[GRASS-SVN] r36667 - grass/trunk/vector/v.in.dxf
svn_grass at osgeo.org
Fri Apr 10 04:04:58 EDT 2009
Author: hcho
Date: 2009-04-10 04:04:56 -0400 (Fri, 10 Apr 2009)
New Revision: 36667
grass/trunk/vector/v.in.dxf/add_3dface.c
grass/trunk/vector/v.in.dxf/add_arc.c
grass/trunk/vector/v.in.dxf/add_circle.c
grass/trunk/vector/v.in.dxf/add_line.c
grass/trunk/vector/v.in.dxf/add_lwpolyline.c
grass/trunk/vector/v.in.dxf/add_point.c
grass/trunk/vector/v.in.dxf/add_polyline.c
grass/trunk/vector/v.in.dxf/add_text.c
grass/trunk/vector/v.in.dxf/dxf_to_vect.c
grass/trunk/vector/v.in.dxf/global.h
grass/trunk/vector/v.in.dxf/layer_list.c
grass/trunk/vector/v.in.dxf/main.c
grass/trunk/vector/v.in.dxf/make_arc.c
grass/trunk/vector/v.in.dxf/v.in.dxf.html
grass/trunk/vector/v.in.dxf/write_vect.c
Added the "handle" column to store entity handles (Benjamin Ducke).
Lowercase entity type => Uppercase entity type
Modified: grass/trunk/vector/v.in.dxf/add_3dface.c
--- grass/trunk/vector/v.in.dxf/add_3dface.c 2009-04-10 02:35:24 UTC (rev 36666)
+++ grass/trunk/vector/v.in.dxf/add_3dface.c 2009-04-10 08:04:56 UTC (rev 36667)
@@ -2,10 +2,11 @@
#include <string.h>
#include "global.h"
-int add_3dface(struct dxf_file *dxf, struct Map_info *Map)
+void add_3dface(struct dxf_file *dxf, struct Map_info *Map)
int code;
- char layer[DXF_BUF_SIZE];
+ char handle[DXF_BUF_SIZE]; /* entity handle, 16 hexadecimal digits */
+ char layer[DXF_BUF_SIZE]; /* layer name */
int layer_flag = 0; /* indicates if a layer name has been found */
int dface_flag = 0; /* indicates if a edge is invisible */
int xflag = 0; /* indicates if a x value has been found */
@@ -13,30 +14,32 @@
int zflag = 0; /* indicates if a z value has been found */
int arr_size = 0;
+ handle[0] = 0;
strcpy(layer, UNIDENTIFIED_LAYER);
/* read in lines and process information until a 0 is read in */
while ((code = dxf_get_code(dxf)) != 0) {
if (code == -2)
- return -1;
+ return;
switch (code) {
+ case 5: /* entity handle */
+ strcpy(handle, dxf_buf);
+ break;
case 8: /* layer name */
if (!layer_flag && *dxf_buf) {
if (flag_list) {
- if (!is_layer_in_list(dxf_buf)) {
- add_layer_to_list(dxf_buf);
- print_layer(dxf_buf);
- return 0;
+ if (!is_layer_in_list(dxf_buf))
+ add_layer_to_list(dxf_buf, 1);
+ return;
- /* skip if layers != NULL && (
+ /* skip if (opt_layers != NULL && (
* (flag_invert == 0 && is_layer_in_list == 0) ||
* (flag_invert == 1 && is_layer_in_list == 1)
- if (layers && flag_invert == is_layer_in_list(dxf_buf))
- return 0;
+ if (opt_layers && flag_invert == is_layer_in_list(dxf_buf))
+ return;
strcpy(layer, dxf_buf);
layer_flag = 1;
@@ -116,8 +119,8 @@
if (xpnts[2] == xpnts[3] && ypnts[2] == ypnts[3] &&
zpnts[2] == zpnts[3])
arr_size--;
- write_face(Map, layer, arr_size);
+ write_vect(Map, layer, "3DFACE", handle, "", arr_size, GV_FACE);
- return 0;
+ return;
Modified: grass/trunk/vector/v.in.dxf/add_arc.c
--- grass/trunk/vector/v.in.dxf/add_arc.c 2009-04-10 02:35:24 UTC (rev 36666)
