripts/v.what.vect/v.what.vect 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/scripts/v.what.vect/v.what.vect 2008-09-29 17:31:56 UTC (rev 33598)
@@ -51,7 +51,7 @@
#%option
#% key: qlayer
#% type: integer
-#% description: Layer of the query vector containg data
+#% description: Layer of the query vector containing data
#% answer: 1
#% required : no
#%end
Modified: grass/trunk/scripts/v.what.vect/v.what.vect.py
--- grass/trunk/scripts/v.what.vect/v.what.vect.py 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/scripts/v.what.vect/v.what.vect.py 2008-09-29 17:31:56 UTC (rev 33598)
@@ -50,7 +50,7 @@
#%option
#% key: qlayer
#% type: integer
#% answer: 1
#% required : no
#%end
Modified: grass/trunk/vector/v.clean/proto.h
--- grass/trunk/vector/v.clean/proto.h 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/vector/v.clean/proto.h 2008-09-29 17:31:56 UTC (rev 33598)
@@ -10,7 +10,7 @@
#define TOOL_PRUNE 10 /* remove vertices in threshold from lines and boundaries */
#define TOOL_RMAREA 11 /* remove small areas */
#define TOOL_RMSA 12 /* remove small angles between lines at nodes */
-#define TOOL_RMLINE 13 /* remove all line or boudaries of zero length */
+#define TOOL_RMLINE 13 /* remove all line or boundaries of zero length */
#define SEP \
Modified: grass/trunk/vector/v.distance/main.c
--- grass/trunk/vector/v.distance/main.c 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/vector/v.distance/main.c 2008-09-29 17:31:56 UTC (rev 33598)
@@ -426,7 +426,7 @@
&& (fctype == DB_C_TYPE_STRING ||
fctype == DB_C_TYPE_DATETIME))
- G_fatal_error(_("Incomatible column types"));
+ G_fatal_error(_("Incompatible column types"));
Modified: grass/trunk/vector/v.edit/a2b.c
--- grass/trunk/vector/v.edit/a2b.c 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/vector/v.edit/a2b.c 2008-09-29 17:31:56 UTC (rev 33598)
@@ -274,7 +274,7 @@
- \brief Close lines (boudaries)
+ \brief Close lines (boundaries)
Using threshold distance (-1 for no limit)
Modified: grass/trunk/vector/v.edit/args.c
--- grass/trunk/vector/v.edit/args.c 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/vector/v.edit/args.c 2008-09-29 17:31:56 UTC (rev 33598)
@@ -170,7 +170,7 @@
_("For 'shorter' use negative threshold value, "
"positive value for 'longer'");
params->query->descriptions =
- _("length;Select only lines or boudaries shorter"
+ _("length;Select only lines or boundaries shorter"
"/longer than threshold distance;"
"dangle;Select dangles shorter/longer than " "threshold distance");
params->query->guisection = _("Query");
Modified: grass/trunk/vector/v.label.sa/main.c
--- grass/trunk/vector/v.label.sa/main.c 2008-09-29 17:26:50 UTC (rev 33597)
+++ grass/trunk/vector/v.label.sa/main.c 2008-09-29 17:31:56 UTC (rev 33598)
@@ -103,7 +103,7 @@
p.hlcolor = G_define_option();
p.hlcolor->key = "hcolor";
- p.hlcolor->description = _("Hilight color for text");
+ p.hlcolor->description = _("Highlight color for text");
p.hlcolor->type = TYPE_STRING;
p.hlcolor->answer = "none";
p.hlcolor->options =
