[GRASS-SVN] r36703 - in grass/trunk: . mswindows
mswindows/Installer-Files mswindows/osgeo4w
svn_grass at osgeo.org
Sun Apr 12 09:39:28 EDT 2009
Author: neteler
Date: 2009-04-12 09:39:28 -0400 (Sun, 12 Apr 2009)
New Revision: 36703
Added:
grass/trunk/mswindows/
grass/trunk/mswindows/GRASS-Installer.nsi
grass/trunk/mswindows/GRASS-Packager.bat
grass/trunk/mswindows/Installer-Files/
grass/trunk/mswindows/Installer-Files/GRASS-WebSite.url
grass/trunk/mswindows/Installer-Files/GRASS.ico
grass/trunk/mswindows/Installer-Files/GRASS_CMD.ico
grass/trunk/mswindows/Installer-Files/GRASS_Web.ico
grass/trunk/mswindows/Installer-Files/InstallHeaderImage.bmp
grass/trunk/mswindows/Installer-Files/Install_GRASS.ico
grass/trunk/mswindows/Installer-Files/MSYS_Custom_Icon.ico
grass/trunk/mswindows/Installer-Files/UnInstallHeaderImage.bmp
grass/trunk/mswindows/Installer-Files/UnWelcomeFinishPage.bmp
grass/trunk/mswindows/Installer-Files/Uninstall_GRASS.ico
grass/trunk/mswindows/Installer-Files/WelcomeFinishPage.bmp
grass/trunk/mswindows/Installer-Files/WinGRASS-README.url
grass/trunk/mswindows/Installer-Files/WinGRASS.ico
grass/trunk/mswindows/README.html
grass/trunk/mswindows/osgeo4w/
grass/trunk/mswindows/osgeo4w/package.cmd
grass/trunk/mswindows/osgeo4w/package.sh
added native winGRASS builder from 6.5; Colin Nielsen <colin nielsen gmail.com>: native winGRASS packager update
Added: grass/trunk/mswindows/GRASS-Installer.nsi
--- grass/trunk/mswindows/GRASS-Installer.nsi (rev 0)
+++ grass/trunk/mswindows/GRASS-Installer.nsi 2009-04-12 13:39:28 UTC (rev 36703)
@@ -0,0 +1,857 @@
+;GRASS Installer for Windows
+;Written by Marco Pasetti
+;Updated for OSGeo4W by Colin Nielsen
+;Last Update: 30 March 2009
+;Mail to: grass-dev at lists.osgeo.org
+;Define the source path of the demolocation files
+!define DEMOLOCATION_PATH "c:\osgeo4w\usr\src\grass-7.0.svn\demolocation"
+;Select if you are building a "Development Version" or a "Release Version" of the GRASS Installer
+;Change the INSTALLER_TYPE variable to Release, Dev6 or Dev7
+!define INSTALLER_TYPE "Dev7"
+;Version variables
+!define RELEASE_VERSION_NUMBER "6.4.0RC4"
+!define RELEASE_SVN_REVISION "36599"
+!define RELEASE_BINARY_REVISION "1"
+!define RELEASE_GRASS_COMMAND "grass64"
+!define RELEASE_GRASS_BASE "GRASS"
+!define DEV6_VERSION_NUMBER "6-SVN"
+!define DEV6_SVN_REVISION "36599"
+!define DEV6_BINARY_REVISION "1"
+!define DEV6_GRASS_COMMAND "grass65"
+!define DEV6_GRASS_BASE "GRASS-6-SVN"
+!define DEV7_VERSION_NUMBER "7-SVN"
+!define DEV7_SVN_REVISION ""
+!define DEV7_BINARY_REVISION "1"
+!define DEV7_GRASS_COMMAND "grass7"
+!define DEV7_GRASS_BASE"GRASS-7-SVN"
+;Don't modify the following lines
+;NSIS Includes
+!include "MUI2.nsh"
+!include "LogicLib.nsh"
+;Set the installer variables, depending on the selected version to build
+!if ${INSTALLER_TYPE} == "Release"
+ !define VERSION_NUMBER "${RELEASE_VERSION_NUMBER}"
+ !define SVN_REVISION "${RELEASE_SVN_REVISION}"
+ !define BINARY_REVISION "${RELEASE_BINARY_REVISION}"
+ !define GRASS_COMMAND "${RELEASE_GRASS_COMMAND}"
+ !define GRASS_BASE "${RELEASE_GRASS_BASE}"
+ !define INSTALLER_NAME "WinGRASS-${VERSION_NUMBER}-${BINARY_REVISION}-Setup.exe"
+ !define DISPLAYED_NAME "GRASS ${VERSION_NUMBER}-${BINARY_REVISION}"
+ !define CHECK_INSTALL_NAME "GRASS"
+ !define PACKAGE_FOLDER ".\GRASS-Release-Package"
+!else if ${INSTALLER_TYPE} == "Dev6"
+ !define VERSION_NUMBER "${DEV6_VERSION_NUMBER}"
+ !define SVN_REVISION "${DEV6_SVN_REVISION}"
+ !define BINARY_REVISION "${DEV6_BINARY_REVISION}"
+ !define GRASS_COMMAND "${DEV6_GRASS_COMMAND}"
+ !define GRASS_BASE "${DEV6_GRASS_BASE}"
+ !define INSTALLER_NAME "WinGRASS-${VERSION_NUMBER}-r${SVN_REVISION}-${BINARY_REVISION}-Setup.exe"
+ !define DISPLAYED_NAME "GRASS ${VERSION_NUMBER}-r${SVN_REVISION}-${BINARY_REVISION}"
+ !define CHECK_INSTALL_NAME "GRASS 6 SVN"
+ !define PACKAGE_FOLDER ".\GRASS-6-Dev-Package"
+!else if ${INSTALLER_TYPE} == "Dev7"
+ !define VERSION_NUMBER "${DV7_VERSION_NUMBER}"
+ !define SVN_REVISION "${DV7_SVN_REVISION}"
+ !define BINARY_REVISION "${DV7_BINARY_REVISION}"
+ !define GRASS_COMMAND "${DEV7_GRASS_COMMAND}"
+ !define GRASS_BASE "${DEV7_GRASS_BASE}"
+ !define CHECK_INSTALL_NAME "GRASS 7 SVN"
+ !define PACKAGE_FOLDER ".\GRASS-7-Dev-Package"
+!endif
+;Publisher variables
+!define PUBLISHER "GRASS Development Team"
+!define WEB_SITE "http://grass.osgeo.org/"
+!define WIKI_PAGE "http://grass.osgeo.org/wiki/Main_Page"
+;General Definitions
+;Name of the application shown during install
+Name "${DISPLAYED_NAME}"
+;Name of the output file (installer executable)
+OutFile "${INSTALLER_NAME}"
+;Define installation folder
+InstallDir "C:\${GRASS_BASE}"
+;Request application privileges for Windows Vista
+RequestExecutionLevel user
+;Tell the installer to show Install and Uninstall details as default
+ShowInstDetails show
+ShowUnInstDetails show
+;StrReplace Function
+;Replaces all ocurrences of a given needle within a haystack with another string
+;Written by dandaman32
+Var STR_REPLACE_VAR_0
+Var STR_REPLACE_VAR_1
+Var STR_REPLACE_VAR_2
+Var STR_REPLACE_VAR_3
+Var STR_REPLACE_VAR_4
+Var STR_REPLACE_VAR_5
+Var STR_REPLACE_VAR_6
+Var STR_REPLACE_VAR_7
+Var STR_REPLACE_VAR_8
+Function StrReplace
+ Exch $STR_REPLACE_VAR_2
+ Exch 1
+ Exch $STR_REPLACE_VAR_1
+ Exch 2
+ Exch $STR_REPLACE_VAR_0
+ StrCpy $STR_REPLACE_VAR_3 -1
+ StrLen $STR_REPLACE_VAR_4 $STR_REPLACE_VAR_1
+ StrLen $STR_REPLACE_VAR_6 $STR_REPLACE_VAR_0
+ loop:
+ IntOp $STR_REPLACE_VAR_3 $STR_REPLACE_VAR_3 + 1
+ StrCpy $STR_REPLACE_VAR_5 $STR_REPLACE_VAR_0 $STR_REPLACE_VAR_4 $STR_REPLACE_VAR_3
+ StrCmp $STR_REPLACE_VAR_5 $STR_REPLACE_VAR_1 found
+ StrCmp $STR_REPLACE_VAR_3 $STR_REPLACE_VAR_6 done
+ Goto loop
+ found:
+ StrCpy $STR_REPLACE_VAR_5 $STR_REPLACE_VAR_0 $STR_REPLACE_VAR_3
+ IntOp $STR_REPLACE_VAR_8 $STR_REPLACE_VAR_3 + $STR_REPLACE_VAR_4
+ StrCpy $STR_REPLACE_VAR_7 $STR_REPLACE_VAR_0 "" $STR_REPLACE_VAR_8
+ StrCpy $STR_REPLACE_VAR_0 $STR_REPLACE_VAR_5$STR_REPLACE_VAR_2$STR_REPLACE_VAR_7
+ Goto loop
+ done:
+ Pop $STR_REPLACE_VAR_1 ; Prevent "invalid opcode" errors and keep the
+ Pop $STR_REPLACE_VAR_1 ; stack as it was before the function was called
+FunctionEnd
+!macro _strReplaceConstructor OUT NEEDLE NEEDLE2 HAYSTACK
