[GRASS-SVN] r33602 - in grass/trunk: lib/python scripts/db.dropcol
scripts/db.droptable scripts/db.in.ogr scripts/i.image.mosaic
scripts/i.landsat.rgb scripts/r.in.aster scripts/v.db.addcol
scripts/v.db.addtable scripts/v.db.dropcol
scripts/v.db.droptable scripts/v.db.join
scripts/v.db.reconnect.all scripts/v.db.renamecol
scripts/v.db.update scripts/v.dissolve scripts/v.in.e00
scripts/v.in.geonames scripts/v.in.gns scripts/v.rast.stats
scripts/v.report
svn_grass at osgeo.org
Mon Sep 29 19:46:48 EDT 2008
Author: glynn
Date: 2008-09-29 19:46:48 -0400 (Mon, 29 Sep 2008)
New Revision: 33602
Added:
grass/trunk/scripts/v.db.addtable/v.db.addtable.py
grass/trunk/lib/python/grass.py
grass/trunk/scripts/db.dropcol/db.dropcol.py
grass/trunk/scripts/db.droptable/db.droptable.py
grass/trunk/scripts/db.in.ogr/db.in.ogr.py
grass/trunk/scripts/i.image.mosaic/i.image.mosaic.py
grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.py
grass/trunk/scripts/r.in.aster/r.in.aster.py
grass/trunk/scripts/v.db.addcol/v.db.addcol.py
grass/trunk/scripts/v.db.dropcol/v.db.dropcol.py
grass/trunk/scripts/v.db.droptable/v.db.droptable.py
grass/trunk/scripts/v.db.join/v.db.join.py
grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.py
grass/trunk/scripts/v.db.renamecol/v.db.renamecol.py
grass/trunk/scripts/v.db.update/v.db.update.py
grass/trunk/scripts/v.dissolve/v.dissolve.py
grass/trunk/scripts/v.in.e00/v.in.e00.py
grass/trunk/scripts/v.in.geonames/v.in.geonames.py
grass/trunk/scripts/v.in.gns/v.in.gns.py
grass/trunk/scripts/v.rast.stats/v.rast.stats.py
grass/trunk/scripts/v.report/v.report.py
Convert v.db.addtable to Python
Add, use several utility wrappers:
vector_db (v.db.connect -g)
db_describe (db.describe -c)
db_connection (db.connect -p)
vector_columns (v.info -c)
vector_history (v.support cmdhist=)
raster_history (r.support history=)
Modified: grass/trunk/lib/python/grass.py
--- grass/trunk/lib/python/grass.py 2008-09-29 19:41:44 UTC (rev 33601)
+++ grass/trunk/lib/python/grass.py 2008-09-29 23:46:48 UTC (rev 33602)
@@ -273,6 +273,15 @@
owstr = 'GRASS_OVERWRITE'
return owstr in os.environ and os.environ[owstr] != '0'
+# check GRASS_VERBOSE
+def verbosity():
+ vbstr = 'GRASS_VERBOSE'
+ if vbstr:
+ return int(vbstr)
+ else:
+ return 0
## various utilities, not specific to GRASS
# basename inc. extension stripping
@@ -314,3 +323,67 @@
except:
pass
+# run "v.db.connect -g ..." and parse output
+def vector_db(map, layer = None, **args):
+ s = read_command('v.db.connect', flags = 'g', map = map, layer = layer, **args)
+ result = []
+ for l in s.splitlines():
+ f = l.split(' ')
+ if len(f) != 5:
+ continue
+ if layer and int(layer) == int(f[0]):
+ return f
+ result.append(f)
+ if not layer:
+ return result
+# run "db.describe -c ..." and parse output
+def db_describe(table, **args):
+ s = read_command('db.describe', flags = 'c', table = table, **args)
+ if not s:
+ return None
+ cols = []
+ result = {}
+ f = l.split(':')
+ key = f[0]
+ f[1] = f[1].lstrip(' ')
+ if key.startswith('Column '):
+ n = int(key.split(' ')[1])
+ cols.insert(n, f[1:])
+ elif key in ['ncols', 'nrows']:
+ result[key] = int(f[1])
+ else:
+ result[key] = f[1:]
+ result['cols'] = cols
+ return result
+# run "db.connect -p" and parse output
+def db_connection():
+ s = read_command('db.connect', flags = 'p')
+ return parse_key_val(s, sep = ':')
+# run "v.info -c ..." and parse output
+def vector_columns(map, layer = None, **args):
+ s = read_command('v.info', flags = 'c', map = map, layer = layer, quiet = True, **args)
+ result = []
+ for line in s.splitlines():
+ f = line.split('|')
+ if len(f) == 2:
+ result.append(f)
+ return result
+# add vector history
+def vector_history(map):
+ run_command('v.support', map = map, cmdhist = os.environ['CMDLINE'])
+# add raster history
+def raster_history(map):
+ run_command('r.support', map = map, history = os.environ['CMDLINE'])
Modified: grass/trunk/scripts/db.dropcol/db.dropcol.py
--- grass/trunk/scripts/db.dropcol/db.dropcol.py 2008-09-29 19:41:44 UTC (rev 33601)
+++ grass/trunk/scripts/db.dropcol/db.dropcol.py 2008-09-29 23:46:48 UTC (rev 33602)
