[GRASS-SVN] r36562 - grass/branches/develbranch_6/gem
svn_grass at osgeo.org
Thu Apr 2 03:07:54 EDT 2009
Author: neteler
Date: 2009-04-02 03:07:53 -0400 (Thu, 02 Apr 2009)
New Revision: 36562
grass/branches/develbranch_6/gem/main.c
fix gem -> gem65
Modified: grass/branches/develbranch_6/gem/main.c
--- grass/branches/develbranch_6/gem/main.c 2009-04-02 07:06:53 UTC (rev 36561)
+++ grass/branches/develbranch_6/gem/main.c 2009-04-02 07:07:53 UTC (rev 36562)
@@ -75,7 +75,7 @@
NEED HELP
- GRASS' make install installs all files BENEATH top level dir with UID
set to benni !!! Is this intentional?
- - provide gem61 as link in /usr/local/bin as part of grass 6.1 base install
+ - provide gem6x as link in /usr/local/bin as part of grass 6.x base install
- description.html should not contain </body> or </html> as Rules.Make seems
to append those ?
- source install copies files COPYING README REQUIREMENTS.html to somewhere (but where?)
@@ -131,9 +131,9 @@
- remove cva, install again: WARNING: list item 'cva' exists in index.html (?)
- superfluous warning upon uninstall of extension w/o "entries-gisman"
- due to bad command line parsing, listing installed extensions only works like this:
- ./gem --grass=/usr/local/grass-6.1.cvs -q
+ ./gem65 --grass=/usr/local/grass-6.5.svn -q
NOT like this:
- ./gem -q --grass=/usr/local/grass-6.1.cvs
+ ./gem65 -q --grass=/usr/local/grass-6.5.svn
@@ -147,7 +147,7 @@
void show_help(void)
- fprintf(stdout, "Usage: gem [OPTION] [ACTION] [FILE|DIR]\n");
+ fprintf(stdout, "Usage: gem65 [OPTION] [ACTION] [FILE|DIR]\n");
fprintf(stdout, "Install a GRASS extension from FILE or DIR.\n");
fprintf(stdout, "Manage (installed) GRASS extension(s).\n");
fprintf(stdout, "\nPossible ACTIONs are:\n");
@@ -203,9 +203,9 @@
"For installation from source code, a C compiler and make tools are needed.\n");
fprintf(stdout, "\nExample:\n");
fprintf(stdout,
- "\tgem -b macosx --grass=/usr/local/grass-6.0.0 -i myExtension\n");
+ "\tgem65 -b macosx --grass=/usr/local/grass-6.5.0 -i myExtension\n");
fprintf(stdout,
- "Installs the MacOS X binaries for 'myExtension' in /usr/local/grass-6.0.0.\n");
+ "Installs the MacOS X binaries for 'myExtension' in /usr/local/grass-6.5.0.\n");
exit(0);
@@ -257,7 +257,7 @@
void show_version(void)
- fprintf(stdout, "gem (GRASS extensions manager) %.2f\n", PROGVERSION);
+ fprintf(stdout, "gem65 (GRASS extensions manager) %.2f\n", PROGVERSION);
fprintf(stdout, "Written by Benjamin Ducke\n");
fprintf(stdout, "\nCopyright (C) 2005 Benjamin Ducke\n");
fprintf(stdout,