+ Push "${HAYSTACK}"
+ Push "${NEEDLE}"
+ Push "${NEEDLE2}"
+ Call StrReplace
+ Pop "${OUT}"
+!macroend
+!define StrReplace '!insertmacro "_strReplaceConstructor"'
+;.onInit Function (called when the installer is nearly finished initializing)
+;Check if GRASS is already installed on the system and, if yes, what version and binary release;
+;depending on that, select the install procedure:
+;1. first installation = if GRASS is not already installed
+;install GRASS asking for the install PATH
+;2. upgrade installation = if an older release of GRASS is already installed
+;call the uninstaller of the currently installed GRASS release
+;if the uninstall procedure succeeded, call the current installer without asking for the install PATH
+;GRASS will be installed in the same PATH of the previous installation
+;3. downgrade installation = if a newer release of GRASS is already installed
+;4. repair installation = if the same release of GRASS is already installed
+;if the uninstall procedure succeeded, call the current installer asking for the install PATH
+;the currently installed release of GRASS is defined by the variable $INSTALLED_VERSION = $INSTALLED_SVN_REVISION + $INSTALLED_BINARY_REVISION
+Function .onInit
+ Var /GLOBAL ASK_FOR_PATH
+ StrCpy $ASK_FOR_PATH "YES"
+ Var /GLOBAL UNINSTALL_STRING
+ Var /GLOBAL INSTALL_PATH
+ Var /GLOBAL INSTALLED_VERSION_NUMBER
+ Var /GLOBAL INSTALLED_SVN_REVISION
+ Var /GLOBAL INSTALLED_BINARY_REVISION
+ Var /GLOBAL DISPLAYED_INSTALLED_VERSION
+ Var /GLOBAL MESSAGE_0_
+ Var /GLOBAL MESSAGE_1_
+ Var /GLOBAL MESSAGE_2_
+ Var /GLOBAL MESSAGE_3_
+ ReadRegStr $UNINSTALL_STRING HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "UninstallString"
+ ReadRegStr $INSTALL_PATH HKLM "Software\${GRASS_BASE}" "InstallPath"
+ ReadRegStr $INSTALLED_VERSION_NUMBER HKLM "Software\${GRASS_BASE}" "VersionNumber"
+ ReadRegStr $INSTALLED_SVN_REVISION HKLM "Software\${GRASS_BASE}" "SvnRevision"
+ ${If} $INSTALLED_SVN_REVISION == ""
+ ReadRegStr $INSTALLED_SVN_REVISION HKLM "Software\${GRASS_BASE}" "Revision"
+ ${EndIf}
+ ReadRegStr $INSTALLED_BINARY_REVISION HKLM "Software\${GRASS_BASE}" "BinaryRevision"
+ StrCpy $MESSAGE_0_ "${CHECK_INSTALL_NAME} is already installed on your system.$\r$\n"
+ StrCpy $MESSAGE_0_ "$MESSAGE_0_$\r$\n"
+ !if ${INSTALLER_TYPE} == "Release"
+ ${If} $INSTALLED_BINARY_REVISION == ""
+ StrCpy $DISPLAYED_INSTALLED_VERSION "$INSTALLED_VERSION_NUMBER"
+ ${Else}
+ StrCpy $DISPLAYED_INSTALLED_VERSION "$INSTALLED_VERSION_NUMBER-$INSTALLED_BINARY_REVISION"
+ ${EndIf}
+ !else
+ StrCpy $DISPLAYED_INSTALLED_VERSION "$INSTALLED_VERSION_NUMBER-$INSTALLED_SVN_REVISION-$INSTALLED_BINARY_REVISION"
+ !endif
+ StrCpy $MESSAGE_0_ "$MESSAGE_0_The installed release is $DISPLAYED_INSTALLED_VERSION$\r$\n"
+ StrCpy $MESSAGE_1_ "$MESSAGE_0_$\r$\n"
+ StrCpy $MESSAGE_1_ "$MESSAGE_1_You are going to install a newer release of ${CHECK_INSTALL_NAME}$\r$\n"
+ StrCpy $MESSAGE_1_ "$MESSAGE_1_$\r$\n"
+ StrCpy $MESSAGE_1_ "$MESSAGE_1_Press OK to uninstall GRASS $DISPLAYED_INSTALLED_VERSION"
+ StrCpy $MESSAGE_1_ "$MESSAGE_1_ and install ${DISPLAYED_NAME} or Cancel to quit."
+ StrCpy $MESSAGE_2_ "$MESSAGE_0_$\r$\n"
+ StrCpy $MESSAGE_2_ "$MESSAGE_2_You are going to install an older release of ${CHECK_INSTALL_NAME}$\r$\n"
+ StrCpy $MESSAGE_2_ "$MESSAGE_2_$\r$\n"
+ StrCpy $MESSAGE_2_ "$MESSAGE_2_Press OK to uninstall GRASS $DISPLAYED_INSTALLED_VERSION"
+ StrCpy $MESSAGE_2_ "$MESSAGE_2_ and install ${DISPLAYED_NAME} or Cancel to quit."
+ StrCpy $MESSAGE_3_ "$MESSAGE_0_$\r$\n"
+ StrCpy $MESSAGE_3_ "$MESSAGE_3_This is the latest release available.$\r$\n"
+ StrCpy $MESSAGE_3_ "$MESSAGE_3_$\r$\n"
+ StrCpy $MESSAGE_3_ "$MESSAGE_3_Press OK to reinstall ${DISPLAYED_NAME} or Cancel to quit."
+ IntOp $INSTALLED_SVN_REVISION $INSTALLED_SVN_REVISION * 1
+ IntOp $INSTALLED_BINARY_REVISION $INSTALLED_BINARY_REVISION * 1
+ IntOp $INSTALLED_VERSION $INSTALLED_SVN_REVISION + $INSTALLED_BINARY_REVISION
+ !define /math VERSION ${SVN_REVISION} + ${BINARY_REVISION}
+ ${If} $INSTALLED_VERSION_NUMBER == ""
+ ${Else}
+ ${If} $INSTALLED_VERSION < ${VERSION}
+ MessageBox MB_OKCANCEL "$MESSAGE_1_" IDOK upgrade IDCANCEL quit_upgrade
+ upgrade:
+ StrCpy $ASK_FOR_PATH "NO"
+ ExecWait '"$UNINSTALL_STRING" _?=$INSTALL_PATH' $0
+ Goto continue_upgrade
+ quit_upgrade:
+ Abort
+ continue_upgrade:
+ ${ElseIf} $INSTALLED_VERSION > ${VERSION}
+ MessageBox MB_OKCANCEL "$MESSAGE_2_" IDOK downgrade IDCANCEL quit_downgrade
+ downgrade:
+ Goto continue_downgrade
+ quit_downgrade:
+ Abort
+ continue_downgrade:
+ ${ElseIf} $INSTALLED_VERSION = ${VERSION}
+ MessageBox MB_OKCANCEL "$MESSAGE_3_" IDOK reinstall IDCANCEL quit_reinstall
+ reinstall:
+ Goto continue_reinstall
+ quit_reinstall:
+ Abort
+ continue_reinstall:
+ ${EndIf}
+ ${EndIf}
+ ${Else}
+ ${If} $0 = 0
+ ${Else}
+ Abort
+ ${EndIf}
+ ${EndIf}
+FunctionEnd
+;CheckUpdate Function
+;Check if to show the MUI_PAGE_DIRECTORY during the installation (to ask for the install PATH)
+Function CheckUpdate
+ ${If} $ASK_FOR_PATH == "NO"
+ Abort
+ ${EndIf}
+FunctionEnd
+;CheckInstDir Function
+;Check if GRASS is going to be installed in a directory containing spaces
+;if yes, show a warning message
+Function CheckInstDir
+ Var /GLOBAL INSTDIR_TEST
+ Var /GLOBAL INSTDIR_LENGHT
+ Var /GLOBAL INSTDIR_TEST_LENGHT
+ Var /GLOBAL MESSAGE_CHKINST_
+ StrCpy $MESSAGE_CHKINST_ "WARNING: you are about to install GRASS into a directory that has spaces$\r$\n"
+ StrCpy $MESSAGE_CHKINST_ "$MESSAGE_CHKINST_in either its name or the path of directories leading up to it.$\r$\n"
+ StrCpy $MESSAGE_CHKINST_ "$MESSAGE_CHKINST_Some functionalities of GRASS might be hampered by this. We would highly$\r$\n"
+ StrCpy $MESSAGE_CHKINST_ "$MESSAGE_CHKINST_appreciate if you tried and reported any problems, so that we can fix them.$\r$\n"
+ StrCpy $MESSAGE_CHKINST_ "$MESSAGE_CHKINST_However, if you want to avoid any such issues, we recommend that you$\r$\n"
+ StrCpy $MESSAGE_CHKINST_ "$MESSAGE_CHKINST_choose a simple installation path without spaces, such as: C:\${GRASS_BASE}.$\r$\n"
+ ${StrReplace} "$INSTDIR_TEST" " " "" "$INSTDIR"
+ StrLen $INSTDIR_LENGHT "$INSTDIR"
+ StrLen $INSTDIR_TEST_LENGHT "$INSTDIR_TEST"
