[GRASS-SVN] r36690 - grass/trunk/display/d.grid
Sat Apr 11 21:15:12 EDT 2009
Author: hcho
Date: 2009-04-11 21:15:12 -0400 (Sat, 11 Apr 2009)
New Revision: 36690
   grass/trunk/display/d.grid/fiducial.c
   grass/trunk/display/d.grid/main.c
Fixed text placement.
Added -a flag to align the origin to the upper-right corner of the current region.
size=0 sets grid size to the north-south resolution of the current region.
"g.region rast=dem; d.grid size=0 -a" will draw grids that align with dem cells.
Modified: grass/trunk/display/d.grid/fiducial.c
--- grass/trunk/display/d.grid/fiducial.c	2009-04-12 01:01:54 UTC (rev 36689)
+++ grass/trunk/display/d.grid/fiducial.c	2009-04-12 01:15:12 UTC (rev 36690)
@@ -25,13 +25,9 @@
     SYMBOL *Symb;
     RGBA_Color *line_color, *fill_color;
     int R, G, B;
-    int x0, y0;
     int size = 16;
     int tolerance = 0;
-    x0 = (int)(D_u_to_d_col(easting) + 0.5);
-    y0 = (int)(D_u_to_d_row(northing) + 0.5);
     line_color = G_malloc(sizeof(RGBA_Color));
     fill_color = G_malloc(sizeof(RGBA_Color));
@@ -52,7 +48,7 @@
 	G_fatal_error(_("Reading symbol"));
     S_stroke(Symb, size, rotation, tolerance);
-    D_symbol(Symb, x0, y0, line_color, fill_color);
+    D_symbol(Symb, easting, northing, line_color, fill_color);
     G_free(line_color);
     G_free(fill_color);
Modified: grass/trunk/display/d.grid/main.c
--- grass/trunk/display/d.grid/main.c	2009-04-12 01:01:54 UTC (rev 36689)
+++ grass/trunk/display/d.grid/main.c	2009-04-12 01:15:12 UTC (rev 36690)
@@ -40,9 +40,10 @@
     struct GModule *module;
     struct Option *opt1, *opt2, *opt3, *opt4, *fsize, *tcolor;
     struct Flag *noborder, *notext, *geogrid, *nogrid, *wgs84, *cross,
-	*fiducial;
+	*fiducial, *align;
     struct pj_info info_in;	/* Proj structures */
     struct pj_info info_out;	/* Proj structures */
+    struct Cell_head wind;
     /* Initialize the GIS calls */
     G_gisinit(argv[0]);
@@ -58,7 +59,7 @@
     opt2->key_desc = "value";
     opt2->type = TYPE_STRING;
     opt2->required = YES;
-    opt2->label = _("Size of grid to be drawn");
+    opt2->label = _("Size of grid to be drawn (0: north-south resolution of the current region)");
     opt2->description = _("In map units or DDD:MM:SS format. "
 			  "Example: \"1000\" or \"0:10\"");
@@ -94,6 +95,10 @@
     fsize->options = "1-72";
     fsize->description = _("Font size for gridline coordinate labels");
+    align = G_define_flag();
+    align->key = 'a';
+    align->description = _("Align the origin to the east-north vertex of the current region");
     geogrid = G_define_flag();
     geogrid->key = 'g';
     geogrid->description =
@@ -157,28 +162,43 @@
     if (fiducial->answer)
 	mark_type = MARK_FIDUCIAL;
-    /* get grid size */
-    if (geogrid->answer) {
-	if (!G_scan_resolution(opt2->answer, &gsize, PROJECTION_LL) ||
-	    gsize <= 0.0)
-	    G_fatal_error(_("Invalid geo-grid size <%s>"), opt2->answer);
-    else {
-	if (!G_scan_resolution(opt2->answer, &size, G_projection()) ||
-	    size <= 0.0)
-	    G_fatal_error(_("Invalid grid size <%s>"), opt2->answer);
+    if (align->answer || strcmp(opt2->answer, "0") == 0)
+	G__get_window(&wind, "", "WIND", G_mapset());
-    /* get grid easting start */
-    if (!G_scan_easting(opt3->answers[0], &east, G_projection())) {
-	G_usage();
-	G_fatal_error(_("Illegal east coordinate <%s>"), opt3->answers[0]);
+    if (strcmp(opt2->answer, "0") == 0) {
+	if (geogrid->answer)
+	    gsize = wind.ns_res;
+	else
+	    size = wind.ns_res;
+    } else {
+        /* get grid size */
+        if (geogrid->answer) {
+	    if (!G_scan_resolution(opt2->answer, &gsize, PROJECTION_LL) ||
+    	        gsize <= 0.0)
+    	        G_fatal_error(_("Invalid geo-grid size <%s>"), opt2->answer);
+        else {
+    	    if (!G_scan_resolution(opt2->answer, &size, G_projection()) ||
+    	        size <= 0.0)
+    	        G_fatal_error(_("Invalid grid size <%s>"), opt2->answer);
-    /* get grid northing start */
-    if (!G_scan_northing(opt3->answers[1], &north, G_projection())) {
-	G_usage();
-	G_fatal_error(_("Illegal north coordinate <%s>"), opt3->answers[1]);
+    if (align->answer) {
+	east = wind.east;
+	north = wind.north;
+    } else {
+        /* get grid easting start */
+        if (!G_scan_easting(opt3->answers[0], &east, G_projection())) {
+    	    G_usage();
+    	    G_fatal_error(_("Illegal east coordinate <%s>"), opt3->answers[0]);
+        /* get grid northing start */
+        if (!G_scan_northing(opt3->answers[1], &north, G_projection())) {
+    	    G_usage();
+    	    G_fatal_error(_("Illegal north coordinate <%s>"), opt3->answers[1]);
     /* Setup driver and check important information */
