[GRASS-SVN] r36737 -
grass/branches/develbranch_6/vector/v.net.visibility
svn_grass at osgeo.org
Wed Apr 15 18:20:04 EDT 2009
Author: neteler
Date: 2009-04-15 18:20:04 -0400 (Wed, 15 Apr 2009)
New Revision: 36737
grass/branches/develbranch_6/vector/v.net.visibility/description.html
+point data Spearfish example
Modified: grass/branches/develbranch_6/vector/v.net.visibility/description.html
--- grass/branches/develbranch_6/vector/v.net.visibility/description.html 2009-04-15 21:43:37 UTC (rev 36736)
+++ grass/branches/develbranch_6/vector/v.net.visibility/description.html 2009-04-15 22:20:04 UTC (rev 36737)
@@ -89,6 +89,17 @@
d.vect lines col=red
</pre></div>
+<h2>EXAMPLE 5</h2>
+An example for connections of points (Spearfish):
+<div class="code"><pre>
+v.net.visibility input=archsites output=graph
+g.region vect=archsites
+d.mon x0
+d.vect graph
+d.vect archsites col=red
+</pre></div>
<h2>KNOWN BUGS</h2>
In some cases when 3 points or nodes are collinear, some wrong edges are added.
This happens only really rarly and shouldn't be a big problem.