@@ -57,8 +57,7 @@
# check if DB parameters are set, and if not set them.
grass.run_command('db.connect', flags = 'c')
- s = grass.read_command('db.connect', flags = 'p')
- kv = grass.parse_key_val(s, sep = ':')
+ kv = grass.db_connection()
database = kv['database']
driver = kv['driver']
# schema needed for PG?
@@ -69,8 +68,7 @@
if column == "cat":
grass.warning("Deleting <%s> column which may be needed to keep table connected to a vector map" % column)
- s = grass.read_command('db.describe', flags = 'c', table = table)
- cols = [l.split(':')[1].lstrip() for l in s.splitlines() if l.startswith('Column ')]
+ cols = [f[0] for f in grass.db_describe()['cols']]
if column not in cols:
grass.fatal("Column <%s> not found in table" % column)
@@ -85,16 +83,11 @@
# http://www.sqlite.org/faq.html#q13
colnames = []
coltypes = []
- for l in s.splitlines():
- if not l.startswith('Column '):
+ for f in grass.db_describe()['cols']:
+ if f[0] == column:
continue
- f = l.split(':')
- f[1] = f[1].lstrip()
- if f[1] == column:
- continue
- colnames.append(f[1])
- coltypes.append("%s %s" % (f[1], f[2]))
+ colnames.append(f[0])
+ coltypes.append("%s %s" % (f[0], f[1]))
colnames = ", ".join(colnames)
coltypes = ", ".join(coltypes)
Modified: grass/trunk/scripts/db.droptable/db.droptable.py
--- grass/trunk/scripts/db.droptable/db.droptable.py 2008-09-29 19:41:44 UTC (rev 33601)
+++ grass/trunk/scripts/db.droptable/db.droptable.py 2008-09-29 23:46:48 UTC (rev 33602)
@@ -45,8 +45,7 @@
@@ -56,19 +55,16 @@
# check if table exists
nuldev = file(os.devnull, 'w')
- if grass.run_command('db.describe', flags = 'c', table = table,
- stdout = nuldev, stderr = nuldev):
+ if not grass.db_describe(table, stdout = nuldev, stderr = nuldev):
grass.fatal("Table <%s> not found in current mapset" % table)
# check if table is used somewhere (connected to vector map)
used = []
vects = grass.list_strings('vect')
for vect in vects:
- s = grass.read_command('v.db.connect', flags = 'g', map = vect, stderr = nuldev)
- if not s:
- continue
- f = l.split()
+ for f in vector_db(vect, stderr = nuldev):
+ if not f:
+ continue
if f[1] == table:
used.append(vect)
break
Modified: grass/trunk/scripts/db.in.ogr/db.in.ogr.py
--- grass/trunk/scripts/db.in.ogr/db.in.ogr.py 2008-09-29 19:41:44 UTC (rev 33601)
+++ grass/trunk/scripts/db.in.ogr/db.in.ogr.py 2008-09-29 23:46:48 UTC (rev 33602)
@@ -111,9 +111,7 @@
grass.run_command('db.dropcol', quiet = True, flags = 'f', table = output,
colum = 'cat', stdout = nuldev, stderr = nuldev)
- s = grass.read_command('db.describe', flags = 'c', table = output)
- records = int(kv['nrows'].strip())
+ records = grass.db_describe(output)['nrows']
grass.message("Imported table <%s> with %d rows" % (output, records))
if __name__ == "__main__":
Modified: grass/trunk/scripts/i.image.mosaic/i.image.mosaic.py
--- grass/trunk/scripts/i.image.mosaic/i.image.mosaic.py 2008-09-29 19:41:44 UTC (rev 33601)
+++ grass/trunk/scripts/i.image.mosaic/i.image.mosaic.py 2008-09-29 23:46:48 UTC (rev 33602)
@@ -108,7 +108,7 @@
grass.message("Ready. File %s created." % output)
# write cmd history:
- grass.run_command('r.support', map = output, history = os.environ['CMDLINE'])
+ raster_history(output)
options, flags = grass.parser()
Modified: grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.py
--- grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.py 2008-09-29 19:41:44 UTC (rev 33601)
+++ grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.py 2008-09-29 23:46:48 UTC (rev 33602)
@@ -132,7 +132,7 @@
for i in [red, green, blue]:
- grass.run_command('r.support', map = i, history = os.environ['CMDLINE'])
+ raster_history(i)
Modified: grass/trunk/scripts/r.in.aster/r.in.aster.py
--- grass/trunk/scripts/r.in.aster/r.in.aster.py 2008-09-29 19:41:44 UTC (rev 33601)
+++ grass/trunk/scripts/r.in.aster/r.in.aster.py 2008-09-29 23:46:48 UTC (rev 33602)
@@ -172,8 +172,7 @@
grass.run_command("r.in.gdal", overwrite = flags['o'], input = tempfile, output = outfile)
# write cmd history
- grass.run_command('r.support', map = outfile, history = os.environ['CMDLINE'])
- #r.support "$GIS_OPT_OUTPUT" history="${CMDLINE}"
+ raster_history(outfile)
Modified: grass/trunk/scripts/v.db.addcol/v.db.addcol.py
--- grass/trunk/scripts/v.db.addcol/v.db.addcol.py 2008-09-29 19:41:44 UTC (rev 33601)
+++ grass/trunk/scripts/v.db.addcol/v.db.addcol.py 2008-09-29 23:46:48 UTC (rev 33602)
@@ -62,10 +62,9 @@
if not exists:
grass.fatal("Vector map <%s> not found in current mapset" % map)
- s = grass.read_command('v.db.connect', flags = 'g', map = map, layer = layer)
- if not s:
+ f = grass.vector_db(map, layer)
+ if not f:
grass.fatal("There is no table connected to this map. Run v.db.connect or v.db.addtable first.")
- f = s.split()
table = f[1]
database = f[3]
driver = f[4]
@@ -83,7 +82,7 @@
grass.fatal("Unable to add column <%s>." % col)
- grass.run_command('v.support', map = map, cmdhist = os.environ['CMDLINE'])
+ grass.vector_history(map)
Added: grass/trunk/scripts/v.db.addtable/v.db.addtable.py
--- grass/trunk/scripts/v.db.addtable/v.db.addtable.py (rev 0)
+++ grass/trunk/scripts/v.db.addtable/v.db.addtable.py 2008-09-29 23:46:48 UTC (rev 33602)
@@ -0,0 +1,152 @@
+#!/usr/bin/env python
+# MODULE: v.db.addtable
+# AUTHOR(S): Markus Neteler
+# Converted to Python by Glynn Clements
+# PURPOSE: interface to db.execute to creates and add a new table to given vector map
+# COPYRIGHT: (C) 2005, 2007, 2008 by Markus Neteler & the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+#%Module
+#% description: Creates and adds a new attribute table to a given layer of an existing vector map.
+#% keywords: vector, database, attribute table
+#%End
+#%option
+#% key: map
+#% type: string
+#% gisprompt: old,vector,vector
+#% description: Vector map for which to add new attribute table
+#% required : yes
+#% key_desc : name
+#%end
+#%option
+#% key: table
+#% type: string
+#% description: Name of new attribute table (default: vector map name)
+#% required : no
+#%end
+#%option
+#% key: layer
+#% type: integer
+#% description: Layer where to add new attribute table
+#% answer: 1
+#% required : no
+#%end
+#%option
+#% key: columns
+#% type: string
+#% description: Name and type of the new column(s) (types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE)
+#% answer: cat integer
+#% required : no
+#% multiple : yes
+#% key_desc : name type
+#%end
+import sys
+import os
+import grass
+def main():
+ map = options['map']
+ table = options['table']
+ layer = options['layer']
+ columns = options['columns']
+ mapset = grass.gisenv()['MAPSET']
+ # does map exist in CURRENT mapset?
