[GRASS-SVN] r36834 - grass-addons/raster/r.surf.volcano
svn_grass at osgeo.org
Tue Apr 21 05:40:47 EDT 2009
Author: hamish
Date: 2009-04-21 05:40:47 -0400 (Tue, 21 Apr 2009)
New Revision: 36834
grass-addons/raster/r.surf.volcano/r.surf.volcano
add a flag to use a gaussian surface instead of 1/d^n
Modified: grass-addons/raster/r.surf.volcano/r.surf.volcano
--- grass-addons/raster/r.surf.volcano/r.surf.volcano 2009-04-21 08:27:43 UTC (rev 36833)
+++ grass-addons/raster/r.surf.volcano/r.surf.volcano 2009-04-21 09:40:47 UTC (rev 36834)
@@ -50,20 +50,48 @@
#% type: integer
#% required: no
#% options: 1-25
-#% description: Friction of distance, (the 'n' in 1/d^n)
+#% label: Friction of distance, (the 'n' in 1/d^n)
+#% description: Higher values generate steeper slopes. (not used in Gaussian curve mode)
#% answer: 6
#%End
+#%Flag
+#% key: g
+#% description: Use a Gaussian curve instead of 1/(d^n) for radial basis function
+#%End
+# normalized Gaussian curve: f(x) = a * e^( (x-b)^2 / 2*(c^2) )
+# parameters: a = 1/(sigma*sqrt(2pi)), b = mu, c = sigma
+# mu is mean value and sigma^2 is variance.
+# so we only need b,c. and b can be locked at 0 here. so user only needs
+# to give sigma (width)
+# thus r.mapcalc expr could look like
+# SIGMA=1.0 # beware variable namespace collision with roughness factor
+# r.mapcalc doesn't have a pi(), so define it: PI=3.14159265358979323846
+# f(distance) = ( 1 / ($SIGMA*sqrt(2*$PI)) ) * exp( -1* $DIST^2 / (2 * $SIGMA^2) )
+## FIXME: ok, it isn't really kurtosis but it's similar and I couldn't
+## think of a better name.
#%Option
-#% key: sigma
+#% key: kurtosis
#% type: double
#% required: no
-#% description: Surface roughness factor
+#% label: Peak steepness (used with Gaussian curve mode)
+#% description: Nearer to 0 is flatter, higher values generate steeper slopes.
#% answer: 1.0
#%End
#%Flag
#% key: r
#% description: Roughen the surface
#%End
+#%Option
+#% key: sigma
+#% type: double
+#% required: no
+#% label: Surface roughness factor
+#% description: Nearer to 0 is smoother, higher values make a rougher surface.
+#% answer: 1.0
+#%End
## TODO
##%Flag
@@ -71,20 +99,6 @@
##% description: Use (d^n)*log(d) instead of 1/(d^n) for radial basis function
##%End
-## TODO
-##%Flag
-##% key: g
-##% description: Use a Gaussian curve instead of 1/(d^n) for radial basis function
-##%End
-# normalized Gaussian curve: f(x) = a * e^( (x-b)^2 / 2*(c^2) )
-# parameters: a = 1/(sigma*sqrt(2pi)), b = mu, c = sigma
-# mu is mean value and sigma^2 is variance.
-# so we only need b,c. and b can be locked at 0 here. so user only needs
-# to give sigma (width)
-# thus r.mapcalc expr could look like
-# SIGMA=1.0 # beware variable namespace collision with roughness factor
-# r.mapcalc doesn't have a pi(), so define it: PI=3.14159265358979323846
-# f(distance) = ( 1 / ($SIGMA*sqrt(2*$PI)) ) * exp( $DIST^2 / (2 * $SIGMA^2) )
if [ -z "$GISBASE" ] ; then
@@ -100,6 +114,7 @@
PEAK="$GIS_OPT_PEAK"
CRATER="$GIS_OPT_CRATER"
SIGMA="$GIS_OPT_SIGMA"
+KURTOSIS="$GIS_OPT_KURTOSIS"
# test for overwrite as r.mapcalc doesn't
@@ -119,16 +134,40 @@
sqrt( (x() - $center_easting)^2 + (y() - $center_northing)^2 )"
-g.message -v "Normalizing cost map with 1 in the center and 0 at outer edge ..."
+g.message -v "Normalizing cost map ..."
eval `r.info -r "volc.dist_units.$$"`
-r.mapcalc "volc.dist_norm.$$ = ($max - volc.dist_units.$$) / $max"
+if [ "$GIS_FLAG_G" -eq 0 ] ; then
+ # Normalize with 1 in the center and 0 at outer edge
+ r.mapcalc "volc.dist_norm.$$ = ($max - volc.dist_units.$$) / $max"
-g.message -v "Creating IDW surface ..."
-r.mapcalc "volc.peak.$$ = ($PEAK + abs($CRATER) ) \
+ g.message -v "Creating IDW surface ..."
+ r.mapcalc "volc.peak.$$ = ($PEAK + abs($CRATER) ) \
* pow( volc.dist_norm.$$, $FRICTION )"
+else
+ # Normalize with 0 in the center and 1 at outer edge
+ r.mapcalc "volc.dist_norm.$$ = volc.dist_units.$$ / $max"
+ g.message -v "Creating Gaussian surface ..."
+ SIGMA_C=1.0 # beware variable namespace collision with roughness factor
+ # r.mapcalc doesn't have a pi(), so define it:
+ PI=3.14159265358979323846
+ # f(distance) = ( 1 / ($SIGMA*sqrt(2*$PI)) ) * exp( -1* $DIST^2 / (2 * $SIGMA^2) )
+ ## FIXME: the 10*kurtosis stuff is a completely bogus hack!
+ r.mapcalc "volc.gauss.$$ = \
+ ( 1 / ( $SIGMA_C * sqrt(2 * $PI) ) ) \
+ * exp( -1* (10 * $KURTOSIS * volc.dist_norm.$$)^2 / (2 * $SIGMA_C^2) )"
+ eval `r.info -r "volc.gauss.$$"`
+ g.message -v "Normalizing Gaussian surface ..."
+ r.mapcalc "volc.peak.$$ = \
+ ( ($PEAK + abs($CRATER) ) / $max ) * volc.gauss.$$"
+ g.remove rast="volc.gauss.$$" --quiet
+fi
if [ "$GIS_FLAG_R" -eq 0 ] ; then
g.rename rast="volc.peak.$$,volc.surf.$$" --quiet
else
@@ -170,14 +209,21 @@
r.support map="$GIS_OPT_OUTPUT" \
description="generated by r.surf.volcano" \
source1="Peak height = $PEAK" \
- source2="Friction of distance = $FRICTION" \
title="Artificial surface resembling a seamount or cone volcano"
if [ "$GIS_FLAG_R" -eq 1 ] ; then
- history="Surface roughness used a Gaussian deviate with sigma of $SIGMA."
+ history="Surface roughness used a Gaussian deviate with sigma of $SIGMA."
fi
+ r.support map="$GIS_OPT_OUTPUT" \
+ source2="IDW surface with friction of distance = $FRICTION"
+else
+ source2="Gaussian surface with pseudo-kurtosis factor = $KURTOSIS"
+fi
g.message -v "Done."
exit
