[GRASS-SVN] r36921 -
grass/branches/releasebranch_6_4/raster/r.reclass
svn_grass at osgeo.org
Thu Apr 30 08:20:56 EDT 2009
Author: epatton
Date: 2009-04-30 08:20:56 -0400 (Thu, 30 Apr 2009)
New Revision: 36921
grass/branches/releasebranch_6_4/raster/r.reclass/description.html
Added note about the requirement for integer data in input raster map; misc. cleanups, merge from devbr6 r36920
Modified: grass/branches/releasebranch_6_4/raster/r.reclass/description.html
--- grass/branches/releasebranch_6_4/raster/r.reclass/description.html 2009-04-30 12:15:17 UTC (rev 36920)
+++ grass/branches/releasebranch_6_4/raster/r.reclass/description.html 2009-04-30 12:20:56 UTC (rev 36921)
@@ -1,7 +1,7 @@
<h2>DESCRIPTION</h2>
<em>r.reclass</em> creates an <em>output</em> map layer
-based on an <em>input</em> raster map layer. The output
+based on an <em>input</em> integer raster map layer. The output
map layer will be a reclassification of the input map layer
based on reclass rules input to <em>r.reclass</em>, and can
be treated in much the same way that raster maps are
@@ -22,8 +22,71 @@
<li>The names of the new categories.
</ol>
-<h2>INTERACTIVE PROGRAM USE: EXAMPLE</h2>
+<h2>NOTES</h2>
+In fact, the <em>r.reclass</em> program does <em>not</em> generate any new
+raster map layers (in the interests of disk space conservation). Instead, a
+<b>reclass table</b> is stored which will be used to reclassify the
+original raster map layer each time the new (reclassed) map name
+is requested. As far as the user (and programmer) is concerned, that
+raster map has been created.
+<p>
+<em>r.reclass</em> only works on an <i>integer</i> input raster map; if the
+input map is instead floating point data, you must multiply the input data by some
+factor to acheive whole number input data, otherwise <em>r.reclass</em> will round
+the raster values down to the next integer.
+<p>
+Also note that although the user can generate a <em>r.reclass</em> map
+which is based on another <em>r.reclass</em> map,
+the new <em>r.reclass</em> map map will be stored in GRASS as a reclass
+of the <em>original</em> raster map on which the first reclassed map was
+based. Therefore, while GRASS allows the user to provide <em>r.reclass</em>
+map layer information which is based on an already reclassified map
+(for the user's convenience), no <em>r.reclass</em> map layer
+(i.e., <em>reclass table</em>) will ever be <em>stored</em>
+as a <em>r.reclass</em> of a <em>r.reclass</em>.
+<p>
+To convert a reclass map to a regular raster map layer, set your
+geographic region settings to match the settings in the header for the
+reclass map (an ASCII file found under the <em>cellhd</em> directory, or
+viewable by running <em><a href="r.support.html">r.support</a></em>) and then run <em><a href="r.resample.html">r.resample</a></em>.
+<p>
+<em><a href="r.mapcalc.html">r.mapcalc</a></em> can be used to convert
+a reclass map to a regular raster map layer:
+<div class="code"><pre>
+ r.mapcalc raster_map=reclass_map
+</pre></div>
+<p>
+where <em>raster_map</em> is the name to be given to the new raster map,
+and <em>reclass_map</em> is an existing reclass map.
+<p>
+Because <em>r.reclass</em> generates a table referencing some original
+raster map layer rather than creating a reclassed raster map layer,
+a <em>r.reclass</em> map layer will no longer be accessible if
+the original raster map layer upon which it was based is later removed.
+<p>
+A <em>r.reclass</em> map is not a true raster map layer.
+Rather, it is a table of reclassification values which reference the
+input raster map layer. Therefore, users who wish to retain reclassified
+map layers must also save the original input raster map layers
+from which they were generated. Alternatively r.recode can be used.
+<p>
+Category values which are not explicitly reclassified to a new value.
+<h2>EXAMPLES</h2>
+<h3>Interactive Program Use</h3>
Suppose we want to reclassify the raster map layer
<em>roads</em>, consisting of five categories, into the
three new categories: paved roads, unpaved roads, and
@@ -97,7 +160,7 @@
the new output map, supporting category, color, history, and header files
are created.
-<h2>NON-INTERACTIVE PROGRAM USE: RECLASS RULES</h2>
+<h3>Non-Interactive Program Use: Reclass Rules</h3>
In non-interactive program use, the names of an input map, output map,
and output map TITLE are given on the command line.
@@ -144,10 +207,11 @@
A line containing only the word <b>end</b> terminates the
input.
-<h2>NON-INTERACTIVE PROGRAM USE: EXAMPLES</h2>
+<h3>Non-Interactive Program Use</h3>
The following examples may help clarify the reclass rules.
<p>
+<dl>
<dt>
<dd>1. This example reclassifies categories 1, 2 and 3 in the input raster
map layer "roads" to category 1 with category label "good quality" in the output map
@@ -209,6 +273,7 @@
25 = 3 good quality
</pre>
</dd>
+</dl>
<p>
The final example was given to show how the labels are handled. If a new
@@ -217,59 +282,6 @@
the last label which was specified becomes the label for that category.
In this case the labels are assigned exactly as in the two previous examples.
-<h2>NOTES</h2>
-In fact, the <em>r.reclass</em> program does <em>not</em> generate any new
-raster map layers (in the interests of disk space conservation). Instead, a
-<b>reclass table</b> is stored which will be used to reclassify the
-original raster map layer each time the new (reclassed) map name
-is requested. As far as the user (and programmer) is concerned, that
-raster map has been created.
-Also note that although the user can generate a <em>r.reclass</em> map
-which is based on another <em>r.reclass</em> map,
-the new <em>r.reclass</em> map map will be stored in GRASS as a reclass
-of the <em>original</em> raster map on which the first reclassed map was
-based. Therefore, while GRASS allows the user to provide <em>r.reclass</em>
-map layer information which is based on an already reclassified map
-(for the user's convenience), no <em>r.reclass</em> map layer
-(i.e., <em>reclass table</em>) will ever be <em>stored</em>
-as a <em>r.reclass</em> of a <em>r.reclass</em>.
-<p>
-To convert a reclass map to a regular raster map layer, set your
-geographic region settings to match the settings in the header for the
-reclass map (an ASCII file found under the <em>cellhd</em> directory, or
-viewable by running <em><a href="r.support.html">r.support</a></em>) and then run <em><a href="r.resample.html">r.resample</a></em>.
-<p>
-<em><a href="r.mapcalc.html">r.mapcalc</a></em> can be used to convert
-a reclass map to a regular raster map layer:
-<div class="code"><pre>
- r.mapcalc raster_map=reclass_map
-</pre></div>
-<p>
-where <em>raster_map</em> is the name to be given to the new raster map,
-and <em>reclass_map</em> is an existing reclass map.
-<h2>BEWARE</h2>
-Because <em>r.reclass</em> generates a table referencing some original
-raster map layer rather than creating a reclassed raster map layer,
-a <em>r.reclass</em> map layer will no longer be accessible if
-the original raster map layer upon which it was based is later removed.
-<p>
-A <em>r.reclass</em> map is not a true raster map layer.
-Rather, it is a table of reclassification values which reference the
-input raster map layer. Therefore, users who wish to retain reclassified
-map layers must also save the original input raster map layers
-from which they were generated. Alternatively r.recode can be used.
-<p>
-Category values which are not explicitly reclassified to a new value
by the user will be reclassified to NULL.
<h2>SEE ALSO</h2>
