[GRASS-SVN] r36615 - grass/trunk/raster/r.cost
svn_grass at osgeo.org
Tue Apr 7 16:23:38 EDT 2009
Author: neteler
Date: 2009-04-07 16:23:38 -0400 (Tue, 07 Apr 2009)
New Revision: 36615
grass/trunk/raster/r.cost/main.c
grass/trunk/raster/r.cost/r.cost.html
grass/trunk/raster/r.cost/stash.h
cnielsen: Added 'backlink' functionality
Modified: grass/trunk/raster/r.cost/main.c
--- grass/trunk/raster/r.cost/main.c 2009-04-07 20:23:19 UTC (rev 36614)
+++ grass/trunk/raster/r.cost/main.c 2009-04-07 20:23:38 UTC (rev 36615)
@@ -8,6 +8,9 @@
* Pierre de Mouveaux <pmx audiovu com>
* Eric G. Miller <egm2 jps net>
+ * Updated for calculation errors and directional surface generation
+ * Colin Nielsen <colin.nielsen gmail com>
* PURPOSE: Outputs a raster map layer showing the cumulative cost
* of moving between different geographic locations on an
* input raster map layer whose cell category values
@@ -74,10 +77,11 @@
} variables[] = {
{"output", CUM_COST_LAYER},
{"input", COST_LAYER},
- {"coor", START_PT}
+ {"coor", START_PT},
+ {"outdir", MOVE_DIR_LAYER}
-char cum_cost_layer[64];
+char cum_cost_layer[64], move_dir_layer[64];
char cost_layer[64];
struct start_pt *head_start_pt = NULL;
struct start_pt *head_end_pt = NULL;
@@ -85,25 +89,26 @@
int main(int argc, char *argv[])
- void *cell, *cell2;
- SEGMENT in_seg, out_seg;
- const char *cost_mapset;
- const char *in_file, *out_file;
+ void *cell, *cell2, *dir_cell;
+ SEGMENT in_seg, out_seg, out_seg2;
+ const char *cost_mapset, *move_dir_mapset;
+ const char *in_file, *out_file, *dir_out_file;
const char *search_mapset;
double *value;
extern struct Cell_head window;
double NS_fac, EW_fac, DIAG_fac, H_DIAG_fac, V_DIAG_fac;
double fcost;
double min_cost, old_min_cost;
+ double cur_dir, old_cur_dir;
double zero = 0.0;
int at_percent = 0;
int col, row, nrows, ncols;
int maxcost;
int maxmem;
double cost;
- int cost_fd, cum_fd;
- int have_stop_points = 0;
- int in_fd, out_fd;
+ int cost_fd, cum_fd, dir_fd;
+ int have_stop_points = 0, dir = 0;
+ int in_fd, out_fd, dir_out_fd;
double my_cost;
double null_cost;
int srows, scols;
@@ -117,13 +122,13 @@
struct GModule *module;
struct Flag *flag2, *flag3, *flag4;
struct Option *opt1, *opt2, *opt3, *opt4, *opt5, *opt6, *opt7, *opt8;
- struct Option *opt9, *opt10;
+ struct Option *opt9, *opt10, *opt11;
struct cost *pres_cell, *new_cell;
struct start_pt *pres_start_pt = NULL;
struct start_pt *pres_stop_pt = NULL;
void *ptr2;
- RASTER_MAP_TYPE data_type;
+ RASTER_MAP_TYPE data_type, dir_data_type = DCELL_TYPE;
struct History history;
double peak = 0.0;
int dsize;
@@ -144,6 +149,14 @@
opt1 = G_define_standard_option(G_OPT_R_OUTPUT);
+ opt11 = G_define_option();
+ opt11->key = "outdir";
+ opt11->type = TYPE_STRING;
+ opt11->required = NO;
+ opt11->gisprompt = "new,cell,raster";
+ opt11->description =
+ _("Name of output raster map to contain movement directions");
opt7 = G_define_standard_option(G_OPT_V_INPUT);
opt7->key = "start_points";
opt7->required = NO;
@@ -225,9 +238,15 @@
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
+ /* If no outdir is specified, set flag to skip all dir */
+ if (opt11->answer != NULL)
+ dir = 1;
/* Initalize access to database and create temporary files */
in_file = G_tempfile();
out_file = G_tempfile();
+ if (dir == 1)
+ dir_out_file = G_tempfile();
/* Get database window parameters */
G_get_window(&window);
@@ -315,6 +334,11 @@
if (cost_mapset == NULL)
G_fatal_error(_("Raster map <%s> not found"), cost_layer);
+ if (dir == 1) {
+ strcpy(move_dir_layer, opt11->answer);
+ search_mapset = "";
+ move_dir_mapset = G_find_cell2(move_dir_layer, search_mapset);
/* Find number of rows and columns in window */