+++ grass/trunk/vector/v.in.dxf/add_arc.c 2009-04-10 08:04:56 UTC (rev 36667)
@@ -2,10 +2,11 @@
#include <string.h>
#include "global.h"
-int add_arc(struct dxf_file *dxf, struct Map_info *Map)
+void add_arc(struct dxf_file *dxf, struct Map_info *Map)
int code;
int yflag = 0; /* indicates if a y value has been found */
@@ -20,30 +21,32 @@
float finish_angle = 0; /* read in from dxf file */
int arr_size = 0;
+ handle[0] = 0;
if (code == -2)
- return -1;
+ return;
switch (code) {
+ break;
if (flag_list) {
- return 0;
+ return;
- return 0;
+ return;
layer_flag = 1;
@@ -78,8 +81,8 @@
arr_size =
make_arc(0, centerx, centery, radius, start_angle, finish_angle,
zcoor);
- write_line(Map, layer, arr_size);
+ write_vect(Map, layer, "ARC", handle, "", arr_size, GV_LINE);
- return 0;
+ return;
Modified: grass/trunk/vector/v.in.dxf/add_circle.c
--- grass/trunk/vector/v.in.dxf/add_circle.c 2009-04-10 02:35:24 UTC (rev 36666)
+++ grass/trunk/vector/v.in.dxf/add_circle.c 2009-04-10 08:04:56 UTC (rev 36667)
@@ -2,10 +2,11 @@
#include <string.h>
#include "global.h"
-int add_circle(struct dxf_file *dxf, struct Map_info *Map)
+void add_circle(struct dxf_file *dxf, struct Map_info *Map)
int code;
@@ -16,30 +17,32 @@
double zcoor = 0; /* read in from dxf file */
int arr_size = 0;
+ handle[0] = 0;
if (code == -2)
- return -1;
+ return;
switch (code) {
+ break;
if (flag_list) {
- return 0;
+ return;
- return 0;
+ return;
layer_flag = 1;
@@ -64,8 +67,8 @@
if (xflag && yflag && rflag) {
arr_size = make_arc(0, centerx, centery, radius, 0.0, 360.0, zcoor);
+ write_vect(Map, layer, "CIRCLE", handle, "", arr_size, GV_LINE);
- return 0;
+ return;
Modified: grass/trunk/vector/v.in.dxf/add_line.c
--- grass/trunk/vector/v.in.dxf/add_line.c 2009-04-10 02:35:24 UTC (rev 36666)
+++ grass/trunk/vector/v.in.dxf/add_line.c 2009-04-10 08:04:56 UTC (rev 36667)
@@ -2,40 +2,43 @@
#include <string.h>
#include "global.h"
-int add_line(struct dxf_file *dxf, struct Map_info *Map)
+void add_line(struct dxf_file *dxf, struct Map_info *Map)
int code;
int arr_size = 0;
+ handle[0] = 0;
if (code == -2)
- return -1;
+ return;
switch (code) {
+ break;
if (flag_list) {
- return 0;
+ return;
- return 0;
+ return;
layer_flag = 1;
@@ -76,7 +79,7 @@
if (arr_size == 2) /* have both start and stop */
+ write_vect(Map, layer, "LINE", handle, "", arr_size, GV_LINE);
- return 0;
+ return;
Modified: grass/trunk/vector/v.in.dxf/add_lwpolyline.c
--- grass/trunk/vector/v.in.dxf/add_lwpolyline.c 2009-04-10 02:35:24 UTC (rev 36666)
+++ grass/trunk/vector/v.in.dxf/add_lwpolyline.c 2009-04-10 08:04:56 UTC (rev 36667)
@@ -2,10 +2,11 @@
#include <string.h>
#include "global.h"
-int add_lwpolyline(struct dxf_file *dxf, struct Map_info *Map)
+void add_lwpolyline(struct dxf_file *dxf, struct Map_info *Map)
int code;
int polyline_flag = 0; /* indicates the type of polyline */
@@ -16,31 +17,33 @@
double bulge = 0.0; /* for arc curves */
