[GRASS-SVN] r36647 - grass-addons/raster/r.terracost
svn_grass at osgeo.org
Wed Apr 8 23:50:43 EDT 2009
Author: ltoma
Date: 2009-04-08 23:50:43 -0400 (Wed, 08 Apr 2009)
New Revision: 36647
grass-addons/raster/r.terracost/common.cc
grass-addons/raster/r.terracost/main.cc
grass-addons/raster/r.terracost/option.h
grass-addons/raster/r.terracost/sortutils.h
grass-addons/raster/r.terracost/tile.cc
Cleaned up and got rid (hopefully) of all references to -DPEARL. Replaced the call to AMI_sort() from main.cc that takes an additional stream name and does not exist in iostream (without PEARL) anymore. I changed setting the environment variables STREAM_DIR and VTMPDIR because I was getting weird errors if they existed, and they were redefined. Still some errors with const char*.
Modified: grass-addons/raster/r.terracost/common.cc
--- grass-addons/raster/r.terracost/common.cc 2009-04-09 03:00:01 UTC (rev 36646)
+++ grass-addons/raster/r.terracost/common.cc 2009-04-09 03:50:43 UTC (rev 36647)
@@ -36,15 +36,13 @@
resolvePath(const char *name) {
static char buf[BUFSIZ];
static char *vtmpdir = NULL;
+ vtmpdir = getenv(VTMPDIR);
- // we should probably save this, but reload each time for now...
- //if(!vtmpdir) {
- if(!(vtmpdir = getenv(VTMPDIR))) {
- fprintf(stderr, "%s: environment not set\n", VTMPDIR);
- exit(1);
+ if(!vtmpdir){
+ fprintf(stderr, "%s: environment not set\n", VTMPDIR);
+ exit(1);
if(name[0] == '/') { // absolute path
strcpy(buf, name);
} else { // relative path - use VTMPDIR
Modified: grass-addons/raster/r.terracost/main.cc
--- grass-addons/raster/r.terracost/main.cc 2009-04-09 03:00:01 UTC (rev 36646)
+++ grass-addons/raster/r.terracost/main.cc 2009-04-09 03:50:43 UTC (rev 36647)
@@ -82,12 +82,15 @@
" set of start points.\n"
"\nDescription:\n"
" r.terracost computes a least-cost surface for a given cost grid and\n"
-" set of start points using an approach that scales to very large grids.\n"
-" See \"TerraCost: A Versatile and Scalable Approach for Path Computations on Massive\n"
+" set of start points using an approach that scales to large grids.\n"
+" For details, see paper \"TerraCost: A Versatile and Scalable Approach for Path Computations on Massive\n"
" Grid-Based Terrains\" by Hazel, Toma, Vahrenhold and Wickremesinghe (2005).\n"
-" \n numtiles is the tiling factor. Run with -i to see the recommended value.\n"
-" It is possible to run r.terracost in five steps. When running in separate\n"
-" steps, the config file stores temporary information, and other streams\n"
+" The basic idea is to split the grid in tiles. "
+" \n numtiles is the number of tiles. Run with -i to see the recommended value for numtiles.\n"
+" When numtiles=1 it runs Dijkstra's algorithm in memory."
+" When numtiles>1 it runs an external SP algorithm that consists of 5 steps."