+ if not grass.find_file(map, element = 'vector', mapset = mapset)['file']:
+ grass.fatal("Vector map <%s> not found in current mapset" % map)
+ map_name = map.split('@')[0]
+ if not table:
+ if layer == '1':
+ grass.message("Using vector map name as table name: " + map_name)
+ table = map_name
+ else:
+ # to avoid tables with identical names on higher layers
+ grass.message("Using vector map name extended by layer number as table name: %s_%s" % (map_name, layer))
+ table = "%s_%s" % (map_name, layer)
+ else:
+ grass.message("Using user specified table name: " + table)
+ # check if DB parameters are set, and if not set them.
+ grass.run_command('db.connect', flags = 'c')
+ #check if anything is connected:
+ nuldev = file(os.devnull, 'w')
+ db = grass.vector_db(map, stderr = nuldev)
+ if db:
+ f = db[0]
+ database = f[3]
+ driver = f[4]
+ else:
+ # nothing defined
+ grass.message("Creating new DB connection based on default mapset settings...")
+ database = kv['database']
+ driver = kv['driver']
+ # maybe there is already a table linked to the selected layer?
+ if grass.vector_db(map, layer, stderr = nuldev):
+ grass.fatal("There is already a table linked to layer <%s>" % layer)
+ # maybe there is already a table with that name?
+ found = False
+ p = grass.pipe_command('db.tables', database = database, driver = driver, stderr = nuldev)
+ for line in p.stdout:
+ if line.rstrip('\r\n') == table:
+ found = True
+ break
+ p.wait()
+ if not found:
+ column_def = [col.strip().lower() for col in columns.split(',')]
+ #if not existing, create it:
+ if "cat integer" not in column_def:
+ column_def.append("cat integer")
+ column_def = ','.join(column_def)
+ grass.message("Creating table with columns (%s)" % column_def)
+ # take care if the DBF directory is missing (heck, the DBF driver should take care!)
+ if driver == "dbf":
+ env = grass.gisenv()
+ path = os.path.join(env['GISDBASE'], env['LOCATION_NAME'], env['MAPSET'], "dbf")
+ if not os.path.isdir(path):
+ grass.message("Creating missing DBF directory in mapset <%s>" % env['MAPSET'])
+ os.mkdir(path)
+ grass.run_command('db.connect', driver = dbf, database = '$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/')
+ sql = "CREATE TABLE %s (%s)" % (table, column_def)
+ if grass.write_command('db.execute', database = database, driver = driver, stdin = sql) != 0:
+ grass.fatal("Cannot continue.")
+ # connect the map to the DB:
+ grass.run_command('v.db.connect', map = map, database = database, driver = driver,
+ layer = layer, table = table, key = 'cat')
+ # finally we have to add cats into the attribute DB to make modules such as v.what.rast happy:
+ # (creates new row for each vector line):
+ grass.run_command('v.to.db', map = map, layer = layer, option = 'cat', col = 'cat')
+ if grass.verbosity() > 0:
+ grass.message("Current attribute table links:")
+ grass.run_command('v.db.connect', flags = 'p', map = map)
+ # write cmd history:
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ main()
Property changes on: grass/trunk/scripts/v.db.addtable/v.db.addtable.py
___________________________________________________________________
Modified: grass/trunk/scripts/v.db.dropcol/v.db.dropcol.py
--- grass/trunk/scripts/v.db.dropcol/v.db.dropcol.py 2008-09-29 19:41:44 UTC (rev 33601)
+++ grass/trunk/scripts/v.db.dropcol/v.db.dropcol.py 2008-09-29 23:46:48 UTC (rev 33602)
@@ -63,10 +63,9 @@
if not grass.find_file(map, element = 'vector', mapset = mapset):
- s = grass.read_command('v.db.connect', flags = 'g', map = map, layer = layer);
- if not s:
+ if not f:
grass.fatal("An error occured while running v.db.connect")
- f = s.split()
table = f[1]
keycol = f[2]
database = f[3]
@@ -78,8 +77,7 @@
if column == keycol:
grass.fatal("Cannot delete <$col> column as it is needed to keep table <%s> connected to the input vector map <%s>" % (table, map))
- s = grass.read_command('v.info', flags = 'c', map = map, layer = layer, quiet = True)
- if column not in [l.split('|')[1].lstrip() for l in s.splitlines()]:
+ if column not in [f[1] for f in grass.vector_columns(map, layer)]:
grass.fatal("Column <%s> not found in table <%s>" % (column, table))
if driver == "sqlite":
@@ -87,16 +85,11 @@
colnames = []
coltypes = []
+ for f in grass.db_describe(table):
continue
- f = l.split(':')
- continue
@@ -121,7 +114,7 @@
grass.fatal("Cannot continue (problem deleting column).")
