[GRASS-SVN] r36918 - in grass/trunk: include lib/stats
raster/r.neighbors raster/r.resamp.stats raster/r.series
svn_grass at osgeo.org
Thu Apr 30 03:39:27 EDT 2009
Author: glynn
Date: 2009-04-30 03:39:26 -0400 (Thu, 30 Apr 2009)
New Revision: 36918
grass/trunk/include/stats.h
grass/trunk/lib/stats/c_ave.c
grass/trunk/lib/stats/c_count.c
grass/trunk/lib/stats/c_divr.c
grass/trunk/lib/stats/c_intr.c
grass/trunk/lib/stats/c_kurt.c
grass/trunk/lib/stats/c_max.c
grass/trunk/lib/stats/c_maxx.c
grass/trunk/lib/stats/c_median.c
grass/trunk/lib/stats/c_min.c
grass/trunk/lib/stats/c_minx.c
grass/trunk/lib/stats/c_mode.c
grass/trunk/lib/stats/c_percentile.c
grass/trunk/lib/stats/c_range.c
grass/trunk/lib/stats/c_reg.c
grass/trunk/lib/stats/c_skew.c
grass/trunk/lib/stats/c_stddev.c
grass/trunk/lib/stats/c_sum.c
grass/trunk/lib/stats/c_var.c
grass/trunk/raster/r.neighbors/main.c
grass/trunk/raster/r.resamp.stats/main.c
grass/trunk/raster/r.series/main.c
Add closure argument to aggregate functions
Export c_quantile, w_quantile
Add method=quantile to r.resamp.stats, r.series, r.neighbors
Add method=quart1/quart3/perc90 to r.neighbors
Modified: grass/trunk/include/stats.h
--- grass/trunk/include/stats.h 2009-04-30 07:36:21 UTC (rev 36917)
+++ grass/trunk/include/stats.h 2009-04-30 07:39:26 UTC (rev 36918)
@@ -4,8 +4,8 @@
#include <grass/gis.h>
-typedef void stat_func(DCELL *, DCELL *, int);
-typedef void stat_func_w(DCELL *, DCELL(*)[2], int);
+typedef void stat_func(DCELL *, DCELL *, int, const void *);
+typedef void stat_func_w(DCELL *, DCELL(*)[2], int, const void *);
extern stat_func c_ave;
extern stat_func c_count;
@@ -27,6 +27,7 @@
extern stat_func c_quart1;
extern stat_func c_quart3;
extern stat_func c_perc90;
+extern stat_func c_quant;
extern stat_func c_skew;
extern stat_func c_kurt;
@@ -39,6 +40,7 @@
extern stat_func_w w_quart1;
extern stat_func_w w_quart3;
extern stat_func_w w_perc90;
+extern stat_func_w w_quant;
extern stat_func_w w_reg_m;
extern stat_func_w w_reg_c;
extern stat_func_w w_reg_r2;
Modified: grass/trunk/lib/stats/c_ave.c
--- grass/trunk/lib/stats/c_ave.c 2009-04-30 07:36:21 UTC (rev 36917)
+++ grass/trunk/lib/stats/c_ave.c 2009-04-30 07:39:26 UTC (rev 36918)
@@ -1,6 +1,6 @@
-void c_ave(DCELL * result, DCELL * values, int n)
+void c_ave(DCELL * result, DCELL * values, int n, const void *closure)
DCELL sum;
int count;
@@ -23,7 +23,7 @@
*result = sum / count;
-void w_ave(DCELL * result, DCELL(*values)[2], int n)
+void w_ave(DCELL * result, DCELL(*values)[2], int n, const void *closure)
DCELL sum;
DCELL count;
Modified: grass/trunk/lib/stats/c_count.c
--- grass/trunk/lib/stats/c_count.c 2009-04-30 07:36:21 UTC (rev 36917)
+++ grass/trunk/lib/stats/c_count.c 2009-04-30 07:39:26 UTC (rev 36918)
@@ -1,6 +1,6 @@
-void c_count(DCELL * result, DCELL * values, int n)
+void c_count(DCELL * result, DCELL * values, int n, const void *closure)
int count;
int i;
@@ -14,7 +14,7 @@
*result = count;
-void w_count(DCELL * result, DCELL(*values)[2], int n)
+void w_count(DCELL * result, DCELL(*values)[2], int n, const void *closure)
