[GRASS-SVN] r36599 - grass/trunk/vector/v.to.db
Sun Apr 5 17:04:27 EDT 2009
Author: neteler
Date: 2009-04-05 17:04:27 -0400 (Sun, 05 Apr 2009)
New Revision: 36599
   grass/trunk/vector/v.to.db/global.h
   grass/trunk/vector/v.to.db/lines.c
   grass/trunk/vector/v.to.db/parse.c
   grass/trunk/vector/v.to.db/report.c
   grass/trunk/vector/v.to.db/units.c
   grass/trunk/vector/v.to.db/update.c
   grass/trunk/vector/v.to.db/v.to.db.html
marisn: v.to.db add azimuth option (forwardport from develbranch_6, r36528)
Modified: grass/trunk/vector/v.to.db/global.h
--- grass/trunk/vector/v.to.db/global.h	2009-04-05 20:42:33 UTC (rev 36598)
+++ grass/trunk/vector/v.to.db/global.h	2009-04-05 21:04:27 UTC (rev 36599)
@@ -68,12 +68,16 @@
 #define O_SINUOUS       14	/* sinuousity of a line (length / <distance between end points>) */
+#define O_AZIMUTH	15	/* line azimuth */
 #define U_ACRES		1
 #define U_HECTARES	2
 #define U_KILOMETERS	3
 #define U_METERS	4
 #define U_MILES		5
 #define U_FEET		6
+#define U_RADIANS	7
+#define U_DEGREES	8
 /* areas.c */
 int read_areas(struct Map_info *);
Modified: grass/trunk/vector/v.to.db/lines.c
--- grass/trunk/vector/v.to.db/lines.c	2009-04-05 20:42:33 UTC (rev 36598)
+++ grass/trunk/vector/v.to.db/lines.c	2009-04-05 21:04:27 UTC (rev 36599)
@@ -62,7 +62,7 @@
     register int line_num;
     struct line_pnts *Points, *EndPoints;
     struct line_cats *Cats, *LCats, *RCats;
-    double len, slope, dist;
+    double len, slope, dist, dx, dy, azimuth;
     /* Initialize the Point struct */
     Points = Vect_new_line_struct();
@@ -192,6 +192,18 @@
 		    EndPoints = Vect_new_line_struct();
 		    Values[idx].d1 = len / dist;
+		else if (options.option == O_AZIMUTH && (type & GV_LINES)) {
+			/* Calculate azimuth between line start and end points in degrees */
+			dx = (Points->x[Points->n_points - 1] - Points->x[0]);
+			dy = (Points->y[Points->n_points - 1] - Points->y[0]);
+			/* If line is closed... */
+			if (dx == 0.0 && dy == 0.0) azimuth = -1;
+			else {
+				azimuth = atan2(dx,dy);
+				if (azimuth < 0) azimuth = azimuth + 2*M_PI;
+			Values[idx].d1 = azimuth;
 		found = 1;
Modified: grass/trunk/vector/v.to.db/parse.c
--- grass/trunk/vector/v.to.db/parse.c	2009-04-05 20:42:33 UTC (rev 36598)
+++ grass/trunk/vector/v.to.db/parse.c	2009-04-05 21:04:27 UTC (rev 36599)
@@ -52,7 +52,7 @@
     parms.option->required = YES;
     parms.option->multiple = NO;
     parms.option->options =
-	"cat,area,compact,fd,perimeter,length,count,coor,start,end,sides,query,slope,sinuous";
+	"cat,area,compact,fd,perimeter,length,count,coor,start,end,sides,query,slope,sinuous,azimuth";
     parms.option->description = _("Value to upload");
     parms.option->descriptions =
 	"cat;insert new row for each category if doesn't exist yet;"
@@ -72,7 +72,8 @@
 	"query;result of a database query for all records of the geometry"
 	"(or geometries) from table specified by 'qlayer' option;"
 	"slope;slope steepness of vector line or boundary;"
-	"sinuous;line sinuousity, calculated as line length / distance between end points;";
+	"sinuous;line sinuousity, calculated as line length / distance between end points;"
