[GRASS-SVN] r36675 - grass-addons/raster/r.terracost
svn_grass at osgeo.org
Fri Apr 10 19:50:56 EDT 2009
Author: ltoma
Date: 2009-04-10 19:50:56 -0400 (Fri, 10 Apr 2009)
New Revision: 36675
grass-addons/raster/r.terracost/main.cc
fixed the ami_sort error
Modified: grass-addons/raster/r.terracost/main.cc
--- grass-addons/raster/r.terracost/main.cc 2009-04-10 17:02:27 UTC (rev 36674)
+++ grass-addons/raster/r.terracost/main.cc 2009-04-10 23:50:56 UTC (rev 36675)
@@ -61,7 +61,7 @@
#define S0OUT "tileStr"
#define S0OUT_ANS "terracost.tileStr"
-#define S0BND "bndStr"
+q#define S0BND "bndStr"
#define S0BND_ANS "terracost.bndStr"
#define S1OUT "bspStr"
#define S1OUT_ANS "terracost.bspStr"
@@ -136,13 +136,14 @@
vtmpdir->type = TYPE_STRING;
vtmpdir->required = NO;
char vtmpdirbuf[BUFSIZ];
+ /* the default answer is /var/tmp/userid */
struct passwd *pw; /* TODO: is this really needed? */
if((pw = getpwuid(getuid())) != NULL) {
sprintf(vtmpdirbuf, "/var/tmp/%s", pw->pw_name);
} else {
sprintf(vtmpdirbuf, "/var/tmp/%d", getuid());
- vtmpdir->answer = strdup(vtmpdirbuf); // leak
+ vtmpdir->answer = strdup(vtmpdirbuf);
vtmpdir->description= _("Location of intermediate STREAMs");
struct Flag *help_f;
@@ -218,14 +219,6 @@
s0out->description= _("Stream name stem for step 0 output");
s0out->answer = S0OUT_ANS;
-// struct Option *s1in;
-// s1in = G_define_option() ;
-// s1in->key = "s1in";
-// s1in->type = TYPE_STRING;
-// s1in->required = NO;
-// s1in->description= _("Stream name stem for step 0 output");
-// s1in->answer = "s1in";
struct Option *s0bnd;
s0bnd = G_define_option() ;
s0bnd->key = S0BND;
@@ -294,6 +287,7 @@
exit (EXIT_FAILURE);
+ /* all user parameters are collected in a global opt */
assert(opt);
opt->cost_grid = input_cost->answer;
opt->out_grid = output_cost->answer;
@@ -304,7 +298,7 @@
opt->verbose= (!quiet->answer);
opt->ascii = ascii->answer;
opt->stats= stats_opt->answer;
- opt->runMode = RUN_NONE;
+ opt->runMode = RUN_NONE;
if(step0->answer) {
opt->runMode |= RUN_S0;
@@ -327,7 +321,6 @@
opt->tilesAreSorted = (tilesAreSorted->answer[0] == 'y');
opt->numtiles = atoi(numtiles->answer);
opt->s0out = s0out->answer;
- // opt->s1in = s1in->answer;
opt->s1out = s1out->answer;
opt->s0bnd = s0bnd->answer;
opt->s2bout = s2bout->answer;
@@ -365,19 +358,20 @@
+/* record current configuration to stats file */
void record_args(int argc, char **argv) {
+ /* record time stamp */
time_t t = time(NULL);
char buf[1000];
if(t == (time_t)-1) {
perror("time");
exit(1);
ctime_r(&t, buf);
buf[24] = '\0';
stats->timestamp(buf);
- *stats << "Not printing stats." << endl;
+ //*stats << "Not printing stats." << endl;
*stats << "Command Line: " << endl;
for(int i=0; i<argc; i++) {
*stats << argv[i] << " ";
@@ -391,7 +385,8 @@
if (opt->runMode & RUN_S1) *stats << " Step2";
if (opt->runMode & RUN_S2) *stats << " Step3";
if (opt->runMode & RUN_S3) *stats << " Step4";
- *stats << "\n";
+ *stats << "\n";
+ /* record memory size */
size_t mm_size = opt->mem << 20; /* (in bytes) */
char tmp[100];
formatNumber(tmp, mm_size);
@@ -406,7 +401,7 @@
statsRecorder *offsetWriter = new statsRecorder("offset.out");
AMI_err ae;
- // won't work with boundary streams
+ // this assert won't work with boundary streams
//assert(testStr->stream_len() == nrows*ncols);
ae = testStr->seek(0);
ijCost *it;
