[GRASS-SVN] r36711 - grass/branches/develbranch_6/general/g.mapsets
Mon Apr 13 02:26:12 EDT 2009
Author: neteler
Date: 2009-04-13 02:26:10 -0400 (Mon, 13 Apr 2009)
New Revision: 36711
Added:
   grass/branches/develbranch_6/general/g.mapsets/main.c
Removed:
   grass/branches/develbranch_6/general/g.mapsets/get_path.c
   grass/branches/develbranch_6/general/g.mapsets/main_cmd.c
   grass/branches/develbranch_6/general/g.mapsets/main_inter.c
   grass/branches/develbranch_6/general/g.mapsets/scan_int.c
   grass/branches/develbranch_6/general/g.mapsets/set_path.c
   grass/branches/develbranch_6/general/g.mapsets/Makefile
removed unused code; main.c sync with pre-r36709
Modified: grass/branches/develbranch_6/general/g.mapsets/Makefile
--- grass/branches/develbranch_6/general/g.mapsets/Makefile	2009-04-13 05:10:32 UTC (rev 36710)
+++ grass/branches/develbranch_6/general/g.mapsets/Makefile	2009-04-13 06:26:10 UTC (rev 36711)
@@ -7,12 +7,6 @@
 LIBES     = $(GISLIB)
 DEPENDENCIES= $(GISDEP)
-CMD_OBJS = \
-	main_cmd.o \
-	dsply_path.o \
-	dsply_maps.o \
-	get_maps.o
 include $(MODULE_TOPDIR)/include/Make/Module.make
 default: cmd $(GUI)
Deleted: grass/branches/develbranch_6/general/g.mapsets/get_path.c
--- grass/branches/develbranch_6/general/g.mapsets/get_path.c	2009-04-13 05:10:32 UTC (rev 36710)
+++ grass/branches/develbranch_6/general/g.mapsets/get_path.c	2009-04-13 06:26:10 UTC (rev 36711)
@@ -1,118 +0,0 @@
-#include <string.h>
-#include "local_proto.h"
-#include <stdio.h>
-#include "externs.h"
-#include <grass/gis.h>
-int get_mapset_path(void)
-    static int first = 1;
-    char buf[4096];
-    char *b;
-    char name[GMAPSET_MAX];
-    int n;
-    int action;			/* defines action to be taken in set_path function */
-    fprintf(stdout, "Hit RETURN to keep current list, or ");
-    fprintf(stdout, "enter a new list of mapsets\n");
-    if (first) {
-	fprintf(stdout, "(enter the numbers before the mapset name, ");
-	fprintf(stdout, "or the names themselves)\n");
-	fprintf(stdout, "    (to ADD to end of list, use + . . .)\n");
-	fprintf(stdout, "    (to DELETE from list, use - . . .)\n");
-	first = 0;
-    nchoices = 0;
-    fprintf(stdout, "\nnew list> ");
-    if (!fgets(b = buf, 4096, stdin))
-	goto same;
-    while (isspace(*b))
-	b++;
-    switch (*b) {
-    case '+':			/* preload existing path into choice array */
-	action = ADD;
-	for (n = 0; n < ncurr_mapsets;
-	     choice[nchoices++] = curr_mapset[n++]) ;
-	b++;
-	break;
-    case '-':
-	action = DELETE;
-	b++;
-	break;
-    default:
-	action = REPLACE;
-    while (1) {
-	if (sscanf(b, "%s", name) != 1) {
-	    if (action == DELETE)
-		return delete_choices();
-	    return 1;
-	for (n = 0; n < nmapsets; n++)
-	    if (strcmp(name, mapset_name[n]) == 0) {
-		choice[nchoices++] = n;
-		goto next;
-	if (scan_int(name, &n)) {
-	    if (n > 0 && n <= nmapsets) {
-		choice[nchoices++] = n - 1;
-		goto next;
-	fprintf(stdout, "\n<%s> not found\n\n", name);
-	return -1;
-      next:
-	while (*b == ' ' || *b == '\t')
-	    b++;
-	while (*b && *b != ' ' && *b != '\t')
-	    b++;
-  same:
-    for (n = 0; b = G__mapset_name(n); n++) {
-	int i;
-	for (i = 0; i < nmapsets; i++)
-	    if (strcmp(b, mapset_name[i]) == 0) {
-		choice[nchoices++] = i;
-		break;
-    return 1;
-int delete_choices(void)
-    int i, n;
-    int deletion;		/* map number to be deleted */
-    /* action is delete:  modify previous mapset list and write to choice array */
-    for (i = 0; i < nchoices; i++) {
-	deletion = choice[i];