DCELL count;
int i;
Modified: grass/trunk/lib/stats/c_divr.c
--- grass/trunk/lib/stats/c_divr.c 2009-04-30 07:36:21 UTC (rev 36917)
+++ grass/trunk/lib/stats/c_divr.c 2009-04-30 07:39:26 UTC (rev 36918)
@@ -1,7 +1,7 @@
#include <grass/stats.h>
-void c_divr(DCELL * result, DCELL * values, int n)
+void c_divr(DCELL * result, DCELL * values, int n, const void *closure)
int count;
DCELL prev;
Modified: grass/trunk/lib/stats/c_intr.c
--- grass/trunk/lib/stats/c_intr.c 2009-04-30 07:36:21 UTC (rev 36917)
+++ grass/trunk/lib/stats/c_intr.c 2009-04-30 07:39:26 UTC (rev 36918)
@@ -1,7 +1,7 @@
-void c_intr(DCELL * result, DCELL * values, int n)
+void c_intr(DCELL * result, DCELL * values, int n, const void *closure)
DCELL center;
int count;
Modified: grass/trunk/lib/stats/c_kurt.c
--- grass/trunk/lib/stats/c_kurt.c 2009-04-30 07:36:21 UTC (rev 36917)
+++ grass/trunk/lib/stats/c_kurt.c 2009-04-30 07:39:26 UTC (rev 36918)
@@ -1,6 +1,6 @@
-void c_kurt(DCELL * result, DCELL * values, int n)
+void c_kurt(DCELL * result, DCELL * values, int n, const void *closure)
DCELL sum, ave, sumsq, sumqt, var;
int count;
@@ -42,7 +42,7 @@
*result = sumqt / (count * var * var) - 3;
-void w_kurt(DCELL * result, DCELL(*values)[2], int n)
+void w_kurt(DCELL * result, DCELL(*values)[2], int n, const void *closure)
int count;
Modified: grass/trunk/lib/stats/c_max.c
--- grass/trunk/lib/stats/c_max.c 2009-04-30 07:36:21 UTC (rev 36917)
+++ grass/trunk/lib/stats/c_max.c 2009-04-30 07:39:26 UTC (rev 36918)
@@ -1,6 +1,6 @@
-void c_max(DCELL * result, DCELL * values, int n)
+void c_max(DCELL * result, DCELL * values, int n, const void *closure)
DCELL max;
int i;
@@ -21,7 +21,7 @@
*result = max;
-void w_max(DCELL * result, DCELL(*values)[2], int n)
+void w_max(DCELL * result, DCELL(*values)[2], int n, const void *closure)
DCELL max;
int i;
Modified: grass/trunk/lib/stats/c_maxx.c
--- grass/trunk/lib/stats/c_maxx.c 2009-04-30 07:36:21 UTC (rev 36917)
+++ grass/trunk/lib/stats/c_maxx.c 2009-04-30 07:39:26 UTC (rev 36918)
@@ -1,6 +1,6 @@
-void c_maxx(DCELL * result, DCELL * values, int n)
+void c_maxx(DCELL * result, DCELL * values, int n, const void *closure)
DCELL max, maxx;
int i;
Modified: grass/trunk/lib/stats/c_median.c
--- grass/trunk/lib/stats/c_median.c 2009-04-30 07:36:21 UTC (rev 36917)
+++ grass/trunk/lib/stats/c_median.c 2009-04-30 07:39:26 UTC (rev 36918)
@@ -1,7 +1,7 @@
-void c_median(DCELL * result, DCELL * values, int n)
+void c_median(DCELL * result, DCELL * values, int n, const void *closure)
n = sort_cell(values, n);
@@ -11,7 +11,7 @@
*result = (values[(n - 1) / 2] + values[n / 2]) / 2;
-void w_median(DCELL * result, DCELL(*values)[2], int n)
+void w_median(DCELL * result, DCELL(*values)[2], int n, const void *closure)
DCELL total;
int i;
Modified: grass/trunk/lib/stats/c_min.c
--- grass/trunk/lib/stats/c_min.c 2009-04-30 07:36:21 UTC (rev 36917)
+++ grass/trunk/lib/stats/c_min.c 2009-04-30 07:39:26 UTC (rev 36918)
@@ -1,6 +1,6 @@
-void c_min(DCELL * result, DCELL * values, int n)
+void c_min(DCELL * result, DCELL * values, int n, const void *closure)