Modified: grass/trunk/scripts/v.db.droptable/v.db.droptable.py
--- grass/trunk/scripts/v.db.droptable/v.db.droptable.py 2008-09-29 19:41:44 UTC (rev 33601)
+++ grass/trunk/scripts/v.db.droptable/v.db.droptable.py 2008-09-29 23:46:48 UTC (rev 33602)
@@ -55,10 +55,10 @@
# do some paranoia tests as well:
- if not s:
+ if not f:
- f = s.split()
if not table:
# Removing table name connected to selected layer
table = f[1]
@@ -100,7 +100,7 @@
grass.run_command('v.db.connect', flags ='p', map = map)
Modified: grass/trunk/scripts/v.db.join/v.db.join.py
--- grass/trunk/scripts/v.db.join/v.db.join.py 2008-09-29 19:41:44 UTC (rev 33601)
+++ grass/trunk/scripts/v.db.join/v.db.join.py 2008-09-29 23:46:48 UTC (rev 33602)
@@ -69,8 +69,9 @@
otable = options['otable']
ocolumn = options['ocolumn']
- f = s.split()
+ if not f:
+ grass.fatal("An error occured while running v.db.connect")
maptable = f[1]
database = f[3]
driver = f[4]
@@ -81,31 +82,23 @@
if not maptable:
grass.fatal("There is no table connected to this map. Cannot join any column.")
- found = False
- for line in s.splitlines():
- f = line.split('|')
- if len(f) > 1 and f[1] == column:
- found = True
- if not found:
grass.fatal("Column <%> not found in table <%s> at layer <%s>" % (column, map, layer))
- s = grass.read_command('db.describe', flags = 'c', driver = driver,
- database = database, table = otable)
- cols = [l.split(':') for l in s.splitlines() if l.startswith('Column ')]
+ cols = grass.db_describe(otable, driver = driver, database = database)['cols']
select = "SELECT $colname FROM $otable WHERE $otable.$ocolumn=$table.$column"
template = string.Template("UPDATE $table SET $colname=(%s);" % select)
for col in cols:
- colname = col[1].lstrip()
- if len(col) > 3:
- coltype = "%s(%s)" % (col[2], col[3])
+ colname = col[0]
+ if len(col) > 2:
+ coltype = "%s(%s)" % (col[1], col[2])
else:
- coltype = "%s" % col[2]
+ coltype = "%s" % col[1]
colspec = "%s %s" % (colname, coltype)
- if grass.run_command('v.db.addcol', map = map, col = colspec) != 0:
+ if grass.run_command('v.db.addcol', map = map, columns = colspec) != 0:
grass.fatal("Error creating column <%s>." % colname)
stmt = template.substitute(table = maptable, column = column,
@@ -116,7 +109,7 @@
grass.fatal("Error filling column <%s>." % colname)
Modified: grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.py
--- grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.py 2008-09-29 19:41:44 UTC (rev 33601)
+++ grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.py 2008-09-29 23:46:48 UTC (rev 33602)
@@ -60,9 +60,7 @@
for vect in grass.list_grouped('vect')[mapset]:
vect = "%s@%s" % (vect, mapset)
grass.message("Reconnecting vector <%s>" % vect)
- for link in s.splitlines():
- f = link.split()
+ for f in grass.vector_db(map, stderr = nuldev):
layer = f[0]
schema_table = f[1]
key = f[2]
Modified: grass/trunk/scripts/v.db.renamecol/v.db.renamecol.py
--- grass/trunk/scripts/v.db.renamecol/v.db.renamecol.py 2008-09-29 19:41:44 UTC (rev 33601)
+++ grass/trunk/scripts/v.db.renamecol/v.db.renamecol.py 2008-09-29 23:46:48 UTC (rev 33602)
@@ -62,10 +62,9 @@
- if not s:
+ if not f:
- f = s.split()
table = f[1]
keycol = f[2]
database = f[3]
@@ -87,15 +86,11 @@
# describe old col
oldcoltype = None
+ if f[0] != oldcol:
continue
- f = l.split(':')
- if f[1].lstrip() != oldcol:
- continue
- oldcoltype = f[2]
- oldcollength = f[3]
+ oldcoltype = f[1]
+ oldcollength = f[2]