+" For debug purposes, it is possible to run the five steps separately. When running in separate\n"
+" steps, an intermediate config file stores temporary information, and other streams\n"
" (see below) contain intermediate data.\n"
" Step 0 (setup) inputs from grass; outputs are "S0OUT" and "S0BND"\n"
" Step 1 (compute substitute graph: intra-tile dijkstra)\n"
@@ -103,6 +106,7 @@
/* get the args from GRASS */
@@ -204,31 +208,51 @@
struct Flag *step0;
step0 = G_define_flag();
step0->key = '0' ;
+<<<<<<< .mine
+ step0->description = _("Step 0 only (default: run all)");
step0->description = "Step 0 only (-h for info)";
+>>>>>>> .r36646
/* step0->answer = 'n'; */
/* Run step 1 only flag*/
struct Flag *step1;
step1 = G_define_flag() ;
step1->key = '1' ;
+<<<<<<< .mine
+ step1->description = _("Step 1 only (default: run all)");
step1->description = "Step 1 only (-h for info)" ;
+>>>>>>> .r36646
/* step1->answer = 'n'; */
/* Run step 2 and 3 only flags */
struct Flag *step2;
step2 = G_define_flag();
step2->key = '2' ;
+<<<<<<< .mine
+ step2->description = _("Step 2 only (default: run all)");
step2->description = "Step 2 only (-h for info)";
+>>>>>>> .r36646
struct Flag *step3;
step3 = G_define_flag();
step3->key = '3' ;
+<<<<<<< .mine
+ step3->description = _("Step 3 only (default: run all)");
step3->description = "Step 3 only (-h for info)";
+>>>>>>> .r36646
struct Flag *step4;
step4 = G_define_flag();
step4->key = '4' ;
+<<<<<<< .mine
+ step4->description = _("Step 4 only (default: run all)");
step4->description = "Step 4 only (-h for info)";
+>>>>>>> .r36646
/* Number of tiles; used in conjunction with step0 flag */
struct Option *numtiles;
@@ -334,6 +358,7 @@
opt->verbose= (!quiet->answer);
opt->ascii = ascii->answer;
opt->stats= stats_opt->answer;
+ opt->runMode = RUN_NONE;
if(step0->answer) {
opt->runMode |= RUN_S0;
@@ -349,6 +374,7 @@
if(step4->answer) {
opt->runMode |= RUN_S4;
+ //if the user does not specify any step, then run all steps
if(opt->runMode == RUN_NONE) {
opt->runMode = RUN_ALL;
@@ -371,11 +397,10 @@
printf(description);
exit(0);
void check_args() {
@@ -416,7 +441,11 @@
*stats << "input cost grid: " << opt->cost_grid << "\n";
*stats << "input source grid: " << opt->source_grid << "\n";
*stats << "output distance grid: " << opt->out_grid << "\n";
+ if (opt->runMode & RUN_S0) *stats << " Step1";
+ if (opt->runMode & RUN_S1) *stats << " Step2";
+ if (opt->runMode & RUN_S2) *stats << " Step3";
+ if (opt->runMode & RUN_S3) *stats << " Step4";
+ *stats << "\n";
size_t mm_size = opt->mem << 20; /* (in bytes) */
char tmp[100];
formatNumber(tmp, mm_size);
@@ -449,31 +478,6 @@
-//cost_type
-// int
-// getb2bValue(dimension_type iFrom, dimension_type jFrom, dimension_type iTo,
-// dimension_type jTo, TileFactory *tf,
-// AMI_STREAM<distanceType> *b2bstr){
-// int fromIndex, toIndex, finalIndex;
-// cout << "getb2bValue()\n";
-// cout << "iFrom: " << iFrom << " jFrom: " << jFrom << "\n";
-// cout << "iTo: " << iTo << " jTo: " << jTo << "\n";
-// fromIndex = getFromIndex(iFrom, jFrom, tf);
-// toIndex = getToIndex(iFrom, jFrom, iTo, jTo, tf);
-// finalIndex = fromIndex+toIndex-1;
-// return finalIndex;
void
compute_tilesize(const char *label, int nr, int nc, int mem,
int *tilesize, int *numtiles) {
@@ -517,6 +521,7 @@
int
main(int argc, char *argv[]) {
@@ -525,7 +530,6 @@
/* initialize GIS library */