@@ -419,48 +414,50 @@
//assert(ae == AMI_ERROR_NO_ERROR);
testStr->seek(0);
delete offsetWriter;
+/* this function computes and returns the optimal tizesize */
void
compute_tilesize(const char *label, int nr, int nc, int mem,
- int *tilesize, int *numtiles) {
+ int *tilesize, int *numtiles) {
- // assume we need tilesize number of all these, that is, we need all
- // of these to be in memory while we compute sssp on a tile
+ // we need all the data below to be in memory while we compute sssp
+ // on a tile
int elt = ( sizeof(costSourceType) /* tile */
- + sizeof(cost_type) /* dist */
- + sizeof(costStructure) ); /* pq */
+ + sizeof(cost_type) /* dist */
+ + sizeof(costStructure) ); /* pq */
printf("%s: avail memory M = %s\n", label, formatNumber(NULL, mem));
+ printf("%s: grid size N = %s elements\n", label, formatNumber(NULL, nr*nc));
printf("%s: sizeof elt = %d\n", label, elt);
- printf("%s: grid size N = %s elements\n", label, formatNumber(NULL, nr*nc));
- int ts = mem / elt;
+ int ts = mem / elt;
int nt = (nr * nc + ts - 1) / ts;
printf("%s: max tilesize R = %s elements\n",label, formatNumber(NULL, ts));
//does it fit into memory?
if (nt == 1) {
- printf("%s: fits in memory, use numtiles=1\n", label);
+ printf("%s: fits in memory, use numtiles=1\n", label);
} else {
- if (nt <4) {
- printf("%s: almost.. fits in memory; try numtiles=1 first\n", label);
- } else {
- printf("%s: does NOT fits in memory\n", label);
- //optimal tilisize, determined experimentally, is approx. 15,000
- //elements
- ts = 15000;
- nt = nr*nc/ts;
+ if (nt <4) {
+ printf("%s: almost.. fits in memory; try numtiles=1 first\n", label);
+ } else {
+ printf("%s: does NOT fits in memory\n", label);
+ //optimal tilisize, determined experimentally, is approx. 15,000
+ //elements
+ ts = 15000;
+ nt = nr*nc/ts;
printf("%s: %s N=%ld elements, M=%d bytes, optimal numtiles=%d\n",
- label, G_location(), (long)(nr*nc), mem, nt);
+ label, G_location(), (long)(nr*nc), mem, nt);
*numtiles = nt;
*tilesize = ts;
@@ -471,6 +468,7 @@
int
main(int argc, char *argv[]) {
struct GModule *module;
char buf[1000];
@@ -484,13 +482,13 @@
region = (struct Cell_head*)malloc(sizeof(struct Cell_head));
assert(region);
if (G_get_set_window(region) == -1) {
- G_fatal_error("r.terracost: error getting current region");
+ G_fatal_error("r.terracost: error getting current region");
int nr = G_window_rows();
int nc = G_window_cols();
if ((nr > dimension_type_max) || (nc > dimension_type_max)) {
- printf("[nrows=%d, ncols=%d] dimension_type overflow--change dimension_type and recompile\n",nr,nc);
- G_fatal_error("[nrows=%d, ncols=%d] dimension_type overflow--change dimension_type and recompile\n",nr,nc);
+ printf("[nrows=%d, ncols=%d] dimension_type overflow--change dimension_type and recompile\n",nr,nc);
+ G_fatal_error("[nrows=%d, ncols=%d] dimension_type overflow--change dimension_type and recompile\n",nr,nc);
} else {
nrows = (dimension_type)nr;
ncols = (dimension_type)nc;
@@ -498,7 +496,7 @@
ncolsPad = (dimension_type)nc;
- /* read user options; fill in global <opt> */
+ /* read user options; fill in global variable opt */
opt = (userOptions*)malloc(sizeof(userOptions));
assert(opt);
parse_args(argc, argv);
@@ -506,7 +504,7 @@
/* setup STREAM_DIR */
sprintf(buf, "%s=%s", STREAM_TMPDIR, opt->streamdir);