-	for (n = 0; n < ncurr_mapsets; n++)
-	    if (curr_mapset[n] == deletion) {	/* delete mapset from path */
-		curr_mapset[n] = -1;
-		break;
-	if (n == ncurr_mapsets) {
-	    fprintf(stdout, "\n<%s> not found in search list\n\n",
-		    mapset_name[deletion]);
-	    return -1;
-    /* prepare choice array list for final processing */
-    nchoices = 0;
-	if (curr_mapset[n] >= 0)	/* i.e., not deleted */
-	    choice[nchoices++] = curr_mapset[n];
-    return 1;
Copied: grass/branches/develbranch_6/general/g.mapsets/main.c (from rev 36710, grass/branches/develbranch_6/general/g.mapsets/main_cmd.c)
--- grass/branches/develbranch_6/general/g.mapsets/main.c	                        (rev 0)
+++ grass/branches/develbranch_6/general/g.mapsets/main.c	2009-04-13 06:26:10 UTC (rev 36711)
@@ -0,0 +1,238 @@
+ * MODULE:       g.mapsets
+ * AUTHOR(S):    Michael Shapiro (CERL), Greg Koerper (ManTech Environmental
+ *                    Technology) (original contributors),
+ *               Glynn Clements <glynn gclements.plus.com>
+ *               Hamish Bowman <hamish_nospam yahoo.com>,
+ *               Markus Neteler <neteler itc.it>,
+ *               Moritz Lennert <mlennert club.worldonline.be>
+ * PURPOSE:      set current mapset path
+ * COPYRIGHT:    (C) 1994-2008 by the GRASS Development Team
+ *               This program is free software under the GNU General Public
+ *               License (>=v2). Read the file COPYING that comes with GRASS
+ *               for details.
+#define MAIN
+#include <string.h>
+#include <stdlib.h>
+#include <unistd.h>
+#include <grass/gis.h>
+#include <grass/spawn.h>
+#include <grass/glocale.h>
+#include "local_proto.h"
+#include "externs.h"
+static char Path[GPATH_MAX];
+int main(int argc, char *argv[])
+    int n;
+    int i;
+    int skip;
+    char *cur_mapset;
+    char **ptr;
+    char **tokens;
+    int no_tokens;
+    FILE *fp;
+    char path[GPATH_MAX];
+    struct GModule *module;
+    struct Option *opt1, *opt2, *opt3;
+    struct Flag *print;
+    struct Flag *list;
+    struct Flag *tcl;
+    G_gisinit(argv[0]);
+    module = G_define_module();
+    module->keywords = _("general, settings");
+    module->description =
+	_("Modifies the user's current mapset "
+	  "search path, affecting the user's access to data existing "
+	  "under the other GRASS mapsets in the current location.");
+    opt1 = G_define_option();
+    opt1->key = "mapset";
+    opt1->type = TYPE_STRING;
+    opt1->required = NO;
+    opt1->multiple = YES;
+    opt1->description = _("Name(s) of existing mapset(s)");
+    opt2 = G_define_option();
+    opt2->key = "addmapset";
+    opt2->type = TYPE_STRING;
+    opt2->required = NO;
+    opt2->multiple = YES;
+    opt2->description =
+	_("Name(s) of existing mapset(s) to add to search list");
+    opt3 = G_define_option();
+    opt3->key = "removemapset";
+    opt3->type = TYPE_STRING;
+    opt3->required = NO;
+    opt3->multiple = YES;
+    opt3->description =
+	_("Name(s) of existing mapset(s) to remove from search list");
+    list = G_define_flag();
+    list->key = 'l';
+    list->description = _("List all available mapsets");
+    print = G_define_flag();
+    print->key = 'p';
+    print->description = _("Print current mapset search path");
+    tcl = G_define_flag();
+    tcl->key = 's';
+    tcl->description = _("Show mapset selection dialog");
+    Path[0] = '\0';
+    nchoices = 0;
+    if (G_parser(argc, argv))
+	exit(EXIT_FAILURE);
+    if (list->answer) {
+	get_available_mapsets();