G_gisinit(argv[0]);
module = G_define_module();
/* get the current region and dimensions */
@@ -536,7 +540,6 @@
int nr = G_window_rows();
int nc = G_window_cols();
if ((nr > dimension_type_max) || (nc > dimension_type_max)) {
printf("[nrows=%d, ncols=%d] dimension_type overflow--change dimension_type and recompile\n",nr,nc);
G_fatal_error("[nrows=%d, ncols=%d] dimension_type overflow--change dimension_type and recompile\n",nr,nc);
@@ -555,48 +558,57 @@
/* setup STREAM_DIR */
sprintf(buf, "%s=%s", STREAM_TMPDIR, opt->streamdir);
- putenv(buf);
+ if(getenv(STREAM_TMPDIR) == NULL) {
+ printf("setenv %s\n", buf);
+ if (putenv(buf) != 0) {
+ printf("cannot setenv %s\n",buf);
+ exit(1);
if (getenv(STREAM_TMPDIR) == NULL) {
- fprintf(stdout, "%s:", STREAM_TMPDIR);
- G_fatal_error("not set");
+ G_fatal_error("TREAM_TMPDIR not set");
+ exit(1);
} else {
fprintf(stdout, "STREAM temporary files in %s\n", getenv(STREAM_TMPDIR));
- fprintf(stdout, "THESE TEMPORARY STREAMS WILL NOT BE DELETED "
- "IN CASE OF ABNORMAL TERMINATION OF THE PROGRAM.\n");
- fprintf(stdout, "TO SAVE SPACE PLEASE DELETE THESE FILES MANUALLY!\n");
+ fprintf(stdout, "\t!!!THESE TEMPORARY STREAMS WILL NOT BE DELETED "
+ "IN CASE OF ABNORMAL TERMINATION OF THE PROGRAM.\n");
+ fprintf(stdout, "\t!!!TO SAVE SPACE PLEASE DELETE THESE FILES MANUALLY!\n");
/* setup VTMPDIR */
sprintf(buf, "%s=%s", VTMPDIR, opt->vtmpdir);
- putenv(buf);
if (getenv(VTMPDIR) == NULL) {
+ if(putenv(buf) !=0) {
+ exit(1);
+ if (getenv(VTMPDIR) == NULL) {
fprintf(stdout, "%s: environment not set", VTMPDIR);
- exit(1);
+ exit(1);
} else {
fprintf(stdout, "terracost intermediate files in %s\n", getenv(VTMPDIR));
if(opt->runMode != RUN_ALL) {
- struct stat sb;
- if(stat(opt->vtmpdir, &sb) < 0) {
+ struct stat sb;
+ if(stat(opt->vtmpdir, &sb) < 0) {
+ perror(opt->vtmpdir);
+ // try to make VTMPDIR
+ fprintf(stderr, "trying to create %s\n", opt->vtmpdir);
+ if(mkdir(opt->vtmpdir, 0777)) {
+ if(errno != EEXIST) {
- // this is only fatal if we actually need the directory. ie: we
- // are using intermediate files, and one or more uses relative paths.
- // allow it for now
- fprintf(stderr, "%s: WARNING! This could cause errors if relative intermediate files in use\n", opt->vtmpdir);
- // try to make VTMPDIR, just to avoid common problem
- fprintf(stderr, "%s: trying to create\n", opt->vtmpdir);
- if(mkdir(opt->vtmpdir, 0777)) {
- if(errno != EEXIST) {
- perror(opt->vtmpdir);
- // this might not be a fatal error (maybe we dont use it), so go on -RW
- //exit(1);
+ // this might not be a fatal error (maybe we dont use it), so go on -RW
+ //exit(1);
if(info) {
printf("\n");
printf("STREAM_TMPDIR=%s\n", getenv(STREAM_TMPDIR));
@@ -605,11 +617,7 @@
int tilesize, numtiles;
compute_tilesize("TILESIZE", nrows, ncols, opt->mem << 20,
&tilesize, &numtiles);
- //LT: i took this out, since i dont agree
- //compute_tilesize("TILE IN CACHE CALC", nrows, ncols, 512 << 10,
- // &tilesize, &numtiles);
- exit(0);
+ return 0;
}//info
if(opt->verbose) {
@@ -698,230 +706,190 @@
- /* STEP: set up tile size, padded grid size and load cost grid and
- compute substitute graph */
size_t availmem1;
availmem1 = MM_manager.memory_available();
char memBuf [100] = "";
formatNumber(memBuf, availmem1);
long nodata_count;
// we don't really know yet, since we might read it from config...
