[GRASS-SVN] r36825 - grass-addons/raster/r.surf.volcano
svn_grass at osgeo.org
Mon Apr 20 23:45:42 EDT 2009
Author: hamish
Date: 2009-04-20 23:45:41 -0400 (Mon, 20 Apr 2009)
New Revision: 36825
grass-addons/raster/r.surf.volcano/description.html
grass-addons/raster/r.surf.volcano/r.surf.volcano
new option to create craters; add new examples
Modified: grass-addons/raster/r.surf.volcano/description.html
--- grass-addons/raster/r.surf.volcano/description.html 2009-04-21 00:42:17 UTC (rev 36824)
+++ grass-addons/raster/r.surf.volcano/description.html 2009-04-21 03:45:41 UTC (rev 36825)
@@ -21,7 +21,7 @@
to create a pit.
-<H2>EXAMPLE</H2>
+<H2>EXAMPLES</H2>
<div class="code"><pre>
r.surf.volcano -r output=seamount
@@ -43,6 +43,23 @@
</pre></div>
+Create a roughened volcano with a crater:
+<div class="code"><pre>
+r.surf.volcano -r output=volcano crater=250 --verbose
+r.shaded.relief volcano
+</pre></div>
+Create a fancy 3D scene:
+r.surf.volcano -r output=base_volcano peak=600 crater=120
+r.surf.fractal output=base_fractal
+r.mapcalc "artificial_land = base_volcano + base_fractal"
+r.colors artificial_land color=srtm
+nviz artificial_land
+</pre></div>
<H2>SEE ALSO</H2>
<EM>
Modified: grass-addons/raster/r.surf.volcano/r.surf.volcano
--- grass-addons/raster/r.surf.volcano/r.surf.volcano 2009-04-21 00:42:17 UTC (rev 36824)
+++ grass-addons/raster/r.surf.volcano/r.surf.volcano 2009-04-21 03:45:41 UTC (rev 36825)
@@ -35,9 +35,16 @@
#% type: double
#% required: no
#% description: Height of cone
-#% answer: 1000
+#% answer: 1000.0
#%End
#%Option
+#% key: crater
+#% type: double
+#% required: no
+#% description: Depth of crater below the cone (bigger means wider)
+#% answer: 0.0
+#%End
+#%Option
#% key: friction
#% type: integer
#% required: no
@@ -56,6 +63,7 @@
#% key: r
#% description: Roughen the surface
#%End
## TODO
##%Flag
##% key: n
@@ -73,6 +81,7 @@
FRICTION="$GIS_OPT_FRICTION"
PEAK="$GIS_OPT_PEAK"
+CRATER="$GIS_OPT_CRATER"
SIGMA="$GIS_OPT_SIGMA"
@@ -81,7 +90,7 @@
if [ -n "$name" ] ; then
# map already exists
if [ -z "$GRASS_OVERWRITE" ] || [ "$GRASS_OVERWRITE" -ne 1 ] ; then
- G_message -e "option <output>: <$GIS_OPT_OUTPUT> exists."
+ g.message -e "option <output>: <$GIS_OPT_OUTPUT> exists."
exit 1
fi
fi
@@ -99,30 +108,44 @@
g.message -v "Creating IDW surface ..."
-r.mapcalc "volc.surf.$$ = $PEAK * pow( volc.dist_norm.$$, $FRICTION )"
+r.mapcalc "volc.peak.$$ = ($PEAK + abs($CRATER) ) \
+ * pow( volc.dist_norm.$$, $FRICTION )"
if [ "$GIS_FLAG_R" -eq 0 ] ; then
- g.rename rast="volc.surf.$$,$GIS_OPT_OUTPUT" --quiet
- g.remove rast="volc.dist_units.$$,volc.dist_norm.$$" --quiet
+ g.rename rast="volc.peak.$$,volc.surf.$$" --quiet
else
# roughen it up a bit
g.message -v "Creating random Gaussian mottle ..."
r.surf.gauss out="volc.surf_gauss.$$" sigma="$SIGMA"
g.message -v "Applying Gaussian mottle ..."
- r.mapcalc "volc.surf_rough.$$ = \
- volc.surf.$$ + (volc.surf_gauss.$$ * $PEAK/400 )"
+ r.mapcalc "volc.peak_rough.$$ = \
+ volc.peak.$$ + (volc.surf_gauss.$$ * $PEAK/400 )"
- g.rename rast="volc.surf_rough.$$,$GIS_OPT_OUTPUT" --quiet
- g.remove rast="volc.dist_units.$$,volc.dist_norm.$$,volc.surf_gauss.$$,volc.surf.$$" --quiet
+ g.rename rast="volc.peak_rough.$$,volc.surf.$$" --quiet
+ g.remove rast="volc.surf_gauss.$$,volc.peak.$$" --quiet
fi
+g.remove rast="volc.dist_units.$$,volc.dist_norm.$$" --quiet
+if [ "$CRATER" == "0.0" ] ; then
+ g.rename rast="volc.surf.$$,$GIS_OPT_OUTPUT" --quiet
+else
+ g.message -v "Creating crater ..."
+ r.mapcalc "volc.full.$$ = if( volc.surf.$$ > $PEAK, \
+ 2*$PEAK - volc.surf.$$, volc.surf.$$ )"
+ g.rename rast="volc.full.$$,$GIS_OPT_OUTPUT" --quiet
+ g.remove rast="volc.surf.$$" --quiet
+fi
# test if it worked
eval `g.findfile element=cell file="$GIS_OPT_OUTPUT" mapset=.`
if [ -z "$name" ] ; then
- G_message -e "Surface creation failed"
+ g.message -e "Surface creation failed"
exit 1
fi
