[GRASS-SVN] r33625 - grass/trunk/scripts/r.fillnulls
Tue Sep 30 16:31:56 EDT 2008
Author: glynn
Date: 2008-09-30 16:31:56 -0400 (Tue, 30 Sep 2008)
New Revision: 33625
Added:
   grass/trunk/scripts/r.fillnulls/r.fillnulls.py
Convert r.fillnulls to Python
Modified: grass/trunk/scripts/r.fillnulls/r.fillnulls
--- grass/trunk/scripts/r.fillnulls/r.fillnulls	2008-09-30 20:30:27 UTC (rev 33624)
+++ grass/trunk/scripts/r.fillnulls/r.fillnulls	2008-09-30 20:31:56 UTC (rev 33625)
@@ -140,7 +140,7 @@
 g.message "Locating and isolating NULL areas..."
 #creating 0/1 map:
-r.mapcalc $TMP1="if(isnull($GIS_OPT_INPUT),1,null())"
+r.mapcalc "$TMP1 = if(isnull($GIS_OPT_INPUT),1,null())"
 #generate a ring:
 # the buffer is set to three times the map resolution so you get nominally
@@ -161,7 +161,7 @@
     exit 1
 fi
-r.mapcalc "MASK=if($TMP1.buf==2,1,null())"
+r.mapcalc "MASK = if($TMP1.buf==2,1,null())"
 # now we only see the outlines of the NULL areas if looking at INPUT.
 # Use this outline (raster border) for interpolating the fill data:
Added: grass/trunk/scripts/r.fillnulls/r.fillnulls.py
--- grass/trunk/scripts/r.fillnulls/r.fillnulls.py	                        (rev 0)
+++ grass/trunk/scripts/r.fillnulls/r.fillnulls.py	2008-09-30 20:31:56 UTC (rev 33625)
@@ -0,0 +1,183 @@
+#!/usr/bin/env python
+# MODULE:	r.fillnulls
+# AUTHOR(S):	Markus Neteler <neteler itc it>
+#               Updated to GRASS 5.7 by Michael Barton
+#               Updated to GRASS 6.0 by Markus Neteler
+#               Ring improvements by Hamish Bowman
+#               Converted to Python by Glynn Clements
+# PURPOSE:	fills NULL (no data areas) in raster maps
+#               The script respects a user mask (MASK) if present.
+# COPYRIGHT:	(C) 2001,2004-2005,2008 by the GRASS Development Team
+#		This program is free software under the GNU General Public
+#		License (>=v2). Read the file COPYING that comes with GRASS
+#		for details.
+#%Module
+#% description: Fills no-data areas in raster maps using v.surf.rst splines interpolation
+#% keywords: raster, elevation, interpolation
+#%End
+#%option
+#% key: input
+#% gisprompt: old,cell,raster
+#% type: string
+#% description: Raster map in which to fill nulls
+#% required : yes
+#%end
+#%option
+#% key: output
+#% gisprompt: new,cell,raster
+#% type: string
+#% description: Output raster map with nulls filled by interpolation from surrounding values
+#% required : yes
+#%end
+#%option
+#% key: tension
+#% type: double
+#% description: Spline tension parameter
+#% required : no
+#% answer : 40.
+#%end
+#%option
+#% key: smooth
+#% type: double
+#% description: Spline smoothing parameter
+#% required : no
+#% answer : 0.1
+#%end
+import sys
+import os
+import atexit
+import grass
+# what to do in case of user break:
+def cleanup():
+    #delete internal mask and any TMP files:
+    rasts = [tmp1 + ext for ext in ['', '.buf', '_filled']]
+    grass.run_command('g.remove', flags = 'f', rast = rasts)
+    grass.run_command('g.remove', flags = 'f', vect = vecttmp)
+    grass.run_command('g.remove', rast = 'MASK')
+    if grass.find_file(usermask, mapset = mapset)['file']:
+	grass.run_command('g.rename', rast = (usermask, 'MASK'))
+def main():
+    global vecttmp, tmp1, usermask, mapset
+    input = options['input']
+    output = options['output']
+    tension = options['tension']
+    smooth = options['smooth']
+    #check if input file exists
+    if not grass.find_file(input)['file']:
+	grass.fatal("<%s> does not exist." % input)
+    mapset = grass.gisenv()['MAPSET']
+    unique = str(os.getpid())
+    # check if a MASK is already present:
+    usermask = "usermask_mask." + unique
+    if grass.find_file('MASK', mapset = mapset)['file']:
+	grass.message("A user raster mask (MASK) is present. Saving it...")