//*stats << "numtiles = " << opt->numtiles << endl;
- size_t mem = memForNormalDijkstra(nrows, ncols);
- if (/*mem < availmem1 */ opt->numtiles == 1) {
+ //size_t mem = memForNormalDijkstra(nrows, ncols);
+ if (opt->numtiles == 1) {
cout << "Using normal Dijkstra" << endl;
stats->comment("Using normal Dijkstra");
normalDijkstra(opt->cost_grid,opt->source_grid, &nodata_count);
- goto cleanup;
+ /* CLEAN up */
+ cout << "cleaning up\n"; cout.flush();
+ free(region);
+ free(opt);
+ delete stats;
+ cout << "r.terracost done\n"; cout.flush();
+ return 0;
- /* Because of all of the if-statements we need to declare these
- here -- huh? why? XXX-RW */
- TileFactory *tf=NULL;
- dimension_type tileSizeRows, tileSizeCols;
- AMI_STREAM<distanceType> *b2bstr = NULL;
- AMI_STREAM<ijCost> *s2bstr = NULL;
- size_t tilemem; /* how much memory we want for a tile */
- size_t tfmem; /* how much memory we want for the tile factory */
- size_t bndmem; /* how much memory we want for the bnd dsrt in STEP 2 */
+ //this is executed if numtiles>1
+ /* STEP: set up tile size, padded grid size and load cost grid and
+ compute substitute graph */
+ TileFactory *tf=NULL;
+ dimension_type tileSizeRows, tileSizeCols;
+ AMI_STREAM<distanceType> *b2bstr = NULL;
+ AMI_STREAM<ijCost> *s2bstr = NULL;
+ size_t tilemem; /* how much memory we want for a tile */
+ size_t tfmem; /* how much memory we want for the tile factory */
+ size_t bndmem; /* how much memory we want for the bnd dsrt in STEP 2 */
+ normally we would set the tile size such that :
+ tilesize*sizeof<ijCostType> + tilesize*sizeof(<costType) = avail,
+ which gives tilesize = avail/(sizeof(ijCostType) +
+ sizeof(<costType>)). in this case the tile factory tf
+ (i.e. bndpoints) will be stored as a stream on disk and use no
+ memory.
+ we can compromise for a smaller tile and save part of the
+ memory to store the tile factory (boundary points) in memory as
+ well. For small N (grid size) the bnd dstrs may fit completely
+ in memory and will be faster than if it was on disk.
+ /* normally tilemem = availmem; tfmem = 0;bndmem = 0; */
+ tilemem = availmem1 / 2;
+ tfmem = availmem1 / 4;
+ bndmem = availmem1 / 4;
+ //if(!opt->step1 && !opt->step2) {
+ if(opt->runMode & RUN_S0) {
+ stats->comment("----------------------------------------");
+ stats->comment("STEP 0: COMPUTE SUBSTITUTE GRAPH");
+ *stats << endl;
+ *stats << "Memory Available: " << memBuf << "bytes\n";
- normally we would set the tile size such that :
- tilesize*sizeof<ijCostType> + tilesize*sizeof(<costType) = avail,
- which gives tilesize = avail/(sizeof(ijCostType) +
- sizeof(<costType>)). in this case the tile factory tf
- (i.e. bndpoints) will be stored as a stream on disk and use no
- memory.
+ /* in STEP 0/1 memory is used for:
+ - a tile<ijCostType>
+ - a tileFactory structure, which is a boundary dstr of
+ <costSourceType> (if ARRAY) or <ijCostType> (if STRREAM)
+ - a PQ for bnd 2 bnd Dijkstra in a tile
+ - a PQ for source 2 bnd Dijkstra in a tile
+ - a tile<costType>
- we can compromise for a smaller tile and save part of the
- memory to store the tile factory (boundary points) in memory as
- well. For small N (grid size) the bnd dstrs may fit completely
- in memory and will be faster than if it was on disk.
+ - are we forgetting anything??check!!
- /* normally tilemem = availmem; tfmem = 0;bndmem = 0; */
- tilemem = availmem1 / 2;
- tfmem = availmem1 / 4;
- bndmem = availmem1 / 4;
- //if(!opt->step1 && !opt->step2) {
- if(opt->runMode & RUN_S0) {
- stats->comment("----------------------------------------");
- stats->comment("STEP 0: COMPUTE SUBSTITUTE GRAPH");
- *stats << endl;
- *stats << "Memory Available: " << memBuf << "bytes\n";
- /* in STEP 0/1 memory is used for:
- - a tile<ijCostType>
- - a tileFactory structure, which is a boundary dstr of
- <costSourceType> (if ARRAY) or <ijCostType> (if STRREAM)
- - a PQ for bnd 2 bnd Dijkstra in a tile
- - a PQ for source 2 bnd Dijkstra in a tile
- - a tile<costType>
- - are we forgetting anything??check!!
