[GRASS-SVN] r36797 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sun Apr 19 15:02:34 EDT 2009
Author: martinl
Date: 2009-04-19 15:02:34 -0400 (Sun, 19 Apr 2009)
New Revision: 36797
grass/trunk/gui/wxpython/gui_modules/location_wizard.py
wxGUI/location wizard - search in codes/desc/params (see trac #554)
(merge from relbr64, r36795)
Modified: grass/trunk/gui/wxpython/gui_modules/location_wizard.py
--- grass/trunk/gui/wxpython/gui_modules/location_wizard.py 2009-04-19 19:00:28 UTC (rev 36796)
+++ grass/trunk/gui/wxpython/gui_modules/location_wizard.py 2009-04-19 19:02:34 UTC (rev 36797)
@@ -424,7 +424,7 @@
"""Search projection by desc"""
str = event.GetString()
try:
- self.proj, self.projdesc = self.projlist.Search(index=1, str=event.GetString())
+ self.proj, self.projdesc = self.projlist.Search(index=1, pattern=event.GetString())
except:
self.proj = self.projdesc = ''
@@ -614,21 +614,21 @@
"""Used by listmix.ColumnSorterMixin"""
return self
- def Search (self, index, str):
+ def Search (self, index, pattern):
"""Search projection by description
Return first found item or None
- if str == '':
+ if pattern == '':
self.Populate(self.sourceData)
return []
data = []
- str = str.lower()
+ pattern = pattern.lower()
for i in range(len(self.sourceData)):
try:
- value = self.sourceData[i][index].lower()
- if str in value:
+ value = str(self.sourceData[i][index]).lower()
+ if pattern in value:
data.append(self.sourceData[i])
except UnicodeDecodeError:
# osgeo4w problem (should be fixed)
@@ -866,7 +866,7 @@
def OnDText(self, event):
self.datum = event.GetString()
- self.transformlist.Search(index=1, str=self.datum)
+ self.transformlist.Search(index=1, pattern=self.datum)
if self.transformlist.GetItemCount() > 0:
self.hastransform = True
else:
@@ -909,8 +909,8 @@
def OnDSearch(self, event):
str = self.searchb.GetValue()
try:
- self.datum, self.datumdesc, self.ellipsoid = self.datumlist.Search(index=1, str=str)
+ self.datum, self.datumdesc, self.ellipsoid = self.datumlist.Search(index=1, pattern=str)
except:
self.datum = self.datumdesc = self.ellipsoid = ''
@@ -1050,7 +1050,7 @@
try:
self.ellipse, self.ellipsedesc = \
- self.ellipselist.Search(index=1, str=event.GetString())
+ self.ellipselist.Search(index=1, pattern=event.GetString())
self.ellipseparams = self.parent.ellipsoids[self.ellipse][1]
self.proj4params = self.parent.ellipsoids[self.ellipse][2]
except:
@@ -1246,9 +1246,11 @@
style=wx.ALIGN_LEFT | wx.ALIGN_CENTER_VERTICAL)
self.lcode= self.MakeLabel(_("EPSG code:"),
- self.lsearch = self.MakeLabel(_("Search in description:"),
+ self.lsearch = self.MakeLabel(_("Search in"),
+ self.csearch = wx.Choice(parent = self, id = wx.ID_ANY,
+ choices = [_("codes"), _("description"), _("parameters")])
# text input
epsgdir = utils.PathJoin(os.environ["GRASS_PROJSHARE"], 'epsg')
self.tfile = self.MakeTextCtrl(text=epsgdir, size=(200,-1))
@@ -1270,42 +1272,46 @@
self.sizer.Add(item=self.lfile,
flag=wx.ALIGN_LEFT |
wx.ALIGN_CENTER_VERTICAL |
- wx.ALL, border=5, pos=(1, 1))
+ wx.ALL, border=5, pos=(1, 1), span=(1, 2))
self.sizer.Add(item=self.tfile,
- wx.ALL, border=5, pos=(1, 2))
+ wx.ALL, border=5, pos=(1, 3))
self.sizer.Add(item=self.bbrowse,
- wx.ALL, border=5, pos=(1, 3))
+ wx.ALL, border=5, pos=(1, 4))
self.sizer.Add(item=self.lcode,
- wx.ALL, border=5, pos=(2, 1))
+ wx.ALL, border=5, pos=(2, 1), span=(1, 2))
self.sizer.Add(item=self.tcode,
- wx.ALL, border=5, pos=(2, 2))
+ wx.ALL, border=5, pos=(2, 3))
self.sizer.Add(item=self.lsearch,
wx.ALL, border=5, pos=(3, 1))
+ self.sizer.Add(item=self.csearch,
+ flag=wx.ALIGN_LEFT |
+ wx.ALIGN_CENTER_VERTICAL |
+ wx.ALL, border=5, pos=(3, 2))
self.sizer.Add(item=self.searchb,
- wx.ALL, border=5, pos=(3, 2))
+ wx.ALL, border=5, pos=(3, 3))
self.sizer.Add(item=self.bbcodes,
- wx.ALL, border=5, pos=(3, 3))
+ wx.ALL, border=5, pos=(3, 4))
self.sizer.AddGrowableRow(4)
self.sizer.Add(item=self.epsglist,
flag=wx.ALIGN_LEFT | wx.EXPAND, pos=(4, 1),
- span=(1, 3))
+ span=(1, 4))
# events
self.bbrowse.Bind(wx.EVT_BUTTON, self.OnBrowse)
@@ -1364,7 +1370,8 @@
return
try:
- self.epsgcode = self.epsglist.Search(index=1, str=value)[0]
+ self.epsgcode = self.epsglist.Search(index=self.csearch.GetSelection(),
+ pattern=value)[0]
self.tcode.SetValue(str(self.epsgcode))
except IndexError: # -> no item found
self.epsgcode = None