- if(getenv(STREAM_TMPDIR) == NULL) {
+ if(getenv(STREAM_TMPDIR) == NULL) {
printf("setenv %s\n", buf);
if (putenv(buf) != 0) {
printf("cannot setenv %s\n",buf);
@@ -527,6 +525,7 @@
/* setup VTMPDIR */
sprintf(buf, "%s=%s", VTMPDIR, opt->vtmpdir);
if (getenv(VTMPDIR) == NULL) {
+ /* if not already set */
if(putenv(buf) !=0) {
@@ -556,7 +555,7 @@
+ /* if info mode, print tileseze and exit */
if(info) {
printf("\n");
printf("STREAM_TMPDIR=%s\n", getenv(STREAM_TMPDIR));
@@ -564,10 +563,11 @@
int tilesize, numtiles;
compute_tilesize("TILESIZE", nrows, ncols, opt->mem << 20,
- &tilesize, &numtiles);
+ &tilesize, &numtiles);
return 0;
}//info
if(opt->verbose) {
printf("region size is %d x %d\n", nrows, ncols);
@@ -645,7 +645,10 @@
4*opt->EW_fac*opt->EW_fac));
update_init(opt->EW_fac, opt->NS_fac, opt->DIAG_fac);
- /* start timing -- after parse_args, which are interactive */
+ /* start timing */
Rtimer rtTotal;
rt_start(rtTotal);
@@ -659,13 +662,15 @@
char memBuf [100] = "";
formatNumber(memBuf, availmem1);
long nodata_count;
+ //*stats << "numtiles = " << opt->numtiles << endl;
// we don't really know yet, since we might read it from config...
- //*stats << "numtiles = " << opt->numtiles << endl;
//size_t mem = memForNormalDijkstra(nrows, ncols);
if (opt->numtiles == 1) {
- cout << "Using normal Dijkstra" << endl;
+ printf("Using normal Dijkstra");
stats->comment("Using normal Dijkstra");
normalDijkstra(opt->cost_grid,opt->source_grid, &nodata_count);
@@ -680,10 +685,11 @@
- //this is executed if numtiles>1
+ //this is executed if numtiles>1: STEP 0, 1, 2, 3, 4
- /* STEP: set up tile size, padded grid size and load cost grid and
+ /* STEP 0: set up tile size, padded grid size and load cost grid and
compute substitute graph */
TileFactory *tf=NULL;
@@ -713,7 +719,7 @@
tfmem = availmem1 / 4;
bndmem = availmem1 / 4;
- //if(!opt->step1 && !opt->step2) {
if(opt->runMode & RUN_S0) {
stats->comment("----------------------------------------");
stats->comment("STEP 0: COMPUTE SUBSTITUTE GRAPH");
@@ -728,12 +734,12 @@
- a PQ for source 2 bnd Dijkstra in a tile
- a tile<costType>
- - are we forgetting anything??check!!
+ - are we forgetting anything?
- /* dimension of a tile: sets tileSizeRows and tileSizeCols based on a user defined
- number of tiles */
+ /* dimension of a tile: sets tileSizeRows and tileSizeCols based
+ on a user defined number of tiles */
initializeTileSize(&tileSizeRows, &tileSizeCols, opt->numtiles);
tsr = tileSizeRows;
tsc = tileSizeCols;
@@ -742,8 +748,8 @@
tile from a a grid and how to iterate on tiles. */
tf = new TileFactory(tileSizeRows, tileSizeCols, 0);
g.ntiles = tf->getNumTiles();
- cout << "Original Grid Size: " << nrows << "x" << ncols << endl;
- cout << "TF #Tiles: " << g.ntiles << endl; cout.flush();
+ printf("Original Grid Size: (%d, %d)\n", nrows, ncols);
+ printf("TF #Tiles: %d\n", g.ntiles); cout.flush();
@@ -764,8 +770,7 @@
- /* @S1 */
+ /* STEP 1 */
if(opt->runMode & RUN_S1) {
stats->comment("STEP 1");
@@ -846,67 +851,63 @@
/* @S2 STEP 2: compute for each boundary point, the SP to any
source. These will be stored in phase2Bnd.
memory in step 2 is used to store:
- a boundaryClass dstr that stores SP to all bnd vertices
- the PQ
- an array that stores whether a point has been settled or not
- are we forgetting anything??check !!!