double prev_bulge = 0.0; /* for arc curves */
+ handle[0] = 0;
zpnts[0] = 0.0;
if (code == -2)
- return -1;
+ return;
switch (code) {
+ break;
if (flag_list) {
- return 0;
+ return;
- return 0;
+ return;
layer_flag = 1;
@@ -88,11 +91,11 @@
zpnts[arr_size] = zpnts[0];
/* arr_size incremented to be consistent with polyline_flag != 1 */
- if (arr_size >= ARR_MAX - 1) {
- ARR_MAX += ARR_INCR;
- xpnts = (double *)G_realloc(xpnts, ARR_MAX * sizeof(double));
- ypnts = (double *)G_realloc(ypnts, ARR_MAX * sizeof(double));
- zpnts = (double *)G_realloc(zpnts, ARR_MAX * sizeof(double));
+ if (arr_size >= arr_max - 1) {
+ arr_max += ARR_INCR;
+ xpnts = (double *)G_realloc(xpnts, arr_max * sizeof(double));
+ ypnts = (double *)G_realloc(ypnts, arr_max * sizeof(double));
+ zpnts = (double *)G_realloc(zpnts, arr_max * sizeof(double));
arr_size++;
@@ -105,7 +108,7 @@
zpnts[i] = 0.0;
+ write_vect(Map, layer, "LWPOLYLINE", handle, "", arr_size, GV_LINE);
- return 0;
+ return;
Modified: grass/trunk/vector/v.in.dxf/add_point.c
--- grass/trunk/vector/v.in.dxf/add_point.c 2009-04-10 02:35:24 UTC (rev 36666)
+++ grass/trunk/vector/v.in.dxf/add_point.c 2009-04-10 08:04:56 UTC (rev 36667)
@@ -2,39 +2,42 @@
#include <string.h>
#include "global.h"
-int add_point(struct dxf_file *dxf, struct Map_info *Map)
+void add_point(struct dxf_file *dxf, struct Map_info *Map)
int code;
+ handle[0] = 0;
zpnts[0] = 0.0;
if (code == -2)
- return -1;
+ return;
switch (code) {
+ break;
if (flag_list) {
- return 0;
+ return;
- return 0;
+ return;
layer_flag = 1;
@@ -61,8 +64,8 @@
* ypnts[1] = ypnts[0];
* zpnts[1] = zpnts[0];
- write_point(Map, layer);
+ write_vect(Map, layer, "POINT", handle, "", 1, GV_POINT);
- return 0;
+ return;
Modified: grass/trunk/vector/v.in.dxf/add_polyline.c
--- grass/trunk/vector/v.in.dxf/add_polyline.c 2009-04-10 02:35:24 UTC (rev 36666)
+++ grass/trunk/vector/v.in.dxf/add_polyline.c 2009-04-10 08:04:56 UTC (rev 36667)
@@ -2,12 +2,13 @@
#include <string.h>
#include "global.h"
-static void write_pnts(struct Map_info *, char *, int, int, int);
+static void write_pnts(struct Map_info *, char *, char *, int, int, int);
-int add_polyline(struct dxf_file *dxf, struct Map_info *Map)
+void add_polyline(struct dxf_file *dxf, struct Map_info *Map)
int code;
int warn_flag66 = 1; /* indicates if error message printed once */
@@ -31,12 +32,13 @@
double *mesh_ypnts = NULL;
double *mesh_zpnts = NULL;
+ handle[0] = 0;
if (code == -2)
- return -1;
+ return;
switch (code) {
case 66: /* vertices follow flag */
@@ -79,7 +81,7 @@
/* loop until SEQEND in the dxf file */
while (strcmp(dxf_buf, "SEQEND") != 0) {
if (feof(dxf->fp)) /* EOF */
- return -1;
+ return;
if (strcmp(dxf_buf, "VERTEX") == 0) {
vertex_idx++;
@@ -88,27 +90,27 @@
zflag = 0;
if (code == -2) /* EOF */
- return -1;
+ return;
switch (code) {
+ break;
/* if no layer previously assigned */
if (flag_list) {
- return 0;
+ return;
- if (layers &&
- flag_invert == is_layer_in_list(dxf_buf))
- return 0;
