[GRASS-SVN] r36852 - grass/branches/develbranch_6/lib/vector/diglib
svn_grass at osgeo.org
Tue Apr 21 14:57:16 EDT 2009
Author: mmetz
Date: 2009-04-21 14:57:16 -0400 (Tue, 21 Apr 2009)
New Revision: 36852
grass/branches/develbranch_6/lib/vector/diglib/allocation.c
grass/branches/develbranch_6/lib/vector/diglib/cindex.c
grass/branches/develbranch_6/lib/vector/diglib/list.c
grass/branches/develbranch_6/lib/vector/diglib/plus.c
grass/branches/develbranch_6/lib/vector/diglib/struct_alloc.c
G_* versions for memory management
Modified: grass/branches/develbranch_6/lib/vector/diglib/allocation.c
--- grass/branches/develbranch_6/lib/vector/diglib/allocation.c 2009-04-21 18:35:07 UTC (rev 36851)
+++ grass/branches/develbranch_6/lib/vector/diglib/allocation.c 2009-04-21 18:57:16 UTC (rev 36852)
@@ -78,7 +78,7 @@
/* first time called allocate initial storage */
if (*n_elements == 0)
- ptr = calloc((unsigned)to_alloc, (unsigned)element_size);
+ ptr = G_calloc((unsigned)to_alloc, (unsigned)element_size);
else
ptr = dig__frealloc((char *)ptr, to_alloc, element_size, *n_elements);
@@ -126,7 +126,7 @@
nelem = 1;
- ptr = calloc((unsigned)nelem, (unsigned)elsize);
+ ptr = G_calloc((unsigned)nelem, (unsigned)elsize);
return (ptr);
@@ -141,7 +141,7 @@
nelem = 1;
/* out of memory */
if (!ptr)
@@ -159,6 +159,6 @@
*a++ = *b++;
- free(oldptr);
+ G_free(oldptr);
return (ptr);
Modified: grass/branches/develbranch_6/lib/vector/diglib/cindex.c
--- grass/branches/develbranch_6/lib/vector/diglib/cindex.c 2009-04-21 18:35:07 UTC (rev 36851)
+++ grass/branches/develbranch_6/lib/vector/diglib/cindex.c 2009-04-21 18:57:16 UTC (rev 36852)
@@ -49,7 +49,7 @@
G_debug(2, "dig_cidx_free()");
for (i = 0; i < Plus->n_cidx; i++) {
ci = &(Plus->cidx[0]);
- free(ci->cat);
+ G_free(ci->cat);
ci->cat = NULL;
ci->field = ci->n_cats = ci->a_cats = ci->n_types = 0;
Modified: grass/branches/develbranch_6/lib/vector/diglib/list.c
--- grass/branches/develbranch_6/lib/vector/diglib/list.c 2009-04-21 18:35:07 UTC (rev 36851)
+++ grass/branches/develbranch_6/lib/vector/diglib/list.c 2009-04-21 18:57:16 UTC (rev 36852)
@@ -37,7 +37,7 @@
if (list->n_values == list->alloc_values) {
size = (list->n_values + 1000) * sizeof(int);
- p = realloc((void *)list->value, size);
+ p = G_realloc((void *)list->value, size);
if (p == NULL)
return 0;
list->value = (int *)p;
Modified: grass/branches/develbranch_6/lib/vector/diglib/plus.c
--- grass/branches/develbranch_6/lib/vector/diglib/plus.c 2009-04-21 18:35:07 UTC (rev 36851)
+++ grass/branches/develbranch_6/lib/vector/diglib/plus.c 2009-04-21 18:57:16 UTC (rev 36852)
@@ -117,12 +117,12 @@
continue;
if (Node->alloc_lines > 0) {
- free(Node->lines);
- free(Node->angles);
+ G_free(Node->lines);
+ G_free(Node->angles);
- free(Node);
+ G_free(Node);
- free(Plus->Node);
+ G_free(Plus->Node);
Plus->Node = NULL;
Plus->n_nodes = 0;
@@ -148,9 +148,9 @@
if (Line == NULL)
continue;
- free(Line);
+ G_free(Line);
- free(Plus->Line);
+ G_free(Plus->Line);
Plus->Line = NULL;
@@ -185,14 +185,14 @@
continue;
if (Area->alloc_lines > 0)
- free(Area->lines);
+ G_free(Area->lines);
if (Area->alloc_isles > 0)
