[GRASS-SVN] r36721 - grass/branches/develbranch_6
svn_grass at osgeo.org
Mon Apr 13 15:32:42 EDT 2009
Author: neteler
Date: 2009-04-13 15:32:40 -0400 (Mon, 13 Apr 2009)
New Revision: 36721
grass/branches/develbranch_6/INSTALL
cosmetics
Modified: grass/branches/develbranch_6/INSTALL
--- grass/branches/develbranch_6/INSTALL 2009-04-13 19:14:56 UTC (rev 36720)
+++ grass/branches/develbranch_6/INSTALL 2009-04-13 19:32:40 UTC (rev 36721)
@@ -3,10 +3,6 @@
Please read *all* text below.
-Note: During the development stages, this version of GRASS was
- previously called GRASS 5.1 and 5.7.
Table of contents
PREREQUISITES
(A) SOURCE CODE DISTRIBUTION
@@ -15,7 +11,7 @@
(D) INSTALLATION (first time)
(E) INSTALLATION ON MACOSX
(F) RUNNING GRASS
-(G) UPDATE OF SOURCE CODE (CVS or CVS snapshot only)
+(G) UPDATE OF SOURCE CODE (SVN or SVN snapshot only)
(H) COMPILING INDIVIDUAL MODULES - OWN MODULES
(I) CODE OPTIMIZATION
(J) DEBUGGING OPTIONS
@@ -44,11 +40,11 @@
GRASS source code is currently distributed in 2 forms:
-1) Officially released source code (e.g. grass-6.0.0.tar.gz or later)
+1) Officially released source code (e.g. grass-6.4.0.tar.gz or later)
The Full source code version contains all the GRASS source code
required for compilation. It is distributed as one file (*.tar.gz
- package) and the version is composed of 3 numbers, e.g. 6.0.0, 6.0.1
+ package) and the version is composed of 3 numbers, e.g. 6.4.0, 6.4.1
etc.
2) SVN or SVN Snapshots of source code (SVN or SVN snapshot)
@@ -57,7 +53,7 @@
repository (http://svn.osgeo.org/grass/) or as a snapshot
(*.tar.gz package) of that SVN repository. The SVN snapshot name
contains the date when the snapshot was created (checked out from
- the SVN repository), e.g. grass-6.3.svn_src_snapshot_2008_01_19.tar.gz
+ the SVN repository), e.g. grass-6.4.svn_src_snapshot_2008_01_19.tar.gz
Further instructions at http://trac.osgeo.org/grass/wiki/DownloadSource
@@ -73,7 +69,7 @@
explains the options used to disable the compilation of non-mandatory
GRASS modules. See REQUIREMENTS.html for details.
-First step of the compilation:
+First step of the compilation (-g for debugging, or -O2 for optimization):
CFLAGS="-g -Wall" ./configure
@@ -93,7 +89,7 @@
make distclean - 'make clean' + delete all files created by './configure'
make libsclean - clean libraries compiled by 'make libs'
- make htmldocs - generate programmer's documentation in HTML
+ make htmldocs - generate programmer's documentation as HTML files
make packagehtmldocs - package programmer's documentation in HTML
make pdfdocs - generate programmer's documentation as PDF files
@@ -155,12 +151,12 @@
./bin.$ARCH
To run GRASS, simply start
- ./bin.$ARCH/grass6
+ ./bin.$ARCH/grass64
or run
make install
- grass6
+ grass64
@@ -170,8 +166,9 @@
(F) RUNNING GRASS
-Download a sample data package from the GRASS web site, for example the
-Spearfish60 data set. Extract the data set and point "database" in the
+Download a sample data package from the GRASS web site, see
+http://grass.osgeo.org/download/data.php
+Extract the data set and point "database" in the
GRASS startup menu to the directory.
Enjoy.
@@ -204,10 +201,14 @@
Then change into the module's directory and launch the "make"
command. The installation can be either done with "make install" from
-the main source code directory or locally with
+the main source code directory or locally with
+either
"INST_NOW=y make"
+or (may not always work)
+ make install
-You may want to define an alias for this:
+You may want to define an alias for the first method:
alias gmake6='INST_NOW=y make'
Then simply compile/install the current module with
gmake6
@@ -292,9 +293,8 @@
The Programmer's manual is generated with doxygen from the source code.
Please see the README file and the files at:
-http://grass.osgeo.org/devel/index.php#prog
+http://download.osgeo.org/grass/grass6_progman/
(N) CONTRIBUTING CODE AND PATCHES
Please see ./SUBMITTING, ./SUBMITTING_DOCS, ./SUBMITTING_TCLTK
@@ -303,8 +303,8 @@
(O) DRAFT TUTORIAL
-http://grass.gdf-hannover.de/twiki/bin/view/GRASS/GrassSixTutorial
+http://grass.osgeo.org/wiki/GRASS_6_Tutorial
-(C) 1999-2008 by The GRASS Development Team
+(C) 1999-2009 by The GRASS Development Team
$Date$