nrows = G_window_rows();
@@ -368,6 +392,12 @@
segment_format(out_fd, nrows, ncols, srows, scols, sizeof(double));
close(out_fd);
+ if (dir == 1) {
+ dir_out_fd = creat(dir_out_file, 0600);
+ segment_format(dir_out_fd, nrows, ncols, srows, scols,
+ sizeof(double));
+ close(dir_out_fd);
/* Open initialize and segment all files */
in_fd = open(in_file, 2);
@@ -377,6 +407,10 @@
out_fd = open(out_file, 2);
segment_init(&out_seg, out_fd, segments_in_memory);
+ if (dir == 1) {
+ dir_out_fd = open(dir_out_file, 2);
+ segment_init(&out_seg2, dir_out_fd, segments_in_memory);
/* Write the cost layer in the segmented file */
G_message(_("Reading raster map <%s>..."),
@@ -465,6 +499,27 @@
G_free(fbuff);
+ if (dir == 1) {
+ G_message(_("Initializing directional output "));
+ double *fbuff;
+ int i;
+ fbuff =
+ (double *)G_malloc((unsigned int)(ncols * sizeof(double)));
+ G_set_d_null_value(fbuff, ncols);
+ for (row = 0; row < nrows; row++) {
+ G_percent(row, nrows, 2);
+ for (i = 0; i < ncols; i++) {
+ segment_put(&out_seg2, &fbuff[i], row, i);
+ G_percent(1, 1, 1);
+ segment_flush(&out_seg2);
+ G_free(fbuff);
/* Scan the start_points layer searching for starting points.
* Create a btree of starting points ordered by increasing costs.
@@ -692,55 +747,71 @@
case 1:
row = pres_cell->row;
col = pres_cell->col - 1;
+ cur_dir = 180.0;
break;
case 2:
col = pres_cell->col + 1;
+ cur_dir = 0.0;
break;
case 3:
row = pres_cell->row - 1;
col = pres_cell->col;
+ cur_dir = 90.0;
break;
case 4:
row = pres_cell->row + 1;
+ cur_dir = 270.0;
break;
case 5:
+ cur_dir = 135.0;
break;
case 6:
+ cur_dir = 45.0;
break;
case 7:
+ cur_dir = 315.0;
break;
case 8:
+ cur_dir = 225.0;
break;
case 9:
row = pres_cell->row - 2;
+ cur_dir = 112.5;
break;
case 10:
+ cur_dir = 67.5;
break;
case 11:
row = pres_cell->row + 2;
+ cur_dir = 292.5;
break;
case 12:
+ cur_dir = 247.5;
break;
case 13:
col = pres_cell->col - 2;
+ cur_dir = 157.5;
break;
case 14:
col = pres_cell->col + 2;
+ cur_dir = 22.5;
break;
case 15:
+ cur_dir = 337.5;
break;
case 16:
+ cur_dir = 202.5;
break;
@@ -755,97 +826,105 @@
case 1:
value = &W;
segment_get(&in_seg, value, row, col);
- fcost = (double)(W + my_cost) / 2.0;
+ fcost = (double)((W / 2.0) + (my_cost / 2.0));
min_cost = pres_cell->min_cost + fcost * EW_fac;
break;
case 2:
value = &E;
- fcost = (double)(E + my_cost) / 2.0;
+ fcost = (double)((E / 2.0) + (my_cost / 2.0));
break;
case 3:
value = &N;
- fcost = (double)(N + my_cost) / 2.0;
+ fcost = (double)((N / 2.0) + (my_cost / 2.0));
min_cost = pres_cell->min_cost + fcost * NS_fac;
break;
case 4:
value = &S;
- fcost = (double)(S + my_cost) / 2.0;
+ fcost = (double)((S / 2.0) + (my_cost / 2.0));
break;
case 5:
value = &NW;
- fcost = (double)(NW + my_cost) / 2.0;
+ fcost = (double)((NW / 2.0) + (my_cost / 2.0));
min_cost = pres_cell->min_cost + fcost * DIAG_fac;
break;
case 6:
value = &NE;
- fcost = (double)(NE + my_cost) / 2.0;
+ fcost = (double)((NE / 2.0) + (my_cost / 2.0));
break;
case 7:
value = &SE;
- fcost = (double)(SE + my_cost) / 2.0;
+ fcost = (double)((SE / 2.0) + (my_cost / 2.0));
break;
case 8:
value = &SW;
- fcost = (double)(SW + my_cost) / 2.0;
+ fcost = (double)((SW / 2.0) + (my_cost / 2.0));
break;
case 9:
value = &NNW;
- fcost = (double)(N + NW + NNW + my_cost) / 4.0;
+ fcost = (double)((N / 4.0) + (NW / 4.0) + (NNW / 4.0) +
+ (my_cost / 4.0));
min_cost = pres_cell->min_cost + fcost * V_DIAG_fac;
break;
case 10:
value = &NNE;
- fcost = (double)(N + NE + NNE + my_cost) / 4.0;
+ fcost = (double)((N / 4.0) + (NE / 4.0) + (NNE / 4.0) +
+ (my_cost / 4.0));
break;
case 11:
value = &SSE;
- fcost = (double)(S + SE + SSE + my_cost) / 4.0;