+ ${If} $INSTDIR_TEST_LENGHT < $INSTDIR_LENGHT
+ MessageBox MB_OK|MB_ICONEXCLAMATION "$MESSAGE_CHKINST_"
+ ${EndIf}
+FunctionEnd
+;Interface Settings
+!define MUI_ABORTWARNING
+!define MUI_ICON ".\Installer-Files\Install_GRASS.ico"
+!define MUI_UNICON ".\Installer-Files\Uninstall_GRASS.ico"
+!define MUI_HEADERIMAGE_BITMAP_NOSTETCH ".\Installer-Files\InstallHeaderImage.bmp"
+!define MUI_HEADERIMAGE_UNBITMAP_NOSTRETCH ".\Installer-Files\UnInstallHeaderImage.bmp"
+!define MUI_WELCOMEFINISHPAGE_BITMAP ".\Installer-Files\WelcomeFinishPage.bmp"
+!define MUI_UNWELCOMEFINISHPAGE_BITMAP ".\Installer-Files\UnWelcomeFinishPage.bmp"
+;Installer Pages
+!insertmacro MUI_PAGE_WELCOME
+!insertmacro MUI_PAGE_LICENSE "${PACKAGE_FOLDER}\GPL.TXT"
+!define MUI_PAGE_CUSTOMFUNCTION_PRE CheckUpdate
+!insertmacro MUI_PAGE_DIRECTORY
+Page custom CheckInstDir
+!insertmacro MUI_PAGE_COMPONENTS
+!insertmacro MUI_PAGE_INSTFILES
+!insertmacro MUI_PAGE_FINISH
+!insertmacro MUI_UNPAGE_WELCOME
+!insertmacro MUI_UNPAGE_CONFIRM
+!insertmacro MUI_UNPAGE_INSTFILES
+!insertmacro MUI_UNPAGE_FINISH
+;Language files
+!insertmacro MUI_LANGUAGE "English"
+;Installer Sections
+;Declares the variables for optional Sample Data Sections
+Var /GLOBAL HTTP_PATH
+Var /GLOBAL ARCHIVE_NAME
+Var /GLOBAL EXTENDED_ARCHIVE_NAME
+Var /GLOBAL ORIGINAL_UNTAR_FOLDER
+Var /GLOBAL CUSTOM_UNTAR_FOLDER
+Var /GLOBAL ARCHIVE_SIZE_KB
+Var /GLOBAL ARCHIVE_SIZE_MB
+Var /GLOBAL DOWNLOAD_MESSAGE_
+Section "GRASS" SecGRASS
+ SectionIn RO
+ ;Set the INSTALL_DIR variable
+ Var /GLOBAL INSTALL_DIR
+ StrCpy $INSTALL_DIR "$INSTALL_PATH"
+ ${Else}
+ StrCpy $INSTALL_DIR "$INSTDIR"
+ ${EndIf}
+ ;Set to try to overwrite existing files
+ SetOverwrite try
+ ;Set the GIS_DATABASE directory
+ SetShellVarContext current
+ Var /GLOBAL GIS_DATABASE
+ StrCpy $GIS_DATABASE "$DOCUMENTS\GIS DataBase"
+ ;Create the GIS_DATABASE directory
+ CreateDirectory "$GIS_DATABASE"
+ ;add Installer files
+ SetOutPath "$INSTALL_DIR\icons"
+ File .\Installer-Files\GRASS.ico
+ File .\Installer-Files\GRASS_Web.ico
+ File .\Installer-Files\GRASS_CMD.ico
+ File .\Installer-Files\MSYS_Custom_Icon.ico
+ File .\Installer-Files\WinGRASS.ico
+ SetOutPath "$INSTALL_DIR"
+ File .\Installer-Files\GRASS-WebSite.url
+ File .\Installer-Files\WinGRASS-README.url
+ ;add GRASS files
+ File /r ${PACKAGE_FOLDER}\*.*
+ ;Install demolocation into the GIS_DATABASE directory
+ SetOutPath "$GIS_DATABASE\demolocation"
+ File /r ${DEMOLOCATION_PATH}\*.*
+ ;Create the Uninstaller
+ WriteUninstaller "$INSTALL_DIR\Uninstall-GRASS.exe"
+ ;Registry Key Entries
+ ;HKEY_LOCAL_MACHINE Install entries
+ ;Set the Name, Version and Revision of GRASS + PublisherInfo + InstallPath
+ WriteRegStr HKLM "Software\${GRASS_BASE}" "Name" "GRASS"
+ WriteRegStr HKLM "Software\${GRASS_BASE}" "VersionNumber" "${VERSION_NUMBER}"
+ WriteRegStr HKLM "Software\${GRASS_BASE}" "SvnRevision" "${SVN_REVISION}"
+ WriteRegStr HKLM "Software\${GRASS_BASE}" "BinaryRevision" "${BINARY_REVISION}"
+ WriteRegStr HKLM "Software\${GRASS_BASE}" "Publisher" "${PUBLISHER}"
+ WriteRegStr HKLM "Software\${GRASS_BASE}" "WebSite" "${WEB_SITE}"
+ WriteRegStr HKLM "Software\${GRASS_BASE}" "InstallPath" "$INSTALL_DIR"
+ ;HKEY_LOCAL_MACHINE Uninstall entries
+ WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "DisplayName" "GRASS"
+ WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "UninstallString" "$INSTALL_DIR\Uninstall-GRASS.exe"
+ WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}"\
+ "DisplayVersion" "${VERSION_NUMBER}-${BINARY_REVISION}"
+ !else
+ "DisplayVersion" "${VERSION_NUMBER}-r${SVN_REVISION}-${BINARY_REVISION}"
+ !endif
+ WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "DisplayIcon" "$INSTALL_DIR\icons\GRASS.ico"
+ WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "EstimatedSize" 1
+ WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "HelpLink" "${WIKI_PAGE}"
+ WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "URLInfoAbout" "${WEB_SITE}"
+ WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "Publisher" "${PUBLISHER}"
+ ;Create the Desktop Shortcut
+ CreateShortCut "$DESKTOP\GRASS ${VERSION_NUMBER}.lnk" "$INSTALL_DIR\${GRASS_COMMAND}.bat" "-wxpython"\
+ "$INSTALL_DIR\icons\GRASS.ico" "" SW_SHOWNORMAL "" "Launch GRASS ${VERSION_NUMBER}"
+ CreateShortCut "$DESKTOP\GRASS ${VERSION_NUMBER} msys.lnk" "$INSTALL_DIR\msys\msys.bat" "/grass/bin/${GRASS_COMMAND} -wxpython"\
+ "$INSTALL_DIR\icons\GRASS.ico" "" SW_SHOWNORMAL "" "Launch GRASS ${VERSION_NUMBER} with msys Terminal"
+ ;Create the Windows Start Menu Shortcuts
+ SetShellVarContext all
+ CreateDirectory "$SMPROGRAMS\${GRASS_BASE}"
+ CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS Old GUI.lnk" "$INSTALL_DIR\${GRASS_COMMAND}.bat" "-tcltk"\
+ CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS ${VERSION_NUMBER}.lnk" "$INSTALL_DIR\${GRASS_COMMAND}.bat" "-wxpython"\
+ CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS Command Line.lnk" "$INSTALL_DIR\${GRASS_COMMAND}.bat" "-text"\
+ "$INSTALL_DIR\icons\GRASS_CMD.ico" "" SW_SHOWNORMAL "" "Launch GRASS in Text Mode on the Command Line"
+ CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS MSYS Console.lnk" "$INSTALL_DIR\msys\msys.bat" ""\
+ "$INSTALL_DIR\icons\MSYS_Custom_Icon.ico" "" SW_SHOWNORMAL "" "Open the GRASS MSYS Console"
+ CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS Web Site.lnk" "$INSTALL_DIR\GRASS-WebSite.url" ""\
+ "$INSTALL_DIR\icons\GRASS_Web.ico" "" SW_SHOWNORMAL "" "Visit the GRASS Web Site"
+ CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS ${VERSION_NUMBER} msys.lnk" "$INSTALL_DIR\msys\msys.bat" "/grass/bin/${GRASS_COMMAND} -wxpython"\
+ CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\Release Notes.lnk" "$INSTALL_DIR\WinGRASS-README.url" ""\
+ "$INSTALL_DIR\icons\WinGRASS.ico" "" SW_SHOWNORMAL "" "Visit the WinGRASS Project Web Page"
+ !endif
+ CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\Uninstall GRASS.lnk" "$INSTALL_DIR\Uninstall-GRASS.exe" ""\
+ "$INSTALL_DIR\Uninstall-GRASS.exe" "" SW_SHOWNORMAL "" "Uninstall GRASS ${VERSION_NUMBER}"
+ ;Create the grass_command.bat
+ ClearErrors
+ FileOpen $0 $INSTALL_DIR\${GRASS_COMMAND}.bat w
+ IfErrors done_create_grass_command.bat