+ return;
layer_flag = 1;
@@ -199,14 +201,10 @@
ypnts[arr_size] = ypnts[0];
arr_size++;
- if (flag_frame) {
- set_entity("POLYFACE FRAME");
- else {
- set_entity("POLYFACE");
+ if (flag_frame)
+ write_vect(Map, layer, "POLYFACE FRAME", handle, "", arr_size, GV_LINE);
+ else
+ write_vect(Map, layer, "POLYFACE", handle, "", arr_size, GV_FACE);
arr_size = 0;
mesh_pnts = 0;
@@ -236,13 +234,13 @@
G_free(mesh_zpnts);
else
- write_pnts(Map, layer, polyline_flag, zflag, arr_size);
+ write_pnts(Map, layer, handle, polyline_flag, zflag, arr_size);
- return 0;
+ return;
-static void write_pnts(struct Map_info *Map, char *layer, int polyline_flag,
- int zflag, int arr_size)
+static void write_pnts(struct Map_info *Map, char *layer, char *handle,
+ int polyline_flag, int zflag, int arr_size)
/* done reading vertices */
if (polyline_flag & 1) { /* only dealing with polyline_flag = 1 */
@@ -255,11 +253,11 @@
arr_size++;
@@ -272,7 +270,7 @@
zpnts[i] = 0.0;
+ write_vect(Map, layer, "POLYLINE", handle, "", arr_size, GV_LINE);
return;
Modified: grass/trunk/vector/v.in.dxf/add_text.c
--- grass/trunk/vector/v.in.dxf/add_text.c 2009-04-10 02:35:24 UTC (rev 36666)
+++ grass/trunk/vector/v.in.dxf/add_text.c 2009-04-10 08:04:56 UTC (rev 36667)
@@ -2,10 +2,11 @@
#include <string.h>
#include "global.h"
-int add_text(struct dxf_file *dxf, struct Map_info *Map)
+void add_text(struct dxf_file *dxf, struct Map_info *Map)
int code;
@@ -14,35 +15,37 @@
char label[DXF_BUF_SIZE]; /* read in from dxf file */
int label_len = 0;
+ handle[0] = 0;
zpnts[0] = 0.0;
if (code == -2)
- return -1;
+ return;
switch (code) {
case 1: /* label value */
label_len = strlen(dxf_buf);
strcpy(label, dxf_buf);
break;
+ break;
if (flag_list) {
- return 0;
+ return;
- return 0;
+ return;
layer_flag = 1;
@@ -78,7 +81,7 @@
if (label_len == 0)
- return -2;
+ return;
if (xflag && yflag) {
/* TODO */
@@ -110,10 +113,10 @@
ypnts[3] = ypnts[0] + (length * sin(theta));
zpnts[3] = zpnts[0];
- write_line(Map, layer, 5);
+ write_vect(Map, layer, "TEXT", handle, "", 5, GV_LINE);
#endif
- write_text(Map, layer, label);
+ write_vect(Map, layer, "TEXT", handle, label, 1, GV_POINT);
- return 0;
+ return;
Modified: grass/trunk/vector/v.in.dxf/dxf_to_vect.c
--- grass/trunk/vector/v.in.dxf/dxf_to_vect.c 2009-04-10 02:35:24 UTC (rev 36666)
+++ grass/trunk/vector/v.in.dxf/dxf_to_vect.c 2009-04-10 08:04:56 UTC (rev 36667)
@@ -12,6 +12,7 @@
static BOUND_BOX ext, dxf_ext;
+/* returns 1 on success, otherwise 0 */
int dxf_to_vect(struct dxf_file *dxf, struct Map_info *Map)
int code;
@@ -22,7 +23,7 @@
code = dxf_get_code(dxf);
while (code != 0) {
- return -1;
+ return 0;
/* only looking for header groups (code == 9) */
if (code != 9)
@@ -33,7 +34,7 @@
* or a 0 is read in */
while ((code = dxf_get_code(dxf)) != 9 && code != 0) {
- return -1;
+ return 0;
switch (code) {
case 10:
@@ -58,7 +59,7 @@
- return -1;
+ return 0;
switch (code) {
case 10:
@@ -80,7 +81,7 @@
else {
