[GRASS-SVN] r36889 -
grass/branches/releasebranch_6_4/vector/v.buffer2
svn_grass at osgeo.org
Thu Apr 23 07:36:12 EDT 2009
Author: hamish
Date: 2009-04-23 07:36:12 -0400 (Thu, 23 Apr 2009)
New Revision: 36889
grass/branches/releasebranch_6_4/vector/v.buffer2/description.html
grass/branches/releasebranch_6_4/vector/v.buffer2/main.c
retain backwards compatibility (merge from devbr6)
Modified: grass/branches/releasebranch_6_4/vector/v.buffer2/description.html
--- grass/branches/releasebranch_6_4/vector/v.buffer2/description.html 2009-04-23 11:32:55 UTC (rev 36888)
+++ grass/branches/releasebranch_6_4/vector/v.buffer2/description.html 2009-04-23 11:36:12 UTC (rev 36889)
@@ -5,30 +5,33 @@
the number of vector segments being generated (the smaller the value, the more
vector segments are generated).
<h2>NOTES</h2>
-<!-- TRUE?? -->
+<!-- Q: True? A: Sure. if two point buffers overlap and are merged, which
+ area's attribute is the one to use in the combined area? -->
Attributes are not transferred due to potential buffer overlap, which
cannot be resolved automatically.
<h2>EXAMPLES</h2>
<h3>Buffer around input lines</h3>
<div class="code"><pre>
-v.buffer input=map output=buffer type=line buffer=100
+v.buffer input=map output=buffer type=line distance=100
</pre></div>
<h3>Circles around input points</h3>
-v.buffer input=pointsmap output=circles type=point buffer=1000
+v.buffer input=pointsmap output=circles type=point distance=1000
</pre></div>
<h3>Non-overlapping circles around input points with attribute transfer</h3>
-v.buffer input=archsites output=circles type=point buffer=200
+v.buffer input=archsites output=circles type=point distance=200
# change original points to centroids:
v.type in=archsites out=archcentroids type=point,centroid
# patch circles and centroids:
@@ -40,6 +43,7 @@
database='$GISDBASE/$LOCATION_NAME/$MAPSET/dbf'
</pre></div>
<h2>SEE ALSO</h2>
<em>
@@ -50,9 +54,11 @@
<a HREF="v.db.connect.html">v.db.connect</a>
</em>
<h2>AUTHORS</h2>
Radim Blazek<br>
-Rewritten by Rosen Matev (with support through the Google Summer of Code program 2008)
+Rewritten by Rosen Matev (with support through the
+ Google Summer of Code program 2008)
<p>
<i>Last changed: $Date: 2008-03-16 16:29:33 +0100 (Sun, 16 Mar 2008) $</i>
Modified: grass/branches/releasebranch_6_4/vector/v.buffer2/main.c
--- grass/branches/releasebranch_6_4/vector/v.buffer2/main.c 2009-04-23 11:32:55 UTC (rev 36888)
+++ grass/branches/releasebranch_6_4/vector/v.buffer2/main.c 2009-04-23 11:36:12 UTC (rev 36889)
@@ -122,7 +122,7 @@
char *mapset;
struct GModule *module;
struct Option *in_opt, *out_opt, *type_opt, *dista_opt, *distb_opt,
- *angle_opt;
+ *angle_opt, *buffer_opt, *debug_opt;
struct Flag *straight_flag, *nocaps_flag;
struct Option *tol_opt, *bufcol_opt, *scale_opt, *field_opt;
@@ -203,6 +203,24 @@
_("Maximum distance between theoretical arc and polygon segments as multiple of buffer");
tol_opt->guisection = _("Distance");
+ debug_opt = G_define_option();
+ debug_opt->key = "debug";
+ debug_opt->type = TYPE_STRING;
+ debug_opt->required = NO;
+ debug_opt->guisection = _("Unused");
+ debug_opt->description =
+ _("This does nothing. It is retained for backwards compatibility");
+ buffer_opt = G_define_option();
+ buffer_opt->key = "buffer";
+ buffer_opt->type = TYPE_DOUBLE;
+ buffer_opt->required = NO;
+ buffer_opt->label =
+ _("This is an alias to the distance option. "
+ "It is retained for backwards compatibility");
+ buffer_opt->description = _("Buffer distance in map units");
+ buffer_opt->guisection = _("Unused");
straight_flag = G_define_flag();
straight_flag->key = 's';
straight_flag->description = _("Make outside corners straight");
@@ -216,11 +234,12 @@
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
type = Vect_option_to_types(type_opt);
field = atoi(field_opt->answer);
- if ((dista_opt->answer && bufcol_opt->answer) ||
- (!(dista_opt->answer || bufcol_opt->answer)))
+ if (((dista_opt->answer || buffer_opt->answer) && bufcol_opt->answer) ||
+ (!(dista_opt->answer || buffer_opt->answer || bufcol_opt->answer)))
G_fatal_error(_("Select a buffer distance/minordistance/angle "
"or column, but not both."));
@@ -230,6 +249,12 @@
"option or clean manually with v.clean tool=break; "
"v.category step=0; v.extract -d type=area"));
+ if (buffer_opt->answer)
+ G_warning(_("The buffer option has been replaced by the distance "
+ "option and will be removed in future."));
+ if (buffer_opt->answer && dista_opt->answer)
+ G_fatal_error(_("Use the distance option instead of the buffer option."));
tolerance = atof(tol_opt->answer);
if (adjust_tolerance(&tolerance))
G_warning(_("The tolerance was reset to %g"), tolerance);
@@ -239,8 +264,11 @@
G_fatal_error("Illegal scale value");
- if (dista_opt->answer) {
- da = atof(dista_opt->answer);
+ if (dista_opt->answer || buffer_opt->answer) {
+ if(buffer_opt->answer)
+ da = atof(buffer_opt->answer);
+ if(dista_opt->answer)
+ da = atof(dista_opt->answer);
if (distb_opt->answer)
db = atof(distb_opt->answer);
