[GRASS-SVN] r36570 - grass/branches/develbranch_6/db/drivers/dbf
Fri Apr 3 03:13:37 EDT 2009
Author: mlennert
Date: 2009-04-03 03:13:37 -0400 (Fri, 03 Apr 2009)
New Revision: 36570
   grass/branches/develbranch_6/db/drivers/dbf/dbfexe.c
ran tools/grass_indent.sh on file before committing fix
Modified: grass/branches/develbranch_6/db/drivers/dbf/dbfexe.c
--- grass/branches/develbranch_6/db/drivers/dbf/dbfexe.c	2009-04-02 15:47:15 UTC (rev 36569)
+++ grass/branches/develbranch_6/db/drivers/dbf/dbfexe.c	2009-04-03 07:13:37 UTC (rev 36570)
@@ -33,27 +33,41 @@
 #define NODE_ERROR  4
 int yyparse(void);
 void get_col_def(SQLPSTMT * st, int col, int *type, int *width,
 		 int *decimals);
 int sel(SQLPSTMT * st, int tab, int **set);
 void eval_val(int tab, int row, int col, SQLPVALUE * inval,
 	      SQLPVALUE * result);
 int set_val(int tab, int row, int col, SQLPVALUE * val);
 double eval_node(SQLPNODE *, int, int, SQLPVALUE *);
 int eval_node_type(SQLPNODE *, int);
 int execute(char *sql, cursor * c)
     int i, j, tab, ret;
     SQLPSTMT *st;
     ROW *dbrows;
     VALUE *dbval;
     int row, nrows;
     int *cols, ncols, col;
     int *selset;
     int dtype, stype;
     int width, decimals;
     char *tmpsql, name[500];
     SQLPVALUE *calctmp;		/* store for calculated values in UPDATE, if any */
     /* parse sql statement */
@@ -451,6 +465,7 @@
 		dbval->d = val->d;
 	    else if (val->type == SQLP_S) {
 		char *tailptr;
 		double dval = strtod(val->s, &tailptr);
 		if (!(*tailptr)) {
@@ -465,14 +480,21 @@
 /* Comparison of 2 rows */
 static int cur_cmp_table;
 static int cur_cmp_ocol;
 static int cmp_row_asc(const void *pa, const void *pb)
     int *row1 = (int *)pa;
     int *row2 = (int *)pb;
     char *c1, *c2;
     int i1, i2;
     double d1, d2;
     TABLE *tbl;
     tbl = &(db.tables[cur_cmp_table]);
@@ -517,7 +539,9 @@
 int sel(SQLPSTMT * st, int tab, int **selset)
     int i, ret, condition;
     int *set;			/* pointer to array of indexes to rows */
     int aset, nset;
     G_debug(2, "sel(): tab = %d", tab);
@@ -644,11 +668,17 @@
 double eval_node(SQLPNODE * nptr, int tab, int row, SQLPVALUE * value)
     int left, right;
     SQLPVALUE left_value, right_value;
     int ccol;
     COLUMN *col;
     VALUE *val;
     double left_dval, right_dval, dval;
     char *rightbuf;
     /* Note: node types were previously checked by eval_node_type */
@@ -988,7 +1018,9 @@
 int eval_node_type(SQLPNODE * nptr, int tab)
     int left, right;
     int ccol;
     COLUMN *col = NULL;
     switch (nptr->node_type) {