+	"azimuth;line azimuth, calculated as angle between North direction and endnode direction at startnode";
     parms.units = G_define_option();
     parms.units->key = "units";
@@ -80,10 +81,10 @@
     parms.units->required = NO;
     parms.units->multiple = NO;
     parms.units->options =
-	"mi,miles,f,feet,me,meters,k,kilometers,a,acres,h,hectares";
+	"mi,miles,f,feet,me,meters,k,kilometers,a,acres,h,hectares,r,radians,d,degrees";
     parms.units->label = _("Units");
     parms.units->description =
-	_("mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares)");
+	_("mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),r(adians),d(egrees)");
     parms.col = G_define_standard_option(G_OPT_DB_COLUMNS);
@@ -140,7 +141,7 @@
     if (!options.print) {
-	if (options.option == O_AREA || options.option == O_LENGTH || options.option == O_COUNT || options.option == O_QUERY || options.option == O_COMPACT || options.option == O_FD || options.option == O_PERIMETER || options.option == O_SLOPE || options.option == O_SINUOUS) {	/* one column required */
+	if (options.option == O_AREA || options.option == O_LENGTH || options.option == O_COUNT || options.option == O_QUERY || options.option == O_COMPACT || options.option == O_FD || options.option == O_PERIMETER || options.option == O_SLOPE || options.option == O_SINUOUS || options.option == O_AZIMUTH) {	/* one column required */
 	    if (ncols != 1) {
 		G_fatal_error(_("This option requires one column"));
@@ -167,6 +168,9 @@
     if (options.option == O_SINUOUS && !(options.type | GV_LINES))
 	G_fatal_error(_("The 'sinuous' option makes sense only for lines"));
+    if (options.option == O_AZIMUTH && !(options.type | GV_LINES))
+	G_fatal_error(_("The 'azimuth' option makes sense only for lines"));
     return 0;
@@ -188,6 +192,10 @@
 	x = U_ACRES;
     else if (match(s, "hectares", 1))
 	x = U_HECTARES;
+    else if (match(s, "radians", 1))
+	x = U_RADIANS;
+    else if (match(s, "degrees", 1))
+	x = U_DEGREES;
     return x;
@@ -224,6 +232,8 @@
 	x = O_SLOPE;
     else if (strcmp(s, "sinuous") == 0)
 	x = O_SINUOUS;
+    else if (strcmp(s, "azimuth") == 0)
+	x = O_AZIMUTH;
     return x;
Modified: grass/trunk/vector/v.to.db/report.c
--- grass/trunk/vector/v.to.db/report.c	2009-04-05 20:42:33 UTC (rev 36598)
+++ grass/trunk/vector/v.to.db/report.c	2009-04-05 21:04:27 UTC (rev 36599)
@@ -164,6 +164,12 @@
 	break;
+    case O_AZIMUTH:
+	if (G_verbose() > G_verbose_min())
+	    fprintf(stdout, "cat|azimuth\n");
+	for (i = 0; i < vstat.rcat; i++)
+		fprintf(stdout, "%d|%.15g\n", Values[i].cat, Values[i].d1);
+	break;
     return 0;
Modified: grass/trunk/vector/v.to.db/units.c
--- grass/trunk/vector/v.to.db/units.c	2009-04-05 20:42:33 UTC (rev 36598)
+++ grass/trunk/vector/v.to.db/units.c	2009-04-05 21:04:27 UTC (rev 36599)
@@ -3,7 +3,7 @@
 int conv_units()
-    int i;
+    int i, rad = 0;
     double f = 1.0, sq_f = 1.0;
     switch (options.units) {
@@ -34,6 +34,12 @@
 	f = 3.28083989501312;	/*  1 / (0.0254 * 12)    */
 	sq_f = 10.7639104167097;	/*  1 / (0.0254 * 12)^2  */
 	break;
+    case U_RADIANS:
+	rad = 1;
+	break;
+    case U_DEGREES:
+	rad = 0;
+	break;
     switch (options.option) {
@@ -46,6 +52,14 @@
 	    Values[i].d1 *= sq_f;