+	grass.run_command('g.rename', rast = ('MASK',usermask))
+    #make a mask of NULL cells
+    tmp1 = "r_fillnulls_" + unique
+    # idea: filter all NULLS and grow that area(s) by 3 pixel, then
+    # interpolate from these surrounding 3 pixel edge
+    grass.message("Locating and isolating NULL areas...")
+    #creating 0/1 map:
+    e = "%s = if(isnull(%s),1,null())" % (tmp1, input)
+    grass.run_command('r.mapcalc', expression = e)
+    #generate a ring:
+    # the buffer is set to three times the map resolution so you get nominally
+    # three points around the edge. This way you interpolate into the hole with
+    # a trained slope & curvature at the edges, otherwise you just get a flat plane.
+    # With just a single row of cells around the hole you often get gaps
+    # around the edges when distance > mean (.5 of the time? diagonals? worse
+    # when ewres!=nsres).
+    reg = grass.region()
+    res = (float(reg['nsres']) + float(reg['ewres'])) * 3 / 2
+    if grass.run_command('r.buffer', input = tmp1, distances = res, out = tmp1 + '.buf') != 0:
+	grass.fatal("abandoned. Removing temporary map, restoring user mask if needed:")
+    grass.run_command('r.mapcalc', expression = "MASK=if(%s.buf==2,1,null())" % tmp1)
+    # now we only see the outlines of the NULL areas if looking at INPUT.
+    # Use this outline (raster border) for interpolating the fill data:
+    vecttmp = "vecttmp_fillnulls_" + unique
+    grass.message("Creating interpolation points...")
+    if grass.run_command('r.to.vect', input = input, output = vecttmp, feature = 'point'):
+	grass.fatal("abandoned. Removing temporary maps, restoring user mask if needed:")
+    # count number of points to control segmax parameter for interpolation:
+    s = grass.read_command('v.info', map = vecttmp)
+    for l in s.splitlines():
+	if "Number of points:" in l:
+	    s = l.split(':')[1].strip()
+	    s = s.split()[0].strip()
+	    pointsnumber = int(s)
+	    break
+    grass.message("Interpolating %d points" % pointsnumber)
+    if pointsnumber < 2:
+	grass.fatal("Not sufficient points to interpolate. Maybe no hole(s) to fill in the current map region?")
+    grass.message("Note: The following warnings may be ignored.")
+    # remove internal MASK first -- WHY???? MN 10/2005
+	grass.message("Using user mask while interpolating")
+	maskmap = usermask
+    else:
+	maskmap = None
+    segmax = 600
+    if pointsnumber > segmax:
+	grass.message("Using segmentation for interpolation...")
+	segmax = None
+    else:
+	grass.message("Using no segmentation for interpolation as not needed...")
+    grass.run_command('v.surf.rst', input = vecttmp, elev = tmp1 + '_filled',
+		      zcol = 'value', tension = tension, smooth = smooth,
+		      maskmap = maskmap, segmax = segmax)
+    grass.message("Note: Above warnings may be ignored.")
+    # restoring user's mask, if present:
+	grass.message("Restoring user mask (MASK)...")
+    # patch orig and fill map
+    grass.message("Patching fill data into NULL areas...")
+    # we can use --o here as g.parser already checks on startup
+    grass.run_command('r.patch', input = (input,tmp1 + '_filled'), output = output, overwrite = True)
+    grass.message("Filled raster map is: %s" % output)
+    # write cmd history:
+    grass.raster_history(output)
+    grass.message("Done.")
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    atexit.register(cleanup)
+    main()
Property changes on: grass/trunk/scripts/r.fillnulls/r.fillnulls.py
___________________________________________________________________