- return -1;
+ return 0;
@@ -91,20 +92,18 @@
else
- ARR_MAX = ARR_INCR;
+ arr_max = ARR_INCR;
ext.E = ext.N = ext.T = DBL_MIN;
ext.W = ext.S = ext.B = DBL_MAX;
- xpnts = (double *)G_malloc(ARR_MAX * sizeof(double));
- ypnts = (double *)G_malloc(ARR_MAX * sizeof(double));
- zpnts = (double *)G_malloc(ARR_MAX * sizeof(double));
+ xpnts = (double *)G_malloc(arr_max * sizeof(double));
+ ypnts = (double *)G_malloc(arr_max * sizeof(double));
+ zpnts = (double *)G_malloc(arr_max * sizeof(double));
if (!flag_list)
Points = Vect_new_line_struct();
while (!feof(dxf->fp)) {
- set_entity(dxf_buf);
/* avoid TEXT having object names: '0' should be followed by objects */
if (code != 0)
@@ -141,11 +140,14 @@
G_free(ypnts);
G_free(zpnts);
- if (!flag_list) {
- Vect_destroy_line_struct(Points);
- write_done(Map);
- if (found_layers)
- make_head(Map);
+ if (flag_list)
+ return 1;
+ Vect_destroy_line_struct(Points);
+ if (write_done(Map)) {
+ make_head(Map);
+ return 1;
return 0;
@@ -169,15 +171,6 @@
return 0;
-void set_entity(char *str)
- strcpy(entity, str);
- for (str = entity; *str; str++)
- *str = tolower(*str);
- return;
static void make_head(struct Map_info *Map)
char *organization;
Modified: grass/trunk/vector/v.in.dxf/global.h
--- grass/trunk/vector/v.in.dxf/global.h 2009-04-10 02:35:24 UTC (rev 36666)
+++ grass/trunk/vector/v.in.dxf/global.h 2009-04-10 08:04:56 UTC (rev 36667)
@@ -19,25 +19,28 @@
#define ARR_INCR 256
#define DXF_BUF_SIZE 256
-extern int flag_list, flag_extent, flag_table, flag_topo, flag_invert,
+#ifdef _MAIN_C_
+#define GLOBAL
+#else
+#define GLOBAL extern
+#endif
+GLOBAL int flag_list, flag_extent, flag_table, flag_topo, flag_invert,
flag_one_layer, flag_frame;
-extern int num_layers, found_layers;
-extern char **layers;
-extern char dxf_buf[DXF_BUF_SIZE], entity[DXF_BUF_SIZE];
-extern int ARR_MAX;
-extern double *xpnts, *ypnts, *zpnts;
-extern struct line_pnts *Points;
+GLOBAL char **opt_layers;
+GLOBAL char dxf_buf[DXF_BUF_SIZE];
+GLOBAL int arr_max;
+GLOBAL double *xpnts, *ypnts, *zpnts;
+GLOBAL struct line_pnts *Points;
/* dxf_to_vect.c */
int dxf_to_vect(struct dxf_file *, struct Map_info *);
int check_ext(double, double, double);
-void set_entity(char *);
/* layer_list.c */
-void add_layer_to_list(char *);
-int is_layer_in_list(char *);
+void add_layer_to_list(const char *, int);
+int is_layer_in_list(const char *);
void init_list(void);
-void print_layer(const char *);
/* read_dxf.c */
struct dxf_file *dxf_open(char *);
@@ -52,35 +55,31 @@
int make_arc_from_polyline(int, double, double);
/* add_point.c */
-int add_point(struct dxf_file *, struct Map_info *);
+void add_point(struct dxf_file *, struct Map_info *);
/* add_line.c */
-int add_line(struct dxf_file *, struct Map_info *);
+void add_line(struct dxf_file *, struct Map_info *);
/* add_lwpolyline.c */
-int add_lwpolyline(struct dxf_file *, struct Map_info *);
+void add_lwpolyline(struct dxf_file *, struct Map_info *);
/* add_polyline.c */
