[GRASS-SVN] r36805 - grass/trunk/vector/v.in.dxf
Sun Apr 19 23:18:22 EDT 2009
Author: hcho
Date: 2009-04-19 23:18:22 -0400 (Sun, 19 Apr 2009)
New Revision: 36805
   grass/trunk/vector/v.in.dxf/add_lwpolyline.c
   grass/trunk/vector/v.in.dxf/add_polyline.c
   grass/trunk/vector/v.in.dxf/make_arc.c
code cleanup
Modified: grass/trunk/vector/v.in.dxf/add_lwpolyline.c
--- grass/trunk/vector/v.in.dxf/add_lwpolyline.c	2009-04-20 03:17:35 UTC (rev 36804)
+++ grass/trunk/vector/v.in.dxf/add_lwpolyline.c	2009-04-20 03:18:22 UTC (rev 36805)
@@ -56,7 +56,7 @@
 	    ypnts[arr_size] = atof(dxf_buf);
 	    yflag = 1;
 	    break;
-	case 38:
+	case 38:		/* elevation */
 	    elevation = atof(dxf_buf);
 	    break;
 	case 42:		/* bulge */
@@ -100,15 +100,15 @@
 	    xpnts[arr_size] = xpnts[0];
 	    ypnts[arr_size] = ypnts[0];
 	    zpnts[arr_size] = zpnts[0];
+	    arr_size++;
 	    /* arr_size incremented to be consistent with polyline_flag != 1 */
-	    if (arr_size >= arr_max - 1) {
+	    if (arr_size == arr_max) {
 		arr_max += ARR_INCR;
 		xpnts = (double *)G_realloc(xpnts, arr_max * sizeof(double));
 		ypnts = (double *)G_realloc(ypnts, arr_max * sizeof(double));
 		zpnts = (double *)G_realloc(zpnts, arr_max * sizeof(double));
-	    arr_size++;
Modified: grass/trunk/vector/v.in.dxf/add_polyline.c
--- grass/trunk/vector/v.in.dxf/add_polyline.c	2009-04-20 03:17:35 UTC (rev 36804)
+++ grass/trunk/vector/v.in.dxf/add_polyline.c	2009-04-20 03:18:22 UTC (rev 36805)
@@ -257,15 +257,15 @@
+	    arr_size++;
-	    arr_size++;
Modified: grass/trunk/vector/v.in.dxf/make_arc.c
--- grass/trunk/vector/v.in.dxf/make_arc.c	2009-04-20 03:17:35 UTC (rev 36804)
+++ grass/trunk/vector/v.in.dxf/make_arc.c	2009-04-20 03:18:22 UTC (rev 36805)
@@ -31,14 +31,14 @@
 	    xpnts[arr_size] = radius * cos(alpha) + centerx;
 	    ypnts[arr_size] = radius * sin(alpha) + centery;
 	    zpnts[arr_size] = zcoor;
+	    arr_size++;
 	    theta -= RSTEP;
-	    arr_size++;
     else {
@@ -48,14 +48,14 @@
+	    arr_size++;
 	    theta += RSTEP;
-	    arr_size++;
     /* this insures that the last point will be correct */
@@ -63,13 +63,13 @@
+    arr_size++;
-    arr_size++;
     return arr_size - offset;
@@ -88,13 +88,13 @@
 	arc_tan = (-1.0) * prev_bulge;
     if (arc_tan == 0.0) {	/* straight line segment */
+	arr_size++;
-	arr_size++;
     else if (!(xpnts[arr_size - 1] == xpnts[arr_size] &&
 	       ypnts[arr_size - 1] == ypnts[arr_size]))
