[GRASS-SVN] r33633 - grass/trunk/scripts/i.oif
svn_grass at osgeo.org
Tue Sep 30 23:44:26 EDT 2008
Author: glynn
Date: 2008-09-30 23:44:25 -0400 (Tue, 30 Sep 2008)
New Revision: 33633
Added:
grass/trunk/scripts/i.oif/i.oif.py
Convert i.oif to Python
Added: grass/trunk/scripts/i.oif/i.oif.py
--- grass/trunk/scripts/i.oif/i.oif.py (rev 0)
+++ grass/trunk/scripts/i.oif/i.oif.py 2008-10-01 03:44:25 UTC (rev 33633)
@@ -0,0 +1,150 @@
+#!/usr/bin/env python
+# MODULE: i.oif
+# AUTHOR(S): Markus Neteler
+# Converted to Python by Glynn Clements
+# PURPOSE: calculates the Optimum Index factor of all band combinations
+# for LANDSAT TM 1,2,3,4,5,7
+# COPYRIGHT: (C) 1999,2008 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+# Ref.: Jensen: Introductory digital image processing 1996, p.98
+# Input: tm1 - tm5, tm7 (not tm6)
+# written by Markus Neteler 21.July 1998
+# neteler geog.uni-hannover.de
+# updated for GRASS 5.7 by Michael Barton 2004/04/05
+#% Module
+#% description: Calculates Optimum-Index-Factor table for LANDSAT TM bands 1-5, & 7
+#% keywords: raster, imagery, statistics
+#% End
+#% option
+#% key: image1
+#% type: string
+#% gisprompt: old,cell,raster
+#% description: LANDSAT TM band 1.
+#% required : yes
+#% end
+#% option
+#% key: image2
+#% type: string
+#% description: LANDSAT TM band 2.
+#% required : yes
+#% end
+#% option
+#% key: image3
+#% type: string
+#% description: LANDSAT TM band 3.
+#% required : yes
+#% end
+#% option
+#% key: image4
+#% type: string
+#% description: LANDSAT TM band 4.
+#% required : yes
+#% end
+#% option
+#% key: image5
+#% type: string
+#% description: LANDSAT TM band 5.
+#% required : yes
+#% end
+#% option
+#% key: image7
+#% type: string
+#% description: LANDSAT TM band 7.
+#% required : yes
+#% end
+#% Flag
+#% key: g
+#% description: Print in shell script style
+#% End
+import sys
+import os
+import grass
+bands = [1,2,3,4,5,7]
+def oifcalc(sdev, corr, k1, k2, k3):
+ # calculate SUM of Stddeviations:
+ ssdev = [sdev[k1], sdev[k2], sdev[k3]]
+ numer = sum(ssdev)
+ # calculate SUM of absolute(Correlation values):
+ scorr = [corr[k1,k2], corr[k1,k3], corr[k2,k3]]
+ denom = sum(map(abs, scorr))
+ # Calculate OIF index:
+ # Divide (SUM of Stddeviations) and (SUM of Correlation)
+ return numer / denom
+def perms():
+ for i in range(0,4):
+ for j in range(i+1,5):
+ for k in range(j+1,6):
+ yield (bands[i], bands[j], bands[k])
+def main():
+ shell = flags['g']
+ image = {}
+ for band in bands:
+ image[band] = options['image%d' % band]
+ # calculate the Stddev for TM bands
+ grass.verbose("Calculating Standard deviations for all bands:")
+ stddev = {}
+ grass.verbose("band %d" % band)
+ s = grass.read_command('r.univar', flags = 'g', map = image[band])
+ kv = grass.parse_key_val(s)
+ stddev[band] = float(kv['stddev'])
+ grass.verbose("Calculating Correlation Matrix")
+ correlation = {}
+ s = grass.read_command('r.covar', flags = 'r', map = [image[band] for band in bands])
+ for i, row in zip(bands, s.splitlines()):
+ for j, cell in zip(bands, row.split(' ')):
+ correlation[i,j] = float(cell)
+ # Calculate all combinations
+ grass.verbose("Calculating OIF for the 20 band combinations...")
+ oif = []
+ for p in perms():
+ oif.append((oifcalc(stddev, correlation, *p), p))
+ oif.sort(reverse = True)
+ grass.verbose("Ready.")
+ grass.verbose("The Optimum Index Factor analysis result:")
+ grass.verbose(" (Best combination comes first.)")
+ if shell:
+ fmt = "%d%d%d:%f\n"
+ else:
+ fmt = "%d%d%d: %f\n"
+ outf = file('i.oif.result', 'w')
+ for v, p in oif:
+ sys.stdout.write(fmt % (p + (v,)))
+ outf.write(fmt % (p + (v,)))
+ outf.close()
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ main()
Property changes on: grass/trunk/scripts/i.oif/i.oif.py
___________________________________________________________________