# old col there?
if not oldcol:
@@ -117,7 +112,7 @@
Modified: grass/trunk/scripts/v.db.update/v.db.update.py
--- grass/trunk/scripts/v.db.update/v.db.update.py 2008-09-29 19:41:44 UTC (rev 33601)
+++ grass/trunk/scripts/v.db.update/v.db.update.py 2008-09-29 23:46:48 UTC (rev 33602)
@@ -76,9 +76,8 @@
grass.fatal("Vector map '$GIS_OPT_MAP' not found in current mapset")
- f = s.rstrip('\r\n').split(' ')
- if len(s) < 2:
+ if not f:
grass.fatal('There is no table connected to this map. Run v.db.connect or v.db.addtable first.')
table = f[1]
@@ -87,11 +86,7 @@
# checking column types
coltype = None
- s = grass.read_command('v.info', flags = 'c', map = map, quiet = True)
- f = l.split('|')
- if len(f) < 2:
- continue
+ for f in grass.vector_columns(map, layer):
if f[1] == column:
coltype = f[0]
@@ -117,7 +112,7 @@
grass.write_command('db.execute', database = database, driver = driver, stdin = cmd)
Modified: grass/trunk/scripts/v.dissolve/v.dissolve.py
--- grass/trunk/scripts/v.dissolve/v.dissolve.py 2008-09-29 19:41:44 UTC (rev 33601)
+++ grass/trunk/scripts/v.dissolve/v.dissolve.py 2008-09-29 23:46:48 UTC (rev 33602)
@@ -71,27 +71,26 @@
# does map exist?
if not grass.find_file(input, element = 'vector')['file']:
- grass.fatal("Vector map '$GIS_OPT_INPUT' not found in mapset search path")
+ grass.fatal("Vector map <%s> not found in mapset search path", input)
if not column:
grass.run_command('v.extract', flags = 'd', input = input,
output = output, type = 'area', layer = layer)
else:
coltype = ''
- s = grass.read_command('v.info', flags = 'c', map = input, quiet = True)
+ if f[1] == column:
coltype = f[0]
if coltype not in ['INTEGER', 'CHARACTER']:
grass.fatal("Key column must be of type integer or string")
- s = grass.read_command('v.db.connect', flags = 'g', map = input, layer = layer)
- table = s.split()[1]
- if not table:
+ f = grass.vector_db(input, layer)
+ if not f:
grass.fatal("There is no table connected to this map")
+ table = f[1]
tmpfile = '%s_%s' % (output, tmp)
grass.run_command('v.reclass', input = input, output = tmpfile,
@@ -101,7 +100,7 @@
- grass.run_command('v.support', map = output, cmdhist = os.environ['CMDLINE'])
+ grass.vector_history(output)
Modified: grass/trunk/scripts/v.in.e00/v.in.e00.py
--- grass/trunk/scripts/v.in.e00/v.in.e00.py 2008-09-29 19:41:44 UTC (rev 33601)
+++ grass/trunk/scripts/v.in.e00/v.in.e00.py 2008-09-29 23:46:48 UTC (rev 33602)
@@ -168,7 +168,7 @@
grass.message("Done.")
