[GRASS-SVN] r36814 - grass/branches/develbranch_6/raster/r.topidx
Mon Apr 20 08:27:27 EDT 2009
Author: neteler
Date: 2009-04-20 08:27:27 -0400 (Mon, 20 Apr 2009)
New Revision: 36814
   grass/branches/develbranch_6/raster/r.topidx/file_io.c
   grass/branches/develbranch_6/raster/r.topidx/main.c
trap if current region resolution is higher than map resolution
Modified: grass/branches/develbranch_6/raster/r.topidx/file_io.c
--- grass/branches/develbranch_6/raster/r.topidx/file_io.c	2009-04-20 12:27:12 UTC (rev 36813)
+++ grass/branches/develbranch_6/raster/r.topidx/file_io.c	2009-04-20 12:27:27 UTC (rev 36814)
@@ -10,12 +10,14 @@
     RASTER_MAP_TYPE data_type;
     CELL *ccell = NULL;
     FCELL *fcell = NULL;
+    struct Cell_head inhead;
     if ((fd = G_open_cell_old(iname, mapset)) < 0)
 	G_fatal_error(_("Cannot open raster map <%s>"), iname);
     data_type = G_get_raster_map_type(fd);
+    if (G_get_cellhd(iname, mapset, &inhead) < 0 )
+	G_fatal_error(_("Unable to read header of raster map <%s>"), iname);
     if (data_type == CELL_TYPE)
 	ccell = (CELL *) G_malloc(sizeof(CELL) * window.cols);
@@ -26,6 +28,9 @@
     atb = (DCELL **) G_malloc(sizeof(DCELL *) * window.rows);
     a = (DCELL **) G_malloc(sizeof(DCELL *) * window.rows);
+    if ((window.ew_res < inhead.ew_res) || (window.ns_res < inhead.ns_res))
+        G_fatal_error(_("Current region resolution [%.2fx%.2f] lower than input map resolution [%.2fx%.2f]! Needs to be at least identical or the current region resolution lower than the input map resolution"),window.ew_res, window.ns_res, inhead.ew_res, inhead.ns_res);
     G_important_message(_("Reading elevation map..."));
     for (i = 0; i < window.rows; i++) {
Modified: grass/branches/develbranch_6/raster/r.topidx/main.c
--- grass/branches/develbranch_6/raster/r.topidx/main.c	2009-04-20 12:27:12 UTC (rev 36813)
+++ grass/branches/develbranch_6/raster/r.topidx/main.c	2009-04-20 12:27:27 UTC (rev 36814)
@@ -19,6 +19,7 @@
 #define	MAIN
+#include <grass/gis.h>
 #include <grass/glocale.h>
 #include "global.h"