+	display_available_mapsets(0);
+    if (tcl->answer) {
+	sprintf(path, "%s/etc/g.mapsets.tcl", G_gisbase());
+	G_spawn(path, "g.mapsets.tcl", NULL);
+    if (opt1->answer) {
+	for (ptr = opt1->answers; *ptr != NULL; ptr++) {
+	    char *mapset;
+	    mapset = *ptr;
+	    if (G__mapset_permissions(mapset) < 0)
+		G_fatal_error(_("Mapset <%s> not found"), mapset);
+	    nchoices++;
+	    strcat(Path, mapset);
+	    strcat(Path, " ");
+    /* add to existing search path */
+    if (opt2->answer) {
+	char *oldname;
+	Path[0] = '\0';
+	/* read existing mapsets from SEARCH_PATH */
+	for (n = 0; (oldname = G__mapset_name(n)); n++) {
+	    strcat(Path, oldname);
+	/* fetch and add new mapsets from param list */
+	for (ptr = opt2->answers; *ptr != NULL; ptr++) {
+	    char *mapset;
+	    mapset = *ptr;
+	    if (G_is_mapset_in_search_path(mapset))
+		continue;
+	    else
+		G_verbose_message(_("Mapset <%s> added to search path"),
+				  mapset);
+	    nchoices++;
+    /* remove from existing search path */
+    if (opt3->answer) {
+	char *oldname;
+	Path[0] = '\0';
+	    int found = 0;
+	    for (ptr = opt3->answers; *ptr; ptr++)
+		if (strcmp(oldname, *ptr) == 0)
+		    found = 1;
+	    if (found) {
+		G_verbose_message(_("Mapset <%s> removed from search path"),
+				  oldname);
+		continue;
+	    nchoices++;
+    /* stuffem sets nchoices */
+    if (nchoices == 0) {
+	goto DISPLAY;
+    /* note I'm assuming that mapsets cannot have ' 's in them */
+    tokens = G_tokenize(Path, " ");
+    fp = G_fopen_new("", "SEARCH_PATH");
+    if (!fp)
+	G_fatal_error(_("Cannot open SEARCH_PATH for write"));
+    cur_mapset = G_mapset();
+     * make sure current mapset is specified in the list
+     * if not add it to the head of the list
+    skip = 0;
+    for (n = 0; n < nchoices; n++)
+	if (strcmp(cur_mapset, tokens[n]) == 0) {
+	    skip = 1;
+	    break;
+    if (!skip) {
+	fprintf(fp, "%s\n", cur_mapset);
+     * output the list, removing duplicates
+    no_tokens = G_number_of_tokens(tokens);
+    for (n = 0; n < no_tokens; n++) {
+	skip = 0;
+	for (i = n; i < no_tokens; i++) {
+	    if (i != n) {
+		if (strcmp(tokens[i], tokens[n]) == 0)
+		    skip = 1;
+	if (!skip)
+	    fprintf(fp, "%s\n", tokens[n]);
+    fclose(fp);
+    G_free_tokens(tokens);
+  DISPLAY:
+    if (print->answer)
+	display_mapset_path(0);
+    exit(EXIT_SUCCESS);
Property changes on: grass/branches/develbranch_6/general/g.mapsets/main.c
___________________________________________________________________
   + text/x-csrc
   + Author Date Id
   + native
Deleted: grass/branches/develbranch_6/general/g.mapsets/main_cmd.c
--- grass/branches/develbranch_6/general/g.mapsets/main_cmd.c	2009-04-13 05:10:32 UTC (rev 36710)
+++ grass/branches/develbranch_6/general/g.mapsets/main_cmd.c	2009-04-13 06:26:10 UTC (rev 36711)
@@ -1,238 +0,0 @@
- * MODULE:       g.mapsets
- * AUTHOR(S):    Michael Shapiro (CERL), Greg Koerper (ManTech Environmental
- *                    Technology) (original contributors),
- *               Glynn Clements <glynn gclements.plus.com>
- *               Hamish Bowman <hamish_nospam yahoo.com>,
- *               Markus Neteler <neteler itc.it>,
- *               Moritz Lennert <mlennert club.worldonline.be>
- * PURPOSE:      set current mapset path
- * COPYRIGHT:    (C) 1994-2008 by the GRASS Development Team
- *               This program is free software under the GNU General Public
- *               License (>=v2). Read the file COPYING that comes with GRASS
- *               for details.
