[GRASS-SVN] r36670 - grass/branches/develbranch_6/vector/v.out.ogr
svn_grass at osgeo.org
Fri Apr 10 08:15:22 EDT 2009
Author: neteler
Date: 2009-04-10 08:15:22 -0400 (Fri, 10 Apr 2009)
New Revision: 36670
grass/branches/develbranch_6/vector/v.out.ogr/main.c
warn if islands are found and -c missing
Modified: grass/branches/develbranch_6/vector/v.out.ogr/main.c
--- grass/branches/develbranch_6/vector/v.out.ogr/main.c 2009-04-10 12:13:05 UTC (rev 36669)
+++ grass/branches/develbranch_6/vector/v.out.ogr/main.c 2009-04-10 12:15:22 UTC (rev 36670)
@@ -214,6 +214,9 @@
Vect_set_open_level(2);
Vect_open_old(&In, in_opt->answer, mapset);
+ if (Vect_get_num_islands(&In) > 0 && !cat_flag->answer)
+ G_warning(_("The map contains islands. To preserve them in the output map, use the -c flag"));
/* fetch PROJ info */
G_get_default_window(&cellhd);
if (cellhd.proj == PROJECTION_XY)