+ FileWrite $0 '@echo off$\r$\n'
+ FileWrite $0 'rem #########################################################################$\r$\n'
+ FileWrite $0 'rem #$\r$\n'
+ FileWrite $0 'rem # File dynamically created by NSIS installer script;$\r$\n'
+ FileWrite $0 'rem # Written by Marco Pasetti;$\r$\n'
+ FileWrite $0 'rem # GRASS Initialization$\r$\n'
+ FileWrite $0 '$\r$\n'
+ FileWrite $0 'rem *******Environment variables***********$\r$\n'
+ FileWrite $0 'rem Set GRASS Installation Directory Variable$\r$\n'
+ FileWrite $0 'set GRASSDIR=$INSTALL_DIR$\r$\n'
+ FileWrite $0 'rem Directory where your .grassrc6 file will be stored$\r$\n'
+ FileWrite $0 'set HOME=%USERPROFILE%$\r$\n'
+ FileWrite $0 'rem Name of the wish (Tk) executable$\r$\n'
+ FileWrite $0 'set GRASS_WISH=wish.exe$\r$\n'
+ FileWrite $0 'rem Path to the shell command$\r$\n'
+ FileWrite $0 'set GRASS_SH=%GRASSDIR%\msys\bin\sh.exe$\r$\n'
+ FileWrite $0 'rem Set Path to utilities (libraries and bynaries) used by GRASS$\r$\n'
+ FileWrite $0 'set PATH=%GRASSDIR%\msys\bin;%PATH%$\r$\n'
+ FileWrite $0 'set PATH=%GRASSDIR%\extrabin;%GRASSDIR%\extralib;%PATH%$\r$\n'
+ FileWrite $0 'set PATH=%GRASSDIR%\tcl-tk\bin;%GRASSDIR%\sqlite\bin;%GRASSDIR%\gpsbabel;%PATH%$\r$\n'
+ FileWrite $0 'rem Set Path to MSIE web browser$\r$\n'
+ FileWrite $0 'set GRASS_HTML_BROWSER=%PROGRAMFILES%/Internet Explorer/iexplore.exe$\r$\n'
+ FileWrite $0 'rem Path to the proj files (notably the epsg projection list)$\r$\n'
+ FileWrite $0 'set GRASS_PROJSHARE=%GRASSDIR%\proj$\r$\n'
+ FileWrite $0 'rem Path to the python directory$\r$\n'
+ FileWrite $0 'set PYTHONHOME=%GRASSDIR%\Python25$\r$\n'
+ FileWrite $0 'set WINGISBASE=%GRASSDIR%$\r$\n'
+ FileWrite $0 '"%WINGISBASE%\etc\init.bat" %*'
+ FileClose $0
+ done_create_grass_command.bat:
+ ;Set the UNIX_LIKE GRASS Path
+ Var /GLOBAL UNIX_LIKE_DRIVE
+ Var /GLOBAL UNIX_LIKE_GRASS_PATH
+ StrCpy $UNIX_LIKE_DRIVE "$INSTALL_DIR" 3
+ StrCpy $UNIX_LIKE_GRASS_PATH "$INSTALL_DIR" "" 3
+ ;replace "\" with "/" in $UNIX_LIKE_DRIVE
+ ${StrReplace} "$UNIX_LIKE_DRIVE" "\" "/" "$UNIX_LIKE_DRIVE"
+ ;replace ":" with "" in $UNIX_LIKE_DRIVE
+ ${StrReplace} "$UNIX_LIKE_DRIVE" ":" "" "$UNIX_LIKE_DRIVE"
+ ;replace "\" with "/" in $UNIX_LIKE_GRASS_PATH
+ ${StrReplace} "$UNIX_LIKE_GRASS_PATH" "\" "/" "$UNIX_LIKE_GRASS_PATH"
+ ;Set the USERNAME variable
+ Var /GLOBAL USERNAME
+ Var /GLOBAL PROFILE_DRIVE
+ Var /GLOBAL PROFILE_ROOT
+ ;It first searches for the Key Regestry value "Logon User Name" in HKCU "Software\Microsoft\Windows\CurrentVersion\Explorer"
+ ReadRegStr $USERNAME HKCU "Software\Microsoft\Windows\CurrentVersion\Explorer" "Logon User Name"
+ ;If the Key Registry value is empty, it uses a work around, retrieving the Username string from the System User Profile variable ($PROFILE)
+ ;It first read the $PROFILE variable, to scan the OS version:
+ ;If equal to "drive:\Users\UserName", the OS is Vista, and the $USERNAME variable set to $PROFILE - "drive:\Users\"
+ ;If not, the OS is XP or previous, and the $USERNAME variable set to $PROFILE - "drive:\Documents and Settings\"
+ ${If} $USERNAME = ""
+ StrCpy $PROFILE_DRIVE "$PROFILE" 2
+ StrCpy $PROFILE_ROOT "$PROFILE" 5 -3
+ ${If} $USERNAME = "Users"
+ ${StrReplace} "$USERNAME" "$PROFILE_DRIVE\Users\" "" "$PROFILE"
+ ${Else}
+ ${StrReplace} "$USERNAME" "$PROFILE_DRIVE\Documents and Settings\" "" "$PROFILE"
+ ${EndIf}
+ ${EndIf}
+ ;Create the $INSTALL_DIR\msys\home and the $INSTALL_DIR\msys\home\$USERNAME directories
+ CreateDirectory $INSTALL_DIR\msys\home
+ CreateDirectory $INSTALL_DIR\msys\home\$USERNAME
+ ;create the $INSTALL_DIR\bin grass_command
+ ClearErrors
+ FileOpen $0 $INSTALL_DIR\bin\${GRASS_COMMAND} w
+ FileWrite $0 '#! /bin/sh$\r$\n'
+ FileWrite $0 '#########################################################################$\r$\n'
+ FileWrite $0 '#$\r$\n'
+ FileWrite $0 '# File dynamically created by NSIS installer script;$\r$\n'
+ FileWrite $0 '# Written by Marco Pasetti;$\r$\n'
+ FileWrite $0 '# MODULE: GRASS Initialization$\r$\n'
+ FileWrite $0 '# AUTHOR(S): Justin Hickey - Thailand - jhickey at hpcc.nectec.or.th$\r$\n'
+ FileWrite $0 '# PURPOSE: The source file for this shell script is in$\r$\n'
+ FileWrite $0 '# lib/init/grass.src and is the grass startup script. It$\r$\n'
+ FileWrite $0 '# requires a source file because the definition of GISBASE$\r$\n'
+ FileWrite $0 '# is not known until compile time and is substituted from the$\r$\n'
+ FileWrite $0 '# Makefile. Any command line options are passed to Init.sh.$\r$\n'
+ FileWrite $0 '# COPYRIGHT: (C) 2000-2005 by the GRASS Development Team$\r$\n'
+ FileWrite $0 '# This program is free software under the GNU General Public$\r$\n'
+ FileWrite $0 '# License (>=v2). Read the file COPYING that comes with GRASS$\r$\n'
+ FileWrite $0 '# for details.$\r$\n'
+ FileWrite $0 '# Modified by Marco Pasetti$\r$\n'
+ FileWrite $0 '# added the export PATH instruction to let GRASS work from$\r$\n'
+ FileWrite $0 '# the MSYS environment in the dynamic NSIS installation$\r$\n'
+ FileWrite $0 'trap "echo '
+ FileWrite $0 "'User break!' ; "
+ FileWrite $0 'exit" 2 3 9 15$\r$\n'
+ FileWrite $0 '# Set the GISBASE variable$\r$\n'
+ FileWrite $0 'GISBASE=/$UNIX_LIKE_DRIVE$UNIX_LIKE_GRASS_PATH$\r$\n'
+ FileWrite $0 'export GISBASE$\r$\n'
+ FileWrite $0 '# Set the PATH variable$\r$\n'
+ FileWrite $0 'PATH="$$GISBASE/extrabin:$$GISBASE/extralib:$$PATH"$\r$\n'
+ FileWrite $0 'PATH="$$GISBASE/tcl-tk/bin:$$GISBASE/sqlite/bin:$$GISBASE/gpsbabel:$$PATH"$\r$\n'
+ FileWrite $0 'export PATH$\r$\n'
+ FileWrite $0 '# Set the PYTHONPATH variable$\r$\n'
+ FileWrite $0 'PYTHONPATH="$$GISBASE/etc/python:$$GISBASE/Python25:$$PYTHONPATH"$\r$\n'
+ FileWrite $0 'export PYTHONPATH$\r$\n'
+ FileWrite $0 'PYTHONHOME="$INSTALL_DIR\Python25"$\r$\n'
+ FileWrite $0 'export PYTHONHOME$\r$\n'
+ FileWrite $0 'exec "$$GISBASE/etc/Init.sh" "$$@"'
+ FileClose $0
+ done_create_grass_command:
+ ;Create the $INSTALL_DIR\msys\grass link directory
+ CreateDirectory $INSTALL_DIR\msys\grass
+ ;create the $INSTALL_DIR\msys\etc\fstab with the main grass dir mount info
+ ClearErrors
+ FileOpen $0 $INSTALL_DIR\msys\etc\fstab w
+ IfErrors done_create_fstab
+ FileWrite $0 '$INSTALL_DIR /grass$\r$\n'
+ FileClose $0
+ done_create_fstab:
+ ;Set the Unix-Like GIS_DATABASE Path
+ Var /GLOBAL UNIX_LIKE_GIS_DATABASE_PATH
+ ;replace \ with / in $GIS_DATABASE
+ ${StrReplace} "$UNIX_LIKE_GIS_DATABASE_PATH" "\" "/" "$GIS_DATABASE"
+ ;create $PROFILE\.grassrc6
+ ClearErrors
+ FileOpen $0 $PROFILE\.grassrc6 w
+ IfErrors done_create_.grassrc6
+ FileWrite $0 'GISDBASE: $UNIX_LIKE_GIS_DATABASE_PATH$\r$\n'
+ FileWrite $0 'LOCATION_NAME: demolocation$\r$\n'
+ FileWrite $0 'MAPSET: PERMANENT$\r$\n'
+ FileClose $0
+ done_create_.grassrc6:
+ CopyFiles $PROFILE\.grassrc6 $INSTALL_DIR\msys\home\$USERNAME
+SectionEnd
+Function DownloadDataSet
+ IntOp $ARCHIVE_SIZE_MB $ARCHIVE_SIZE_KB / 1024
+ StrCpy $DOWNLOAD_MESSAGE_ "The installer will download the $EXTENDED_ARCHIVE_NAME sample data set.$\r$\n"
+ StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_$\r$\n"
+ StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_The archive is about $ARCHIVE_SIZE_MB MB and may take"
+ StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ several minutes to be downloaded.$\r$\n"
+ StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_The $EXTENDED_ARCHIVE_NAME will be copyed to:$\r$\n"
+ StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_$GIS_DATABASE\$CUSTOM_UNTAR_FOLDER.$\r$\n"
+ StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_Press OK to continue or Cancel to skip the download and complete the GRASS"
+ StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ installation without the $EXTENDED_ARCHIVE_NAME data set.$\r$\n"
+ MessageBox MB_OKCANCEL "$DOWNLOAD_MESSAGE_" IDOK download IDCANCEL cancel_download
+ download:
+ InitPluginsDir
+ NSISdl::download "$HTTP_PATH/$ARCHIVE_NAME" "$TEMP\$ARCHIVE_NAME"
+ Pop $0
+ StrCmp $0 "success" download_ok download_failed
+ download_ok:
+ InitPluginsDir
+ untgz::extract "-d" "$GIS_DATABASE" "$TEMP\$ARCHIVE_NAME"
+ Pop $0
+ StrCmp $0 "success" untar_ok untar_failed
+ untar_ok:
+ Rename "$GIS_DATABASE\$ORIGINAL_UNTAR_FOLDER" "$GIS_DATABASE\$CUSTOM_UNTAR_FOLDER"
+ Delete "$TEMP\$ARCHIVE_NAME"
+ Goto end
+ download_failed:
+ DetailPrint "$0" ;print error message to log
+ MessageBox MB_OK "Download Failed.$\r$\nGRASS will be installed without the $EXTENDED_ARCHIVE_NAME sample data set."
+ Goto end
+ cancel_download:
+ MessageBox MB_OK "Download Cancelled.$\r$\nGRASS will be installed without the $EXTENDED_ARCHIVE_NAME sample data set."
+ Goto end
+ untar_failed:
+ end:
+FunctionEnd
+Section /O "North Carolina Data Set" SecNorthCarolinaSDB
+ ;Set the size (in KB) of the archive file
+ StrCpy $ARCHIVE_SIZE_KB 138629
+ ;Set the size (in KB) of the unpacked archive file
+ AddSize 293314
+ StrCpy $HTTP_PATH "http://grass.osgeo.org/sampledata"
+ StrCpy $ARCHIVE_NAME "nc_spm_latest.tar.gz"
+ StrCpy $EXTENDED_ARCHIVE_NAME "North Carolina"
+ StrCpy $ORIGINAL_UNTAR_FOLDER "nc_spm_08"
+ StrCpy $CUSTOM_UNTAR_FOLDER "North-Carolina"
+ Call DownloadDataSet
+SectionEnd
+Section /O "South Dakota (Spearfish) Data Set" SecSpearfishSDB
+ StrCpy $ARCHIVE_SIZE_KB 20803
+ AddSize 42171
+ StrCpy $ARCHIVE_NAME "spearfish_grass60data-0.3.tar.gz"
+ StrCpy $EXTENDED_ARCHIVE_NAME "South Dakota (Spearfish)"
+ StrCpy $ORIGINAL_UNTAR_FOLDER "spearfish60"
+ StrCpy $CUSTOM_UNTAR_FOLDER "Spearfish60"
+SectionEnd
+;Uninstaller Section
+Section "Uninstall"
+ ;remove files
+ Delete "$INSTDIR\Uninstall-GRASS.exe"
+ Delete "$INSTDIR\GPL.TXT"
+ Delete "$INSTDIR\AUTHORS"
+ Delete "$INSTDIR\CHANGES"
+ Delete "$INSTDIR\COPYING"
+ Delete "$INSTDIR\${GRASS_COMMAND}.bat"
+ Delete "$INSTDIR\GRASS-WebSite.url"
+ Delete "$INSTDIR\WinGRASS-README.url"
+ Delete "$INSTDIR\REQUIREMENTS.html"
+ ;remove folders
+ RMDir /r "$INSTDIR\bin"
+ RMDir /r "$INSTDIR\bwidget"
+ RMDir /r "$INSTDIR\docs"
+ RMDir /r "$INSTDIR\driver"
+ RMDir /r "$INSTDIR\etc"
+ RMDir /r "$INSTDIR\extrabin"
+ RMDir /r "$INSTDIR\extralib"
+ RMDir /r "$INSTDIR\fonts"
+ RMDir /r "$INSTDIR\gpsbabel"
+ RMDir /r "$INSTDIR\icons"
+ RMDir /r "$INSTDIR\include"
+ RMDir /r "$INSTDIR\lib"
+ RMDir /r "$INSTDIR\locale"
+ RMDir /r "$INSTDIR\msys"
+ RMDir /r "$INSTDIR\proj"
+ RMDir /r "$INSTDIR\Python25"
+ RMDir /r "$INSTDIR\scripts"
+ RMDir /r "$INSTDIR\sqlite"
+ RMDir /r "$INSTDIR\tcl-tk"
+ ;if empty, remove the install folder
+ RMDir "$INSTDIR"
+ ;remove the Desktop ShortCut
+ Delete "$DESKTOP\GRASS ${VERSION_NUMBER}.lnk"
+ Delete "$DESKTOP\GRASS ${VERSION_NUMBER} msys.lnk"
+ ;remove the Programs Start ShortCuts
+ RMDir /r "$SMPROGRAMS\${GRASS_BASE}"
+ ;remove the .grassrc6 file
+ Delete "$PROFILE\.grassrc6"
+ ;remove the Registry Entries
+ DeleteRegKey HKLM "Software\${GRASS_BASE}"
+ DeleteRegKey HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}"
+SectionEnd
+;Installer Section Descriptions
+!insertmacro MUI_FUNCTION_DESCRIPTION_BEGIN
+ !insertmacro MUI_DESCRIPTION_TEXT ${SecGRASS} "Install GRASS ${VERSION_NUMBER}"
+ !insertmacro MUI_DESCRIPTION_TEXT ${SecNorthCarolinaSDB} "Download and install the North Carolina sample data set"
+ !insertmacro MUI_DESCRIPTION_TEXT ${SecSpearfishSDB} "Download and install the South Dakota (Spearfish) sample data set"
+!insertmacro MUI_FUNCTION_DESCRIPTION_END
Added: grass/trunk/mswindows/GRASS-Packager.bat
--- grass/trunk/mswindows/GRASS-Packager.bat (rev 0)
+++ grass/trunk/mswindows/GRASS-Packager.bat 2009-04-12 13:39:28 UTC (rev 36703)
@@ -0,0 +1,211 @@
+ at echo off
+rem --------------------------------------------------------------------------------------------------------------------------
+rem Set the script variables
+set GRASS_RELEASE_PACKAGE_DIR=.\GRASS-Release-Package
+set GRASS_6_DEV_PACKAGE_DIR=.\GRASS-6-Dev-Package
+set GRASS_7_DEV_PACKAGE_DIR=.\GRASS-7-Dev-Package
+set OSGEO4W_DIR=c:\osgeo4w
+set GRASS_RELEASE_INSTALL_FOLDER=%OSGEO4W_DIR%\apps\grass\grass-6.4.0RC4
+set GRASS_6_DEV_INSTALL_FOLDER=%OSGEO4W_DIR%\apps\grass\grass-6.5.svn
+set GRASS_7_DEV_INSTALL_FOLDER=%OSGEO4W_DIR%\apps\grass\grass-7.0.svn
+ at echo -----------------------------------------------------------------------------------------------------------------------
+ at echo Self Contained GRASS Automated Packager
+ at echo Edited by: Marco Pasetti
+ at echo Revised for OSGeo4W by: Colin Nielsen
+ at echo Last Update: 30 March 2009
+ at echo Select the GRASS version to pack:
+ at echo.