-int add_polyline(struct dxf_file *, struct Map_info *);
+void add_polyline(struct dxf_file *, struct Map_info *);
/* add_3dface.c */
-int add_3dface(struct dxf_file *, struct Map_info *);
+void add_3dface(struct dxf_file *, struct Map_info *);
/* add_arc.c */
-int add_arc(struct dxf_file *, struct Map_info *);
+void add_arc(struct dxf_file *, struct Map_info *);
/* add_circle.c */
-int add_circle(struct dxf_file *, struct Map_info *);
+void add_circle(struct dxf_file *, struct Map_info *);
/* add_text.c */
-int add_text(struct dxf_file *, struct Map_info *);
+void add_text(struct dxf_file *, struct Map_info *);
/* write_vect.c */
-#define write_point(a, b) write_vect(a, b, entity, "", 1, GV_POINT)
-#define write_line(a, b, c) write_vect(a, b, entity, "", c, GV_LINE)
-#define write_face(a, b, c) write_vect(a, b, entity, "", c, GV_FACE)
-#define write_text(a, b, c) write_vect(a, b, entity, c, 1, GV_POINT)
-void write_vect(struct Map_info *, char *, char *, char *, int, int);
-void write_done(struct Map_info *);
+void write_vect(struct Map_info *, char *, char *, char *, char *, int, int);
+int write_done(struct Map_info *);
#endif
Modified: grass/trunk/vector/v.in.dxf/layer_list.c
--- grass/trunk/vector/v.in.dxf/layer_list.c 2009-04-10 02:35:24 UTC (rev 36666)
+++ grass/trunk/vector/v.in.dxf/layer_list.c 2009-04-10 08:04:56 UTC (rev 36667)
@@ -1,33 +1,36 @@
#include <string.h>
#include "global.h"
-void add_layer_to_list(char *layer)
- /* capital column names are a pain in SQL */
- G_str_to_lower(layer);
+static int num_layers = 0;
+static char **layers = NULL;
+void add_layer_to_list(const char *layer, int print)
if (is_layer_in_list(layer))
return;
layers = (char **)G_realloc(layers, (num_layers + 2) * sizeof(char *));
- layers[num_layers++] = G_store(layer);
+ layers[num_layers] = G_store(layer);
+ G_str_to_lower(layers[num_layers]);
+ if (print) {
+ fprintf(stdout, _("Layer %d: %s\n"), num_layers+1, layers[num_layers]);
+ fflush(stdout);
+ num_layers++;
layers[num_layers] = NULL;
return;
-int is_layer_in_list(char *layer)
+int is_layer_in_list(const char *layer)
char **p;
if (!layers)
return 0;
p = layers;
- while (*p && strcmp(layer, *p) != 0)
+ while (*p && G_strcasecmp(layer, *p) != 0)
p++;
return *p != NULL;
@@ -51,12 +54,3 @@
return;
-void print_layer(const char *layer_name)
- fprintf(stdout, _("Layer %d: %s\n"), num_layers,
- layer_name);
- fflush(stdout);
- return;
Modified: grass/trunk/vector/v.in.dxf/main.c
--- grass/trunk/vector/v.in.dxf/main.c 2009-04-10 02:35:24 UTC (rev 36666)
+++ grass/trunk/vector/v.in.dxf/main.c 2009-04-10 08:04:56 UTC (rev 36667)
@@ -15,34 +15,30 @@
* Rewrite for GRASS 6:
* Huidae Cho <grass4u gmail.com>
+ * Enhancements:
+ * Benjamin Ducke <benjamin.ducke at oadigital.net>
* PURPOSE: Import DXF file
- * COPYRIGHT: (C) 1999-2006 by the GRASS Development Team
+ * COPYRIGHT: (C) 1999-2009 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
* for details.
