[GRASS-SVN] r36620 - grass/branches/develbranch_6/vector/v.in.dxf
svn_grass at osgeo.org
Tue Apr 7 22:43:14 EDT 2009
Author: hcho
Date: 2009-04-07 22:43:14 -0400 (Tue, 07 Apr 2009)
New Revision: 36620
grass/branches/develbranch_6/vector/v.in.dxf/write_vect.c
Fixed table naming
Modified: grass/branches/develbranch_6/vector/v.in.dxf/write_vect.c
--- grass/branches/develbranch_6/vector/v.in.dxf/write_vect.c 2009-04-08 02:41:47 UTC (rev 36619)
+++ grass/branches/develbranch_6/vector/v.in.dxf/write_vect.c 2009-04-08 02:43:14 UTC (rev 36620)
@@ -122,9 +122,18 @@
int *cat)
int i, type;
+ char x = 0;
- /* make table name SQL compliant */
+ /* make table name SQL compliant: Vect_default_field_info returns
+ * mapname_layername in ->table, and mapname is always SQL compliant.
+ * Because layername is followed by mapname_, it (field_name here) can
+ * start with [a-zA-Z0-9]. No need to change the first digit to 'x'.
+ if (field_name[0] >= '0' && field_name[0] <= '9')
+ x = field_name[0];
G_str_to_sql(field_name);
+ if (x)
+ field_name[0] = x;
for (i = 0; i < num_fields; i++) {
/* field name already exists */