+ at echo 1. Current GRASS Release Version
+ at echo.
+ at echo 2. Current GRASS-6 Development Version
+ at echo.
+ at echo 3. Current GRASS-7 Development Version
+ at echo.
+set /p SELECTION=Enter your selection (1/2/3):
+if %SELECTION%==1 (
+set PACKAGE_DIR=%GRASS_RELEASE_PACKAGE_DIR%
+set GRASS_PREFIX=%GRASS_RELEASE_INSTALL_FOLDER%
+if %SELECTION%==2 (
+set PACKAGE_DIR=%GRASS_6_DEV_PACKAGE_DIR%
+set GRASS_PREFIX=%GRASS_6_DEV_INSTALL_FOLDER%
+if %SELECTION%==3 (
+set PACKAGE_DIR=%GRASS_7_DEV_PACKAGE_DIR%
+set GRASS_PREFIX=%GRASS_7_DEV_INSTALL_FOLDER%
+ at echo.
+ at echo Remove the previous Selected Package and create a new PACKAGE_DIR
+ at echo.
+pause
+if exist %PACKAGE_DIR% rmdir /S/Q %PACKAGE_DIR%
+mkdir %PACKAGE_DIR%
+ at echo.
+ at echo Copy %GRASS_PREFIX% content to PACKAGE_DIR
+ at echo.
+xcopy %GRASS_PREFIX% %PACKAGE_DIR% /S/V/F
+ at echo.
+ at echo Copy Extralibs to PACKAGE_DIR\extralib
+ at echo.
+mkdir %PACKAGE_DIR%\extralib
+copy %OSGEO4W_DIR%\bin\*.dll %PACKAGE_DIR%\extralib
+rem copy %OSGEO4W_DIR%\pgsql\lib\libpq.dll %PACKAGE_DIR%\extralib
+ at echo.
+ at echo Copy Extrabins to PACKAGE_DIR\extrabin
+ at echo.
+mkdir %PACKAGE_DIR%\extrabin
+copy %OSGEO4W_DIR%\bin\*.exe %PACKAGE_DIR%\extrabin
+ at echo.
+ at echo Copy SQLite content to PACKAGE_DIR\sqlite
+ at echo.
+mkdir %PACKAGE_DIR%\sqlite
+mkdir %PACKAGE_DIR%\sqlite\bin
+mkdir %PACKAGE_DIR%\sqlite\include
+mkdir %PACKAGE_DIR%\sqlite\lib
+xcopy %OSGEO4W_DIR%\bin\sqlite3.dll %PACKAGE_DIR%\sqlite\bin /S/V/F/I
+copy %OSGEO4W_DIR%\include\btree.h %PACKAGE_DIR%\sqlite\include
+copy %OSGEO4W_DIR%\include\fts1*.h %PACKAGE_DIR%\sqlite\include
+copy %OSGEO4W_DIR%\include\hash.h %PACKAGE_DIR%\sqlite\include
+copy %OSGEO4W_DIR%\include\keywordhash.h %PACKAGE_DIR%\sqlite\include
+copy %OSGEO4W_DIR%\include\opcodes.h %PACKAGE_DIR%\sqlite\include
+copy %OSGEO4W_DIR%\include\os.h %PACKAGE_DIR%\sqlite\include
+copy %OSGEO4W_DIR%\include\os_common.h %PACKAGE_DIR%\sqlite\include
+copy %OSGEO4W_DIR%\include\pager.h %PACKAGE_DIR%\sqlite\include
+copy %OSGEO4W_DIR%\include\parse.h %PACKAGE_DIR%\sqlite\include
+copy %OSGEO4W_DIR%\include\sqlite*.h %PACKAGE_DIR%\sqlite\include
+copy %OSGEO4W_DIR%\include\vdbe.h %PACKAGE_DIR%\sqlite\include
+copy %OSGEO4W_DIR%\include\vdbeInt.h %PACKAGE_DIR%\sqlite\include
+copy %OSGEO4W_DIR%\lib\sqlite3_i.lib %PACKAGE_DIR%\sqlite\lib
+ at echo.
+ at echo Copy GPSBABEL executable and dll to PACKAGE_DIR\gpsbabel
+ at echo.
+mkdir %PACKAGE_DIR%\gpsbabel
+copy %OSGEO4W_DIR%\gpsbabel.exe %PACKAGE_DIR%\gpsbabel
+rem copy %OSGEO4W_DIR%\libexpat.dll %PACKAGE_DIR%\gpsbabel
+ at echo.
+ at echo Copy shared PROJ.4 files to PACKAGE_DIR\proj
+ at echo.
+xcopy %OSGEO4W_DIR%\share\proj %PACKAGE_DIR%\proj /S/V/F/I
+ at echo.
+ at echo Copy Tcl/Tk content to PACKAGE_DIR\tcl-tk
+ at echo.
+mkdir %PACKAGE_DIR%\tcl-tk
+mkdir %PACKAGE_DIR%\tcl-tk\bin
+mkdir %PACKAGE_DIR%\tcl-tk\include
+mkdir %PACKAGE_DIR%\tcl-tk\lib
+mkdir %PACKAGE_DIR%\tcl-tk\lib\tcl8.5
+mkdir %PACKAGE_DIR%\tcl-tk\lib\tk8.5
+xcopy %OSGEO4W_DIR%\bin\tclpip85.dll %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
+xcopy %OSGEO4W_DIR%\bin\tcl85.dll %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
+xcopy %OSGEO4W_DIR%\bin\tclsh.exe %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
+xcopy %OSGEO4W_DIR%\bin\tclsh85.exe %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
+xcopy %OSGEO4W_DIR%\bin\tk85.dll %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
+xcopy %OSGEO4W_DIR%\bin\wish.exe %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
+xcopy %OSGEO4W_DIR%\bin\wish85.exe %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
+copy %OSGEO4W_DIR%\include\tcl*.h %PACKAGE_DIR%\tcl-tk\include
+copy %OSGEO4W_DIR%\include\tk*.h %PACKAGE_DIR%\tcl-tk\include
+copy %OSGEO4W_DIR%\include\tommath_class.h %PACKAGE_DIR%\tcl-tk\include
+copy %OSGEO4W_DIR%\include\tommath_superclass.h %PACKAGE_DIR%\tcl-tk\include
+copy %OSGEO4W_DIR%\include\ttkDecls.h %PACKAGE_DIR%\tcl-tk\include
+copy %OSGEO4W_DIR%\lib\tcl8.5\*.tcl %PACKAGE_DIR%\tcl-tk\lib\tcl8.5
+copy %OSGEO4W_DIR%\lib\tcl8.5\tclIndex %PACKAGE_DIR%\tcl-tk\lib\tcl8.5
+copy %OSGEO4W_DIR%\lib\tk8.5\*.tcl %PACKAGE_DIR%\tcl-tk\lib\tk8.5
+copy %OSGEO4W_DIR%\lib\tk8.5\tclIndex %PACKAGE_DIR%\tcl-tk\lib\tk8.5
+xcopy %OSGEO4W_DIR%\lib\tk8.5\ttk %PACKAGE_DIR%\tcl-tk\lib\tk8.5\ttk /S/V/F/I
+ at echo.
+ at echo Copy MSYS files to PACKAGE_DIR\msys
+ at echo.