- free(Area->isles);
+ G_free(Area->isles);
- free(Area);
+ G_free(Area);
- free(Plus->Area);
+ G_free(Plus->Area);
Plus->Area = NULL;
Plus->n_areas = 0;
@@ -219,11 +219,11 @@
continue;
if (Isle->alloc_lines > 0)
- free(Isle->lines);
+ G_free(Isle->lines);
- free(Isle);
+ G_free(Isle);
- free(Plus->Isle);
+ G_free(Plus->Isle);
Plus->Isle = NULL;
Modified: grass/branches/develbranch_6/lib/vector/diglib/struct_alloc.c
--- grass/branches/develbranch_6/lib/vector/diglib/struct_alloc.c 2009-04-21 18:35:07 UTC (rev 36851)
+++ grass/branches/develbranch_6/lib/vector/diglib/struct_alloc.c 2009-04-21 18:57:16 UTC (rev 36852)
@@ -41,7 +41,7 @@
P_NODE *Node;
- Node = (P_NODE *) malloc(sizeof(P_NODE));
+ Node = (P_NODE *) G_malloc(sizeof(P_NODE));
if (Node == NULL)
return NULL;
@@ -69,12 +69,12 @@
num = node->n_lines + add;
- p = realloc(node->lines, num * sizeof(plus_t));
+ p = G_realloc(node->lines, num * sizeof(plus_t));
if (p == NULL)
return -1;
node->lines = (plus_t *) p;
- p = realloc(node->angles, num * sizeof(float));
+ p = G_realloc(node->angles, num * sizeof(float));
if (p == NULL)
return -1;
node->angles = (float *)p;
@@ -96,7 +96,7 @@
char *p;
size = Plus->alloc_nodes + 1 + add;
- p = realloc(Plus->Node, size * sizeof(P_NODE *));
+ p = G_realloc(Plus->Node, size * sizeof(P_NODE *));
if (p == NULL)
return -1;
@@ -111,7 +111,7 @@
P_LINE *Line;
- Line = (P_LINE *) malloc(sizeof(P_LINE));
+ Line = (P_LINE *) G_malloc(sizeof(P_LINE));
if (Line == NULL)
return NULL;
@@ -130,7 +130,7 @@
char *p;
size = Plus->alloc_lines + 1 + add;
- p = realloc(Plus->Line, size * sizeof(P_LINE *));
+ p = G_realloc(Plus->Line, size * sizeof(P_LINE *));
if (p == NULL)
return -1;
@@ -152,7 +152,7 @@
char *p;
size = Plus->alloc_areas + 1 + add;
- p = realloc(Plus->Area, size * sizeof(P_AREA *));
+ p = G_realloc(Plus->Area, size * sizeof(P_AREA *));
if (p == NULL)
return -1;
@@ -175,7 +175,7 @@
G_debug(3, "dig_alloc_isle():");
size = Plus->alloc_isles + 1 + add;
- p = realloc(Plus->Isle, size * sizeof(P_ISLE *));
+ p = G_realloc(Plus->Isle, size * sizeof(P_ISLE *));
if (p == NULL)
return -1;
@@ -190,7 +190,7 @@
P_AREA *Area;
- Area = (P_AREA *) malloc(sizeof(P_AREA));
+ Area = (P_AREA *) G_malloc(sizeof(P_AREA));
if (Area == NULL)
return NULL;
@@ -212,7 +212,7 @@
P_ISLE *Isle;
- Isle = (P_ISLE *) malloc(sizeof(P_ISLE));
+ Isle = (P_ISLE *) G_malloc(sizeof(P_ISLE));
if (Isle == NULL)
return NULL;
@@ -307,7 +307,7 @@
num = area->alloc_lines + add;
- p = realloc(area->lines, num * sizeof(plus_t));
+ p = G_realloc(area->lines, num * sizeof(plus_t));
if (p == NULL)
return -1;
area->lines = (plus_t *) p;
@@ -330,7 +330,7 @@
G_debug(5, "dig_area_alloc_isle(): add = %d", add);
num = area->alloc_isles + add;
- p = realloc(area->isles, num * sizeof(plus_t));
+ p = G_realloc(area->isles, num * sizeof(plus_t));
if (p == NULL)
return -1;
area->isles = (plus_t *) p;
@@ -353,7 +353,7 @@
G_debug(3, "dig_isle_alloc_line():");
num = isle->alloc_lines + add;
- p = realloc(isle->lines, num * sizeof(plus_t));
+ p = G_realloc(isle->lines, num * sizeof(plus_t));
if (p == NULL)
return -1;
isle->lines = (plus_t *) p;
