[GRASS-SVN] r38560 - grass/branches/develbranch_6/lib/rst/interp_float
Sat Aug 1 17:15:56 EDT 2009
Author: helena
Date: 2009-08-01 17:15:55 -0400 (Sat, 01 Aug 2009)
New Revision: 38560
   grass/branches/develbranch_6/lib/rst/interp_float/segmen2d.c
fix for running out of memory problem for large data sets
Modified: grass/branches/develbranch_6/lib/rst/interp_float/segmen2d.c
--- grass/branches/develbranch_6/lib/rst/interp_float/segmen2d.c	2009-07-31 21:06:43 UTC (rev 38559)
+++ grass/branches/develbranch_6/lib/rst/interp_float/segmen2d.c	2009-08-01 21:15:55 UTC (rev 38560)
@@ -190,23 +190,33 @@
 		return -1;
-	if (!
-	    (point =
-	     (struct triple *)G_malloc(sizeof(struct triple) *
+        /* allocate memory for CV points only if cv is performed */
+        if (params->cv){
+	   if (!
+	       (point =
+	        (struct triple *)G_malloc(sizeof(struct triple) *
 				       data->n_points))) {
-	    fprintf(stderr, "Cannot allocate memory for point\n");
-	    return -1;
+	       fprintf(stderr, "Cannot allocate memory for point\n");
+	       return -1;
 	/*normalize the data so that the side of average segment is about 1m */
+        /* put data_points into point only if CV is performed */
 	for (i = 0; i < data->n_points; i++) {
 	    data->points[i].x = (data->points[i].x - data->x_orig) / dnorm;
+	    data->points[i].y = (data->points[i].y - data->y_orig) / dnorm;
+            if (params->cv){
 	    point[i].x = data->points[i].x;	/*cv stuff */
-	    data->points[i].y = (data->points[i].y - data->y_orig) / dnorm;
 	    point[i].y = data->points[i].y;	/*cv stuff */
 	    point[i].z = data->points[i].z;	/*cv stuff */
 	    /* commented out by Helena january 1997 as this is not necessary
+               although it may be useful to put normalization of z back?
 	       data->points[i].z = data->points[i].z / dnorm;
+               this made smoothing self-adjusting  based on dnorm
 	       if (params->rsm < 0.) data->points[i].sm = data->points[i].sm / dnorm;
@@ -217,7 +227,13 @@
 	else
 	    m_skip = 1;
+        /* remove after cleanup - this is just for testing */
+               skip_point.x = 0.;
+               skip_point.y = 0.;
+               skip_point.z = 0.;
 	for (skip_index = 0; skip_index < m_skip; skip_index++) {
+          if (params->cv) {
 	    segtest = 0;
 	    j = 0;
 	    xx = point[skip_index].x * dnorm + data->x_orig + params->x_orig;
@@ -240,7 +256,7 @@
 	    }			/* segment area test */
 	    if (!params->cv) {
 		if (params->
 		    matrix_create(params, data->points, data->n_points,
@@ -253,13 +269,13 @@
 				  matrix, indx) < 0)
 		    return -1;
 	    if (!params->cv) {
-		    b[i + 1] = data->points[i].z;
-		b[0] = 0.;
-		G_lubksb(matrix, data->n_points + 1, indx, b);
-		params->check_points(params, data, b, ertot, zmin, dnorm,
+		b[i + 1] = data->points[i].z;
+	        b[0] = 0.;
+	        G_lubksb(matrix, data->n_points + 1, indx, b);
+/* put here condition to skip ertot if not needed */
+	        params->check_points(params, data, b, ertot, zmin, dnorm,
 				     skip_point);
 	    else if (segtest == 1) {
@@ -270,9 +286,8 @@
 				     skip_point);
+	}			/*end of cv loop */
-	}			/*cv loop */
 	if (!params->cv)
 	    if ((params->Tmp_fd_z != NULL) || (params->Tmp_fd_dx != NULL) ||
 		(params->Tmp_fd_dy != NULL) || (params->Tmp_fd_xx != NULL) ||
@@ -292,7 +307,7 @@
 	if (totsegm != 0) {
 	    G_percent(cursegm, totsegm, 1);
 	   G_free_matrix(matrix);
 	   G_free_ivector(indx);
 	   G_free_vector(b);