+mkdir %PACKAGE_DIR%\msys
+copy %OSGEO4W_DIR%\apps\msys\* %PACKAGE_DIR%\msys
+xcopy %OSGEO4W_DIR%\apps\msys\bin %PACKAGE_DIR%\msys\bin /S/V/F/I
+xcopy %OSGEO4W_DIR%\apps\msys\doc %PACKAGE_DIR%\msys\doc /S/V/F/I
+xcopy %OSGEO4W_DIR%\apps\msys\etc %PACKAGE_DIR%\msys\etc /S/V/F/I
+xcopy %OSGEO4W_DIR%\apps\msys\info %PACKAGE_DIR%\msys\info /S/V/F/I
+xcopy %OSGEO4W_DIR%\apps\msys\lib %PACKAGE_DIR%\msys\lib /S/V/F/I
+xcopy %OSGEO4W_DIR%\apps\msys\man %PACKAGE_DIR%\msys\man /S/V/F/I
+del %OSGEO4W_DIR%\apps\msys\etc\fstab
+ at echo.
+ at echo Copy Python content to PACKAGE_DIR\Python25
+ at echo.
+mkdir %PACKAGE_DIR%\Python25
+copy %OSGEO4W_DIR%\apps\Python25\* %PACKAGE_DIR%\Python25
+xcopy %OSGEO4W_DIR%\apps\Python25\DLLs %PACKAGE_DIR%\Python25\DLLs /S/V/F/I
+xcopy %OSGEO4W_DIR%\apps\Python25\include %PACKAGE_DIR%\Python25\include /S/V/F/I
+xcopy %OSGEO4W_DIR%\apps\Python25\Lib %PACKAGE_DIR%\Python25\Lib /S/V/F/I
+xcopy %OSGEO4W_DIR%\apps\Python25\libs %PACKAGE_DIR%\Python25\libs /S/V/F/I
+xcopy %OSGEO4W_DIR%\apps\Python25\Scripts %PACKAGE_DIR%\Python25\Scripts /S/V/F/I
+ at echo.
+ at echo Packaging Completed
+ at echo Remove lines 11-16 from %PACKAGE_DIR%\msys\msys.bat
+ at echo.
+pause
Added: grass/trunk/mswindows/Installer-Files/GRASS-WebSite.url
--- grass/trunk/mswindows/Installer-Files/GRASS-WebSite.url (rev 0)
+++ grass/trunk/mswindows/Installer-Files/GRASS-WebSite.url 2009-04-12 13:39:28 UTC (rev 36703)
@@ -0,0 +1,5 @@
+[InternetShortcut]
+URL=http://grass.osgeo.org/
+IDList=
+[{000214A0-0000-0000-C000-000000000046}]
+Prop3=19,2
Added: grass/trunk/mswindows/Installer-Files/GRASS.ico
(Binary files differ)
Property changes on: grass/trunk/mswindows/Installer-Files/GRASS.ico
___________________________________________________________________
+ application/octet-stream
Added: grass/trunk/mswindows/Installer-Files/GRASS_CMD.ico
Property changes on: grass/trunk/mswindows/Installer-Files/GRASS_CMD.ico
Added: grass/trunk/mswindows/Installer-Files/GRASS_Web.ico
Property changes on: grass/trunk/mswindows/Installer-Files/GRASS_Web.ico
Added: grass/trunk/mswindows/Installer-Files/InstallHeaderImage.bmp
Property changes on: grass/trunk/mswindows/Installer-Files/InstallHeaderImage.bmp
Added: grass/trunk/mswindows/Installer-Files/Install_GRASS.ico
Property changes on: grass/trunk/mswindows/Installer-Files/Install_GRASS.ico
Added: grass/trunk/mswindows/Installer-Files/MSYS_Custom_Icon.ico
Property changes on: grass/trunk/mswindows/Installer-Files/MSYS_Custom_Icon.ico
Added: grass/trunk/mswindows/Installer-Files/UnInstallHeaderImage.bmp
Property changes on: grass/trunk/mswindows/Installer-Files/UnInstallHeaderImage.bmp
Added: grass/trunk/mswindows/Installer-Files/UnWelcomeFinishPage.bmp
Property changes on: grass/trunk/mswindows/Installer-Files/UnWelcomeFinishPage.bmp
Added: grass/trunk/mswindows/Installer-Files/Uninstall_GRASS.ico
Property changes on: grass/trunk/mswindows/Installer-Files/Uninstall_GRASS.ico
Added: grass/trunk/mswindows/Installer-Files/WelcomeFinishPage.bmp
Property changes on: grass/trunk/mswindows/Installer-Files/WelcomeFinishPage.bmp
Added: grass/trunk/mswindows/Installer-Files/WinGRASS-README.url
--- grass/trunk/mswindows/Installer-Files/WinGRASS-README.url (rev 0)
+++ grass/trunk/mswindows/Installer-Files/WinGRASS-README.url 2009-04-12 13:39:28 UTC (rev 36703)
@@ -0,0 +1,7 @@
+[InternetShortcut]
+URL=http://grass.osgeo.org/grass63/binary/mswindows/native/README.html
+IDList=
+IconFile=http://grass.osgeo.org/favicon.ico
+IconIndex=1
+Prop3=19,2
Added: grass/trunk/mswindows/Installer-Files/WinGRASS.ico
Property changes on: grass/trunk/mswindows/Installer-Files/WinGRASS.ico
Added: grass/trunk/mswindows/README.html
--- grass/trunk/mswindows/README.html (rev 0)
+++ grass/trunk/mswindows/README.html 2009-04-12 13:39:28 UTC (rev 36703)
@@ -0,0 +1,289 @@
+<html>
+<head>
+<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
+<meta http-equiv="Content-Language" content="en" />
+<meta name="Author" content="Marco Pasetti" />
+<meta name="Description" content="SVN mswindows README" />
+<title>SVN mswindows README</title>
+<style type="text/css" />
+/* Wiki Pages Styles */
+/* TableOfContents */
+.table-of-contents {
+ border: 1px solid #bbbbbb;
+ color: black; background-color: #eeeeee;
+ font-size: small;
+ text-align:left;
+ margin: 0.5em; padding-left: 1em;
+ width: 360;
+/* Contents */
+html {
+ background-color: white;
+ color: black;
+ font-family: Arial, Lucida Grande, sans-serif;
+ font-size: 10pt;
+body {
+ margin: 30;
+ol {
+ font-size: 10pt;
+ margin-top: 0;
+ margin-bottom: 0;
+ margin-left: 0;
+h1 {
+ font-size: 18pt;
+ margin-top: 0;
+ margin-bottom: 50;
+h2 {
+ font-size: 16pt;
+ margin-top: 60;
+ margin-bottom: 20;
+h3 {
+ font-size: 14pt;
+ margin-top: 60;
+h4 {
+ font-size: 11pt;
+ margin-top: 0;
+ margin-bottom: 0;
+p {
+ font-size: 10pt;
+ margin-top: 10;
+ margin-bottom: 10;
+code {
+ font-family: Courier-new, monospace;
+ font-size: 10pt;
+ margin-top: 10;
+pre {
+ padding: 1em;
+ border: 1px dashed #2f6fab;
+ color: black;
+ background-color: #f9f9f9;
+ line-height: 1.1em;
+/* Tables */
+table
+ margin: 0.5em 0 0 0.5em;
+ border-collapse: collapse;
+td
+ padding: 0.25em 0.5em 0.25em 0.5em;
+ border: 0pt solid #ADB9CC;
+ font-size: 10pt;
+/* Links */
+a {
+ text-decoration: none;
+ color: #002bb8;
+ background: none;
+a:hover {
+ text-decoration: underline;
+ color: green;
+a:visited:hover {
+ color: red;
+</style>
+</head>
+<body>
+<h1>How to prepare a WinGRASS Release</h1>
+<div class="table-of-contents">
+<p><strong>Table of Contents</strong></p>
+<p><a href="#Introduction">Introduction</a></p>
+<p><ol>
+<li><a href="#Install OSGeo4w Tree and Compile Grass">Install OSGeo4w Tree and Compile Grass</a></li>
+<li><a href="#Create a GRASS self-contained Package">Create a GRASS self-contained Package</a></li>
+<li><a href="#Remove OSGeo4W Traces from Package">Remove OSGeo4W Traces from Package</a></li>
+<li><a href="#Install NSIS">Install NSIS</a></li>
+<li><a href="#Install NSIS: Untgz Plugin">Install NSIS: Untgz Plugin</a></li>
+<li><a href="#Create the WinGRASS Installer">Create the WinGRASS Installer</a></li>
+</ol></p>
+<p><a href="#Credits and Contacts">Credits and Contacts</a></p>
+<br>
+</div>
+<div id="Introduction">
+<p><h3>Introduction</h3></p>
+<p>This document explains how to prepare a WinGRASS release (as a self-contained package installer) using the scripts contained
