[GRASS-SVN] r36770 - grass/branches/develbranch_6/raster/r.out.gdal
svn_grass at osgeo.org
Sat Apr 18 02:24:49 EDT 2009
Author: mmetz
Date: 2009-04-18 02:24:48 -0400 (Sat, 18 Apr 2009)
New Revision: 36770
grass/branches/develbranch_6/raster/r.out.gdal/export_band.c
grass/branches/develbranch_6/raster/r.out.gdal/main.c
added -f flag to force export (merge from trunk r36769)
Modified: grass/branches/develbranch_6/raster/r.out.gdal/export_band.c
--- grass/branches/develbranch_6/raster/r.out.gdal/export_band.c 2009-04-18 06:24:10 UTC (rev 36769)
+++ grass/branches/develbranch_6/raster/r.out.gdal/export_band.c 2009-04-18 06:24:48 UTC (rev 36770)
@@ -287,21 +287,6 @@
- if (nodatavalmatch && n_nulls) {
- if (default_nodataval) { /* default nodataval didn't work */
- G_fatal_error(_("Raster band <%s> contains NULL cells and "
- "the default nodata value would lead to data loss. Please "
- "specify a nodata value with the %s parameter."),
- name, nodatakey);
- else { /* user-specified nodataval didn't work */
- "the given nodata value would lead to data loss. Please "
- "specify a different nodata value with the %s parameter."),
- name, nodatakey);
if (n_nulls > 0 && default_nodataval) {
if (maptype == CELL_TYPE)
G_important_message(_("Input raster map contains cells with NULL-value (no-data). "
@@ -315,5 +300,22 @@
nodataval, nodatakey);
+ if (nodatavalmatch && n_nulls) {
+ if (default_nodataval) { /* default nodataval didn't work */
+ G_warning(_("The default nodata value is present in raster"
+ "band <%s> and would lead to data loss. Please specify a "
+ "different nodata value with the %s parameter."),
+ name, nodatakey);
+ else { /* user-specified nodataval didn't work */
+ G_warning(_("The given nodata value is present in raster"
+ name, nodatakey);
+ return -2;
return 0;
Modified: grass/branches/develbranch_6/raster/r.out.gdal/main.c
--- grass/branches/develbranch_6/raster/r.out.gdal/main.c 2009-04-18 06:24:10 UTC (rev 36769)
+++ grass/branches/develbranch_6/raster/r.out.gdal/main.c 2009-04-18 06:24:48 UTC (rev 36770)
@@ -104,7 +104,7 @@
struct GModule *module;
- struct Flag *flag_l, *flag_c;
+ struct Flag *flag_l, *flag_c, *flag_f;
struct Option *input, *format, *type, *output, *createopt, *metaopt,
*nodataopt;
@@ -116,6 +116,7 @@
double dfCellMin;
double dfCellMax;
struct FPRange sRange;
+ int retval;
G_gisinit(argv[0]);
@@ -134,6 +135,11 @@
flag_c->label = _("Do not write GDAL standard colortable");
flag_c->description = _("Only applicable to Byte or UInt16 data types.");
+ flag_f = G_define_flag();
+ flag_f->key = 'f';
+ flag_f->label = _("Force raster export also if data loss may occur");
+ flag_f->description = _("Overrides saftey checks.");
input = G_define_standard_option(G_OPT_R_INPUT);
input->required = NO;
input->description = _("Name of raster map (or group) to export");
@@ -396,8 +402,12 @@
nodataval = atof(nodataopt->answer);
default_nodataval = 0;
/* check nodataval here, not in export_band(), because it is specified only once */
- if (nullvalue_check(nodataval, datatype))
- G_fatal_error("Raster export aborted.");
+ if (nullvalue_check(nodataval, datatype)) {
+ if (flag_f->answer)
+ G_warning(_("Forcing raster export."));
+ else
+ G_fatal_error(_("Raster export aborted."));
G_debug(3, "Input map datatype=%s\n",
@@ -489,17 +499,29 @@
G_debug(3, "Range: min: %f, max: %f", dfCellMin, dfCellMax);
if (bHaveMinMax == TRUE) {
if (range_check
- (dfCellMin, dfCellMax, datatype, ref.file[band].name))
- G_fatal_error("Raster export aborted");
+ (dfCellMin, dfCellMax, datatype, ref.file[band].name)) {
+ else
/* ready to export */
- if (export_band
+ retval = export_band
(hCurrDS, band + 1, ref.file[band].name, ref.file[band].mapset,
&cellhead, maptype, nodataval, nodataopt->key, flag_c->answer,
- default_nodataval) < 0)
+ default_nodataval);
+ if (retval == -1) {
G_warning(_("Unable to export raster map <%s>"),
ref.file[band].name);
+ else if (retval == -2) {
+ else
/* Finaly create user required raster format from memory raster if in-memory driver was used */