DCELL min;
int i;
@@ -21,7 +21,7 @@
*result = min;
-void w_min(DCELL * result, DCELL(*values)[2], int n)
+void w_min(DCELL * result, DCELL(*values)[2], int n, const void *closure)
DCELL min;
int i;
Modified: grass/trunk/lib/stats/c_minx.c
--- grass/trunk/lib/stats/c_minx.c 2009-04-30 07:36:21 UTC (rev 36917)
+++ grass/trunk/lib/stats/c_minx.c 2009-04-30 07:39:26 UTC (rev 36918)
@@ -1,7 +1,7 @@
-void c_minx(DCELL * result, DCELL * values, int n)
+void c_minx(DCELL * result, DCELL * values, int n, const void *closure)
DCELL min, minx;
int i;
Modified: grass/trunk/lib/stats/c_mode.c
--- grass/trunk/lib/stats/c_mode.c 2009-04-30 07:36:21 UTC (rev 36917)
+++ grass/trunk/lib/stats/c_mode.c 2009-04-30 07:39:26 UTC (rev 36918)
@@ -1,7 +1,7 @@
-void c_mode(DCELL * result, DCELL * values, int n)
+void c_mode(DCELL * result, DCELL * values, int n, const void *closure)
DCELL mode;
int max;
@@ -34,7 +34,7 @@
*result = mode;
-void w_mode(DCELL * result, DCELL(*values)[2], int n)
+void w_mode(DCELL * result, DCELL(*values)[2], int n, const void *closure)
DCELL mode;
DCELL max;
Modified: grass/trunk/lib/stats/c_percentile.c
--- grass/trunk/lib/stats/c_percentile.c 2009-04-30 07:36:21 UTC (rev 36917)
+++ grass/trunk/lib/stats/c_percentile.c 2009-04-30 07:39:26 UTC (rev 36918)
@@ -2,8 +2,9 @@
-static void percentile(DCELL * result, DCELL * values, int n, double percent)
+void c_quant(DCELL * result, DCELL * values, int n, const void *closure)
+ double quant = *(const double *)closure;
double k;
int i0, i1;
@@ -14,7 +15,7 @@
return;
- k = n * percent / 100;
+ k = n * quant;
i0 = (int)floor(k);
i1 = (int)ceil(k);
@@ -23,24 +24,27 @@
: values[i0] * (i1 - k) + values[i1] * (k - i0);
-void c_quart1(DCELL * result, DCELL * values, int n)
+void c_quart1(DCELL * result, DCELL * values, int n, const void *closure)
- percentile(result, values, n, 25.0);
+ static const double q = 0.25;
+ c_quant(result, values, n, &q);
-void c_quart3(DCELL * result, DCELL * values, int n)
+void c_quart3(DCELL * result, DCELL * values, int n, const void *closure)
- percentile(result, values, n, 75.0);
+ static const double q = 0.75;
-void c_perc90(DCELL * result, DCELL * values, int n)
+void c_perc90(DCELL * result, DCELL * values, int n, const void *closure)
- percentile(result, values, n, 90.0);
+ static const double q = 0.90;
-static void percentile_w(DCELL * result, DCELL(*values)[2], int n,
- double percent)
+void w_quant(DCELL * result, DCELL(*values)[2], int n, const void *closure)
DCELL total;
int i;
DCELL k;
@@ -59,24 +63,27 @@
k = 0.0;
for (i = 0; i < n; i++) {
k += values[i][1];
- if (k >= total * percent / 100)
+ if (k >= total * quant)
break;
*result = values[i][0];
-void w_quart1(DCELL * result, DCELL(*values)[2], int n)
+void w_quart1(DCELL * result, DCELL(*values)[2], int n, const void *closure)
- percentile_w(result, values, n, 25.0);
+ w_quant(result, values, n, &q);
-void w_quart3(DCELL * result, DCELL(*values)[2], int n)
+void w_quart3(DCELL * result, DCELL(*values)[2], int n, const void *closure)
- percentile_w(result, values, n, 75.0);