+#define _MAIN_C_
#include <stdlib.h>
#include <grass/gis.h>
#include <grass/glocale.h>
#include "global.h"
-int flag_list, flag_extent, flag_table, flag_topo, flag_invert,
- flag_one_layer, flag_frame;
-int num_layers, found_layers;
-char **layers;
-char dxf_buf[DXF_BUF_SIZE], entity[DXF_BUF_SIZE];
-int ARR_MAX;
-double *xpnts, *ypnts, *zpnts;
-struct line_pnts *Points;
int main(int argc, char *argv[])
struct dxf_file *dxf;
struct Map_info *Map;
- char *output = NULL;
+ char *output;
+ int ret;
struct GModule *module;
struct
@@ -112,7 +108,7 @@
opt.layers->type = TYPE_STRING;
opt.layers->required = NO;
opt.layers->multiple = YES;
- opt.layers->description = _("List of layers to import");
+ opt.layers->description = _("List of layers to import (default: all)");
opt.layers->guisection = _("DXF layers");
if (G_parser(argc, argv))
@@ -124,22 +120,27 @@
flag_invert = flag.invert->answer;
flag_one_layer = flag.one_layer->answer;
flag_frame = flag.frame->answer;
+ opt_layers = opt.layers->answers;
+ if (flag_invert && !opt_layers)
+ G_fatal_error(_("Please specify list of layers to exclude"));
/* open DXF file */
if (!(dxf = dxf_open(opt.input->answer)))
G_fatal_error(_("Unable to open DXF file <%s>"), opt.input->answer);
- if (flag_list) {
- num_layers = 0;
- layers = NULL;
- Map = NULL;
+ if (flag_list)
G_verbose_message(_("Layer number: layer name / GRASS compliant name"));
else {
- output = G_store(opt.output->answer);
+ int i;
- layers = opt.layers->answers;
+ if (opt_layers){
+ for(i=0; opt_layers[i]; i++)
+ add_layer_to_list(opt_layers[i], 0);
+ output = opt.output->answer;
/* create vector map */
Map = (struct Map_info *)G_malloc(sizeof(struct Map_info));
if (Vect_open_new(Map, output, 1) < 0)
@@ -151,7 +152,7 @@
/* import */
- dxf_to_vect(dxf, Map);
+ ret = dxf_to_vect(dxf, Map);
dxf_close(dxf);
@@ -160,7 +161,7 @@
else {
Vect_close(Map);
- if (found_layers) {
+ if (ret) {
if (Vect_open_old(Map, output, G_mapset())) {
if (!flag_topo)
if (!Vect_build(Map))
@@ -173,7 +174,6 @@
G_fatal_error(_("Failed to import DXF file!"));
- G_free(output);
G_free(Map);
Modified: grass/trunk/vector/v.in.dxf/make_arc.c
--- grass/trunk/vector/v.in.dxf/make_arc.c 2009-04-10 02:35:24 UTC (rev 36666)
+++ grass/trunk/vector/v.in.dxf/make_arc.c 2009-04-10 08:04:56 UTC (rev 36667)
@@ -32,11 +32,11 @@
ypnts[arr_size] = radius * sin(alpha) + centery;
zpnts[arr_size] = zcoor;
theta -= RSTEP;
- if (arr_size == ARR_MAX) {
+ if (arr_size == arr_max) {
arr_size++;
@@ -49,11 +49,11 @@
theta += RSTEP;
arr_size++;
@@ -63,11 +63,11 @@
xpnts[arr_size] = radius * cos(alpha) + centerx;
arr_size++;
@@ -88,11 +88,11 @@
arc_tan = (-1.0) * prev_bulge;
if (arc_tan == 0.0) { /* straight line segment */
arr_size++;
@@ -161,11 +161,11 @@
arc_arr_size = make_arc(arr_size, cent_x, cent_y,
rad, ang1, ang2, zpnts[0]);
arr_size += arc_arr_size;
- while (arr_size >= ARR_MAX) {
+ while (arr_size >= arr_max) {
} /* arc */
Modified: grass/trunk/vector/v.in.dxf/v.in.dxf.html
--- grass/trunk/vector/v.in.dxf/v.in.dxf.html 2009-04-10 02:35:24 UTC (rev 36666)
+++ grass/trunk/vector/v.in.dxf/v.in.dxf.html 2009-04-10 08:04:56 UTC (rev 36667)
@@ -1,6 +1,7 @@
<h2>DESCRIPTION</h2>
-Standard DXF is imported. The following graphical objects are supported:
+Converts DXF format CAD files to GRASS vector format. The following graphical
+objects (DXF entities) are supported:
<ul>
<li>GRASS point type:</li>
@@ -23,13 +24,25 @@
</ul></li>
</ul>
-Capital column names are changed to lowercase characters as for easier
-SQL usage (lowercase column names avoid the need to quote them if the
-attribute table is stored in a SQL DBMS such as PostgreSQL).
