[GRASS-SVN] r36661 -
grass/branches/releasebranch_6_4/raster/simwe/r.sim.water
svn_grass at osgeo.org
Thu Apr 9 06:22:06 EDT 2009
Author: neteler
Date: 2009-04-09 06:22:06 -0400 (Thu, 09 Apr 2009)
New Revision: 36661
Added:
grass/branches/releasebranch_6_4/raster/simwe/r.sim.water/r_sim_water.png
grass/branches/releasebranch_6_4/raster/simwe/r.sim.water/description.html
example added
Modified: grass/branches/releasebranch_6_4/raster/simwe/r.sim.water/description.html
--- grass/branches/releasebranch_6_4/raster/simwe/r.sim.water/description.html 2009-04-09 10:21:56 UTC (rev 36660)
+++ grass/branches/releasebranch_6_4/raster/simwe/r.sim.water/description.html 2009-04-09 10:22:06 UTC (rev 36661)
@@ -48,7 +48,7 @@
through the structure (the values will be 0-1).
<p>
-Output includes a water depth raster map <i>depth</i> in [m], anda water discharge
+Output includes a water depth raster map <i>depth</i> in [m], and a water discharge
raster map <i>disch</i> in [m3/s]. Error of the numerical solution can be analyzed using
the <i>err</i> raster map (the resulting water depth is an average, and err is its RMSE).
The output vector points map <i>outwalk</i> can be used to analyze and visualize
@@ -122,6 +122,40 @@
are useful both for everyday exploratory work using a desktop computer and
for large, cutting-edge applications using high performance computing.
+<h2>EXAMPLE</h2>
+Spearfish region:
+<div class="code"><pre>
+g.region rast=elevation.10m -p
+r.slope.aspect elevation=elevation.10m elev_dx=elev_dx elev_dy=elev_dy
+# synthetic maps
+r.mapcalc "rain = if(elevation.10m, 5.0, null())"
+r.mapcalc "manning = if(elevation.10m, 0.05, null())"
+r.mapcalc "infilt = if(elevation.10m, 0.0, null())"
+# simulate
+r.sim.water elevin=elevation.10m elev_dxin=elev_dx elev_dyin=elev_dy \
+ rain=rain manin=manning infil=infilt \
+ nwalk=5000000 depth=depth
+# visualize
+r.shaded.relief elevation.10m
+d.mon x0
+d.font Vera
+d.rast.leg depth pos=85
+d.his i=elevation.10m.shade h=depth
+d.barscale at=4,92 bcolor=none tcolor=black -t
+</pre></div>
+<p>
+<center>
+<img src="r_sim_water.png" alt="r.sim.water generated depth map"><br>
+<i>Water depth map in the Spearfish (SD) area</i>
+</center>
<h2>ERROR MESSAGES</h2>
If the module fails with
Added: grass/branches/releasebranch_6_4/raster/simwe/r.sim.water/r_sim_water.png
(Binary files differ)
Property changes on: grass/branches/releasebranch_6_4/raster/simwe/r.sim.water/r_sim_water.png
___________________________________________________________________
+ image/png
