[GRASS-SVN] r36778 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sat Apr 18 08:27:20 EDT 2009
Author: martinl
Date: 2009-04-18 08:27:20 -0400 (Sat, 18 Apr 2009)
New Revision: 36778
grass/trunk/gui/wxpython/gui_modules/location_wizard.py
Fix wxGUI location wizard: Search in description with 0 hits (trac #554)
(merge from relbr64, r36775 & r36776)
Modified: grass/trunk/gui/wxpython/gui_modules/location_wizard.py
--- grass/trunk/gui/wxpython/gui_modules/location_wizard.py 2009-04-18 12:18:18 UTC (rev 36777)
+++ grass/trunk/gui/wxpython/gui_modules/location_wizard.py 2009-04-18 12:27:20 UTC (rev 36778)
@@ -621,7 +621,7 @@
if str == '':
self.Populate(self.sourceData)
- return None
+ return []
data = []
str = str.lower()
@@ -633,12 +633,13 @@
except UnicodeDecodeError:
# osgeo4w problem (should be fixed)
pass
- self.Populate(data)
if len(data) > 0:
+ self.Populate(data)
return data[0]
else:
- return None
+ self.Populate(self.sourceData)
+ return []
class ProjTypePage(TitledPage):
@@ -1351,10 +1352,11 @@
if not nextButton.IsEnabled():
nextButton.Enable(True)
else:
+ self.epsgcode = None # not found
if nextButton.IsEnabled():
nextButton.Enable(False)
self.epsgdesc = self.epsgparams = ''
def OnSearch(self, event):
value = self.searchb.GetValue()
if self.epsglist.GetItemCount() == 0:
@@ -1364,9 +1366,10 @@
try:
self.epsgcode = self.epsglist.Search(index=1, str=value)[0]
self.tcode.SetValue(str(self.epsgcode))
- except IndexError:
+ except IndexError: # -> no item found
self.tcode.SetValue('')
+ self.searchb.SetValue('')
event.Skip()