-void w_perc90(DCELL * result, DCELL(*values)[2], int n)
+void w_perc90(DCELL * result, DCELL(*values)[2], int n, const void *closure)
- percentile_w(result, values, n, 90.0);
Modified: grass/trunk/lib/stats/c_range.c
--- grass/trunk/lib/stats/c_range.c 2009-04-30 07:36:21 UTC (rev 36917)
+++ grass/trunk/lib/stats/c_range.c 2009-04-30 07:39:26 UTC (rev 36918)
@@ -1,6 +1,6 @@
-void c_range(DCELL * result, DCELL * values, int n)
+void c_range(DCELL * result, DCELL * values, int n, const void *closure)
DCELL min, max;
int i;
Modified: grass/trunk/lib/stats/c_reg.c
--- grass/trunk/lib/stats/c_reg.c 2009-04-30 07:36:21 UTC (rev 36917)
+++ grass/trunk/lib/stats/c_reg.c 2009-04-30 07:39:26 UTC (rev 36918)
@@ -73,17 +73,17 @@
G_set_d_null_value(result, 1);
-void c_reg_m(DCELL * result, DCELL * values, int n)
+void c_reg_m(DCELL * result, DCELL * values, int n, const void *closure)
regression(result, values, n, REGRESSION_SLOPE);
-void c_reg_c(DCELL * result, DCELL * values, int n)
+void c_reg_c(DCELL * result, DCELL * values, int n, const void *closure)
regression(result, values, n, REGRESSION_OFFSET);
-void c_reg_r2(DCELL * result, DCELL * values, int n)
+void c_reg_r2(DCELL * result, DCELL * values, int n, const void *closure)
regression(result, values, n, REGRESSION_COEFF_DET);
@@ -157,17 +157,17 @@
-void w_reg_m(DCELL * result, DCELL(*values)[2], int n)
+void w_reg_m(DCELL * result, DCELL(*values)[2], int n, const void *closure)
regression_w(result, values, n, REGRESSION_SLOPE);
-void w_reg_c(DCELL * result, DCELL(*values)[2], int n)
+void w_reg_c(DCELL * result, DCELL(*values)[2], int n, const void *closure)
regression_w(result, values, n, REGRESSION_OFFSET);
-void w_reg_r2(DCELL * result, DCELL(*values)[2], int n)
+void w_reg_r2(DCELL * result, DCELL(*values)[2], int n, const void *closure)
regression_w(result, values, n, REGRESSION_COEFF_DET);
Modified: grass/trunk/lib/stats/c_skew.c
--- grass/trunk/lib/stats/c_skew.c 2009-04-30 07:36:21 UTC (rev 36917)
+++ grass/trunk/lib/stats/c_skew.c 2009-04-30 07:39:26 UTC (rev 36918)
@@ -1,7 +1,7 @@
#include <math.h>
-void c_skew(DCELL * result, DCELL * values, int n)
+void c_skew(DCELL * result, DCELL * values, int n, const void *closure)
DCELL sum, ave, sumsq, sumcb, sdev;
int count;
@@ -43,7 +43,7 @@
*result = sumcb / (count * sdev * sdev * sdev);
-void w_skew(DCELL * result, DCELL(*values)[2], int n)
+void w_skew(DCELL * result, DCELL(*values)[2], int n, const void *closure)
int count;
Modified: grass/trunk/lib/stats/c_stddev.c
--- grass/trunk/lib/stats/c_stddev.c 2009-04-30 07:36:21 UTC (rev 36917)
+++ grass/trunk/lib/stats/c_stddev.c 2009-04-30 07:39:26 UTC (rev 36918)
@@ -2,11 +2,11 @@
-void c_stddev(DCELL * result, DCELL * values, int n)
+void c_stddev(DCELL * result, DCELL * values, int n, const void *closure)
DCELL var;
- c_var(&var, values, n);
+ c_var(&var, values, n, closure);
if (G_is_d_null_value(&var))
@@ -14,11 +14,11 @@
*result = sqrt(var);
-void w_stddev(DCELL * result, DCELL(*values)[2], int n)
+void w_stddev(DCELL * result, DCELL(*values)[2], int n, const void *closure)
