[GRASS-SVN] r36678 -
grass/branches/releasebranch_6_4/vector/v.in.dxf
svn_grass at osgeo.org
Sat Apr 11 02:55:00 EDT 2009
Author: neteler
Date: 2009-04-11 02:54:59 -0400 (Sat, 11 Apr 2009)
New Revision: 36678
grass/branches/releasebranch_6_4/vector/v.in.dxf/add_line.c
grass/branches/releasebranch_6_4/vector/v.in.dxf/write_vect.c
huidae: backported import fixes
Modified: grass/branches/releasebranch_6_4/vector/v.in.dxf/add_line.c
--- grass/branches/releasebranch_6_4/vector/v.in.dxf/add_line.c 2009-04-11 06:18:02 UTC (rev 36677)
+++ grass/branches/releasebranch_6_4/vector/v.in.dxf/add_line.c 2009-04-11 06:54:59 UTC (rev 36678)
@@ -76,11 +76,8 @@
- if (arr_size == 2) { /* have both start and stop */
- if (!zflag)
- zpnts[0] = zpnts[1] = 0.0;
+ if (arr_size == 2) /* have both start and stop */
write_line(Map, layer, arr_size);
return 0;
Modified: grass/branches/releasebranch_6_4/vector/v.in.dxf/write_vect.c
--- grass/branches/releasebranch_6_4/vector/v.in.dxf/write_vect.c 2009-04-11 06:18:02 UTC (rev 36677)
+++ grass/branches/releasebranch_6_4/vector/v.in.dxf/write_vect.c 2009-04-11 06:54:59 UTC (rev 36678)
@@ -118,13 +118,24 @@
return;
-static int get_field_cat(struct Map_info *Map, char *field_name, int *field,
+static int get_field_cat(struct Map_info *Map, char *layer, int *field,
int *cat)
int i, type;
+ char field_name[DXF_BUF_SIZE];
+ char x = 0;
- /* make table name SQL compliant */
+ /* make table name SQL compliant: Vect_default_field_info returns
+ * mapname_layername in ->table, and mapname is always SQL compliant.
+ * Because layername is followed by mapname_, it (field_name here) can
+ * start with [a-zA-Z0-9]. No need to change the first digit to 'x'.
+ strcpy(field_name, layer);
+ if (field_name[0] >= '0' && field_name[0] <= '9')
+ x = field_name[0];
G_str_to_sql(field_name);
+ if (x)
+ field_name[0] = x;
for (i = 0; i < num_fields; i++) {
/* field name already exists */
