[GRASS-SVN] r33606 - grass/trunk/scripts/r.plane
svn_grass at osgeo.org
Mon Sep 29 23:49:44 EDT 2008
Author: glynn
Date: 2008-09-29 23:49:44 -0400 (Mon, 29 Sep 2008)
New Revision: 33606
Added:
grass/trunk/scripts/r.plane/r.plane.py
Re-implement r.plane in Python and r.mapcalc
Added: grass/trunk/scripts/r.plane/r.plane.py
--- grass/trunk/scripts/r.plane/r.plane.py (rev 0)
+++ grass/trunk/scripts/r.plane/r.plane.py 2008-09-30 03:49:44 UTC (rev 33606)
@@ -0,0 +1,127 @@
+#!/usr/bin/env python
+# MODULE: r.plane for GRASS 5.7; based on r.plane for GRASS 5
+# AUTHOR(S): CERL?; updated to GRASS 5.7 by Michael Barton
+# Dec 2004: Alessandro Frigeri & Ivan Marchesini
+# Modified to produce floating and double values maps
+# Converted to Python by Glynn Clements
+# PURPOSE: Creates a raster plane map from user specified inclination and azimuth
+# COPYRIGHT: (C) 2004,2008 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+#%Module
+#% description: Creates raster plane map given dip (inclination), aspect (azimuth) and one point.
+#% keywords: raster, elevation
+#%End
+#%option
+#% key: name
+#% type: string
+#% gisprompt: new,cell,raster
+#% description: Name of raster plane to be created
+#% required : yes
+#%end
+#%option
+#% key: dip
+#% type: double
+#% gisprompt: -90-90
+#% answer: 0.0
+#% description: Dip of plane. Value must be between -90 and 90 degrees
+#% required : yes
+#%end
+#%option
+#% key: azimuth
+#% type: double
+#% gisprompt: 0-360
+#% answer: 0.0
+#% description: Azimuth of the plane. Value must be between 0 and 360 degrees
+#% required : yes
+#%end
+#%option
+#% key: easting
+#% type: double
+#% description: Easting coordinate of a point on the plane
+#% required : yes
+#%end
+#%option
+#% key: northing
+#% type: double
+#% description: Northing coordinate of a point on the plane
+#% required : yes
+#%end
+#%option
+#% key: elevation
+#% type: double
+#% description: Elevation coordinate of a point on the plane
+#% required : yes
+#%end
+#%option
+#% key: type
+#% type: string
+#% options: int,float,double
+#% description: Type of the raster map to be created
+#% required : yes
+#%end
+import sys
+import os
+import math
+import string
+import grass
+def main():
+ name = options['name']
+ type = options['type']
+ dip = float(options['dip'])
+ az = float(options['azimuth'])
+ ea = float(options['easting'])
+ no = float(options['northing'])
+ el = float(options['elevation'])
+ reg = grass.region()
+ ### test input values ###
+ if abs(dip) >= 90:
+ grass.fatal("dip must be between -90 and 90.")
+ if az < 0 or az >= 360:
+ grass.fatal("azimuth must be between 0 and 360")
+ ### now the actual algorithm
+ az_r = math.radians(-az)
+ sinaz = math.sin(az_r)
+ cosaz = math.cos(az_r)
+ dip_r = math.radians(-dip)
+ tandip = math.tan(dip_r)
+ kx = sinaz * tandip
+ ky = cosaz * tandip
+ kz = el - ea * sinaz * tandip - no * cosaz * tandip
+ if type == "int":
+ round = "round"
+ else:
+ round = ""
+ t = string.Template('$name = $type($round(x() * $kx + y() * $ky + $kz))')
+ e = t.substitute(name = name, type = type, round = round, kx = kx, ky = ky, kz = kz)
+ grass.run_command('r.mapcalc', expression = e)
+ grass.raster_history(name)
+ grass.message("Done.")
+ t = string.Template("Raster map <$name> generated by r.plane " +
+ "at point $ea E, $no N, elevation $el with dip = $dip degrees and " +
+ "aspect = $az degrees ccw from north.")
+ grass.message(t.substitute(name = name, ea = ea, no = no, el = el, dip = dip, az = az))
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ main()
Property changes on: grass/trunk/scripts/r.plane/r.plane.py
___________________________________________________________________