- /* dimension of a tile */
- //if (opt->step0) {
- //if(opt->runMode & RUN_S0) {
- /* sets tileSizeRows and tileSizeCols based on a user defined
- number of tiles */
- initializeTileSize(&tileSizeRows, &tileSizeCols, opt->numtiles);
- tsr = tileSizeRows;
- tsc = tileSizeCols;
- tf = new TileFactory(tileSizeRows, tileSizeCols, 0);
- g.ntiles = tf->getNumTiles();
- cout << "Original Grid Size: " << nrows << "x" << ncols << endl;
- cout << "TF #Tiles: " << g.ntiles << endl; cout.flush();
- // else {
- // /* sets tileSizeRows, tileSizeCols, nrowsPad, ncolsPad
- // given the memory to be used by a tile; the size of a tile
- // is chosen so that a tile uses at most tilemem memory; in
- // order that boundary tiles have same size as internal tiles
- // we pad the grid we extra rows and columns; the size of the
- // grid is thus (nrowsPad, ncolsPad) */
- // initializeTileSize(&tileSizeRows, &tileSizeCols, tilemem);
- // /*normally tilesize = tilemem /(sizeof(ijCostType) +
- // sizeof(costType));*/ //tileSizeRows = 4; //tileSizeCols =
- // 5;
- // /* create a tileFactory structure that will know how to
- // extract a tile from a a grid and how to iterate on
- // tiles. This structure should never use more than tfmem
- // memory */
- // tf = new TileFactory(tileSizeRows, tileSizeCols, tfmem);
- // ntiles = tf->getNumTiles();
- /* read input cost grid and populate tf */
- loadGrid(opt->cost_grid,opt->source_grid, &nodata_count, tf);
- *stats <<"Total elements read=" << formatNumber(NULL, (long)nrows*ncols);
- *stats <<", nodata elements=" << formatNumber(NULL, nodata_count) <<endl;
- /* since we work internally with a padded grid, we need to add the
- padded values to bndCost and intCost */
- tf->pad();
- /* Sorting messes up the stream name on disk */
- // already below
- // if (!opt->step0)
- // tf->sortTF();
- // if(debug) {
- // dump_file((const char *)VTMPDIR "s0out", (const char *)VTMPDIR "s0out.dump", ijCostSource());
- // dump_file((const char *)VTMPDIR "s0bnd", (const char *)VTMPDIR "s0bnd.dump", ijCostSource());
- if(opt->runMode != RUN_ALL) {
- tf->serialize(resolvePath(opt->s0bnd));
- writeConfigFile(resolvePath(opt->config));
- //exit(0);
+ /* dimension of a tile: sets tileSizeRows and tileSizeCols based on a user defined
+ number of tiles */
+ initializeTileSize(&tileSizeRows, &tileSizeCols, opt->numtiles);
+ tsr = tileSizeRows;
+ tsc = tileSizeCols;
+ /* create a tileFactory structure that will know how to extract a
+ tile from a a grid and how to iterate on tiles. */
+ tf = new TileFactory(tileSizeRows, tileSizeCols, 0);
+ g.ntiles = tf->getNumTiles();
+ cout << "Original Grid Size: " << nrows << "x" << ncols << endl;
+ cout << "TF #Tiles: " << g.ntiles << endl; cout.flush();
+ /* read input cost grid and populate tf */
+ loadGrid(opt->cost_grid,opt->source_grid, &nodata_count, tf);
+ *stats <<"Total elements read=" << formatNumber(NULL, (long)nrows*ncols);
+ *stats <<", nodata elements=" << formatNumber(NULL, nodata_count) <<endl;
+ /* since we work internally with a padded grid, we need to add the
+ padded values to bndCost and intCost */
+ tf->pad();
+ if(opt->runMode != RUN_ALL) {
+ tf->serialize(resolvePath(opt->s0bnd));
+ writeConfigFile(resolvePath(opt->config));
- /* @S1 */
- if(opt->runMode & RUN_S1) {
- stats->comment("STEP 1");
- Rtimer rtStep;
- rt_start(rtStep);
- if(!(opt->runMode & RUN_S0)) {
- stats->comment("restoring data structures...");
- readConfigFile(resolvePath(opt->config));
- // if(debug) {
- // opt->s1fd = open(resolvePath(opt->s1in), O_RDONLY);
- // if(opt->s1fd < 0) {
- // perror(resolvePath(opt->s1in));
- // exit(1);
- // cerr << "debug: using fd " << opt->s1fd << " for file " << buf << endl;
- AMI_STREAM<ijCostSource> *dataStream;
- if(opt->s1fd > 0) {
-#ifdef PEARL
- dataStream = new AMI_STREAM<ijCostSource>(opt->s1fd, AMI_READ_STREAM);
-#else
- assert(0);
- dataStream = NULL;
-#endif
- } else {
- dataStream = new AMI_STREAM<ijCostSource>(resolvePath(opt->s0out),
- AMI_READ_STREAM);
- tf = new TileFactory(tsr, tsc, dataStream, resolvePath(opt->s0bnd));
- } // end exclusively-step1 init
- /* this sort is a permute to get the tiles in order.
