[GRASS-SVN] r36622 - grass/branches/develbranch_6/vector/v.in.dxf
svn_grass at osgeo.org
Tue Apr 7 23:09:19 EDT 2009
Author: hcho
Date: 2009-04-07 23:09:19 -0400 (Tue, 07 Apr 2009)
New Revision: 36622
grass/branches/develbranch_6/vector/v.in.dxf/write_vect.c
Don't change layer names
Modified: grass/branches/develbranch_6/vector/v.in.dxf/write_vect.c
--- grass/branches/develbranch_6/vector/v.in.dxf/write_vect.c 2009-04-08 03:08:19 UTC (rev 36621)
+++ grass/branches/develbranch_6/vector/v.in.dxf/write_vect.c 2009-04-08 03:09:19 UTC (rev 36622)
@@ -118,10 +118,11 @@
return;
-static int get_field_cat(struct Map_info *Map, char *field_name, int *field,
+static int get_field_cat(struct Map_info *Map, char *layer, int *field,
int *cat)
int i, type;
+ char field_name[DXf_BUF_SIZE];
char x = 0;
/* make table name SQL compliant: Vect_default_field_info returns
@@ -129,6 +130,7 @@
* Because layername is followed by mapname_, it (field_name here) can
* start with [a-zA-Z0-9]. No need to change the first digit to 'x'.
+ strcpy(field_name, layer);
if (field_name[0] >= '0' && field_name[0] <= '9')
x = field_name[0];
G_str_to_sql(field_name);