- grass.run_command('v.support', map = name, cmdhist = os.environ['CMDLINE'])
+ grass.vector_history(name)
Modified: grass/trunk/scripts/v.in.geonames/v.in.geonames.py
--- grass/trunk/scripts/v.in.geonames/v.in.geonames.py 2008-09-29 19:41:44 UTC (rev 33601)
+++ grass/trunk/scripts/v.in.geonames/v.in.geonames.py 2008-09-29 23:46:48 UTC (rev 33602)
@@ -66,8 +66,7 @@
grass.fatal("File <%s> not found" % infile)
# DBF doesn't support lengthy text fields
- kv = grass.parse_key_val(s, ':')
dbfdriver = kv['driver'] == 'dbf'
if dbfdriver:
grass.warning("Since DBF driver is used, the content of the 'alternatenames' column might be cut with respect to the original Geonames.org column content")
@@ -145,7 +144,7 @@
grass.try_remove(tmpfile)
- grass.run_command('v.support', map = outfile, cmdhist = os.environ['CMDLINE'])
+ grass.vector_history(outfile)
Modified: grass/trunk/scripts/v.in.gns/v.in.gns.py
--- grass/trunk/scripts/v.in.gns/v.in.gns.py 2008-09-29 19:41:44 UTC (rev 33601)
+++ grass/trunk/scripts/v.in.gns/v.in.gns.py 2008-09-29 23:46:48 UTC (rev 33602)
@@ -147,7 +147,7 @@
- grass.run_command('v.support', map = filevect, cmdhist = os.environ['CMDLINE'])
+ grass.vector_history(filevect)
Modified: grass/trunk/scripts/v.rast.stats/v.rast.stats.py
--- grass/trunk/scripts/v.rast.stats/v.rast.stats.py 2008-09-29 19:41:44 UTC (rev 33601)
+++ grass/trunk/scripts/v.rast.stats/v.rast.stats.py 2008-09-29 23:46:48 UTC (rev 33602)
@@ -71,14 +71,7 @@
import grass
def has_column(vector, col):
- s = grass.read_command('v.info', flags = 'c', map = vector, quiet = True)
- f = l.split('|')
- if len(f) < 2:
- continue
- if f[1] == col:
- return True
- return False
+ return
def cleanup():
grass.run_command('g.remove', rast = '%s_%s' % (vector, tmpname), quiet = True)
@@ -163,9 +156,10 @@
grass.fatal("No categories found in raster map")
#check if DBF driver used, in this case cut to 10 chars col names:
- s = grass.read_command('v.db.connect', flags = 'g', map = vector, layer = layer)
+ f = grass.vector_db(vector, layer)
+ if not f:
+ grass.fatal('There is no table connected to this map. Run v.db.connect or v.db.addtable first.')
# we need this for non-DBF driver:
- f = s.split()
table = f[1]
db_database = f[3]
db_sqldriver = f[4]
@@ -173,7 +167,7 @@
#Find out which table is linked to the vector map on the given layer
if not table:
- grass.fatal('There is no table connected to this map! Run v.db.connect or v.db.addtable first.')
basecols = ['n', 'min', 'max', 'range', 'mean', 'stddev', 'variance', 'cf_var', 'sum']
@@ -200,7 +194,7 @@
if dbfdriver:
currcolumn = currcolumn[:10]
- if has_column(vector, currcolumn):
+ if currcolumn in [f[1] for f in grass.vector_columns(vector, layer)]:
if not flags['c']:
grass.fatal(("Cannot create column <%s> (already present)." % currcolumn) +
"Use -c flag to update values in this column.")
Modified: grass/trunk/scripts/v.report/v.report.py
--- grass/trunk/scripts/v.report/v.report.py 2008-09-29 19:41:44 UTC (rev 33601)
+++ grass/trunk/scripts/v.report/v.report.py 2008-09-29 23:46:48 UTC (rev 33602)
@@ -58,14 +58,6 @@
import os
import grass
-def find_key(map, layer):
- s = grass.read_command('v.db.connect', flags = 'g', map = map);
- fields = line.split()
- if fields[0] == layer:
- return fields[3]
- return '<unknown>'
def uniq(l):
result = []
last = None
@@ -89,18 +81,10 @@
if not grass.find_file(mapname, 'vector')['file']:
grass.fatal("Vector map '%s' not found in mapset search path." % mapname)
- table_exists = grass.run_command('v.info', flags = 'c', map = mapname,
- layer = layer, stdout = nuldev,
- stderr = nuldev) == 0
+ table_exists = grass.vector_columns(mapname, layer, stderr = nuldev)
if table_exists:
- p = grass.pipe_command('v.info', flags = 'c', map = mapname, layer = layer, stderr = nuldev)
- colnames = []
- for line in p.stdout:
- if '|' not in line:
- continue
- colnames.append(line.rstrip('\r\n').split('|')[1])
- p.wait()
+ colnames = [f[1] for f in grass.vector_columns(mapname, layer, stderr = nuldev)]
else:
colnames = ['cat']
@@ -132,7 +116,8 @@
records1.sort()
if len(records1) == 0:
- key = find_key(mapname, layer)
+ f = grass.vector_db(mapname, layer)
+ key = f[2]
grass.fatal("There is a table connected to input vector map '%s', but" +
"there are no categories present in the key column '%s'. Consider using" +
"v.to.db to correct this." % (mapname, key))