+Table and column names are changed to lowercase characters for easier SQL usage
+(lowercase table/column names avoid the need to quote them if the attribute
+table is stored in a SQL DBMS such as PostgreSQL).<p>
+The "layer" column will contain the name(s) of the DXF input layer(s). The DXF
+entity type string will be stored in the "entity" column as uppercase.<p>
+The "handle" column can be used to store small bits of data associated with any
+entity in the DXF file (i.e., entity handle or unique object identifiers in the
+layer). The entity handle is a "text string of up to 16 hexadecimal digits",
+which is a 64-bit integer (currently not supported by GRASS database drivers).
+For text type entities, the text value will be stored in the "label" column of
+the GRASS vector output map. Neither the "handle" nor "label" column is
+mandatory.
<H2>REFERENCES</H2>
-<a href="http://en.wikipedia.org/wiki/AutoCAD_DXF">AutoCad DXF</a> (from Wikipedia, the free encyclopedia)
+<a href="http://en.wikipedia.org/wiki/AutoCAD_DXF">AutoCad DXF</a> (from Wikipedia, the free encyclopedia)<br>
+<a href="http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=12272454&linkID=10809853">DXF References</a> (Autodesk-supplied documentation)
<H2>SEE ALSO</H2>
@@ -43,6 +56,7 @@
Revised by Dave Gerdes, 12/1989<BR>
US Army Construction Engineering Research Lab
<P>
-Updated for GRASS 6 and 3D support. Huidae Cho, 3/2006
+Updated for GRASS 6 and 3D support. Huidae Cho, 3/2006<BR>
+With minor additions by Benjamin Ducke (Oxford Archaeology), 4/2009
<P><I>Last changed: $Date$</I>
Modified: grass/trunk/vector/v.in.dxf/write_vect.c
--- grass/trunk/vector/v.in.dxf/write_vect.c 2009-04-10 02:35:24 UTC (rev 36666)
+++ grass/trunk/vector/v.in.dxf/write_vect.c 2009-04-10 08:04:56 UTC (rev 36667)
@@ -11,8 +11,8 @@
static dbString sql, str;
static char buf[1000];
-void write_vect(struct Map_info *Map, char *layer, char *entity, char *label,
- int arr_size, int type)
+void write_vect(struct Map_info *Map, char *layer, char *entity, char *handle,
+ char *label, int arr_size, int type)
struct line_cats *Cats;
int i, field, cat;
@@ -30,6 +30,7 @@
sprintf(buf, "insert into %s (%s"
", layer"
", entity"
+ ", handle"
", label" ") values (%d, '", Fi[i]->table, Fi[i]->key, cat);
if (layer) {
@@ -46,6 +47,17 @@
strcat(buf, "', '");
+ if (handle) {
+ if (strlen(handle) > 16) {
+ G_warning(_("Entity handle truncated to 16 characters."));
+ handle[16] = 0;
+ db_set_string(&str, handle);
+ db_double_quote_string(&str);
+ strcat(buf, db_get_string(&str));
+ strcat(buf, "', '");
if (label) {
db_set_string(&str, label);
@@ -71,13 +83,13 @@
return;
-void write_done(struct Map_info *Map)
+int write_done(struct Map_info *Map)
int i;
- if (!(found_layers = (num_fields > 0))) {
+ if (!num_fields) {
G_warning(_("No DXF layers found!"));
- return;
+ return 0;
if (!flag_table) {
@@ -116,7 +128,7 @@
driver = NULL;
- return;
+ return 1;
static int get_field_cat(struct Map_info *Map, char *layer, int *field,
@@ -211,6 +223,7 @@
sprintf(buf, "create table %s (cat integer"
", layer varchar(%d)"
", entity varchar(%d)"
+ ", handle varchar(16)"
", label varchar(%d)"
")", Fi[i]->table, DXF_BUF_SIZE, DXF_BUF_SIZE, DXF_BUF_SIZE);
db_set_string(&sql, buf);