 	break;
+    case O_AZIMUTH:
+	    if (rad == 0) {
+		    for (i = 0; i < vstat.rcat; i++) {
+			    if (Values[i].d1 > 0)
+				   Values[i].d1 = Values[i].d1*(180/M_PI);
+	break;
Modified: grass/trunk/vector/v.to.db/update.c
--- grass/trunk/vector/v.to.db/update.c	2009-04-05 20:42:33 UTC (rev 36598)
+++ grass/trunk/vector/v.to.db/update.c	2009-04-05 21:04:27 UTC (rev 36599)
@@ -67,6 +67,7 @@
     case O_PERIMETER:
     case O_SLOPE:
     case O_SINUOUS:
+    case O_AZIMUTH:
 	sprintf(buf1, "update %s set %s =", Fi->table, options.col[0]);
 	break;
     case O_COOR:
@@ -102,6 +103,7 @@
 	case O_PERIMETER:
 	case O_SLOPE:
 	case O_SINUOUS:
+	case O_AZIMUTH:
 	    sprintf(buf2, "%s %f where %s = %d", buf1, Values[i].d1, Fi->key,
 		    Values[i].cat);
 	    break;
Modified: grass/trunk/vector/v.to.db/v.to.db.html
--- grass/trunk/vector/v.to.db/v.to.db.html	2009-04-05 20:42:33 UTC (rev 36598)
+++ grass/trunk/vector/v.to.db/v.to.db.html	2009-04-05 21:04:27 UTC (rev 36599)
@@ -4,7 +4,8 @@
 table, or prints them (or the SQL queries used to obtain them) in a
 form of a human-readable report. For uploaded/printed category values
 '-1' is used for 'no category' and 'null'/'-' if category cannot be
-found or multiple categories were found.
+found or multiple categories were found. For line azimuths '-1' is used
+for closed lines (start equals end).
 <H2>NOTES</H2>
 The units <em>miles</em>, <em>feet</em>, <em>meters</em> and
@@ -20,20 +21,27 @@
 When using <em>option=coor</em> on a vector area map,
 only coordinates of centroids with unique category will be reported.
 <p>
+Line azimuth is calculaded as angle from the North direction to the line endnode
+direction at the line statnode. By default it's reported in decimal degrees (0-360, CW) but
+it also may be repored in radians with <em>unit=radians</em>. Azimuth value
+<b>-1</b> is used to report closed line with it's startnode and endnode being in
+same place. Azimuth values make sense only if every vector line has only one
+entry in database (unique CAT value).
+<p>
 If the module is apparently slow <em>and</em> the map attributes are
 stored in an external DBMS such as PostgreSQL, it is highly recommended
 to create an index on the key (category) column.
 <p>
 Uploading the vector map attributes to a database requires a table attached to
 a given input vector <em>layer</em>. The <b>print only</b> (<b>-p</b>) mode
-doesn't require a table. Use <em><a href=db.execute.html>db.execute</a></em>
-or <em><a href=v.db.addtable.html>v.db.addtable</a></em> to create a table if
+doesn't require a table. Use <em><a href="db.execute.html">db.execute</a></em>
+or <em><a href="v.db.addtable.html">v.db.addtable</a></em> to create a table if
 needed.
 <p>
 Updating the table has to be done column-wise. The <em>column</em> must be
 present in the table, except when using the <b>print only</b> (<b>-p</b>)
-mode. Use <em><a href=db.execute.html>db.execute</a></em> or
-<em><a href=v.db.addcol.html>v.db.addcol</a></em> to add new columns if
+mode. Use <em><a href="db.execute.html">db.execute</a></em> or
+<em><a href="v.db.addcol.html">v.db.addcol</a></em> to add new columns if
 needed.
 <H2>EXAMPLES</H2>