DCELL var;
- w_var(&var, values, n);
+ w_var(&var, values, n, closure);
Modified: grass/trunk/lib/stats/c_sum.c
--- grass/trunk/lib/stats/c_sum.c 2009-04-30 07:36:21 UTC (rev 36917)
+++ grass/trunk/lib/stats/c_sum.c 2009-04-30 07:39:26 UTC (rev 36918)
@@ -1,6 +1,6 @@
-void c_sum(DCELL * result, DCELL * values, int n)
+void c_sum(DCELL * result, DCELL * values, int n, const void *closure)
DCELL sum;
int count;
@@ -23,7 +23,7 @@
*result = sum;
-void w_sum(DCELL * result, DCELL(*values)[2], int n)
+void w_sum(DCELL * result, DCELL(*values)[2], int n, const void *closure)
DCELL sum;
DCELL count;
Modified: grass/trunk/lib/stats/c_var.c
--- grass/trunk/lib/stats/c_var.c 2009-04-30 07:36:21 UTC (rev 36917)
+++ grass/trunk/lib/stats/c_var.c 2009-04-30 07:39:26 UTC (rev 36918)
@@ -1,6 +1,6 @@
-void c_var(DCELL * result, DCELL * values, int n)
+void c_var(DCELL * result, DCELL * values, int n, const void *closure)
DCELL sum, ave, sumsq;
int count;
@@ -39,7 +39,7 @@
*result = sumsq / count;
-void w_var(DCELL * result, DCELL(*values)[2], int n)
+void w_var(DCELL * result, DCELL(*values)[2], int n, const void *closure)
int count;
Modified: grass/trunk/raster/r.neighbors/main.c
--- grass/trunk/raster/r.neighbors/main.c 2009-04-30 07:36:21 UTC (rev 36917)
+++ grass/trunk/raster/r.neighbors/main.c 2009-04-30 07:39:26 UTC (rev 36918)
@@ -56,6 +56,10 @@
"number of different values"},
{c_intr, NULL, intr_cats, 0, 0, "interspersion",
"number of values different than center value"},
+ {c_quart1, w_quart1, NO_CATS, 1, 0, "quart1", "first quartile"},
+ {c_quart3, w_quart3, NO_CATS, 1, 0, "quart3", "third quartile"},
+ {c_perc90, w_perc90, NO_CATS, 1, 0, "perc90", "ninetieth percentile"},
+ {c_quant, w_quant, NO_CATS, 1, 0, "quantile", "arbitrary quantile"},
{0, 0, 0, 0, 0, 0, 0}
@@ -78,6 +82,8 @@
stat_func *newvalue;
stat_func_w *newvalue_w;
ifunc cat_names;
+ double quantile;
+ const void *closure;
struct Colors colr;
struct Cell_head cellhd;
struct Cell_head window;
@@ -90,6 +96,7 @@
struct Option *title;
struct Option *weight;
struct Option *gauss;
+ struct Option *quantile;
} parm;
struct
@@ -159,6 +166,14 @@
parm.gauss->required = NO;
parm.gauss->description = _("Sigma (in cells) for Gaussian filter");
+ parm.quantile = G_define_option();
+ parm.quantile->key = "quantile";
+ parm.quantile->type = TYPE_DOUBLE;
+ parm.quantile->required = NO;
+ parm.quantile->description = _("Quantile to calculate for method=quantile");
+ parm.quantile->options = "0.0-1.0";
+ parm.quantile->answer = "0.5";
flag.align = G_define_flag();
flag.align->key = 'a';
flag.align->description = _("Do not align output with the input");
@@ -216,6 +231,11 @@
exit(EXIT_FAILURE);
+ if (menu[method].method == c_quant) {
+ quantile = atoi(parm.quantile->answer);
+ closure = &quantile;
half = (map_type == CELL_TYPE) ? menu[method].half : 0;
/* establish the newvalue routine */
@@ -297,9 +317,9 @@
G_set_d_null_value(rp, 1);
else {
if (newvalue_w)
- newvalue_w(rp, values_w, n);
+ newvalue_w(rp, values_w, n, closure);
else
- newvalue(rp, values, n);