- * in parallel version, we want to just split here;
- * we will get the sort for free within a tile.
- * (each tile is a separate file) -RW */
- if(! opt->tilesAreSorted) {
- tf->sortTF();
- if(opt->tilesAreSorted) { // maybe this sould be a different option...
- tf->markBoundaryAsSorted();
- Run Dijkstra on each tile and compute bnd2bnd SP; these will be
- stored in b2bstr; also, for each point on the bnd of the tile,
- compute SP to any source point in the tile; store this in s2bstr.
- // outputs
- b2bstr = new AMI_STREAM<distanceType>(resolvePath(opt->s1out),
- AMI_WRITE_STREAM);
- s2bstr = new AMI_STREAM<ijCost>(resolvePath(opt->s2bout),
+ /* @S1 */
+ if(opt->runMode & RUN_S1) {
+ stats->comment("STEP 1");
+ Rtimer rtStep;
+ rt_start(rtStep);
+ if(!(opt->runMode & RUN_S0)) {
+ //step 1 was not run: restore data from disk
+ stats->comment("restoring data structures...");
+ readConfigFile(resolvePath(opt->config));
+ AMI_STREAM<ijCostSource> *dataStream;
+ if(opt->s1fd > 0) {
+ assert(0);
+ //not sure what to do here; PEARL used to be
+ //defined. but s1fd seems to never be set. #ifdef
+ //PEARL dataStream = new
+ //AMI_STREAM<ijCostSource>(opt->s1fd,
+ //AMI_READ_STREAM); #else
+ dataStream = NULL;
+ //dataStream = new AMI_STREAM<ijCostSource>(opt->s1fd, AMI_READ_STREAM);
+ //#endif
} else {
- b2bstr = new AMI_STREAM<distanceType>();
- s2bstr = new AMI_STREAM<ijCost>();
+ dataStream = new AMI_STREAM<ijCostSource>(resolvePath(opt->s0out), AMI_READ_STREAM);
- tf->reset();
- assert(s2bstr);
- computeSubstituteGraph(tf, b2bstr, s2bstr);
-// if(debug) {
-// dump_file(b2bstr->name(), "/tmp/s1out.dump", distanceType());
-// dump_file(s2bstr->name(), "/tmp/s2bout.dump", ijCost());
- /* sort b2bstr by (<i,j>,<i,j>) */
-// if (!opt->step1) {
-// cout << "Sorting b2b stream" << endl;
-// stats->comment("Sorting b2bstr");
-// distanceCompareType srtFun;
-// sort(&b2bstr, srtFun);
- //printStream(b2bstr);
- //printStream(s2bstr);
- //if(opt->runMode == RUN_S1) {
- //exit(0);
- rt_stop(rtStep);
- stats->recordTime("STEP1", rtStep);
+ tf = new TileFactory(tsr, tsc, dataStream, resolvePath(opt->s0bnd));
+ } // end exclusively-step1 init
+ /* this sort is a permute to get the tiles in order. in
+ * parallel version, we want to just split here; we will get the
+ * sort for free within a tile. (each tile is a separate file)
+ * -RW */
+ if(! opt->tilesAreSorted) {
+ tf->sortTF();
+ if(opt->tilesAreSorted) { // maybe this sould be a different option...