+ fcost = (double)((S / 4.0) + (SE / 4.0) + (SSE / 4.0) +
+ (my_cost / 4.0));
break;
case 12:
value = &SSW;
- fcost = (double)(S + SW + SSW + my_cost) / 4.0;
+ fcost = (double)((S / 4.0) + (SW / 4.0) + (SSW / 4.0) +
+ (my_cost / 4.0));
break;
case 13:
value = &WNW;
- fcost = (double)(W + NW + WNW + my_cost) / 4.0;
+ fcost = (double)((W / 4.0) + (NW / 4.0) + (WNW / 4.0) +
+ (my_cost / 4.0));
min_cost = pres_cell->min_cost + fcost * H_DIAG_fac;
break;
case 14:
value = &ENE;
- fcost = (double)(E + NE + ENE + my_cost) / 4.0;
+ fcost = (double)((E / 4.0) + (NE / 4.0) + (ENE / 4.0) +
+ (my_cost / 4.0));
break;
case 15:
value = &ESE;
- fcost = (double)(E + SE + ESE + my_cost) / 4.0;
+ fcost = (double)((E / 4.0) + (SE / 4.0) + (ESE / 4.0) +
+ (my_cost / 4.0));
break;
case 16:
value = &WSW;
- fcost = (double)(W + SW + WSW + my_cost) / 4.0;
+ fcost = (double)((W / 4.0) + (SW / 4.0) + (WSW / 4.0) +
+ (my_cost / 4.0));
break;
@@ -854,15 +933,24 @@
continue;
segment_get(&out_seg, &old_min_cost, row, col);
+ if (dir == 1) {
+ segment_get(&out_seg2, &old_cur_dir, row, col);
if (G_is_d_null_value(&old_min_cost)) {
segment_put(&out_seg, &min_cost, row, col);
new_cell = insert(min_cost, row, col);
+ if (dir == 1) {
+ segment_put(&out_seg2, &cur_dir, row, col);
else {
if (old_min_cost > min_cost) {
+ if (dir == 1) {
else {
@@ -888,9 +976,17 @@
cum_fd = G_open_raster_new(cum_cost_layer, data_type);
+ if (dir == 1) {
+ dir_fd = G_open_raster_new(move_dir_layer, dir_data_type);
+ dir_cell = G_allocate_raster_buf(dir_data_type);
/* Write pending updates by segment_put() to output map */
segment_flush(&out_seg);
+ if (dir == 1) {
/* Copy segmented map to output map */
G_message(_("Writing raster map <%s>..."), cum_cost_layer);
@@ -1000,19 +1096,52 @@
G_percent(1, 1, 1);
+ double *p;
+ if (dir == 1) {
+ G_message(_("Writing movement direction file %s..."), move_dir_layer);
+ p = dir_cell;
+ for (col = 0; col < ncols; col++) {
+ segment_get(&out_seg2, &cur_dir, row, col);
+ *(p + col) = cur_dir;
+ G_put_raster_row(dir_fd, dir_cell, dir_data_type);
segment_release(&in_seg); /* release memory */
segment_release(&out_seg);
+ if (dir == 1) {
+ segment_release(&out_seg2);
G_close_cell(cost_fd);
G_close_cell(cum_fd);
+ if (dir == 1) {
+ G_close_cell(dir_fd);
close(in_fd); /* close all files */
close(out_fd);
+ if (dir == 1) {
unlink(in_file); /* remove submatrix files */
unlink(out_file);
+ if (dir == 1) {
+ unlink(dir_out_file);
G_short_history(cum_cost_layer, "raster", &history);
G_command_history(&history);
G_write_history(cum_cost_layer, &history);
+ if (dir == 1) {
+ G_short_history(move_dir_layer, "raster", &history);
+ G_command_history(&history);
+ G_write_history(move_dir_layer, &history);
/* Create colours for output map */
Modified: grass/trunk/raster/r.cost/r.cost.html
--- grass/trunk/raster/r.cost/r.cost.html 2009-04-07 20:23:19 UTC (rev 36614)
+++ grass/trunk/raster/r.cost/r.cost.html 2009-04-07 20:23:38 UTC (rev 36615)
@@ -6,11 +6,13 @@
other user-specified cell(s) whose locations are specified by their
geographic coordinate(s). Each cell in the original cost surface map
will contain a category value which represents the cost of traversing
-that cell. <em>r.cost</em> will produce an <b>output</b> raster map in
+that cell. <em>r.cost</em> will produce 1) an <b>output</b> raster map in
which each cell contains the lowest total cost of traversing the
-space between each cell and the user-specified points. (Diagonal
+space between each cell and the user-specified points (diagonal
costs are multiplied by a factor that depends on the dimensions of
-the cell.) This program uses the current geographic region settings.