-#define MAIN
-#include <stdlib.h>
-#include <unistd.h>
-#include <grass/spawn.h>
-#include <grass/glocale.h>
-static char Path[GPATH_MAX];
-int main(int argc, char *argv[])
-    int n;
-    int i;
-    int skip;
-    char *cur_mapset;
-    char **ptr;
-    char **tokens;
-    int no_tokens;
-    FILE *fp;
-    char path[GPATH_MAX];
-    struct GModule *module;
-    struct Option *opt1, *opt2, *opt3;
-    struct Flag *print;
-    struct Flag *list;
-    struct Flag *tcl;
-    G_gisinit(argv[0]);
-    module = G_define_module();
-    module->keywords = _("general, settings");
-    module->description =
-	_("Modifies the user's current mapset "
-	  "search path, affecting the user's access to data existing "
-	  "under the other GRASS mapsets in the current location.");
-    opt1 = G_define_option();
-    opt1->key = "mapset";
-    opt1->type = TYPE_STRING;
-    opt1->required = NO;
-    opt1->multiple = YES;
-    opt1->description = _("Name(s) of existing mapset(s)");
-    opt2 = G_define_option();
-    opt2->key = "addmapset";
-    opt2->type = TYPE_STRING;
-    opt2->required = NO;
-    opt2->multiple = YES;
-    opt2->description =
-	_("Name(s) of existing mapset(s) to add to search list");
-    opt3 = G_define_option();
-    opt3->key = "removemapset";
-    opt3->type = TYPE_STRING;
-    opt3->required = NO;
-    opt3->multiple = YES;
-    opt3->description =
-	_("Name(s) of existing mapset(s) to remove from search list");
-    list = G_define_flag();
-    list->key = 'l';
-    list->description = _("List all available mapsets");
-    print = G_define_flag();
-    print->key = 'p';
-    print->description = _("Print current mapset search path");
-    tcl = G_define_flag();
-    tcl->key = 's';
-    tcl->description = _("Show mapset selection dialog");
-    Path[0] = '\0';
-    nchoices = 0;
-    if (G_parser(argc, argv))
-	exit(EXIT_FAILURE);
-    if (list->answer) {
-	get_available_mapsets();
-	display_available_mapsets(0);
-    if (tcl->answer) {
-	sprintf(path, "%s/etc/g.mapsets.tcl", G_gisbase());
-	G_spawn(path, "g.mapsets.tcl", NULL);
-    if (opt1->answer) {
-	for (ptr = opt1->answers; *ptr != NULL; ptr++) {
-	    char *mapset;
-	    mapset = *ptr;
-	    if (G__mapset_permissions(mapset) < 0)
-		G_fatal_error(_("Mapset <%s> not found"), mapset);
-	    nchoices++;
-	    strcat(Path, mapset);
-	    strcat(Path, " ");
-    /* add to existing search path */
-    if (opt2->answer) {
-	char *oldname;
-	Path[0] = '\0';
-	/* read existing mapsets from SEARCH_PATH */
-	for (n = 0; (oldname = G__mapset_name(n)); n++) {
-	    strcat(Path, oldname);
-	/* fetch and add new mapsets from param list */
-	for (ptr = opt2->answers; *ptr != NULL; ptr++) {
-	    char *mapset;
-	    mapset = *ptr;
-	    if (G_is_mapset_in_search_path(mapset))
-		continue;
-	    else
-		G_verbose_message(_("Mapset <%s> added to search path"),
-				  mapset);
-	    nchoices++;
-    /* remove from existing search path */
-    if (opt3->answer) {
-	char *oldname;
-	Path[0] = '\0';
-	    int found = 0;
-	    for (ptr = opt3->answers; *ptr; ptr++)
-		if (strcmp(oldname, *ptr) == 0)
-		    found = 1;
-	    if (found) {
-		G_verbose_message(_("Mapset <%s> removed from search path"),
-				  oldname);
-		continue;
-	    nchoices++;
-    /* stuffem sets nchoices */
-    if (nchoices == 0) {
-	goto DISPLAY;
-    /* note I'm assuming that mapsets cannot have ' 's in them */