+ tf->markBoundaryAsSorted();
+ /* Run Dijkstra on each tile and compute bnd2bnd SP; these will be
+ stored in b2bstr; also, for each point on the bnd of
+ the tile, compute SP to any source point in the tile;
+ store this in s2bstr.
+ // set up the output streams of Step2
+ b2bstr = new AMI_STREAM<distanceType>(resolvePath(opt->s1out),AMI_WRITE_STREAM);
+ s2bstr = new AMI_STREAM<ijCost>(resolvePath(opt->s2bout),AMI_WRITE_STREAM);
+ } else {
+ b2bstr = new AMI_STREAM<distanceType>();
+ s2bstr = new AMI_STREAM<ijCost>();
+ tf->reset();
+ assert(s2bstr && b2bstr);
+ computeSubstituteGraph(tf, b2bstr, s2bstr);
+ // if(debug) {
+ // dump_file(b2bstr->name(), "/tmp/s1out.dump", distanceType());
+ // dump_file(s2bstr->name(), "/tmp/s2bout.dump", ijCost());
+ //printStream(b2bstr);
+ //printStream(s2bstr);
+ //if(opt->runMode == RUN_S1) {
+ //exit(0);
+ rt_stop(rtStep);
+ stats->recordTime("STEP1", rtStep);
@@ -959,60 +927,38 @@
/* sort and rename */
/* in the parallel version, this could be just a merge of runs. */
cout << "Sorting b2b stream" << endl; cout.flush();
distanceIJCompareType srtFun;
- char *b2bstrname;
- b2bstr->name(&b2bstrname);
- if(opt->runMode == RUN_ALL) {
- sort(&b2bstr, srtFun);
- } else {
- AMI_STREAM<distanceType> *sortedStr;
- int deleteInput = 1;
- AMI_sort(b2bstr, &sortedStr, &srtFun, deleteInput, b2bstrname);
- b2bstr = sortedStr;
- b2bstr->seek(0);
- delete b2bstrname;
-#if 0
- char *b2bstrname_new;
- b2bstr->name(&b2bstrname_new);
- b2bstr->persist(PERSIST_PERSISTENT);
- delete b2bstr;
- if(rename(b2bstrname_new, b2bstrname) < 0) {
- cerr << "WARNING could not rename " << b2bstrname_new << " to " << b2bstrname << endl;
- perror("rename");
- cerr << "continue computation using s1out=" << b2bstrname_new << "." << endl;
- // how to free opt->s1out? leak it!
- opt->s1out = strdup(b2bstrname_new); // fix the name
- cerr << "continuing..." << endl;
- delete b2bstrname_new;
-#endif
+ char *b2bstrname;
+ b2bstr->name(&b2bstrname);
+ if(opt->runMode == RUN_ALL) {
+ sort(&b2bstr, srtFun);
+ } else {
+ AMI_STREAM<distanceType> *sortedStr;
+ int deleteInput = 1;
+ AMI_sort(b2bstr, &sortedStr, &srtFun, deleteInput, b2bstrname);
+ b2bstr = sortedStr;
+ b2bstr->seek(0);
+ delete b2bstrname;
rt_stop(rtStep);
stats->recordTime("STEP2", rtStep);
- BoundaryType<cost_type> *phase2Bnd = NULL;
- /* STEP 3 */
- /* step3 = old step2 (sans big sort) and old step3 */
+ BoundaryType<cost_type> *phase2Bnd = NULL;
+ /* STEP 3 */
+ /* step3 = old step2 (sans big sort) and old step3 */
if(opt->runMode & RUN_S3) {
stats->comment("STEP 3");
@@ -1215,16 +1161,17 @@
rt_stop(rtTotal);
stats->recordTime("Total running time", rtTotal);
stats->timestamp("end");
- cleanup:
- /* CLEAN up */
- cout << "cleaning up\n"; cout.flush();
- free(region);
- free(opt);
- delete stats;
- cout << "r.terracost done\n"; cout.flush();
- return 0;
+ /* CLEAN up */
+ free(region);
+ free(opt);
+ delete stats;
+ return 0;
Modified: grass-addons/raster/r.terracost/option.h
--- grass-addons/raster/r.terracost/option.h 2009-04-09 03:00:01 UTC (rev 36646)
+++ grass-addons/raster/r.terracost/option.h 2009-04-09 03:50:43 UTC (rev 36647)
@@ -44,9 +44,6 @@
int verbose; /* 1 if verbose, 0 otherwise */