+the cell) and 2) a second raster map layer showing the movement
+direction to the next cell on the path back to the start point (see
+<a href="#move">Movement Direction</a>). This program uses the current geographic region settings.
The <b>output</b> map will be of the same data format as the <b>input</b>
map, integer or floating point.</p>
@@ -18,7 +20,8 @@
The <b>input</b> <em>name</em> is the name of a raster map whose category values
represent the surface cost. The <b>output</b> <em>name</em> is the name of the
-resultant raster map of cumulative cost.
+resultant raster map of cumulative cost. The <b>outdir</b> <em>name</em> is the
+name of the resultant raster map of movement directions (see <a href="#move">Movement Direction</a>).
<p>
<em>r.cost</em> can be run with three different methods of identifying the
@@ -203,11 +206,11 @@
The output map can be viewed, for example, as an elevation model in which
the starting location(s) is/are the lowest point(s). Outputs from <em>r.cost</em>
-can be used as inputs to <em><a href="r.drain.html">r.drain</a></em>, in order
-to trace the least-cost path given by this model between any given cell
-and the <em>r.cost</em> starting location(s). The two programs, when
-used together, generate least-cost paths or corridors between any two
-map locations (cells).
+can be used as inputs to <em><a href="r.drain.html">r.drain</a></em> with
+the direction flag <b>-d</b>, in order to trace the least-cost path given by this
+model between any given cell and the <em>r.cost</em> starting location(s). The
+two programs, when used together, generate least-cost paths or corridors between any
+two map locations (cells).
<h4>Shortest distance surfaces</h4>
The <em>r.cost</em> module allows for computing the shortest distance
@@ -228,6 +231,26 @@
d.rast dist_meters
</pre></div>
+<a name="move"></a>
+<h2>Movement Direction</h2>
+<p>
+The movement direction surface is created to record the sequence of
+movements that created the cost accumulation surface. Without it
+<em>r.drain</em> would not correctly create a path from an end point
+back to the start point. The direction shown in each cell points <b>away</b>
+from the cell that came before it. The directions are recorded as
+GRASS standard directions:<div class="code"><pre>
+ 112.5 90 67.5 i.e. a cell with the value 135
+157.5 135 0 45 22.5 means the cell <b>before</b> it is
+ 180 x 0 to the south-east.
+202.5 225 270 315 337.5
+ 247.5 292.5
+</pre></div>
+<p>
+Once <em>r.cost</em> computes the cumulative cost map, <em>r.drain</em>
+can be used to find the minimum cost path. Make sure to use the <b>-d</b> flag
+and the movement direction raster map when running r.drain to ensure
+the path is computed according to the proper movement directions.
<h2>BUGS</h2>
Modified: grass/trunk/raster/r.cost/stash.h
--- grass/trunk/raster/r.cost/stash.h 2009-04-07 20:23:19 UTC (rev 36614)
+++ grass/trunk/raster/r.cost/stash.h 2009-04-07 20:23:38 UTC (rev 36615)
@@ -29,6 +29,7 @@
#define CUM_COST_LAYER 1
#define COST_LAYER 2
#define START_PT 3
+#define MOVE_DIR_LAYER 4
struct start_pt
@@ -37,7 +38,7 @@
struct start_pt *next;
-extern char cum_cost_layer[];
+extern char cum_cost_layer[], move_dir_layer[];
extern char cost_layer[];
extern struct start_pt *head_start_pt;
extern struct start_pt *head_end_pt;
