[GRASS-SVN] r36882 - grass/branches/releasebranch_6_4/display/d.path
svn_grass at osgeo.org
Thu Apr 23 04:10:46 EDT 2009
Author: neteler
Date: 2009-04-23 04:10:45 -0400 (Thu, 23 Apr 2009)
New Revision: 36882
grass/branches/releasebranch_6_4/display/d.path/description.html
polished; examples improved
Modified: grass/branches/releasebranch_6_4/display/d.path/description.html
--- grass/branches/releasebranch_6_4/display/d.path/description.html 2009-04-23 07:59:12 UTC (rev 36881)
+++ grass/branches/releasebranch_6_4/display/d.path/description.html 2009-04-23 08:10:45 UTC (rev 36882)
@@ -1,8 +1,6 @@
<h2>DESCRIPTION</h2>
-<em>d.path</em> enables shortest path vector networking - based on DGLib
-(Directed Graph Library) vector network library
-(see <a href="http://grass.gdf-hannover.de/wiki/Vector_network_analysis">screenshot</a>).
+<em>d.path</em> enables shortest path vector networking.
Costs may be either line lengths, or attributes saved in a database table.
Supported are cost assignments for both arcs and nodes, and also different
in both directions of a vector line. For areas cost will be calculated along
@@ -21,18 +19,23 @@
<h2>EXAMPLE</h2>
+Interactive shortest path routing on road network (Spearfish region):
<div class="code"><pre>
-# Spearfish
+g.region vector=roads
+d.mon x0
d.vect roads
-d.path -b roads coor="601653.5,4922869.2","593330.8,4924096.6"
+d.path roads
</pre></div>
+Non-interactive shortest path routing on road network (Spearfish region):
+<div class="code"><pre>
+d.path -b roads coor=601653.5,4922869.2,593330.8,4924096.6
+</pre></div>
<h2>SEE ALSO</h2>
<em>
-<a HREF="v.net.path.html">v.net.path</a>,
-<a HREF="http://grass.itc.it/dglib/">DGLib</a>
+<a HREF="v.net.path.html">v.net.path</a>
</em>
<h2>AUTHOR</h2>