- /* step2 = old step2a - just the big sort */
- if(opt->runMode & RUN_S2) {
- stats->comment("----------------------------------------");
- stats->comment("STEP 2");
- Rtimer rtStep;
- rt_start(rtStep);
- if(!(opt->runMode & RUN_S1)) {
- stats->comment("restoring data structures...");
- readConfigFile(resolvePath(opt->config));
- // tileSizeRows = tsr;
- // tileSizeCols = tsc;
- b2bstr = new AMI_STREAM<distanceType>(resolvePath(opt->s1out));
- b2bstr->persist(PERSIST_PERSISTENT);
- //cout << "b2bLen: " << b2bstr->stream_len() << endl;cout.flush();
- stats->recordLength("b2bstr ", b2bstr);
- /* sort and rename */
+ if(opt->runMode & RUN_S2) {
+ stats->comment("----------------------------------------");
+ stats->comment("STEP 2");
+ Rtimer rtStep;
+ rt_start(rtStep);
+ if(!(opt->runMode & RUN_S1)) {
+ stats->comment("restoring data structures...");
+ readConfigFile(resolvePath(opt->config));
+ // tileSizeRows = tsr;
+ // tileSizeCols = tsc;
- /* in the parallel version, this could be just a merge of runs. */
- cout << "Sorting b2b stream" << endl; cout.flush();
- stats->comment("Sorting b2bstr");
- distanceIJCompareType srtFun;
- char *b2bstrname;
- b2bstr->name(&b2bstrname);
- if(opt->runMode == RUN_ALL) {
- sort(&b2bstr, srtFun);
- } else {
- AMI_STREAM<distanceType> *sortedStr;
- int deleteInput = 1;
- AMI_sort(b2bstr, &sortedStr, &srtFun, deleteInput, b2bstrname);
- b2bstr = sortedStr;
- b2bstr->seek(0);
- delete b2bstrname;
- rt_stop(rtStep);
- stats->recordTime("STEP2", rtStep);
+ b2bstr = new AMI_STREAM<distanceType>(resolvePath(opt->s1out));
+ b2bstr->persist(PERSIST_PERSISTENT);
+ //cout << "b2bLen: " << b2bstr->stream_len() << endl;cout.flush();
+ stats->recordLength("b2bstr ", b2bstr);
+ /* sort and rename */
+ /* in the parallel version, this could be just a merge of runs. */
+ cout << "Sorting b2b stream" << endl; cout.flush();
+ stats->comment("Sorting b2bstr");
+ distanceIJCompareType srtFun;
+ char *b2bstrname;
+ b2bstr->name(&b2bstrname);
- BoundaryType<cost_type> *phase2Bnd = NULL;
+ if(opt->runMode == RUN_ALL) {
+ sort(&b2bstr, srtFun);
+ } else {
+ AMI_STREAM<distanceType> *sortedStr;
+ int deleteInput = 1;
+ //AMI_sort(b2bstr, &sortedStr, &srtFun, deleteInput, b2bstrname);
+ AMI_sort(b2bstr, &sortedStr, &srtFun, deleteInput);
+ b2bstr = sortedStr;
+ b2bstr->seek(0);
+ delete b2bstrname;
+ rt_stop(rtStep);
+ stats->recordTime("STEP2", rtStep);
+ BoundaryType<cost_type> *phase2Bnd = NULL;
- /* STEP 3 */
- /* step3 = old step2 (sans big sort) and old step3 */
+ /* STEP 3 */
+ /* step3 = old step2 (sans big sort) and old step3 */
if(opt->runMode & RUN_S3) {
stats->comment("STEP 3");
@@ -1029,8 +1030,7 @@
tileSizeCols = tsc;
AMI_STREAM<ijCostSource> *dataStream;
- dataStream = new AMI_STREAM<ijCostSource>(resolvePath(opt->s0out),
- AMI_READ_STREAM);
+ dataStream = new AMI_STREAM<ijCostSource>(resolvePath(opt->s0out), AMI_READ_STREAM);
tf = new TileFactory(tsr, tsc, dataStream, resolvePath(opt->s0bnd));
if(! opt->tilesAreSorted) {