-    tokens = G_tokenize(Path, " ");
-    fp = G_fopen_new("", "SEARCH_PATH");
-    if (!fp)
-	G_fatal_error(_("Cannot open SEARCH_PATH for write"));
-    cur_mapset = G_mapset();
-     * make sure current mapset is specified in the list
-     * if not add it to the head of the list
-    skip = 0;
-    for (n = 0; n < nchoices; n++)
-	if (strcmp(cur_mapset, tokens[n]) == 0) {
-	    skip = 1;
-	    break;
-    if (!skip) {
-	fprintf(fp, "%s\n", cur_mapset);
-     * output the list, removing duplicates
-    no_tokens = G_number_of_tokens(tokens);
-    for (n = 0; n < no_tokens; n++) {
-	skip = 0;
-	for (i = n; i < no_tokens; i++) {
-	    if (i != n) {
-		if (strcmp(tokens[i], tokens[n]) == 0)
-		    skip = 1;
-	if (!skip)
-	    fprintf(fp, "%s\n", tokens[n]);
-    fclose(fp);
-    G_free_tokens(tokens);
-  DISPLAY:
-    if (print->answer)
-	display_mapset_path(0);
-    exit(EXIT_SUCCESS);
Deleted: grass/branches/develbranch_6/general/g.mapsets/main_inter.c
--- grass/branches/develbranch_6/general/g.mapsets/main_inter.c	2009-04-13 05:10:32 UTC (rev 36710)
+++ grass/branches/develbranch_6/general/g.mapsets/main_inter.c	2009-04-13 06:26:10 UTC (rev 36711)
@@ -1,41 +0,0 @@
- * PURPOSE:      Allow user to select new mapset path
- * COPYRIGHT:    (C) 1994-2006 by the GRASS Development Team
- *               for details.
-#define MAIN
-int main(int argc, char **argv)
-    G_clear_screen();
-    fprintf(stdout, "MAPSET SEARCH LIST UTILITY");
-    fprintf(stdout, "     LOCATION: %s    MAPSET: %s\n\n", G_location(),
-	    G_mapset());
-    do {
-	display_mapset_path(1);
-	display_available_mapsets(1);
-    while (get_mapset_path() < 0);
-    set_mapset_path();
-    return 0;
Deleted: grass/branches/develbranch_6/general/g.mapsets/scan_int.c
--- grass/branches/develbranch_6/general/g.mapsets/scan_int.c	2009-04-13 05:10:32 UTC (rev 36710)
+++ grass/branches/develbranch_6/general/g.mapsets/scan_int.c	2009-04-13 06:26:10 UTC (rev 36711)
@@ -1,12 +0,0 @@
-#include <stdio.h>
-int scan_int(char *buf, int *n)
-    char dummy[2];
-    *dummy = 0;
-    if (sscanf(buf, "%d%1s", n, dummy) != 1)
-	return 0;
-    return (*dummy == 0 ? 1 : 0);
Deleted: grass/branches/develbranch_6/general/g.mapsets/set_path.c
--- grass/branches/develbranch_6/general/g.mapsets/set_path.c	2009-04-13 05:10:32 UTC (rev 36710)
+++ grass/branches/develbranch_6/general/g.mapsets/set_path.c	2009-04-13 06:26:10 UTC (rev 36711)
@@ -1,67 +0,0 @@
-int set_mapset_path(void)
-    char command[4096];
-    int n;
-    int i;
-    int skip;
-    int any;
-    char *cur_mapset;
-    if (nchoices == 0)		/* they didn't choose any, exit w/out change */
-	return 0;
-    /* build first part of command string */
-    strcpy(command, "g.mapsets -p mapset=");
-    any = 0;
-    skip = 0;
-	if (strcmp(cur_mapset, mapset_name[choice[n]]) == 0) {
-	    skip = 1;
-	    break;
-    if (!skip) {
-	if (any++)
-	    strcat(command, ",");
-	strcat(command, cur_mapset);
-    for (n = 0; n < nchoices; n++) {
-	skip = 0;
-	for (i = 0; i < n; i++)
-	    if (strcmp(mapset_name[choice[i]], mapset_name[choice[n]]) == 0) {
-		skip = 1;
-		break;
-	if (!skip) {
-	    if (any++)
-	    strcat(command, mapset_name[choice[n]]);
-    fprintf(stdout, "\nMapset search list set to\n ");
-    fflush(stdout);
-    if (system(command) == 0) {
-	return (0);
-    else {
-	G_warning("call to g.mapsets failed");
-	return (-1);