+ newvalue(rp, values, n, closure);
if (half && !G_is_d_null_value(rp))
*rp += 0.5;
Modified: grass/trunk/raster/r.resamp.stats/main.c
--- grass/trunk/raster/r.resamp.stats/main.c 2009-04-30 07:36:21 UTC (rev 36917)
+++ grass/trunk/raster/r.resamp.stats/main.c 2009-04-30 07:39:26 UTC (rev 36918)
@@ -38,6 +38,7 @@
{c_sum, w_sum, "sum", "sum of values"},
{c_var, w_var, "variance", "variance value"},
{c_stddev, w_stddev, "stddev", "standard deviation"},
+ {c_quant, w_quant, "quantile", "arbitrary quantile"},
{NULL, NULL, NULL}
@@ -77,7 +78,9 @@
static DCELL *outbuf;
static DCELL **bufs;
static int method;
+static const void *closure;
static int row_scale, col_scale;
+static double quantile;
static void resamp_unweighted(void)
@@ -141,7 +144,7 @@
if (null && nulls)
G_set_d_null_value(&outbuf[col], 1);
else
- (*method_fn) (&outbuf[col], values, n);
+ (*method_fn) (&outbuf[col], values, n, closure);
G_set_window(&dst_w);
@@ -227,7 +230,7 @@
if (null && nulls)
else
@@ -240,7 +243,7 @@
struct GModule *module;
struct
- struct Option *rastin, *rastout, *method;
+ struct Option *rastin, *rastout, *method, *quantile;
} parm;
struct
@@ -271,6 +274,14 @@
parm.method->options = build_method_list();
parm.method->answer = "average";
flag.nulls = G_define_flag();
flag.nulls->key = 'n';
flag.nulls->description = _("Propagate NULLs");
@@ -288,6 +299,11 @@
if (method < 0)
G_fatal_error(_("Unknown method <%s>"), parm.method->answer);
G_get_set_window(&dst_w);
/* set window to old map */
Modified: grass/trunk/raster/r.series/main.c
--- grass/trunk/raster/r.series/main.c 2009-04-30 07:36:21 UTC (rev 36917)
+++ grass/trunk/raster/r.series/main.c 2009-04-30 07:39:26 UTC (rev 36918)
@@ -47,6 +47,7 @@
{c_quart1, 0, "quart1", "first quartile"},
{c_quart3, 0, "quart3", "third quartile"},
{c_perc90, 0, "perc90", "ninetieth percentile"},
+ {c_quant, 0, "quantile", "arbitrary quantile"},
{c_skew, 0, "skewness", "skewness"},
{c_kurt, 0, "kurtosis", "kurtosis"},
{NULL, 0, NULL, NULL}
@@ -65,6 +66,7 @@
int fd;
DCELL *buf;
stat_func *method_fn;
+ double quantile;
static char *build_method_list(void)
@@ -104,7 +106,7 @@
struct
- struct Option *input, *output, *method, *range;
+ struct Option *input, *output, *method, *quantile, *range;
} parm;
struct
@@ -143,6 +145,14 @@
parm.method->description = _("Aggregate operation");
parm.method->multiple = YES;
+ parm.quantile->multiple = YES;
parm.range = G_define_option();
parm.range->key = "range";
parm.range->type = TYPE_DOUBLE;
@@ -203,6 +213,9 @@
out->name = output_name;
out->method_fn = menu[method].method;
+ out->quantile = (parm.quantile->answer && parm.quantile->answers[i])
+ ? atof(parm.quantile->answers[i])
+ : 0;
out->buf = G_allocate_d_raster_buf();
out->fd = G_open_raster_new(
output_name, menu[method].is_int ? CELL_TYPE : DCELL_TYPE);
@@ -249,7 +262,7 @@
G_set_d_null_value(&out->buf[col], 1);
else {
memcpy(values_tmp, values, num_inputs * sizeof(DCELL));
- (*out->method_fn)(&out->buf[col], values_tmp, num_inputs);
+ (*out->method_fn)(&out->buf[col], values_tmp, num_inputs, &out->quantile);
