[GRASS-SVN] r36664 - grass/branches/releasebranch_6_4/imagery/i.atcorr
Thu Apr 9 09:22:23 EDT 2009
Author: neteler
Date: 2009-04-09 09:22:23 -0400 (Thu, 09 Apr 2009)
New Revision: 36664
   grass/branches/releasebranch_6_4/imagery/i.atcorr/main.cpp
write cmd line to history; const backported from 7.trunk
Modified: grass/branches/releasebranch_6_4/imagery/i.atcorr/main.cpp
--- grass/branches/releasebranch_6_4/imagery/i.atcorr/main.cpp	2009-04-09 13:21:54 UTC (rev 36663)
+++ grass/branches/releasebranch_6_4/imagery/i.atcorr/main.cpp	2009-04-09 13:22:23 UTC (rev 36664)
@@ -76,11 +76,11 @@
 int mis = 0;
 /* function prototypes */
-static void adjust_region (char *, char *);
+static void adjust_region (char *, const char *);
 static CELL round_c (FCELL);
 static void write_fp_to_cell (int, FCELL *);
 static void process_raster (int, InputMask, ScaleRange, int, int, int, bool, ScaleRange, bool);
-static void copy_colors (char *, char *, char *);
+static void copy_colors (char *, const char *, char *);
 static void define_module (void);
 static struct Options define_options (void);
 static void read_scale (Option *, ScaleRange &);
@@ -91,7 +91,7 @@
    Atmospheric corrections should be done on the whole
    satelite image, not just portions.
-static void adjust_region (char *name, char *mapset)
+static void adjust_region (char *name, const char *mapset)
     struct Cell_head iimg_head;	/* the input image header file */
@@ -406,7 +406,7 @@
 /* Copy the colors from map named iname to the map named oname */
-static void copy_colors (char *iname, char *imapset, char *oname)
+static void copy_colors (char *iname, const char *imapset, char *oname)
     struct Colors colors;
@@ -560,7 +560,8 @@
     int oimg_fd;	        /* output image's file descriptor */
     int ialt_fd = -1;       /* input elevation map's file descriptor */
     int ivis_fd = -1;       /* input visibility map's file descriptor */
-    char *iimg_mapset, *ialt_mapset, *iviz_mapset;
+    const char *iimg_mapset, *ialt_mapset, *iviz_mapset;
+    struct History hist;
     /* Define module */
     define_module();
@@ -632,11 +633,15 @@
     /* Close the input and output file descriptors */
+    G_short_history(opts.oimg->answer, "raster", &hist);
     G_close_cell(iimg_fd);
     if(opts.ialt->answer) G_close_cell(ialt_fd);
     if(opts.ivis->answer) G_close_cell(ivis_fd);
     G_close_cell(oimg_fd);
+    G_command_history(&hist);
+    G_write_history(opts.oimg->answer, &hist);
     /* Copy the colors of the input raster to the output raster.
        Scaling is ignored and color ranges might not be correct. */
     copy_colors(opts.iimg->answer, iimg_mapset, opts.oimg->answer);