int ascii; /* 1 if save output to ascii file */
- //int step0; /* 1 if step0 only, 0 otherwise */
- //int step1; /* 1 if step1 only, 0 otherwise */
- //int step2; /* 1 if step 2 and 3 only, 0 otherwise */
int runMode; /* which step(s) to run */
int numtiles; /* number of tiles in the grid */
Modified: grass-addons/raster/r.terracost/sortutils.h
--- grass-addons/raster/r.terracost/sortutils.h 2009-04-09 03:00:01 UTC (rev 36646)
+++ grass-addons/raster/r.terracost/sortutils.h 2009-04-09 03:50:43 UTC (rev 36647)
@@ -131,38 +131,38 @@
/* deletes input stream *str and replaces it by the sorted stream */
template<class T, class FUN>
void
-cachedSort(AMI_STREAM<T> **str, FUN fo) {
+ cachedSort(AMI_STREAM<T> **str, FUN fo) {
AMI_STREAM<T> *sortedStr;
char *unsortedName = strdup((*str)->name());
char sortedName[BUFSIZ];
sprintf(sortedName, "%s.sorted", unsortedName);
/* check if file exists */
struct stat sb;
if(stat(sortedName, &sb) == 0) {
- sortedStr = new AMI_STREAM<T>(sortedName, AMI_READ_STREAM);
- /* now see if stream is right length */
- if(sortedStr->stream_len() == (*str)->stream_len()) {
- fprintf(stderr, "Guessing that %s is sorted version of %s (skipping sort)\n",
- sortedName, unsortedName);
- *stats << "Guessing that " << sortedName
- << " is sorted version of " << unsortedName << " (skipping sort)\n";
- delete *str;
- *str = sortedStr;
- return;
+ /* if file exists */
+ sortedStr = new AMI_STREAM<T>(sortedName, AMI_READ_STREAM);
+ /* now see if stream is right length */
+ if(sortedStr->stream_len() == (*str)->stream_len()) {
+ fprintf(stderr, "Guessing that %s is sorted version of %s (skipping sort)\n",
+ sortedName, unsortedName);
+ *stats << "Guessing that " << sortedName
+ << " is sorted version of " << unsortedName << " (skipping sort)\n";
+ delete *str;
+ *str = sortedStr;
+ return;
/* not found; got to sort now */
int eraseInputStream = 1;
- AMI_sort(*str, &sortedStr, &fo, eraseInputStream, sortedName);
+ AMI_sort_withpath(*str, &sortedStr, &fo, eraseInputStream, sortedName);
sortedStr->persist(PERSIST_PERSISTENT); /* might leave streams lying around... */
- fprintf(stderr, "Saving %s as sorted version of %s\n",
+ fprintf(stderr, "Saving %s as sorted version of %s\n",sortedName, unsortedName);
sortedStr->seek(0);
*str = sortedStr;
free(unsortedName);
Modified: grass-addons/raster/r.terracost/tile.cc
--- grass-addons/raster/r.terracost/tile.cc 2009-04-09 03:00:01 UTC (rev 36646)
+++ grass-addons/raster/r.terracost/tile.cc 2009-04-09 03:50:43 UTC (rev 36647)
@@ -223,19 +223,24 @@
void
TileFactory::sortTF() {
- internalstr->seek(0); // is this required? RW
+ internalstr->seek(0); // is this necessary?
ijTileCostCompareType fun;
fun.setTileSize(tileSizeRows, tileSizeCols);
stats->comment("TileFactory: Sorting internalstr...");
-#if 0
- sort(&internalstr, fun);
-#else
- cachedSort(&internalstr, fun);
-#endif
+ //sort(&internalstr, fun);
+ //cachedSort(&internalstr, fun);
+ AMI_STREAM<ijCostSource> *sortedInternalstr;
+ AMI_sort(internalstr, &sortedInternalstr, &fun, 1);
+ sortedInternalstr->seek(0);
+ internalstr = sortedInternalstr;
//internalstr->seek(0); // is this required? RW
stats->comment("TileFactory: Sorting internalstr... done.");
void
TileFactory::insert(ijCostSource in) {
AMI_err ae;
