[GRASS-SVN] r36625 - grass/branches/releasebranch_6_4/raster/r.terraflow
Wed Apr 8 03:47:20 EDT 2009
Author: neteler
Date: 2009-04-08 03:47:20 -0400 (Wed, 08 Apr 2009)
New Revision: 36625
   grass/branches/releasebranch_6_4/raster/r.terraflow/description.html
cosmetics
Modified: grass/branches/releasebranch_6_4/raster/r.terraflow/description.html
--- grass/branches/releasebranch_6_4/raster/r.terraflow/description.html	2009-04-08 07:47:08 UTC (rev 36624)
+++ grass/branches/releasebranch_6_4/raster/r.terraflow/description.html	2009-04-08 07:47:20 UTC (rev 36625)
@@ -176,27 +176,25 @@
 r.terraflow elev=elevation.10m filled=elevation10m.filled \
     dir=elevation10m.mfdir swatershed=elevation10m.watershed \
     accumulation=elevation10m.accu tci=elevation10m.tci d8cut=500 memory=800 \
-    STREAM-DIR=/var/tmp/ stats=elevation10mstats.txt
+    stats=elevation10mstats.txt
 </pre></div>
 <h2>SEE ALSO</h2>
-<ul>
-  <li>The <a
-href="http://www.cs.duke.edu/geo*/terraflow/">TerraFlow</a> project at Duke University
-  <li><a href=r.flow.html>r.flow</a>,
-       <a href="r.basins.fill.html">r.basins.fill</a>,
-       <a href="r.drain.html">r.drain</a>,
-       <a href="r.topidx.html">r.topidx</a>,
-       <a href="r.topmodel.html">r.topmodel</a>,
-       <a href="r.water.outlet.html">r.water.outlet</a>,
-       <a href="r.watershed.html">r.watershed</a>
-</ul>
+<em>
+<a href=r.flow.html>r.flow</a>,
+<a href="r.basins.fill.html">r.basins.fill</a>,
+<a href="r.drain.html">r.drain</a>,
+<a href="r.topidx.html">r.topidx</a>,
+<a href="r.topmodel.html">r.topmodel</a>,
+<a href="r.water.outlet.html">r.water.outlet</a>,
+<a href="r.watershed.html">r.watershed</a>
+</em>
 <h2>AUTHORS</h2>
 <dl>
@@ -223,6 +221,7 @@
 <h2>REFERENCES</h2>
 <ol>
+  <li> The <a href="http://www.cs.duke.edu/geo*/terraflow/">TerraFlow</a> project at Duke University
   <li><A NAME="arge:drainage"
        HREF="http://www.cs.duke.edu/geo*/terraflow/papers/alenex00_drainage.ps.gz">
        I/O-efficient algorithms for problems on grid-based