+in the mswindows folder. In order to avoid mistakes or misunderstandings, I highly recommend to follow each step and command
+exactly as they are written in this document.</p>
+</div>
+<div id="Install OSGeo4w Tree and Compile Grass">
+<p><h3>1. Install OSGeo4w Tree and Compile Grass</h3></p>
+<p>Follow the instructions <a target="_blank" href="http://trac.osgeo.org/grass/wiki/CompileOnWindows">here</a> to download the OSGeo4W installer, install the required dependencies, and build Grass from source.</p>
+<p>Do not move on to step two until you have successfully <a target="_blank" href="http://trac.osgeo.org/grass/wiki/HowToTestGrass6">tested</a> your new version of Grass.</p>
+</div>
+<div id="Create a GRASS self-contained Package">
+<p><h3>2. Create a GRASS self-contained Package</h3></p>
+<p>Copy all the content of the mswindows folder to a temporary directory, for example <code>c:\temp</code>.</p>
+<p>Edit lines 11-15 in the file <code>c:\temp\GRASS-Packager.bat</code> to reflect the path to your OSGeo4W tree (eg. <code>c:\OSGeo4W</code>),
+and the Grass version being packaged (eg. <code>grass-7.0.svn</code>.</p>
+<p>Launch the file <code>c:\temp\GRASS-Packager.bat</code> and select the option number 1.</p>
+<p>When finished, you should have a GRASS self-contained release package in <code>c:\temp\GRASS-Release-Package</code>.</p>
+</div>
+<div id="Remove OSGeo4W Traces from Package">
+<p><h3>3. Remove OSGeo4W Traces from Package</h3></p>
+<p>Open <code>c:\temp\GRASS-Release-Package\msys\msys.bat</code> and remove lines 11-16.</p>
+<p>At the end of line 88 change:
+<pre><code>--login -i</code></pre>
+To:
+<pre><code>--login -c "%*"</code></pre>
+</div>
+<div id="Install NSIS">
+<p><h3>4. Install NSIS (2.38)</h3></p>
+<p>Download the <a target="_blank" href="http://prdownloads.sourceforge.net/nsis/nsis-2.38-setup.exe">NSIS installer</a></p>
+<p>Install to <code>c:\DevTools</code></p>
+</div>
+<div id="Install NSIS: Untgz Plugin">
+<p><h3>5. Install NSIS: Untgz Plugin (1.0.15)</h3></p>
+<p>Download the <a target="_blank" href="http://nsis.sourceforge.net/mediawiki/images/9/9d/Untgz.zip">NSIS Untgz Plugin</a></p>
+<p>Unzip to <code>c:\DevTools\Plugins\</code></p>
+<p>Copy <code>c:\DevTools\Plugins\untgz\untgz.dll</code> to <code>c:\DevTools\Plugins\</code></p>
+</div>
+<div id="Create the WinGRASS Installer">
+<p><h3>6. Create the WinGRASS Installer</h3></p>
+<p>Open the the file <code>c:\temp\GRASS-Installer.nsi</code>.</p>
+<p>At line 13 set the <code>DEMOLOCATION_PATH</code> varibale to the demolocation folder in the source tree.
+For example, <code>c:\msys\local\src\grass-6.4.0RC3\demolocation</code>
+<p>At line 18 set the <code>INSTALLER_TYPE</code> variable to <code>"Release"</code>, then, at lines 24-26, set the
+<code>RELEASE_VERSION_NUMBER</code>, the <code>RELEASE_SVN_REVISION</code> and the <code>RELEASE_BINARY_REVISION</code> variables.</p>
+<p>Finally, right click on the file <code>c:\temp\GRASS-Installer.nsi</code> and select <code>Compile NSIS Script</code>.</p>
+<p>When finished, you should have the WinGRASS release installer in <code>c:\temp</code>.</p>
+</div>
+<div id="Credits and Contacts">
+<p><h3>Credits and Contacts</h3></p>
+<p>The GRASS MSYS Environment and the GRASS Packager and Installer scripts were created by Marco Pasetti, and updated for use on the
+osgeo4w tree by Colin Nielsen</p>
+<p>To contact them, e-mail to: GRASS Development Mailing List
+(<a target="_blank" href="http://lists.osgeo.org/mailman/listinfo/grass-dev">http://lists.osgeo.org/mailman/listinfo/grass-dev</a>).</p>
+<p>Last edited by Colin Nielsen on 06 April 2009.</p>
+</div>
+</body>
+</html>
Added: grass/trunk/mswindows/osgeo4w/package.cmd
--- grass/trunk/mswindows/osgeo4w/package.cmd (rev 0)
+++ grass/trunk/mswindows/osgeo4w/package.cmd 2009-04-12 13:39:28 UTC (rev 36703)
@@ -0,0 +1,38 @@
+path %PATH%;%OSGEO4W_ROOT%\apps\swig
+set WXWIN=h:\windows\wxPython-src-2.8.9.1
+set GRASS_HOME=%OSGEO4W_ROOT%\apps\grass\grass-6.4.0RC3
+set GRASS_INC=%GRASS_HOME%\include
+set GRASS_LPATH=%GRASS_HOME%\lib
+set WX_INC=%WXWIN%\lib\vc_dll\mswud;%WXWIN%\lib\vc_dll\mswu;%WXWIN%\include
+set WXPY_INC=%WXWIN%\wxPython\include
+set WX_LPATH=%OSGEO4W_ROOT%\lib;%WXWIN%\lib\vc_dll
+set OLD=%CD%
+cd %OLD%\gui\wxpython\nviz
+python setup.py build_ext -I %OSGEO4W_ROOT%\include;%GRASS_INC%;%WX_INC% -L %GRASS_LPATH%
+copy grass6_wxnviz.py %GRASS_HOME%\etc\wxpython\nviz
+copy build\lib.win32-2.5\_grass6_wxnviz.pyd %GRASS_HOME%\etc\wxpython\nviz
+if exist build\lib.win32-2.5\_grass6_wxnviz.pdb copy build\lib.win32-2.5\_grass6_wxnviz.pdb %GRASS_HOME%\etc\wxpython\nviz
+cd %OLD%\gui\wxpython\vdigit
+python setup.py build_ext -D WXUSINGDLL -I %OSGEO4W_ROOT%\include;%GRASS_INC%;%WX_INC%;%WXPY_INC% -L %GRASS_LPATH%;%WX_LPATH%
+copy grass6_wxvdigit.py %GRASS_HOME%\etc\wxpython\vdigit
+copy build\lib.win32-2.5\_grass6_wxvdigit.pyd %GRASS_HOME%\etc\wxpython\vdigit
+if exist build\lib.win32-2.5\_grass6_wxvdigit.pdb copy build\lib.win32-2.5\_grass6_wxvdigit.pdb %GRASS_HOME%\etc\wxpython\vdigit
+goto skip
+cd %OLD%\swig\python
+python setup.py build_ext -I %GRASS_INC%;%OSGEO4W_ROOT%\include -L %OSGEO4W_ROOT%\lib;%GRASS_LPATH%
+cd %OLD%\swig\python\NumPtr
+:skip
+cd %OLD%
Added: grass/trunk/mswindows/osgeo4w/package.sh
--- grass/trunk/mswindows/osgeo4w/package.sh (rev 0)
+++ grass/trunk/mswindows/osgeo4w/package.sh 2009-04-12 13:39:28 UTC (rev 36703)
@@ -0,0 +1,50 @@
+set -e
+echo
+echo
+echo
+if ! [ -f configure-stamp ]; then
+ echo $(date): STARTING configure
+ ./configure \
+ --with-libs="/c/OSGeo4W/lib /c/MinGW/lib" \
+ --with-includes="/c/OSGeo4W/include /c/MinGW/include" \
+ --exec-prefix=/c/OSGeo4W/bin \
+ --libexecdir=/c/OSGeo4W/bin \
+ --prefix=/c/OSGeo4W/apps/grass \
+ --includedir=/c/OSGeo4W/include \
+ --disable-x --without-x \
+ --with-cxx \
+ --enable-shared \
+ --enable-largefile \
+ --with-opengl=windows \
+ --with-fftw \
+ --with-freetype \
+ --with-proj-share=/c/OSGeo4W/share/proj \
+ --with-gdal=/C/OSGeo4W/bin/gdal-config \
+ --with-tcltk \
+ --with-sqlite \
+ --with-postgres \
+ --with-curses \
+ --with-regex \
+ --with-nls \
+ --without-swig \
+ --with-freetype-includes=/c/OSGeo4W/include/freetype2
+ echo $(date): STARTING make clean
+ make clean
+ touch configure-stamp
+fi
+echo $(date): STARTING make
+make || make
+echo $(date): STARTING make install
+make install
+echo $(date): END
+) | tee -a package.log
Property changes on: grass/trunk/mswindows/osgeo4w/package.sh
+ native
